Page 1 of 3 123 LastLast
Results 1 to 10 of 24
Thread: VW TRANSPORTER 2008 T5 2.5TDI NO POWER AND VIBRATIONS UNDER LOAD.
    May 2018
    Australia
    Hi guys.
    could any one help?
    cheers
    Tuesday,24,March,2020,12:42:47:39620
    VCDS Version: 19.6.2.2 (x64)  HEX-NET CB: 0.4508.4
    VIN: WV1ZZZ7HZ8H047706   License Plate: CS76AQ
    Mileage: 284600km-176842mi   Repair Order:
              57 6E 76 77 78 7D
    VIN: WV1ZZZ7HZ8H047706   Mileage: 284600km-176842miles
    Address 01: Engine        Labels: 070-906-016-BPC.clb
       Part No SW: 070 906 016 DQ    HW: 070 906 016 DQ
       Component: R5 2,5L EDC G000SG  1583
       Revision: --H05---    Serial number: VWZ7Z0G5746272
       Coding: 0051172
       Shop #: WSC 02736 790 00000
       VCID: E288F0DD3CD5F55F53-513C
    000665 - Boost Pressure Regulation
                   P0299 - 000 - Control Range Not Reached - Intermittent
                        Mileage: 284301 km
                        RPM: 2016 /min
                        Speed: 44.0 km/h
                        Load: 100.0 %
                        Voltage: 13.83 V
                        Bin. Bits: 00101100
                        Absolute Pres.: 2315.4 mbar
                        Absolute Pres.: 1723.8 mbar
    Readiness: 0 1 0 0 0
    Address 03: ABS Brakes        Labels: 7H0-907-37x-ESP.lbl
       Part No SW: 7H0 907 379 R    HW: 7H0 907 379 R
       Component: ESP MK25E1          0104
       Revision: 00H31001
       Coding: 0001634
       VCID: C4C4164586019B6F41-5118
       Part No: 7H0 820 045 R
       Component: CLIMA/AC            0202
       VCID: B4244685D6A12BEFF1-5118
       Part No: 7H0 937 049 AD
       Component: BORDNETZ SGVER 1.0  2101
       Coding: 0000101
       VCID: F4A4868596216BEF31-5118
    01598 - Drive Battery Voltage
                002 - Lower Limit Exceeded
       Part No: 1C0 909 605 F
       Component: 0T AIRBAG VW61 0R   0004
       Coding: 12372
       Shop #: WSC 02736
       VCID: A71EA1C94777507744-5118
       Part No: 7H0 920 851 R
       Coding: 00722
       Shop #: WSC 00001
       VCID: BA3868BDA4C5DD9F2B-5118
       WV1ZZZ7HZ8H047706     VWZ7Z0G5746272
                30-00 - Open or Short to Plus
       Part No: 6N0 909 901
       Coding: 00022
       Shop #: WSC 02736
       VCID: F0AC8A95B23957CFD5-5118
    Address 22: AWD        Labels: 7H0-907-554.clb
       Part No: 7H0 907 554 F
       Component: HALDEX 4Motion      2110
       VCID: B3264599D3AF2CD7E8-5118
       Part No: 7H0 959 433 B
       Component: C11 Komfortgerát     0004
       Coding: 00031
       Shop #: WSC 02736
       VCID: B228409D7CB525DFE3-4B00
    Address 76: Park Assist        Labels: 7H0-919-283.lbl
       Part No: 7H0 919 283
       Component: Parkingsyst. T5 T5N 401
       Coding: 00137
       Shop #: WSC 02736
       VCID: EFAE89E9AF074837CC-513C
    01545 - Sensor for Parking Aid; Rear Left (G203)
                37-00 - Faulty
    01547 - Sensor for Parking Aid; Rear Mid-Right (G205)
                37-00 - Faulty
    End----------(Elapsed Time: 05:54, VBatt start/end: 14.0V/14.0V)-----------
    Jul 2014
    Hi Gapel3,
    What have you done to check for boost pressure leaks?
    Regards HMC
  3. Likes Uwe liked this post
    I would log MVB 011, where you will find
    * Engine Speed
    * Specified Manifold Pressure
    * Actual (Measured Manifold Pressure)
    * Duty Cycle being applied to the solenoid that controls charge pressure
    See also:
    http://wiki.ross-tech.com/wiki/index...3/P0299/000665
    May 2018
    Australia
    One injector is new,had to change it.I checked exhaust dpf,boost sensor ,new n75 new differencial pressure sensor....turbo is boosting but seems to be to late and too long getting over boost on graf but no faults just one which i posted it.
    check for boost leak no leak.
    Uwe what to look for in group 11?
    May 2018
    Australia
    chanell 011 ENGINE 798/min boost pressure(specified)1009.8mbar boost pressure (actual) 1020 mbar charge pressure control duty cycle 75.4%
    Quote Originally Posted by Gapel3 View Post
    Those values are not terribly interesting at idle.
    Please log values under load:
    https://www.ross-tech.com/vcds/tour/logging.php
    May 2018
    Australia
    WHAT AM I LOOKING FOR ...DIFFERENCE BETWEEN SPEC AND ACTUAL
  9. #8
    Yes, how actual behaves in relation to spec.
  10. Likes Jack@European_Parts liked this post
  11. #9
    May 2018
    Australia
    got log but not sure how to transfer ower here....on test drive asking for more boost as creates...other hand it good ...low rpm its feels like turbo kick in to late around 1800-2100rpm. i know u send me how to post logs here but seems to be to complicated
  12. #10
    Those logs are just text files. Right-click on one of them, Open with Notepad, then copy the contents in-line here, same as the Auto-Scan in your first post.
