Results 1 to 6 of 6
Thread: 2007 Passat 3C- USA, ABS & EPB Coding
    Mar 2020
    Hi I have a 2007 Passat Sedan 3C w-Auto Trans. The EPB control module was replaced with a used unit and needs coded. Unfortunately an auto scan was commenced prior to replacement and coding for ABS and EPB modules appear to be lost or at a default state. Any help in obtaining the correct coding for the ABS and EPB modules would be very much appreciated.
    AUTO SCAN WITH ORIGINAL EPB FITTED
    Windows Based VAG/VAS Emulator Running on Windows 10 x64
    VCDS Version: Release 19.6.1(x64) Data version: 20190529 DS308.0
    Dealer/Shop Name:
    Workshop Code: 000 00000 000000
    Self-Diagnosis Log
    Monday,16,March,2020,19:45:04:41049
    VIN: WVWAK73C07P000904 License Plate:
    Mileage: 223990km-139180mi Repair Order:
    Chassis Type: 3C (3C0)
    Scan: 01 02 03 08 09 15 16 17 19 1C 25 42 44 46 52 53 56 62 65 72
    VIN: WVWAK73C07P000904 Mileage: 223990km-139180miles
    53-Parking Brake -- Status: Malfunction 1010
    72-Door, Rear Right -- Status: Cannot be reached 1100
    Self-Diagnosis Log
    Page 2
    Address 01: Engine Labels:. 06F-907-115-AXX.clb
    Part No SW: 3C0 907 115 S HW: 8P0 907 115 B
    Component: 2.0l R4/4V TFSI 0020
    Revision: --H14--- Serial number: VWZCZ000000000
    Coding: 0404010A19070160
    Shop #: WSC 24223 444 85562
    VCID: 30651F90A3830ACF29-8064
    P1653 - 004 -
    Mileage: 223996 km
    Date: 2020.01.30
    Time: 20:01:14
    Load: 0.0 %
    Temperature: 47.0C
    Temperature: 13.0C
    Absolute Pres.: 980.0 mbar
    Voltage: 12.065 V
    049448 - No Communications with Parking Brake Control Module
    U0128 - 008 - - Intermittent
    Mileage: 223997 km
    Date: 2020.01.31
    Time: 01:44:57
    Load: 0.0 %
    Temperature: 25.0C
    Temperature: 24.0C
    Voltage: 11.811 V
    Readiness: 0110 0101
    Self-Diagnosis Log
    Page 3
    Part No SW: 09G 927 750 HJ HW: 09G 927 750 FP
    Component: AQ 250 6F 1068
    Revision: 00H38000 Serial number:
    Coding: 0000072
    VCID: 00058F5053A35A4F99-8054
    Self-Diagnosis Log
    Page 4
    Address 03: ABS Brakes Labels:. 3C0-614-095-C2.clb
    Part No SW: 3C0 614 095 S HW: 3C0 614 095 S
    Component: ESP 440 C2 H015 0004
    Revision: H015 Serial number: 0667525099
    Coding: 0010000
    Shop #: WSC 00028 028 00001
    VCID: 32611598AD8F38DF5F-8066
    8 Faults Found:
    Fault Frequency: 7
    008 - Implausible Signal
    Fault Status: 01101000
    Reset counter: 22
    Mileage: 223997 km
    Date: 2020.01.31
    Time: 01:42:31
    Reset counter: 22
    Mileage: 223997 km
    Date: 2020.01.31
    Time: 01:43:11
    Reset counter: 22
    Mileage: 223997 km
    Date: 2020.01.31
    Self-Diagnosis Log
    Page 5
    Time: 01:44:30
    Reset counter: 22
    Mileage: 223997 km
    Date: 2020.01.31
    Time: 01:44:30
    Reset counter: 22
    Mileage: 223997 km
    Date: 2020.01.31
    Time: 01:43:11
    Reset counter: 22
    Mileage: 223997 km
    Date: 2020.01.31
    Time: 01:44:30
    Reset counter: 22
    Mileage: 223997 km
    Date: 2020.01.31
    Time: 01:44:30
    Self-Diagnosis Log
    Page 6
    Part No: 1K0 820 047 EC
    Component: Climatic PQ35 090 0505
    VCID: 69D3B2F440D9BB072E-803C
    Self-Diagnosis Log
    Page 7
    Address 09: Cent. Elect. Labels:. 3C0-937-049-23-H.lbl
    Part No SW: 3C0 937 049 Q HW: 3C0 937 049 Q
    Component: Bordnetz-SG H46 1501
    Revision: 00H46000 Serial number: 00000005590367
    Coding: 14848F0340041A00470A00000F00000000285D435C0000
    VCID: 3777248C46EDDDF768-8062
    Subsystem 1 - Part No: 3C1 955 419 Labels: 1KX-955-119.CLB
    Component: Wischer VW461 001 0101
    Coding: 00063445
    Shop #: WSC 00028
    00061 - Footwell Lights
    Fault Status: 01101100
    Reset counter: 23
    Mileage: 223996 km
    Date: 2020.01.24
    Time: 14:50:00
    Voltage: 11.95 V
    010 - Open or Short to Plus
    Fault Status: 01101010
    Reset counter: 23
    Mileage: 223996 km
    Date: 2020.01.24
    Time: 14:50:00
    Voltage: 11.95 V
    Self-Diagnosis Log
    Page 8
    Reset counter: 23
    Mileage: 223996 km
    Date: 2020.01.24
    Time: 14:41:00
    Voltage: 11.95 V
    Self-Diagnosis Log
    Page 9
    Address 15: Airbags Labels: 3C0-909-605.lbl
    Part No SW: 3C0 909 605 K HW: 3C0 909 605 K
    Component: 0N AIRBAG VW8R 029 2521
    Revision: 10029000 Serial number: 003A3P8KLADR
    Coding: 0012366
    VCID: 2E5901E8B9B71C3F3B-807A
    Subsystem 1 - Part No: 3C0 959 339 A
    Component: BF-Gewichtsens. 006 0002
    Subsystem 2 - Serial number: 0000000003AK0H
    Subsystem 3 - Serial number: 0001.01.000000600000000000 63
    Subsystem 4 - Serial number: 000000 6332MSME0E6243549 63
    Subsystem 5 - Serial number: 243549 6342MSME0E72244FK 63
    Subsystem 6 - Serial number: 2244FK 6351HTS6OLLAP7P2F 63
    Subsystem 7 - Serial number: AP7P2F 6361HTS6OLLM06Q23 63
    Subsystem 8 - Serial number: M06Q23 63727TS64IKMM462E 63
    Subsystem 9 - Serial number: MM462E 63827TS63IKQSMV2O
    Subsystem 10 - Serial number: QSMV2O
    01578 - Airbag Deactivation Warning Lamp; Passenger Side (K145)
    009 - Open or Short to Ground - Intermittent - MIL ON
    Address 16: Steering wheel Labels: 3C0-953-549-SW20.lbl
    Part No SW: 3C0 953 549 H HW: 3C0 953 549 H
    Component: J0527 0015
    Revision: 00005000 Serial number: 3C5953507R
    Coding: 0002013
    VCID: 31631A94A88903C726-8064
    Self-Diagnosis Log
    Page 10
    Address 17: Instruments Labels: 3C0-920-xxx-17.lbl
    Part No SW: 3C0 920 971 A HW: 3C0 920 971 A
    Component: KOMBIINSTRUMENT VD1 1614
    Revision: X0006000 Serial number: 00000000000000
    Coding: 0007205
    VCID: 234FE0DCE275A157A4-8076
    Fault Frequency: 9
    Reset counter: 63
    Mileage: 223996 km
    Date: 2020.01.24
    Time: 16:45:41
    Self-Diagnosis Log
    Page 11
    Address 19: CAN Gateway Labels:. 3C0-907-530-V1.clb
    Part No SW: 3C0 907 530 C HW: 3C0 907 951 A
    Component: Gateway 007 0040
    Revision: 00007000 Serial number: 0700C065030515
    Coding: 3FFD0E04D21002
    VCID: 2143EAD4F869B347B6-8074
    Reset counter: 22
    Mileage: 223996 km
    Date: 2020.01.30
    Time: 19:40:37
    Reset counter: 63
    Mileage: 223997 km
    Date: 2020.01.31
    Time: 01:44:58
    Part No SW: 3C0 919 965 HW: 3C0 919 965
    Component: Kompass 005 0002
    Revision: 00005000 Serial number: 1166279TQJ8K05
    VCID: 6DDBC6E47431A72742-8038
    Self-Diagnosis Log
    Page 12
    Part No SW: 3C0 959 433 AA HW: 3C0 959 433 AA
    Component: IMMO 051 0383
    Revision: 00051000 Serial number: VWZCZ000000000
    Shop #: WSC 24223 444 105587
    Component: ELV 029 0380
    3C0905861J ELV 029 0380
    Part No SW: 1K0 959 701 Q HW: 1K0 959 793 M
    Component: J386 TUER-SG FT 1123
    Revision: 31007001 Serial number: 00000061769102
    Coding: 0001205
    Shop #: WSC 43380 001 1048576
    VCID: 3C7D3BA07FCBFEAF85-8068
    01034 - Electric Window Thermal Protection Active; Driver
    Fault Frequency: 73
    Reset counter: 62
    Mileage: 223996 km
    Date: 2020.01.27
    Time: 10:07:11
    Self-Diagnosis Log
    Page 13
    Address 44: Steering Assist Labels: 1Kx-909-144-G2V2.clb
    Part No: 1K1 909 144 K
    Component: EPS_ZFLS Kl.5 D06 1701
    VCID: 336F109C529531D754-8066
    00625 - Vehicle Speed Signal
    Mileage: 3960 km
    Temperature: 17.0C
    Voltage: 13.10 V
    Voltage: 12.80 V
    Component: KSG PQ46 RDK 051 0218
    Coding: 13910F8001862E521004141FF08A0F0E085800
    Shop #: WSC 00611 002 1048576
    Self-Diagnosis Log
    Page 14
    Part No SW: 1K0 959 702 Q HW: 1K0 959 792 M
    Component: J387 TUER-SG BT 1123
    Revision: 11007001 Serial number: 00000028868923
    Coding: 0001204
    VCID: 3D7B36A464D1F7A7B2-8068
    01035 - Electric Window Thermal Protection Active; Passenger
    Fault Frequency: 72
    Reset counter: 62
    Mileage: 223996 km
    Date: 2020.01.27
    Time: 10:07:11
    Self-Diagnosis Log
    Page 15
    Address 53: Parking Brake Labels: 3C0-907-801-53.clb
    Part No SW: 3C0 907 801 B HW: 3C0 907 801 B
    Component: EPB VC8HC001 013 0001
    Revision: 013
    Coding: 0010000
    01316 - ABS Control Module
    Fault Status: 11101101
    Fault Frequency: 122
    Reset counter: 23
    Mileage: 223992 km
    Date: 2020.01.31
    Time: 01:45:53
    Voltage: 11.49 V
    Count: 236
    000 - - - MIL ON
    Fault Status: 11100000
    Reset counter: 23
    Mileage: 223992 km
    Date: 2020.01.31
    Time: 01:45:53
    Voltage: 11.49 V
    Count: 170
    02433 - Supply Voltage for Right Parking Brake Motor (V283)
    011 - Open Circuit - MIL ON
    Fault Status: 11111011
    Reset counter: 22
    Mileage: 223992 km
    Date: 2020.01.24
    Time: 15:10:19
    Self-Diagnosis Log
    Page 16
    Voltage: 11.59 V
    Count: 117
    02432 - Supply Voltage for Left Parking Brake Motor (V282)
    Fault Status: 11111100
    Fault Frequency: 7
    Reset counter: 17
    Mileage: 223808 km
    Date: 2020.01.13
    Time: 22:14:48
    Voltage: 12.84 V
    Count: 86
    Reset counter: 22
    Mileage: 223992 km
    Date: 2020.01.24
    Time: 15:10:19
    Voltage: 11.59 V
    Count: 116
    Address 56: Radio Labels: 1K0-035-161.lbl
    Part No SW: 1K0 035 161 B HW: 1K0 035 161 B
    Component: Radio DE2 014 0016
    Revision: 00014000 Serial number: VWZ4Z7F6138104
    Coding: 0040401
    VCID: 1E39D128C9178CBF8B-804A
    Self-Diagnosis Log
    Page 17
    Part No SW: 1K0 959 703 Q HW: 1K0 959 795 J
    Component: J388 TUER-SG HL 1109
    Revision: 12005001 Serial number: 00000000029359
    Coding: 0001168
    VCID: 3E7931A869D7ECBFAB-806A
    01036 - Electric Window Thermal Protection Active; Rear Left
    Fault Frequency: 20
    Reset counter: 62
    Mileage: 223996 km
    Date: 2020.01.27
    Time: 10:18:09
    01813 - Supply Voltage for Door Controller; Rear Left (J388)
    Fault Status: 00100001
    Reset counter: 62
    Mileage: 223996 km
    Date: 2020.01.30
    Time: 19:21:19
    Component: RDK 0420
    Coding: 0100101
    Self-Diagnosis Log
    Page 18
    Address 72: Door, Rear Right Labels: None
    Part No: No response
    Component: Error LIN Slave 0
    VCID: 2C5D0BE08FAB6E2F15-8078
    End-------------------------(Elapsed Time: 02:09)--------------------------
    AUTO SCAN WITH USED REPLACEMENT EPB MODULE FITTED
    Dealer/Shop Name:
    Self-Diagnosis Log
    Monday,16,March,2020,19:49:52:41049
    Self-Diagnosis Log
    Page 2
    P1653 - 004 -
    Mileage: 223996 km
    Date: 2020.01.30
    Time: 20:01:14
    Load: 0.0 %
    Temperature: 47.0C
    Temperature: 13.0C
    Voltage: 12.065 V
    Mileage: 223997 km
    Date: 2020.01.31
    Time: 01:44:57
    Load: 0.0 %
    Temperature: 25.0C
    Temperature: 24.0C
    Voltage: 11.811 V
    Self-Diagnosis Log
    Page 3
    Coding: 0000072
    Self-Diagnosis Log
    Page 4
    Coding: 0010000
    Reset counter: 22
    Mileage: 223997 km
    Date: 2020.01.31
    Time: 01:50:55
    Reset counter: 22
    Mileage: 223997 km
    Date: 2020.01.31
    Time: 01:50:56
    Reset counter: 22
    Mileage: 223997 km
    Date: 2020.01.31
    Time: 01:50:56
    Reset counter: 22
    Self-Diagnosis Log
    Page 5
    Mileage: 223997 km
    Date: 2020.01.31
    Time: 01:50:56
    Reset counter: 22
    Mileage: 223997 km
    Date: 2020.01.31
    Time: 01:50:56
    Reset counter: 22
    Mileage: 223997 km
    Date: 2020.01.31
    Time: 01:50:56
    Self-Diagnosis Log
    Page 6
    Coding: 00063445
    Shop #: WSC 00028
    Reset counter: 23
    Mileage: 223997 km
    Date: 2020.01.31
    Time: 01:50:00
    Voltage: 11.70 V
    Reset counter: 23
    Mileage: 223997 km
    Date: 2020.01.31
    Time: 01:52:00
    Voltage: 11.65 V
    Self-Diagnosis Log
    Page 7
    Reset counter: 23
    Mileage: 223997 km
    Date: 2020.01.31
    Time: 01:50:00
    Voltage: 11.70 V
    Self-Diagnosis Log
    Page 8
    Coding: 0012366
    Coding: 0002013
    Self-Diagnosis Log
    Page 9
    Coding: 0007205
    Reset counter: 23
    Mileage: 223997 km
    Date: 2020.01.31
    Time: 01:50:56
    Self-Diagnosis Log
    Page 10
    Coding: 0001205
    Self-Diagnosis Log
    Page 11
    Coding: 0001204
    Self-Diagnosis Log
    Page 12
    Part No SW: 3C0 907 801 E HW: 3C0 907 801 E
    Component: EPB VC8HC003 013 0003
    Revision: 013
    Coding: 0010000
    VCID: 244DE3C0E77BA66FDD-8070
    000 - - - MIL ON
    Reset counter: 22
    Mileage: 223992 km
    Date: 2020.01.30
    Time: 19:41:48
    Voltage: 11.18 V
    Count: 170
    000 - - - MIL ON
    Reset counter: 22
    Mileage: 223992 km
    Date: 2020.01.30
    Time: 19:41:48
    Voltage: 11.18 V
    Count: 171
    Reset counter: 22
    Mileage: 223992 km
    Date: 2020.01.30
    Time: 19:55:27
    Self-Diagnosis Log
    Page 13
    Voltage: 12.84 V
    Count: 86
    02443 - Control Head
    Fault Status: 00111000
    Reset counter: 62
    Voltage: 9.42 V
    Count: 46
    Reset counter: 23
    Mileage: 223480 km
    Date: 2018.08.06
    Time: 00:05:00
    Voltage: 11.39 V
    Count: 236
    Coding: 0040401
    Self-Diagnosis Log
    Page 14
    Coding: 0001168
    Component: RDK 0420
    Coding: 0100101
    End-------------------------(Elapsed Time: 02:05
    HQ
    ABS coding will be 0013755.
    EPB module coding is 0000013
    Go to this wiki page:
    http://wiki.ross-tech.com/wiki/index..._Parking_Brake
    Work your way through the items listed under "Replacement".
    Jef
  3. Likes Uwe, Jack@European_Parts, Dana liked this post
    Admin Note: Please do not use the [Print] function in VCDS to post data here. Please post the native text that VCDS produces; it is much more legible on a forum. The native text of all scans is saved in the Scans sub-folder.
  5. Likes Dana liked this post
    Mar 2020
    Understood and noted for the future thanks
  7. Likes Uwe liked this post
  8. #5
    Mar 2020
    Excellent your coding data was spot on and car is fixed!
    Thank Jef and Ross-Tech you guys are great!
  9. Likes Uwe, Dana liked this post
  10. #6
    Mar 2020
    Car is fixed!
    Auto Scan after Coding and Basic Settings applied
    Tuesday,24,March,2020,16:17:56:41049
    VCDS Version: 19.6.2.2
    Mileage: 224020km-139199mi   Repair Order: RVA6
    VIN: WVWAK73C07P000904   Mileage: 224020km-139199miles
       VCID: 30651F90A3830ACF15-8064
       Coding: 0000072
       VCID: 00058F5053A35A4FA5-8054
       Coding: 0013755
       VCID: 32611598AD8F38DF63-8066
       VCID: 69D3B2F440D9BB0712-803C
       VCID: 3777248C46EDDDF754-8062
       Coding: 00063445
       Shop #: WSC 00028
                        Reset counter: 24
                        Mileage: 224028 km
                        Date: 2020.02.07
                        Time: 00:18:00
                        Voltage: 11.75 V
                        Reset counter: 24
                        Mileage: 224028 km
                        Date: 2020.02.07
                        Time: 00:18:00
                        Voltage: 11.80 V
       Coding: 0012366
       VCID: 2E5901E8B9B71C3F07-807A
       Subsystem 3 - Serial number: 0001.01.00000060000000000063
       Subsystem 4 - Serial number: 0000006332MSME0E624354963
       Subsystem 5 - Serial number: 2435496342MSME0E72244FK63
       Subsystem 6 - Serial number: 2244FK6351HTS6OLLAP7P2F63
       Subsystem 7 - Serial number: AP7P2F6361HTS6OLLM06Q2363
       Subsystem 8 - Serial number: M06Q2363727TS64IKMM462E63
       Subsystem 9 - Serial number: MM462E63827TS63IKQSMV2O
       Coding: 0002013
       VCID: 31631A94A88903C71A-8064
       Coding: 0007205
       VCID: 234FE0DCE275A15798-8076
       VCID: 2143EAD4F869B3478A-8074
                        Reset counter: 24
                        Mileage: 224028 km
                        Date: 2020.02.07
                        Time: 00:18:29
       VCID: 6DDBC6E47431A7277E-8038
       Coding: 0001205
       VCID: 3C7D3BA07FCBFEAFB9-8068
       VCID: 336F109C529531D768-8066
       Coding: 0001204
       VCID: 3D7B36A464D1F7A78E-8068
       Revision:   013
       Coding: 0000013
       VCID: 244DE3C0E77BA66FE1-8070
       Coding: 0040401
       VCID: 1E39D128C9178CBFB7-804A
       Coding: 0001168
       VCID: 3E7931A869D7ECBF97-806A
       Component:    RDK              0420
       Coding: 0100101
       VCID: 2C5D0BE08FAB6E2F29-8078
    End-------------------------(Elapsed Time: 01:59)--------------------------
  11. Likes Uwe, Dana liked this post
