Results 1 to 3 of 3
Thread: Golf mk7 acc replaced
    Jan 2017
    Hi all,
    My story is....
    I bought golf mk7 from Copart with front damage and acc sensor was missing.
    I bought second hand acc from eBay and got cp removed by vw specialist cause I don’t have acces to odis
    Now situation is that I’m still getting codes vw specialist told me it will need only calibration and that’s it nothing else but when I connect my VCDS it looks like actual acc wasn’t even coded to the car....
    Can anyone tell me what to do or were to start. I really don’t wanna spend £400 for calibration just to find out that it’s still not working. Pls
    Tuesday,24,March,2020,00:26:27:38492
    VCDS Version: 19.6.2.2 (x64)
    VIN: WVWZZZAUZGW072679   License Plate:
    Mileage: 60277km-37454mi   Repair Order:
    Chassis Type: AU-VW37 (5Q0)
    Scan: 01 02 03 08 09 10 13 15 16 17 19 22 42 44 52 55 5F A9
    VIN: WVWZZZAUZGW072679   Mileage: 60277km-37454miles
    Address 01: Engine (J623-CJXC)       Labels:. 06K-907-425-V1.clb
       Part No SW: 5G0 906 259 F    HW: 06K 907 425 B
       Revision: --H13---
       Coding: 091D00322466050B2004
       ASAM Dataset: EV_ECM20TFS0205G0906259F 001004
       ROD: EV_ECM20TFS0205G0906259F.rod
       VCID: 3169399760BF06C71A-8064
    17169 - Check Coding of ECUs on Powertrain Data Bus
              P1647 00 [167] - -
                        Mileage: 60277 km
                        Date: 2020.03.24
                        Time: 00:19:38
                        Engine speed: 761.50 /min
                        Normed load value: 19.2 %
                        Coolant temperature: 99 °C
                        Intake air temperature: 27 °C
                        Voltage terminal 30: 14.511 V
                        ACC variants (coding): ACC with braking until at standstill/Stop & Go
                        CCS Switch: ACC operating unit
                        Cruise control switch actuation-Main switch hardware: not activated
                        Cruise control switch actuation-Main switch CAN: not activated
                        ACC variants: ACC
                        Engine: operating status: IS
    Readiness: 1010 0001
       Part No SW: 0D9 300 012     HW: 02E 927 770 AQ
       Component: DQ250-6A MQB  H53 4911
       Revision: 06253104    Serial number: TFK01506250997
       ROD: EV_TCMDQ250021.rod
       VCID: 53A5531F3A6314D748-8006
       Revision: 00000000    Serial number: 61925000000464
       Coding: 01FA93A15427296E077D070741CC6980C92A94E0E08296F718425078C208
       VCID: 7AFBDEBBFD49059FEB-802E
    8309 - Engine Control Module Incorrectly Coded
              P1612 00 [009] - -
                        Fault Frequency: 23
                        Reset counter: 73
                        Mileage: 60178 km
                        Date: 2020.03.20
                        Time: 14:21:57
       Part No SW: 5G0 907 044 BD    HW: 5G0 907 044 BD
       Revision: 00001K08
       Coding: 00120004100100001105000011101402
       VCID: 6ADBEEFB8DE9B51F1B-803E
    459024 - Databus
                        Reset counter: 67
                        Mileage: 60178 km
                        Date: 2020.03.20
                        Time: 13:02:20
       Part No SW: 5Q0 937 084 AS    HW: 5Q0 937 084 AN
       Serial number: 01061519705597
       Coding: 03001A42C24122F30BA44080B10C07281000000000000000000000000000
       ROD: EV_BCMBOSCH_015.rod
       VCID: 0919B177A8AF1E07F2-805C
       Component: WWS    150703  042 0551
       Serial number:         150712084610
       Component: RLHS  037 0059
       Serial number: S2Y15M07D27H13M28S02
       Coding: 90A8DD
       Component: Sensor, DWA  006 0326
       Serial number: 000000000ZY1516742DU
       Serial number: 00000000000063102420
    13697024 - Component Protection
              U1100 00 [008] - No Basic Setting
                        Reset counter: 107
                        Mileage: 60178 km
                        Date: 2020.03.20
                        Time: 12:57:54
       Revision: --------    Serial number: 39331520103714
       Coding: 0071051011
       VCID: 4385635FCA038457F8-8016
       Part No SW: 5Q0 907 572 A    HW: 5Q0 907 572 A
       Component: ACC Bosch MQB H04 0150
       Serial number: 13081376510599
       Coding: 00001300FE033B
       ASAM Dataset: EV_ACCMRRBoschVW372 001013
       VCID: 35610D8794D72AE746-8060
    1807 - No Enable Indentifications Active
              B2032 00 [009] - -
                        Reset counter: 74
                        Mileage: 60277 km
                        Date: 2020.03.24
                        Time: 00:09:33
                        Control Module temperature: 30 °C
                        Voltage terminal 15: 14.4 V
                        Vehicle speed: 0.00 m/s
                        Acceleration: 0.00 m/s²
    1043 - Automatic Distance Control
              B10E7 F0 [009] - Disconnected
                        Reset counter: 74
                        Mileage: 60277 km
                        Date: 2020.03.24
                        Time: 00:09:33
       Serial number: 003MLR0YPXMF
       ROD: EV_AirbaVW20SMEVW37X.rod
       VCID: 7F0D2FAFE66B20B7DC-802A
       Belt Pretensioner left:
       Component: BeltPretRevFL  H36 0350
       Serial number: 34169677B21071570618
       Coding: 333135
       Belt Pretensioner right:
       Component: BeltPretRevFR  H36 0350
       Serial number: 34169676B22071590358
       Coding: 333135
       Subsystem 3 - Part No SW: -----------    HW: 480 001 807 15
       Serial number: 357670000002E289651W
       Subsystem 4 - Part No SW: -----------    HW: 480 001 807 15
       Serial number: 3586700000002474651F
       Subsystem 5 - Part No SW: -----------    HW: 480 401 507 15
       Serial number: 3516502AF1C52F43812E
       Subsystem 6 - Part No SW: -----------    HW: 480 401 607 15
       Serial number: 3526502B11C52F2350C6
       Subsystem 7 - Part No SW: -----------    HW: 480 401 607 15
       Serial number: 3556502B71C52F42C2CP
    Address 16: Steering wheel (J527)       Labels:. 5Q0-953-549.clb
       Part No SW: 5Q0 953 507 GK    HW: 5Q0 953 549 E
       Component: Lenks. Modul  003 0110
       Revision: --------    Serial number: 24071504220865
       Coding: 0C10
       ROD: EV_SMLSKLOMQB_010_VW37.rod
       VCID: 0501BD4784B77A6796-8050
    No ASAM data for: "EV_SMLSKLOMQB" (VW37)
       Part No SW: 5G1 920 958 A    HW: 5G1 920 958 A
       Component: KOMBI         302 6420
       Coding: 27AD08082F80260001886A011400000000000000
       VCID: 2F6D3FEF768B10370C-807A
       Part No SW: 5Q0 907 530 AF    HW: 5Q0 907 530 F
       Component: GW MQB High   128 1224
       Revision: --------    Serial number: 0003775802
       Coding: 030100043F085900FB00027E1C0F00010001050000000000000000000000
       ROD: EV_GatewLear_013.rod
       VCID: 75E1CD87D4576AE786-8020
       Component: E221__MFL-DC1  H10 0040
       Serial number: 29150001450120085293
       Coding: 2DFFFF
       Serial number: 2391617203
       Serial number: HA1-00002.06.15
       Coding: 0001
       VCID: 46837A4BF931B17FDF-8012
       Serial number: 080715BG80492A
       Coding: 003F0220D001048000001000
       Serial number: 00000000000006796053
       Coding: 0D0000
    65608 - Lamp for Ambient Speaker Illumination
              B13C8 01 [008] - Electrical Failure
                        Fault Frequency: 36
                        Reset counter: 113
                        Mileage: 60156 km
                        Date: 2020.03.19
                        Time: 17:40:12
       Coding: 8103
       VCID: 377D078F8EDBD8F754-8062
       Serial number: 100715BG918952
       Coding: 003F0020DE01048000801000
       VCID: 428B665BD5198D5FF3-8016
       Serial number: 00000000000006841186
       Coding: 150000
                        Fault Frequency: 36
                        Reset counter: 113
                        Mileage: 60156 km
                        Date: 2020.03.19
                        Time: 17:40:12
    589849 - Window Regulator Switch; Rear Passenger Side
              B1324 29 [009] - Signal Implausible
                        Fault Frequency: 28
                        Reset counter: 74
                        Mileage: 60156 km
                        Date: 2020.03.19
                        Time: 17:34:43
       Coding: 02AE01000B000200
       VCID: 408F6C53DB159F4FE5-8014
       Subsystem 1 - Part No SW: 3D0 941 329 E    HW: 3D0 941 329 E  Labels: 3D0-941-329.CLB
       Coding: 2E0000
       Subsystem 2 - Part No SW: 3D0 941 329 E    HW: 3D0 941 329 E  Labels: 3D0-941-329.CLB
       Coding: 2E0000
       Part No SW: 3Q0 035 874 A    HW: 3Q0 035 874 A
       Component: MU-S-ND-ER    820 0627
       Coding: 02730001FF00000051111101008808001F0207C601200100CF
       Shop #: WSC 29899 001 1048576
       ROD: EV_MUStd4CDELP_VW37.rod
       VCID: 306F3C936BB50FCF15-8064
       Component: ABT_Std-2_Nav  H50 8130
       Serial number: VWZ6ZHV0114202
       Subsystem 2 - Part No SW: 3G0 919 866 H    HW: -----------
       Component: ECE 2015/16  --- 0430
    7 Faults Found:
              B201A 00 [008] - -
                        Reset counter: 113
                        Mileage: 60156 km
                        Date: 2020.03.19
                        Time: 17:34:47
                        Voltage terminal 30: 14.8 V
                        Status_Software_Version_Management-module_name: C
                        Reset counter: 107
                        Mileage: 60178 km
                        Date: 2020.03.20
                        Time: 12:58:08
                        Voltage terminal 30: 12.1 V
    2571 - Navigation system
              B126C F2 [008] - Navigation database not enabled
                        Reset counter: 107
                        Mileage: 60178 km
                        Date: 2020.03.20
                        Time: 12:58:09
                        Voltage terminal 30: 12.0 V
    0013 - Antenna Amplifier 1 for Digital Radio
              B1270 13 [009] - Open Circuit
                        Reset counter: 66
                        Mileage: 60156 km
                        Date: 2020.03.19
                        Time: 17:34:47
                        Status of digital radio antenna 1-Antenna current: 0 mA
                        Status of digital radio antenna 1-Connection between radio and antenna amplifier: Open circuit
                        Status of digital radio antenna 1-Connection between antenna amplifier and antenna: Not available
                        Status of digital radio antenna 1-DAB_Bit_Error_Rate_FIC: 0.393216
                        Status of digital radio antenna 1-DAB_Bit_Error_Rate_MSC: 4.245282
    0014 - Connection between Antenna Amp 1 for Digital Radio and Antenna
              B1274 13 [009] - Open Circuit
                        Reset counter: 66
                        Mileage: 60156 km
                        Date: 2020.03.19
                        Time: 17:34:47
              U1111 00 [008] - -
                        Reset counter: 107
                        Mileage: 60156 km
                        Date: 2020.03.19
                        Time: 17:34:51
                        Voltage terminal 30: 14.7 V
                        BAP-BAP_Function_ID: 02
    7195 - Function Restricted due to Missing Message(s)
              U1111 00 [008] - -
                        Reset counter: 107
                        Mileage: 60156 km
                        Date: 2020.03.19
                        Time: 17:34:51
       Part No SW: 5G0 907 159 D    HW: 4H0 907 159 A
       Serial number: 150619201412
    End-------------------------(Elapsed Time: 04:37)--------------------------
    May 2017
    Not that simple. You need to take the car to an authorized VW maintenance shop where they need restore the feature enablement codes for the ACC.
    BUT, is the replacement radar EXACTLY the same as the one that was in the car originally? It has to be, otherwise the official way does not work.
  3. Likes darkchina811, Uwe liked this post
    Apr 2018
    ITALY
    other than restoring FeC to the radar (provided it's the correct part number like downtime said) you have Component Protection active in other modules. you might want to deal with that as well.
    my Golf came out of the factory with 13 ECUs. now she has 20. and counting
  5. Likes downtime, Uwe liked this post
