Results 1 to 10 of 10
Thread: 2011 A3 TDI with several codes
    Jan 2016
    I just got a 2011 A3 TDI for my wife and TPMS "underinflated" warning came up. I went to fill it up to 36 PSI and I thought that was it. The warning went away bu the icon on the dashboard remained, so I went ahead and scanned it with the VCDS to clear it but it still remained and there was a couple more codes that I was not aware of before.
    Posting the autoscan.
    Sunday,22,March,2020,14:10:00:32299
    VCDS Version: 19.6.2.2 (x64)
    VIN: WAUKJAFM1CA158350   License Plate: AUDI SILVER 2
    Mileage: 160680km-99841mi   Repair Order:
    Chassis Type: FM-AU35 (7N0)
    Scan: 01 02 03 08 09 0F 15 16 17 19 25 42 44 46 47 4C 52 55 56 62
              72 77
    VIN: WAUKJAFM1CA158350   Mileage: 160680km-99841miles
    Address 01: Engine (CBE)       Labels: 03L-906-022-CBE.clb
       Part No SW: 03L 997 030 A    HW: 03L 906 019 EJ
       Component: R4 2.0l TDI G000AG  9983
       Revision: 12H14---    Serial number: AUX7Z0L3FNB0II
       Coding: 0050078
       Shop #: WSC 46531 003 1048576
       VCID: 2C576E9F8F751C2F29-8078
                   P0300 - 000 -  - Intermittent
                        Mileage: 160371 km
                        Date: 2019.10.19
                        Time: 20:17:53
                        RPM: 2530 /min
                        Speed: 134.0 km/h
                        Load: 43.5 %
                        Voltage: 13.91 V
                        Voltage: 13.91 V
                        Voltage: 13.91 V
                        Voltage: 13.91 V
    000772 - Cylinder 4
                   P0304 - 000 - Misfire Detected - Intermittent
                        Mileage: 160372 km
                        Date: 2019.10.19
                        Time: 20:18:24
                        RPM: 2254 /min
                        Speed: 112.0 km/h
                        Load: 63.9 %
                        Bin. Bits: 00000010
                        Torque: 294.0 Nm
                        Bin. Bits: 00000000
                        Ign. Timing: 17.1 ATDC
    000770 - Cylinder 2
                   P0302 - 000 - Misfire Detected - Intermittent
                        Mileage: 160372 km
                        Date: 2019.10.19
                        Time: 20:18:24
                        RPM: 2254 /min
                        Speed: 112.0 km/h
                        Load: 63.9 %
                        Bin. Bits: 00000010
                        Torque: 276.0 Nm
                        Bin. Bits: 00000000
    000771 - Cylinder 3
                   P0303 - 000 - Misfire Detected - Intermittent
                        Mileage: 160374 km
                        Date: 2019.10.19
                        Time: 20:19:47
                        RPM: 2668 /min
                        Speed: 123.0 km/h
                        Load: 71.4 %
                        Bin. Bits: 00000010
                        Torque: 276.0 Nm
                        Bin. Bits: 00000000
                        Ign. Timing: 15.3 ATDC
       Part No SW: 02E 300 057 P    HW: 02E 927 770 AL
       Component: GSG DSG AG6     512 9432
       Revision: 05551213    Serial number: 00001204100097
       Shop #: WSC 06314 000 00000
       VCID: 26439CB79199267FFF-8072
       Revision: 00H31001
       Coding: 1150400F49270002880E02E992190042BF0C00
       VCID: 7BF59DC3FA9B4B97F0-802E
    02214 - Tire Pressure Warning
                002 - Lower Limit Exceeded
                        Fault Status: 01100010
                        Reset counter: 116
                        Mileage: 160688 km
                        Date: 2020.03.22
                        Time: 02:34:33
                        Count: 14
                        Count: 12800
                        Count: 16401
                        Count: 50176
                        Count: 252
       Part No SW: 8P0 820 043 BN    HW: 8P0 820 043 BN
       Component: KlimavollautomatH09 0180
       Revision: 000773      Serial number: 8P0820043BN
       VCID: 79F987CB30A77987E2-802C
                        Reset counter: 150
                        Mileage: 160592 km
                        Date: 2020.03.15
                        Time: 22:41:59
                        Temperature: 14.0C
    Address 09: Cent. Elect.
       Part No SW: 8E0 035 593 P    HW: 8E0 035 593 P
       Component: SDAR SIRIUS     H07 0160
       Revision: 00000000    Serial number: AUZ4Z7M0613556
       Coding: 0000100
       VCID: 36634CF7413956FF4F-8062
                        Reset counter: 116
                        Mileage: 160688 km
                        Date: 2020.03.22
                        Time: 02:34:45
    Address 15: Airbags (J234)       Labels:* 8P0-959-655-10.clb
       Part No SW: 8P0 959 655 Q    HW: 8P0 959 655 Q
       Component: Airbag AU1042 H10 0250
       Revision: --------    Serial number: 003FC001PZ27
       Coding: 303142393041303030374A55304C38503053
       ROD: EV_Airba10AURB4.rod
       VCID: 50AF1A6F0B9D18CF75-8004
       Subsystem 1 - Part No SW: 8P0 959 339 E    HW: 8P0 959 339 E
       Component: BF-Gewichtss.  H04 0040
       Serial number: 5850000R12312016KD
       Serial number: 3572DRB40000E9C06981
       Serial number: 3582DRB40000E9CD3A49
       Serial number: 35128RB400006A9A3B9X
       Serial number: 35228RB400006A99D7B+
       Serial number: 35547RB400006B4FE92+
       Serial number: 35647RB400006B4FEC22
       Part No SW: 8P0 953 549 K    HW: 8P0 953 549 K
       Component: J0527           H38 0070
       Coding: 0014142
       VCID: 46833C3731D9C67FDF-8012
       Component: E0221           H02 0100
    Address 17: Instruments        Labels: 8P0-920-xxx-17-MY8.clb
       Part No SW: 8P0 920 983 D    HW: 8P0 920 983 D
       Component: KOMBIINSTR. VDO H04 0150
       Revision: D0H04003    Serial number: 2243L003003809
       Coding: 0272288
       Shop #: WSC 01307 067 57207
       VCID: 3B755DC37A1B8B97B0-806E
    00003 - Control Module
                        Fault Status: 01100101
                        Mileage: 160688 km
                        Date: 2020.03.22
                        Time: 02:34:33
       Revision:   H42       Serial number: 080412F2000802
       Coding: 352102
       VCID: 3A7B58C7B521B29FAB-806E
       Revision: D0H04003    Serial number: AUX7Z0L3FNB0II
    Address 42: Door Elect, Driver        Labels: 8P0-959-801-MIN3.lbl
       Part No SW: 8P0 959 801 Q    HW: 8P0 959 801 Q
       Component: Tuer-SG         H04 0101
       Coding: 0001213
       VCID: 4999370B20C7290732-801C
       Part No: 1K0 909 144 P
       Component: EPS_ZFLS Kl. 233    3305
       Revision: 00H22000
       VCID: 377D41F34633AFF754-8062
    Address 46: Central Conv.
       Part No SW: 8P4 035 382 E    HW: 8P4 035 382 E
       Component: AB2 SUBWOOFERBOXH07 0180
       Revision: 00006       Serial number: 92158230507286
       Part No SW: 8P0 959 802 Q    HW: 8P0 959 802 Q
       Coding: 0001213
       VCID: 4A9B080725C1221F3B-801E
       Component: ****LWR12**** H02 0012
       Serial number: 120419-0002-125
       Coding: 1163951010020000
       ROD: EV_HeadlRegulBasic.rod
       VCID: 428B2027D5F1FA5FF3-8016
       Part No SW: 8P0 035 186 AC    HW: 8P0 035 186 AC
       Component: R Concert2+     H05 0293
       Revision: 00H05000    Serial number: AUZ1Z3M3122966
       Coding: 0750112
       VCID: 73E5B5E312CB03D7A8-8026
    Address 62: Door, Rear Left        Labels: 8P4-959-801.lbl
       Part No SW: 8P4 959 801 F    HW: 8P4 959 801 F
       Component: Tuer-SG         H04 0050
       Coding: 0001176
       Shop #: WSC 06314 000 1012544
       VCID: 428B20271DF1FA5FF3-8016
    Address 72: Door, Rear Right        Labels: 8P4-959-802.lbl
       Part No SW: 8P4 959 802 F    HW: 8P4 959 802 F
       Coding: 0001176
       VCID: 4385252302EBF357F8-8016
       Part No SW: 8P1 862 336 A    HW: 8P1 862 336
       Component: FSE_256x BT     H44 0660
       Revision: 00000000    Serial number: 00000005164677
       Coding: 0001277
    End-------------------------(Elapsed Time: 02:25)--------------------------
    Can you help me resolve them?
    Did you try clearing codes and road test after verifying all PSI of tires is accurate?
    What does OBD2 mode report?
    JPPSG
    That's an indirect TPMS system that uses a fancy analysis of the wheel speeds to detect a lack of pressure. There should be a manual reset switch somewhere. On some cars its in the glove box. If you can't find it, check the owner's manual.
    Jan 2016
    Thanks Jack - tried that but it did not reset. I was not sure what you wanted me to scan for OBD2?
    Thanks Uwe - your suggestion made me think of the menu display option.
    I was able to reset the TPMS through the MENU DISPLAY. But I did not have the manual handy so I resorted to the next best thing, YouTube (lol). Found a video that showed where and how.
    Here's the link: https://youtu.be/TNOr1c1TwYs
    As far as the misfire codes - it may be an old code, the car runs perfectly fine when I test drove it even on the freeway, slow and fast speeds. Is it safe to clear it?
    On to the next codes below:
    Auto HVAC: 01592 - Air Quality Sensor (G238) - is this safe to clear? What is it for?
    Instruments: 00003 - Control Module
    How do I resolve this one?
    Thanks in advance!
    Quote Originally Posted by jaysol33 View Post
    I believe it gives your HVAC the ability to switch to recirc mode automatically when it decides that's desirable, for example in a tunnel or if you're following someone who's rolling coal. Yes, it's safe to clear, but don't be surprised if it comes back at some point; it's a pretty common fault.
    This means some of the values in the Adaptation channels of your instrument cluster that determine when the cluster will give you a Service Reminder aren't set to the cluster's liking. Go to [SRI Reset], wait for VCDS to read the SRI-related channels, click [Add to logfile] and then post the resulting log here.
    Jan 2016
    Hi Uwe,
    Cleared the HVAC error code.
    Here's the SRI log
    Tuesday,24,March,2020,11:56:49:32299
    VIN:    License Plate: AUDI SILVER
    Mileage: 160720km-99866mi   Repair Order:
    VCDS Release 19.6.2:  SRI Reset
    Control Module Part Number: 8P0 920 983 D       Labels:  8P0-920-xxx-17-MY8.clb
    Component:KOMBIINSTR. VDO H04 0150, Coding:0272288
    Channel  	Description                                       	Unit      	Current val.  	New val.
    02       	Service Reminder Status                           	          	1             	---
    40       	Distance since Service                            	km x100   	3             	---
    41       	Time since Service                                	Days      	222           	---
    42       	Minimum Distance to Service                       	km x100   	150           	---
    43       	Maximum Distance to Service                       	km x100   	150           	---
    44       	Maximum Time to Service                           	Days      	365           	---
    45       	Oil Quality                                       	          	1             	---
    47       	Soot Quantity                                     	km x100   	0             	---
    48       	Thermal Load                                      	km x100   	0             	---
    49       	Minimum Time to Service                           	Days      	365           	---
    50       	Basic Distance Value for Oil Change               	km x100   	160           	---
    51       	Basic Time Value for Oil Change                   	Days      	365           	---
    52       	Basic Distance Value for Inspection               	km x100   	160           	---
    53       	Distance since Inspection                         	km x100   	315           	---
    54       	Basic Time Value for Inspection                   	Days      	365           	---
    55       	Time since Inspection                             	Days      	997           	---
    56       	Day Counter                                       	Days      	2540          	---
  7. #7
    Well, I'm not surprised that your Service Reminder remains active.
    55 Time since Inspection exceeds 54 Basic Time Value for Inspection
    and
    53 Distance since Inspection exceeds 52 Basic Distance Value for Inspection
    However, it's not obvious to me why the cluster throwing the "No Basic Settings" fault.
  8. #8
    I think these 3 channels, should be changed to shown values.
    43 Maximum Distance to Service km x100 > 300
    44 Maximum Time to Service Days > 730
    54 Basic Time Value for Inspection Days > 730
  9. Likes Uwe, Jack@European_Parts, PetrolDave liked this post
  10. #9
    Jan 2016
    I got the SRI reset and done, so that is taken cared of. However, just like what Uwe said, I still have this code:
    I actually have this code pop up on my other Audi TDI too. Any ideas?
  11. #10
    Post a new current complete auto-scan of vehicles status as of now & OBD2 mode ( 0x33 ) ( OBD-II ) Modes 1-01, 03, 07 & 09.
    Do the adaption of all the needed sensors, drive it or if no issues are observed, ignore it?
