Page 1 of 5 123 ... LastLast
Results 1 to 10 of 46
Thread: 2004 TOUAREG YES CRANK, NO START
    Nov 2019
    Alright, well I am still at it.
    Here are of the things that I have tried so far and then here is a fresh auto scan...
    Originally I purchased this car and it would start, run for 30 seconds & die. Replaced both fuel pumps and fixed this problem.
    Then my wife was driving it & all electrical shut off and so did the car. Pulled over & towed home.
    Then a few intermittent starts, but died shortly after. Never to start again.
    YES CRANK BUT NO START.
    WHAT I HAVE TRIED:
    1) New Fuel Pumps
    2) New battery
    3) Bench test ECU/PCM: found in good working order. no fault to grounds.
    4) Pulled up drivers carpet & inspected drivers footwell wiring for corrosion. Found minor & cut and re-spliced connections.
    5) Checked 404 relay under passenger side hood relay box, working
    What I'm doing today:
    Checking the electrical grounds under the hood.
    Questions: Is there anything that I am missing or is there a way to track down all of the listed fault to ground and intermittent faults?
    Thanks as always for the help and my fight continues!!!
    ps. I didn't know how to link this to the old thread and also post a new auto scan.
    Sunday,22,March,2020,13:49:22:54382
    Dealer/Shop Name: Dave and Joey's Bone-Yard
    VIN: WVGBC77L34D064021   License Plate:
    Chassis Type: 7L (7L - VW Touareg (2003 > 11/2006))
    Scan: 01 02 03 05 06 08 09 11 13 15 16 17 18 19 1C 22 29 32 34 36
              37 39 3C 46 47 55 56 57 64 65 68 69 6C 6D 6E 75 76 77
    VIN: WVGBC77L34D064021   Mileage: 252670km-157001miles
    Address 01: Engine        Labels: 022-906-032-BMX.lbl
       Part No SW: 022 906 032 BF    HW:
       Component: MOTRONIC ME7.1.1G   9779
       Coding: 0000133
       Shop #: WSC 19226 444 59215
       VCID: 50F97738A6FE7567197-5160
    19 Faults Found:
    17069 - ECM Power Relay Control Circuit
                P0685 - 004 - Open Circuit
    16660 - Fuel Injector #6 (N84)
                P0276 - 002 - Short to Ground
    17833 - EVAP Purge Valve (N80)
                P1425 - 002 - Short to Ground
    16645 - Fuel Injector #1 (N30)
                P0261 - 002 - Short to Ground
    16651 - Fuel Injector #3 (N32)
                P0267 - 002 - Short to Ground
    16657 - Fuel Injector #5 (N83)
                P0273 - 002 - Short to Ground
    17880 - EVAP Leak Detection Pump
                P1472 - 002 - Short to Ground
    17843 - Secondary Air Pump Relay (J299)
                P1435 - 002 - Short to Ground
    16654 - Fuel Injector #4 (N33)
                P0270 - 002 - Short to Ground
    17457 - Bank1; Exhaust Cam Adjustment Valve 1 (N318)
                P1049 - 002 - Short to Ground
    17935 - Camshaft Timing Adj. Bank1 (N205)
                P1527 - 002 - Short to Ground
    16648 - Fuel Injector #2 (N31)
                P0264 - 002 - Short to Ground
    18334 - Relay for Aux Coolant Pump (J496)
                P1926 - 002 - Short to Ground
    16441 - Oxygen (Lambda) Sensor B2 S2: Heating Circuit
                P0057 - 002 - Short to Ground
    16421 - Oxygen (Lambda) Sensor B1 S2: Heating Circuit
                P0037 - 002 - Short to Ground
    17876 - EVAP Canister Solenoid Valve 2 (N115)
                P1468 - 002 - Short to Ground
    17836 - Circuit for Brake Vacuum Pump
                P1428 - 002 - Short to Ground
    17522 - Oxygen (Lambda) Sensor; B1 S2
                P1114 - 002 - Internal Resistance too High
    17548 - Oxygen (Lambda) Sensor; B2 S2
                P1140 - 002 - Internal Resistance too High
    Readiness: 0110 1101
       Part No: 09D 927 750 BD
       Component: AL 600 6Q           0582
       Coding: 0004153
       Shop #: WSC 19419 444 53362
       VCID: 71BFD2BC0DB45C6F369-5160
    Address 03: ABS Brakes        Labels: 7L0-907-379-MK25.lbl
       Part No: 7L0 907 379 D
       Component: ESP ALLRAD MK25     0108
       Coding: 0014337
       Shop #: WSC 31414 000 00000
       VCID: 3A2D35901042DF37C73-5160
    65534 - Unknown Error Code
                015 - Cannot Be Tested at this Time - MIL ON
       Part No SW: 3D0 909 135 K    HW: 5WK 470 25
       Component:    Kessy            6400
       Coding: 0000232
       VCID: 2D070ECCD10C788F521-5160
    6 Faults Found:
    00166 - Access/Start Authorization Switch (E415)
    00172 - Key 2 not learned
    00087 - Terminal 30 for Starting Relevant Consumers
    Address 08: Auto HVAC        Labels: 7L6-907-040.clb
       Part No: 7L6 907 040 H
       Component: CLIMAtronic R/L   X 3716
       Coding: 0000030
       VCID: 353726AC395C304F2A1-5160
    00898 - Control Circuit A/C compressor
    Address 09: Cent. Elect.        Labels:. 7Lx-937-049-V1.clb
       Part No: 7L6 937 049 K
       Component:                     2703
       Coding: 0101599
       Shop #: WSC 19400 444 85723
       VCID: 44D14B68628699C7ADF-5160
    02088 - Lights for Auxiliary High Beams
       Part No: 3D0 909 601 C
       Component: 05 Airbag 8.4E++H01 0352
       Revision: BB36963     Serial number: 00009760
       Coding: 0012341
       VCID: 2313E8F487C8BEFFF45-5160
       Subsystem 1 - Part No: 7L0 959 339 B
       Component: BF-Gewichtsens. 005 0006
                        Date: 2063.15.31
                        Time: 31:60:00
                        Date: 2063.15.31
                        Time: 31:60:00
    00532 - Supply Voltage B+
                        Fault Frequency: 15
                        Reset counter: 39
                        Date: 2063.15.31
                        Time: 31:60:00
       Part No: 7L6 953 549 D
       Component: Lenksäulenmodul     3301
       Coding: 0000031
       VCID: 40D94778769E85E7897-5160
    Address 17: Instruments        Labels: 7L6-920-xxx-7LA.lbl
       Part No: 7L6 920 970 RX
       Component: KOMBIINSTRUMENT RB0 2035
       Coding: 0007231
       VCID: 1E65D900ACAA9317DBB-5160
    00438 - Fuel Supply Sensor 2 (G169)
       Part No: 6N0 909 901
       Coding: 0000006
       VCID: 70B9D7B806BE5567397-5160
    Address 1C: Position Sensing        Labels: 7L6-919-879.lbl
       Part No: 7L6 919 879
       Component: JCI PathPoint       1700
       VCID: 04518B68220659C7EDF-5160
       Part No: 0AD 927 755 BE
       Component: TRANSFERCASE        0122
       VCID: 7F5B04844BE03A1FB0D-5160
    Address 29: Left Light        Labels: 3D0-909-157.lbl
       Part No: 3D0 909 157
       Component: EVG GDL+AutoLWR(l)  0001
       VCID: 6695B1E0347A8BD753B-5184
       Part No: 7L0 959 760
       Component: Sitzverstellung     0702
       VCID: 77ABECA463D0025FF8D-5160
    02327 - Position Sensor for Front Seat Height Adjustment (G438)
                006 - Short to Plus
    02341 - Position Sensor for Seat Fore/Aft Adjustment (G441)
    02328 - Position Sensor for Rear Seat Height Adjustment (G439)
    01916 - Lumbar Support Fore / Aft Adjustment Sensor (G375)
       Part No: 3D0 909 158
       VCID: 678BBCE4337092DF68D-5160
       Part No: 7L0 959 933 E
       Component: 2K HSG              0201
       Coding: 0000085
       VCID: 3E2539800C6AF317FBB-4B3C
       Subsystem 1 - Part No: 7L0 959 701 A
       Component: Tuersteuergeraet FS 0201
       Subsystem 2 - Part No: 7L0 959 702 A
       Component: Tuersteuergeraet BF 0201
       Subsystem 3 - Part No: 7L0 959 703
       Subsystem 4 - Part No: 7L0 959 704
    12 Faults Found:
    00927 - Terminal 30 (Right)
    01516 - Terminal 30; Left
    00926 - Terminal 30
    00132 - Outside Door Handle Illumination/mirror Light Passenger Side
    Address 56: Radio        Labels: 7L6-035-180-56.lbl
       Part No: 7L6 035 180 B
       Component: Radio DE2           0016
       Coding: 0000401
       VCID: 2C0103C8EA16718745F-5160
    00878 - Connection to Speaker Front Left
    00879 - Connection to Speaker Front Right
    00881 - Connection to Speaker Rear Right
    Address 65: Tire Pressure        Labels:. 7L6-907-273.lbl
       Part No: 7L6 907 273
       Component: Reifendruckueberw.  0052
       Coding: 0211390
       VCID: 75B7E6AC79DC704FEA1-5160
    01312 - Powertrain Data Bus
    Address 68: Wiper Electr.        Labels: 7L0-955-119-V1.clb
       Part No: 7L0 955 119 F
       Component: Front Wiper         2416
       Coding: 0000004
       Shop #: WSC 31414 000 376832
       VCID: 372B2CA42350C25F38D-5160
    Address 6E: Ctrl Head Roof        Labels: None
       Part No: 7L6 919 044 F
       Component: DACHDISPLAY         0530
       Revision: 00600530    Serial number: 2009289.02
    End----(Elapsed Time: 08:34, VBatt start/end: 11.9V/11.7V. VIgn 11.7V)-----
    Wet Kessy?
    Kessy needs to be fixed for terminal 15/30 and Fuel Pump Relay or you are not going anywhere?
    I don't think it would crank if this were the Kessy's fault.
    All those Short to Ground codes make me thing there's no 12V on the hot side of those actuators. Blown fuse or relay not passing power to them.
    Usually not intermittent though when fuse is blown but corrosion in fuse box or Kessy from water is likely maybe bad E415 possible too.
    Nov 2019
    Hi Jack & Ewe,
    Thank you for your replies. One bit of good info that I can supply is that when I purchased the car the under hood drivers side electrical box (with all of the relays) was escew & had standing water. I dried it out with a shop vac & fan in my garage.
    Could corrosion in the electrical box be causing all of these faults? Should I start by removing/replacing the electrical box or all of the relays?
    Question: I am not sure if the car has a kessy system. Do all Touareg's have Kessy if not then how do I check?
    Jack, you said..."Kessy needs to be fixed for terminal 15/30 and Fuel Pump Relay or you are not going anywhere?"
    Do you mean to check that the Kessy works (if I have one) in order for terminal 15/30 & the fuel pump relay to work? The reason that I ask is because I have tested the 404 Fuel pump relay & it works fine, but the fuel pumps do not prime when I open the drivers door as they should. If I provide direct power to the pumps themselves they both work fine.
    Thank you as always for the help. I am trying everything that I can think of.
    Hi Jack & Ewe,
    JPPSG and RTFB
    WHAT'S THIS SAY BELOW IN SCAN?
    Component: Kessy
    6400
    Coding: 0000232
    Component: ELV XXXX
    6 Faults Found:
  7. #7
    Nov 2019
    Hi Jack,
    I get it...
    So here is my plan. I will start by checking the Kessy and visually inspect the electrical box on the drivers side plenum (after I have removed all of the fuses/relays). The I will use my multi-meter to make sure that all of the relays are working.
    Does this sound like the correct line of attach?
    Jack, How do you check for a bad E415? Does this mean that the cars security immobilizer is not recognizing the key?
    I plan on trying all of these solutions tonight/every night this week after work.
    Dave
  8. #8
    Hi Jack,
    I get it...
    Dave
    The fish tank can't be cleaned or inspected properly until it's empty, huh?
    Did you clear codes in 0x05 and see if they come back & after all needed inputs are verified present by load light isolated and that VCDS blocks show key or transponder status by antenna or D2 are present with proper E415 function using RTFB and WD by basic electrical troubleshooting skills?
  9. #9
    Nov 2019
    2004 TOUAREG V6 3.2L YES CRANKS BUT NO START
    Down below is the latest auto scan from my Touareg.
    Still has some of the "short to ground" or "open circuit" faults.
    Just yesterday I replaced the 433 relay under the drivers seat (the thinking being that because of all of the electrical faults/ground shorts) that possibly this relay going bad could have been effecting the other things further down stream (not sure if this logic is correct).
    The Treg still will crank but not start. When I first put the key in the ignition the dash lights up as normal, but it will not even crank if I turn it right away. If I wait for approx 15 sec the EPC light will come on and then I can crank the car...but no start ever.
    I was thinking about replacing the J519 Power Control Module (its on the side of the electrical cluster behind the steering wheel, by the drivers knees) in the hopes that this is what is at fault for all my electrical worries.
    Or should I be looking elswhere?
    Thoughts???
    Here's the scan...Thanks again. Dave
    Friday,10,April,2020,17:44:01:54382
       Coding: 0000133
    19 Faults Found:
       Coding: 0004153
       Coding: 0014337
       Coding: 0000232
       Coding: 0000030
       Component:                     2703
       Coding: 0101599
       Coding: 0012341
       Coding: 0000031
       Coding: 0007231
       Coding: 0000006
       Coding: 0000085
    12 Faults Found:
    00926 - Terminal 30
       Coding: 0000401
       Coding: 0211390
       Coding: 0000004
    End----------(Elapsed Time: 09:19, VBatt start/end: 12.5V/12.5V)-----------
  10. #10
    You still have all those "Short to Ground" codes. Those things are low-side switched. That means they should have 12V on one side and the ECU pulls the other side to GND to turn those things on. Dig into your wiring diagrams and figure out why there's no +12V on the other side.
