Results 1 to 7 of 7
Thread: 2013 Golf VI GTI OEM LED with rear foglight
    Mar 2014
    Hello
    I have a 2013 Golf VI GTI with DRL, OEM Halogen headlights and OEM taillights. I also have the (front fog and rear fog) OEM switch installed.
    I will install the OEM LED Taillights with rear fog light.
    Now I need some help with the coding and wiring.
    I did the retrofit with the DIY from the VWVortex on my 2012 Golf R
    http://forums.vwvortex.com/showthrea...ar-Fog-Install
    Is the coding and wiring the same like with a Golf VI R?
    Can someone confirm if this will work for the Golf VI GTI or if I am wrong?
    Any help would be appreciated.
    Cheers
    Torsten
    Auto scan :
    Saturday,29,March,2014,14:26:11:00778
    VCDS Version: 12.12.2.0 (x64)
    Data version: 20140212
    VIN: WVWFV7AJ9DW121883   License Plate: DETLEF GTI 2
    Chassis Type: AJ (7N0)
    Scan: 01 02 03 08 09 15 16 17 19 1C 25 2E 42 44 46 52 56 77
    Address 01: Engine (CCT)       Labels: 06J-906-026-CCT.clb
       Part No SW: 1K0 907 115 AS    HW: 1K0 907 115 AA
       Revision: AAH18---    Serial number:
       Coding: 0403010A1C070160
       VCID: 77FD319A06CE4EA6AAD-8022
       Part No SW: 02E 300 058 P    HW: 02E 927 770 AL
       Component: GSG DSG AG6     512 3513
       Revision: 05651213    Serial number: 00001212041632
       VCID: 275D21DA96EE1E26FAD-8072
       Revision: 00H31001
       Coding: 114B600C492400FB881306EC921C0041B70800
       VCID: 7DF123B2E4F264F6F01-8028
    Address 08: Auto HVAC (J301)       Labels: 7N0-907-426.clb
       Part No SW: 7N0 907 426 BH    HW: 7N0 907 426 BH
       Component: AC Manuell    H20 0505
       Revision: 00001018
       Coding: 0010002002
       ROD: EV_ACManueBHBVW36X_SE36.rod
       VCID: 7BF52DAAF2E66AC6CE5-802E
       Part No SW: 1K0 937 086 T    HW: 1K0 937 086 T
       Component: BCM PQ35  M   111 0709
       Revision: AC111709
       Coding: 6F180A1A90272A04008800C17000054448010386534D8D60648020200040
       VCID: 41899F42D88AC016D49-8014
       Component: Wischer 12121  26  0512
       Coding: 009795
       Part No SW: 5C0 959 655 M    HW: 5C0 959 655 M
       Component: AirbagVW10G   014 0726
       Serial number: 003L4R0147L2
       Coding: 00004737
       ROD: EV_AirbaVW10SMEVW360.rod
       VCID: 3C77EEB6B768ADFE87F-8069
       Serial number: ---0000R--00004VYU00
       Serial number: 3572MSME61725375ZZZT
       Serial number: 3582MSME0A0E5475ZZZ$
       Serial number: 3512QSME5A4A2308ZZZX
       Serial number: 3522QSME480B2167ZZZV
       Serial number: 35527SME13096B2EZZZM
       Crash sensor for front airbag; passenger side:
       Serial number: 35627SME5F2B6B2EZZZ0
       Part No SW: 5K0 953 507 AH    HW: 5K0 953 549 B
       Component: Lenks.Modul   008 0090
       Revision: --------    Serial number:  90422LLD000ZM
       Coding: 189A140000
       ROD: EV_SMLSNGKUDS_SE36.rod
       VCID: 76E33C9EC9C437AEB1B-8023
       Subsystem 1 - Part No SW: 5K0 959 542 B    HW: 5K0 959 542 B  Labels: 3C8-959-537.CLB
       Component: E221__MFL-TAS  H30 0032
       Serial number: 0101244
       Coding: 830000
       Part No SW: 5K6 920 973 C    HW: 5K6 920 973 C
       Coding: 270F01
       ROD: EV_Kombi_UDS_VDD_RM09_VW21.rod
       VCID: 377DF19A8E4E8EA66AD-8062
       Part No SW: 7N0 907 530 AF    HW: 7N0 907 530 AF
       Component: J533  Gateway H52 1634
       Revision:   H52       Serial number: 131212F2000900
       Coding: 350000
       VCID: 74E70696D7B825BE8FF-8021
       Part No SW: 5N0 919 879     HW: 5N0 919 879
       Component: Kompass         002 0002
       Revision: 00002000    Serial number: 1225223RLWLF07
       VCID: FEF3A4BEA9F4FFEE69B-80AB
       ROD: EV_Immo_UDS_VDD_RM09_SE36.rod
       VCID: EADB98EE0D7C634EA53-80BF
       Component: SG EXT.PLAYER H19 0550
       Revision: A1001003    Serial number: 7663972789
       Coding: 010100
       VCID: 2A5BD8EE45FC234EE53-807F
       Component: Tuer-SG         009 2117
       Coding: 0001076
       VCID: 3169CF82A82A5096249-8064
       Part No: 1K0 909 144 P
       Component: EPS_ZFLS Kl. 74     3305
       Revision: 00H22000
       VCID: 377DF19A464E8EA66AD-8062
       Coding: 0001076
       VCID: 326BC08EAD2C6B8E5D3-8067
    Address 56: Radio (J503)       Labels: 5M0-035-1xx-56.clb
       Part No SW: 1K0 035 180 AF    HW: 1K0 035 180 AF
       Component: Radio Prem-8  H04 0008
       Revision: -----08S    Serial number: VWZ4Z7M1141172
       Coding: 01000400040005
       VCID: 64C776D66758B53E1FF-8031
                        Reset counter: 15
                        Mileage: 5573 km
                        Date: 2013.14.28
                        Time: 14:23:07
    Address 77: Telephone (J412)       Labels: 7P6-035-730.clb
       Part No SW: 7P6 035 730 K    HW: 7P6 035 730 K
       Revision: 1B001001    Serial number: 00007663989358
       Coding: 0A10040000010100
       ASAM Dataset: EV_UHVNA 002720
       ROD: EV_UHVNA.rod
       VCID: 3A7BE8AEBD5C93CE953-806F
    Last edited by Uwe; 03-29-2014 at 06:17 PM. Reason: Wrapped CODE tags around Auto-Scan
    United States
    Hello Torsten,
    With the exception of nicer seats and AWD with a manual transmission... the US market Golf R is a Mk6 Golf so the DIY you linked pretty much applies. RoW Golf R models actually come with Golf R tail lights unlike the poor guys over here that have to retrofit R lights.
    After you install the headlight switch (and any necessary wires to/from the BCM) and install the tails with the BCM side wire swap Hex 04 should work in Byte 18 with the rear fog lamp. If you encounter any difficulty post another scan with the lights installed and coded.
    Regards,
    Dana
    Mar 2014
    Smile
    Hello Torsten,
    Regards,
    Dana
    Hello Dana
    Thank you for your quick answer. I will install the LED Tails tomorrow on the GTI.
    I will let you know if it worked.
    Regards
    Torsten
    Mar 2014
    Dana
    Her my feedback..
    So I installed the tail lights with the BCM side wire and swapped HEX 04/BITE 18 today.Everything is working fine. The Rear fog light is working, also the front fog lights.
    The only problem that I have now is that the DRL's in the headlights are not working anymore. There are not even displayed in the cluster anymore.
    Do you have any Idea how I can solve the problem, and can run the DRL's with the rear fog lights together?
    Regards
    Torsten
    Friday,04,April,2014,10:18:56:00778
    VIN: WVWFV7AJ9DW121883   License Plate: GTI VI 2013
    Readiness: 1110 0101
       Revision: 00H31001
       Revision: 00001018
       Coding: 0010002002
       Revision: AC111709
       Coding: 009795
       Coding: 00004737
       Coding: 189A140000
       Coding: 830000
       Coding: 270F01
       Coding: 350000
       Coding: 010100
       Coding: 0001076
       Revision: 00H22000
       Coding: 0001076
                        Reset counter: 28
                        Mileage: 5833 km
                        Date: 2014.14.02
                        Time: 00:09:05
       ROD: EV_UHVNA.rod
    Last edited by Uwe; 04-04-2014 at 05:13 PM. Reason: Wrapped CODE tags around Auto-Scan
    United States
    Quote Originally Posted by cochino2000 View Post
       Revision: AC111709
    Hi Torsten. Sorry I missed that. The Long Coding is exactly the same in both scans. Are you sure you posted the newest scan (after modifications) from Friday, April 4th? Since Hex 04 didn't work you might want to try Hex 22 but I would like to see if the latest scan has any DRL functionality faults first.
    -Dana
    Mar 2014
    -Dana
    Hello Dana
    that's the latest scan from today.
    Thursday,01,May,2014,20:23:54:00778
    VIN: WVWFV7AJ9DW121883   License Plate: GTI VI DETLEF
       Revision: 00H31001
       Revision: 00001018
       Coding: 0010002002
       Revision: AC111709
       Coding: 6F180A1A90252A04008800C17000054448010486534D8D60648020200040
       Coding: 009795
       Coding: 00004737
       Coding: 189A140000
       Coding: 830000
       Coding: 270F01
       Coding: 350000
       Coding: 010100
       Coding: 0001076
       Revision: 00H22000
       Coding: 0001076
                        Reset counter: 29
                        Mileage: 5836 km
                        Date: 2014.14.02
                        Time: 01:02:03
       ROD: EV_UHVNA.rod
    Tanks for helping
    Regards
    Torsten
    Last edited by Uwe; 05-01-2014 at 10:41 PM. Reason: Wrapped CODE tags around Auto-Scan
  7. #7
    United States
    Revision: AC111709
    Revision: AC111709
    Ok, Byte 5 (Locking Confirmation via Horn active) is tweaked but I don't' think that would cause issues. So.. I do not see anything alarming but I'm not sure if the DRL issue is directly related to Byte 18.
    What happens if you enable 'Daytime Running Light (DRL) Adaptation active (MFA+)' in Byte 15? Please see if that enables a tick box on the MFA, and if it does, see if ticking it on/off either enables DRLs or creates fault code to confirm that Byte 18 may require some fine tuning.
    -Dana
  8. Likes Uwe liked this post
