Chassis Type: NS (3Q0)
Scan: 01 02 03 05 06 08 09 10 13 14 15 16 17 19 22 2B 36 3C 42 44
          47 52 55 5F 69 6C 6D 75 A5
VIN: TMBLK7NS4H8009467
Address 01: Engine (J623-DFHA)       Labels: 04L-907-309-V1.clb
   Part No SW: 04L 906 026 EJ    HW: 04L 907 309 P
   Component: R4 2.0l TDI   H24 3661
   Revision: B4H24---
   Coding: 0125003204761D083000
   Shop #: WSC 33361 790 00133
   ASAM Dataset: EV_ECM20TDI01104L906026EJ 004003
   ROD: EV_ECM20TDI01104L906026EC.rod
   VCID: 76E644F4C97359F1C3-8022
Address 02: Auto Trans (J743)       Labels: None
   Part No SW: 0DL 300 011 J    HW: 0GC 927 711 G
   Component: GSG DQ500     H06 2004
   Revision: 00H06V07
   ROD: EV_TCMDQ500021_VW41.rod
   VCID: 2F68B19076A9283940-807A
   Revision: 00000000    Serial number: 60357000000884
   Coding: 60076A9F54200B75477B070662CA4906562AD0E2E046927D386150F8E2AA4200002F641A1B13111435351919323200
   VCID: 77F849F0CE7920F9D8-8022
   Part No SW: 3Q0 959 435 E    HW: 3Q0 959 435 E
   Component: VWKESSYMQB    036 0811
   Revision: 00036000    Serial number: 0430375353
   Coding: 032C0C0F03
   Shop #: WSC 33361 790 00063
   VCID: 3C7296DCB7DFC3A1F5-8068
   Subsystem 1 - Part No SW: 3G0 962 243 B    HW: 3G0 962 243 B
   Component: GEB.F.Heckoef  H17 0904
   Serial number: 58020492
14222592 - Databus
                    Reset counter: 43
12786208 - Databus
                    Reset counter: 62
                    Mileage: 261 km
                    Date: 2017.03.03
                    Time: 13:06:20
   Component: Sitzmemory    H08 0021
   Serial number: Y0006QAJ21434
   Coding: 0010000000000500018281818181000000008181000000D400
   ASAM Dataset: EV_SeatMemorPasseSide 002021
   ROD: EV_SeatMemorPasseSide.rod
   Part No SW: 565 907 044 R    HW: 565 907 044 R
   Revision: 00001K00
   Coding: 1601010400311001110510080010110A
   Shop #: WSC 73430 790 00063
   ROD: EV_ACClimaBHBVW37X_004_VW48.rod
   VCID: 2A5EA0844D4B4D1197-807E
   Subsystem 4 - Part No SW: 5Q0 907 659 C    HW: 5Q0 907 659 C
   Component: G238 _AQS  H30 0119
   Serial number: 45326176
1048834 - Functional Limitation due to Energy Management
          B10CD 00 [008] -  -
                    Reset counter: 64
                    Mileage: 18 km
                    Date: 2017.03.02
                    Time: 07:49:13
                    Voltage terminal 30: 14.6 V
                    Auxiliary heater: controlled-Status: not active
                    Auxiliary heater: controlled-Current: actual value: 0 A
                    Auxiliary heater: controlled-Power: actual value: 1260 W
                    Auxiliary heater: controlled-Power: target value: 1300 W
Address 09: Cent. Elect. (J519)       Labels: 5Q0-937-08X-V2.clb
   Part No SW: 5Q0 937 086 BH    HW: 5Q0 937 086 BH
   Component: BCM PQ37BOSCH 032 0223
   Revision: --------    Serial number: 865822011700OI
   ASAM Dataset: EV_BodyContrModul1UDSBosc 017002
   ROD: EV_BCMBOSCH_017.rod
   VCID: 010C272890BD6E49E6-8054
   Subsystem 1 - Part No SW: 566 955 119     HW: 566 955 119
   Component: WWS326 161128  051 0905
   Serial number: 887353F0401633300373
   Coding: 164DDD
   Component: RLHS  042 0105
   Serial number: S4Y17M01D30H16M47S47
   Coding: 00885D
   Serial number: 000000000ZY170022WU9
   Serial number: 00000000000068331646
Address 10: Park/Steer Assist (J791)       Labels: None
   Part No SW: 3Q0 919 298 A    HW: 3Q0 919 298
   Component: PLA 3.0 12K   H10 0021
   Serial number: 002601177478082
   Coding: 0231267A51
   ASAM Dataset: EV_EPHBO2CVW3260000 010016
   ROD: EV_EPHVA2CAU3700000_008.rod
   VCID: 3B7095C0B2D1C499FC-806E
Address 13: Auto Dist. Reg (J428)       Labels: 2Q0-907-572.clb
   Part No SW: 2Q0 907 572 J    HW: 2Q0 907 572 B
   Component: ACCCONTIMQB   H01 0156
   Coding: 320147CB50FF8728749C8065304085
   Shop #: WSC 33361 790 00137
   ASAM Dataset: EV_ACCMRRCONTIVW376 001011
   ROD: EV_ACCMRRCONTIVW376_VW37.rod
   Serial number: 14011741350365
   ROD: EV_DRCONTITEMIC.rod
   VCID: 387A8ACC83E7EF8111-806C
   Part No SW: 3Q0 959 655 AK    HW: 3Q0 959 655 AK
   Component: Airbag VW21   004 0306
   Revision: --------    Serial number: 003R6P1SALQI
   Coding: 98CCC0C0000000005C5400CF004800000065
   ASAM Dataset: EV_AirbaVW21TS6VW48X 001010
   ROD: EV_AirbaVW21TS6VW48X.rod
   VCID: 07183930BE995079A8-8052
   Subsystem 1 - Part No SW: -----------    HW: 454 001 801 17
   Serial number: 35700000000700AC822D
   Subsystem 2 - Part No SW: -----------    HW: 454 002 001 17
   Serial number: 358000000001B801F12C
   Subsystem 3 - Part No SW: -----------    HW: 454 801 701 17
   Serial number: 35100E220D30E000000E
   Subsystem 4 - Part No SW: -----------    HW: 454 801 401 17
   Serial number: 352000B50E80D000000I
   Subsystem 5 - Part No SW: -----------    HW: 454 801 412 16
   Serial number: 35500364E0E0E000000P
   Part No SW: 3Q0 953 521 ED    HW: 5Q0 953 569 A
   Revision: FF036036    Serial number: 20170130400179
   Coding: 6414
   ROD: EV_SMLSVALEOMQB.rod
Address 17: Instruments (J285)       Labels: None
   Part No SW: 565 920 751     HW: 565 920 751
   Component: KOMBI         310 8311
   Coding: 07A4081CFF84000801886B0B5001000800000000
   Shop #: WSC 73430 031 00063
   VCID: 58BA2A4C23A70F81F1-800C
   Component: GW MQB High   515 5286
   Serial number: 29011710801586
   Coding: 030100344F087300EB03225A9E0F00010001070000000000000000000000
   Shop #: WSC 33361 790 00114
   ROD: EV_GatewConti_013.rod
   Subsystem 2 - Part No SW: 3V0 919 719 B    HW: 3V0 919 719 B
   Component: E221__MFL-PR6  H02 0160
   Serial number: 000000000B3058190117
   Subsystem 3 - Part No SW: 5QA 915 181 C    HW: 5QA 915 181 C
   Serial number: 75189706001701251878
Address 22: AWD (J492)       Labels: 0CQ-907-554.clb
   Serial number: HA1-00019.12.16
   Coding: 0101
   VCID: 4A9EC004ED0B6D1177-801E
   Serial number: 17000023720015
   Coding: 0800000000000000
   ROD: EV_ELVMarquMQBB.rod
   VCID: 71EC77E8A01D7EC916-8024
Address 36: Seat Mem. Drvr (J810)       Labels: None
   Serial number: Y0006QAJ21563
   ROD: EV_SeatMemorDriveSide_VW37.rod
Address 3C: Lane Change (J1086)       Labels: None
   Component: HRE_Master    H12 0071
   Serial number: 0429052119
   Coding: 02012103
   ROD: EV_HREntryHella.rod
   Lane Change Assistant 2:
   Component: TSG FS        010 0032
   Serial number: 0000239621177
   Coding: 00150820DE00040000001100
   VCID: 4798F930FE19907968-8012
   Serial number: 00000000000013120511
   Coding: 010200
Address 44: Steering Assist (J500)       Labels: 5Q0-909-143.clb
   Revision: 00000000    Serial number: 0001358624
   Coding: 01010011004001
   ROD: EV_SteerAssisVWBSMQBA_007.rod
   VCID: 408AE22CDB37A741A9-8014
   Part No SW: 81A 035 223     HW: 81A 035 223
   Component: MIB2_amp_P_SK H10 0410
   Revision: 00000001    Serial number: SKZ8Z1GJE013XFD
   Coding: 0323160000AA002AAA0000000000
   ASAM Dataset: EV_AMPMst16C4Gen2ALPI 001003
   ROD: EV_AMPMst16C4Gen2ALPI.rod
   VCID: 59BC2F4858AD1689CE-800C
   Component: TSG BFS       010 0032
   Serial number: 0000239280210
   Coding: 00150020DE00040000001100
   VCID: 4686F434F913897193-8012
   Serial number: 00000000000013152886
   Coding: 190200
   Part No SW: 7P6 907 357 E    HW: 7P6 907 357 A
   Component: AFS-ECU       H07 0070
   Coding: 03E202003D210901
   ASAM Dataset: EV_HeadlRegulAFSMQBMAX 001001
   ROD: N/A
   VCID: 418CE728D03DAE49A6-8014
No ASAM data for: "EV_HeadlRegulAFSMQBMAX" (VW52)
   Part No SW: 5Q0 035 864 B    HW: 5Q0 035 864 B
   Component: MU-S-N-ER     H30 0361
   Serial number: SKZAZ2T5041544
   Coding: 03231601000000005111000200000A232F0300E4012081008E
   ROD: EV_MUStd4CTSAT_VW26.rod
   VCID: 326EB8E4659B05D12F-8066
   Subsystem 1 - Part No SW: 565 919 605 B    HW: 565 919 605 B
   Component: ABT_Std-2_Nav  H33 8074
   Serial number: SKZ6ZDT0350580
7219 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
                    Reset counter: 60
                    Mileage: 768 km
                    Date: 2017.03.13
                    Time: 10:01:28
                    BAP-BAP_Function_ID: 10
Address 69: Trailer (J345)       Labels: 5Q0-907-383.clb
   Part No SW: 5Q0 907 383 G    HW: 5Q0 907 383 D
   Component: Anhaenger     H21 0204
   Revision: 8A001003    Serial number: 0428687644
   Coding: 0100000202000000
Address 6C: Back-up Cam. (J928)       Labels: None
   Part No SW: 5Q0 907 556 B    HW: 5Q0 907 556
   Component: Areaview 2    H13 0607
   Serial number: C854707JG009770
   Coding: 04231601A70FA0000060400C
   ASAM Dataset: EV_CamSysRVAV2ARCE2MQBAB 006017
Address 6D: Trunk Elect. (J605)       Labels: 5Q0-959-107.clb
   Part No SW: 5Q0 959 107 L    HW: 5Q0 959 107 J
   Component: HDSG-Modul    H13 0261
   Revision: --------    Serial number: 31154965000000
   Coding: 1B88
Address 75: Telematics (J949)       Labels: 5QE-035-285.clb
   Part No SW: 5NA 035 284 A    HW: 5NA 035 284 A
   Component: OCULowMQBLGE  H13 0613
   Coding: 03231601EA421A0D3B1C9E020045400382E608
   ASAM Dataset: EV_OCULowMQBLGE 003042
   ROD: EV_OCULowMQB.rod
Address A5: Frt Sens. Drv. Assist (R242)       Labels: 3Q0-980-65X-A5.clb
   Part No SW: 3Q0 980 654 G    HW: 3Q0 980 654
   Component: MQB_B_MFK     H06 0231
   Serial number: 30011711K11231
   Coding: 020307060000040100221355C050A90098000E200020
   ROD: EV_MFKBoschMQBB.rod
