Results 1 to 4 of 4
Thread: MK6 jetta tdi retrofitting door modules help
    Feb 2020
    I'm trying to retrofit folding mirrors on a mk6 jetta tdi and have upgraded the BCM to 7H0937090EZ1G (PQ25 MAX3) and utilized a door wiring harnesses from a 2016 Jetta GLI. I obtained door modules 561959701A and 702A and having issues with the door modules actually communicating with the BCM. (errors are intermittent/loss of communications with door module. When I do a Gateway Installation check, 42 and 52 are not there. However, I can go into chassis, and actually connect to 42 and 52 just fine. I configured them for the car, everything works, EXCEPT: I get intermittent communication errors between BCM and door control modules. Power door lock buttons do not lock and unlock the car and the driver door trunk door does not open the trunk. If I select lock/unlock on the center rear control, It locks/unlocks doors just fine, including the front ones. I've read somewhere that whether I have canbus or UDS modules is important. I'm wondering if this is why its not working? If I need to do a dump, let me know. I'm guess its a compatability issue? If this isn't going to work, then are there other options? If the BCM is the isue, could i go to a XXX-937-088F which is a standalone BCM w/o CANBUS, and used a newer can bus module? Any help thrown my way would be greatly appreciated.
    Feb 2020
    Ok, here is the autoscan with a xxx 937-087J CECM:
    Wednesday,25,March,2020,16:39:13:43477
    VCDS Version: 19.6.2.2 (x64)
    Workshop Code: 001 00001 000001
    VIN: 3VW3L7AJ3EM384376   License Plate: BCM 087 SCAN
    Chassis Type: AJ-VW36 (6N0)
    Scan: 01 03 08 09 15 17 19 25 2E 37 44 56 77
    Address 01: Engine (CJA)       Labels: 03L-906-022-CBE.clb
       Part No SW: 03L 997 030 N    HW: 03L 907 309 AA
       Component: R4 2.0l TDI G000SG  9983
       Revision: 12H16---    Serial number:
       Coding: 0050072
       Shop #: WSC 74291 008 00000
       VCID: 3957DC5570F04787A2-806C
    Readiness: 0 0 0 1 1
       Revision: 00H31001
       Coding: A14B400C492A00FE850E02EB921F0042A71000
       Shop #: WSC 00001 001 00001
       VCID: 7DDF0845E458BBA7CE-8028
       Part No SW: 5C0 820 047 BA    HW: 5C0 820 047 BA
       Component: J301  Klimaanlage   0204
       Revision: 2001012S    Serial number: 00000001832383
       VCID: 60E15131B3EA764FC5-8034
       Part No SW: 5C0 937 087 J    HW: 5C0 937 087 A
       Component: BCM25 JLB H3  H34 0411
       Revision: B2034001    Serial number: 08013124140417
       Coding: 7B994B3808AB0B0000382600240804D400C2502E60004000300010002000
       VCID: 3449ED619792BAEF71-8060
       Subsystem 1 - Part No SW: 6R0 959 802 AS    HW: 6R0 959 802 AS  Labels: 6R0-959-802.CLB
       Serial number: 14202584130919072258
       Coding: 820000
       Subsystem 2 - Part No SW: 5K0 959 542 C    HW: 5K0 959 542 C
       Component: E221__MFL-TAS  H31 0037
       Serial number: 0005616 FLE 20130910
       Coding: 820000
       Subsystem 3 - Part No SW: 6R0 959 811 M    HW: 6R0 959 811 M
       Serial number: 14202587130910161739
       Coding: 800000
       Subsystem 4 - Part No SW: 6R0 959 812 M    HW: 6R0 959 812 M
       Serial number: 14102586130918162601
       Coding: 800000
                        Reset counter: 71
                        Mileage: 56353 km
                        Date: 2061.14.24
                        Time: 00:46:55
       Part No SW: 5C0 959 655 AD    HW: 5C0 959 655 AD
       Component: AirbagVW10    102 0912
       Serial number: 003MVD01EHL-
       Coding: 00004138
       ROD: EV_AirbaVW10SMEVW360.rod
       VCID: 74C92D61DF12FAEFB1-8020
       Serial number: 6940000Y130000YG350T
       Coding: 303036
       Serial number: 3572MSME6813067DZZZ.
       Serial number: 3582MSME3C20327CZZZZ
       Serial number: 3516KSME48524227ZZZN
       Serial number: 3526KSME03144127ZZZC
       Serial number: 3556LSME65025328ZZZP
       Serial number: 3566LSME31355328ZZZP
    Address 17: Instruments
       Part No SW: 6N0 909 901     HW: 5C0 937 087 A
       Component: GW-K-CAN TP20 H34 0411
       Revision: B2034001
       Coding: 102200
       VCID: 70C12171A30AC6CF55-8024
       Component: IMMO          H04 0809
       VCID: 6AF533198DD63C1F1B-803E
    Address 2E: Media Player 3
    Address 37: Navigation
       Part No: 1K0 909 144 R
       Component: EPS_ZFLS Kl. 70     3501
       Revision: 00H22000
    Address 56: Radio
       Component: TELEFON       H05 0315
       Revision: 1B001001    Serial number: 00007665111546
       Coding: 0A10030081010110
       Shop #: WSC 01383 790 50316
       ROD: EV_UHVUMI.rod
       VCID: 2E7DFF0971BE903F07-807A
    9455635 - Telephone Microphone
              B1048 13 [009] - Open Circuit
                        Reset counter: 71
                        Mileage: 56353 km
                        Date: 2061.14.24
                        Time: 00:10:41
    9457170 - Right audio channel for speech/telephone
              B104E 12 [009] - Short to GND
                        Reset counter: 71
                        Mileage: 56353 km
                        Date: 2061.14.24
                        Time: 00:10:39
    End-------------------------(Elapsed Time: 01:43)--------------------------
    Feb 2020
    I edited my original reply because I noticed there are differences between the XXX 937-087J CECM and XXX 937-090E CECM. But I'll start with this autoscan, and once I resolve this I will put the 090E back in the car and address it seperately.
