Results 1 to 5 of 5
Thread: 2009 GOLF TDi DSG DQ200 GEARBOX HELP !
    Jan 2015
    2009 mk6 golf 1.6tdi dsg with gearbox issue, we have had a new mechatronics fitted and the original tcm software cloned onto it but still got same fault !
    car doesn't know which gear to select, bangs between gears, sometimes when you put into drive the car stalls, slows down whilst driving as if you were pressing brakes until it changes gear and then goes again ? possible adaptations ? tried the basic settings a few times and it drives ok for about a mile then starts playing up again.
    had new clutches last year (apparently according to customer ?)
    any help appreciated ? possible coding issue ??
    Sunday,22,March,2020,11:43:45:17628
    VCDS Version: 19.6.2.2 (x64)
    VIN: WVWZZZ1KZAW215483   License Plate: GOLF TDI DSG 59
    Mileage: 183020km-113723mi   Repair Order:
    Chassis Type: 1K-VW36 (1K0)
    Scan: 01 02 03 08 09 15 16 17 19 25 2E 42 44 46 52 56 62 72
    VIN: WVWZZZ1KZAW215483   Mileage: 183020km-113723miles
    Address 01: Engine (J623-CAYC)       Labels:. 03L-906-023-CAY.clb
       Part No SW: 03L 997 558 A    HW: 03L 906 023 A
       Component: R4 1.6l TDI   H23 9980
       Revision: --H23---    Serial number: 00000000000000
       Coding: 00254014032500080000
       ASAM Dataset: EV_ECM16TDI02103L997558A 003002
       ROD: EV_ECM16TDI02103L997557M.rod
       VCID: 3B7F76B5B2217C97B0-806E
       Part No SW: 0AM 300 053 J    HW: 0AM 927 769 D
       Component: GSG DSG AG7     451 3012
       Revision: 00045014    Serial number: CU501905295635
       Coding: 0000024
       Shop #: WSC 06402 785 00200
       VCID: 336F5E955271B4D768-8066
    006011 - Clutch 1
                   P177B - 003 - Tolerance Limit Reached
                        Fault Status: 01100011
                        Reset counter: 10
                        Mileage: 183024 km
                        Date: 2014.08.13
                        Time: 11:33:30
    005925 - Comparison of Transmission Output Speeds 1 + 2
                   P1725 - 001 - Implausible Signal - Intermittent
                        Fault Status: 00100001
                        Reset counter: 10
                        Mileage: 183025 km
                        Date: 2014.08.13
                        Time: 11:34:36
    006012 - Clutch 2
                   P177C - 003 - Tolerance Limit Reached
                        Reset counter: 10
                        Mileage: 183026 km
                        Date: 2014.08.13
                        Time: 11:37:51
       Part No SW: 1K0 907 379 AJ    HW: 1K0 907 379 AJ
       Revision: 00H30001
       Coding: 133B200D092300FFC80F04EC901C0080310000
       VCID: 7AF1B3B1F59B859FEB-802E
       Part No SW: 3C8 907 336 AB    HW: 3C8 907 336 AB
       Component: Climatic      H14 0305
       Revision: 00009001
       Coding: 0000000002
       ROD: EV_ClimaBasis_VW36.rod
       VCID: 6DDB88EDBCD522277E-8038
       Part No SW: 1K0 937 084 B    HW: 1K0 937 084 B
       Component: BCM PQ35  B   103 0573
       Revision: 00103 AF
       Coding: 48180A3A9025F1C044000080340000E443510088536D8160648000200000
       VCID: 2D5B48ED7455E2273E-8078
       Subsystem 1 - Part No: 1K2 955 119 F  Labels: 1KX-955-119.CLB
       Component: Wischer 20100  21  0512
       Coding: 009795
       Component: RLS 101109 05  54  0402
       Coding: 0330AD
       Subsystem 4 - Part No: 1K8 951 605
       Component: LIN BACKUP HO  H09 9002
       Part No SW: 5K0 959 655 D    HW: 5K0 959 655 D
       Component: AirbagVW10    037 0606
       Serial number: 003FKRA0FDK.
       Coding: 00003133
       ROD: EV_AirbaVW10SMEVW360.rod
       Serial number: 3572MSME3F19554AZZZ2
       Serial number: 3582MSME2617664CZZZ
       Serial number: 3512QSME28544216ZZZN
       Serial number: 3522QSME06423D65ZZZV
    9440017 - Driver's side; side-airbag igniter
              B100B 11 [136] - Short to Ground
                        Fault Frequency: 14
                        Mileage: 182998 km
                        Date: 2020.03.19
                        Time: 01:52:04
       Part No SW: 1K0 953 549 CP    HW: 1K0 953 549 CP
       Component: J0527           053 0111
       Coding: 0001034
       VCID: 0201CB515D4BCD5FB3-8056
       Part No SW: 5K0 920 960 N    HW: 5K0 920 960 N
       Component: KOMBI         H04 0308
       Coding: 470B00
       VCID: 387569B98317578F5D-806C
       Part No SW: 1K0 907 530 AD    HW: 1K0 907 951
       Component: J533  Gateway   H16 0231
       Revision:   H16       Serial number: 4320K09B110809
       Coding: ED807F06000212000003
       VCID: 69D3FCFD403D3E0712-803C
       Component: IMMO          H04 0308
       VCID: 6AD183F18D3B351F1B-803E
       Part No SW: 5N0 035 342 B    HW: 5N0 035 342 B
       Component: SG EXT.PLAYER H13 0090
       Revision: A1001003    Serial number: 7667656908
       VCID: 2649B7C151A3D17FFF-8072
       Component: Tuer-SG         009 2114
       Coding: 0000692
       VCID: 3163549DA86D86C71A-8064
       Part No: 1K0 909 144 J
       Component: EPS_ZFLS Kl. 70     3001
       Revision: 00H17000
       Part No SW: 5K0 959 702 D    HW: 5K0 959 702 D
       Component: Tuer-SG         009 2140
       Coding: 0000692
       VCID: 346D5D89577FB3EF71-8060
       Part No SW: 1K0 035 186 AA    HW: 1K0 035 186 AA
       Component: Radio RCD310  016 0049
       Revision: 00000000    Serial number: VWZ1Z2I7194866
       Coding: 0100040004
       VCID: 65CBF0CD6C251A6736-8030
                        Reset counter: 241
                        Mileage: 183018 km
                        Date: 2014.08.11
                        Time: 13:02:27
       Part No SW: 5K0 959 703 C    HW: 5K0 959 703 C
       Coding: 0000144
       Shop #: WSC 01357 011 1012552
       Part No SW: 5K0 959 704 C    HW: 5K0 959 704 C
       Coding: 0000144
       VCID: 356B608D5C05AAE746-8060
    End-------------------------(Elapsed Time: 02:18)--------------------------
    Quote Originally Posted by TD&MCK Car Sales View Post
    Any chance those clutches were Chinese Replacement Auto Parts?
    The faults seem to point directly at the clutches...
    Dud you know that mechanical components can not be circumvented by a controller being replaced or failure to set new adaption limits when tolerance have been altered from or too baseline?
    OP are you aware that firmware levels appear way behind for the ECU & TCU at 9980/3012?
    Sure makes you wonder if any of this is under warranty extension or for useful life & even in the Queens Country for Her Royal subjects being violated?
    Verified VCDS User Danners74's Avatar
    Jun 2016
    Clutches sound as though they were not shimmed properly. Run the latest software as there have been issue with this and a full adaption drive...…. Also pattern parts as UWE said as there have been an updated clutch pack kit in the last few months. Improves shift quality but as I said only as good as the software and the installer if you knows what youre doing. Also has the needle roller been replaced in the crankshaft?
    Mandatory whenever gearbox is removed and reinstalled.
    regards Danners74
    Jun 2016
    Guyana
    Looks pretty much like the clutch unit maybe the adjusters are worn, but i would recommend to recheck your software version, what flash file are you using? use MVB 041 to view flash file, and why is your coding 0000024???? on the 0AM is usually 20, instead of 24?
    also did the dual mass flywheel was changed on this car?? looks like the input speed sensor G182 does not equal the engine speed when in comparison, the control unit need this signal to control the clutches and to calculate slip, the TCU is good?
  6. Likes NEtech, Uwe liked this post
