Results 1 to 8 of 8
Thread: Audi A7 2012 Media player 1 0E cannot be reached.
    Feb 2019
    Hi. I took from A7 autoscan and there is a lot of faults. Cars owner just bought that car and almost all the faults was about 5000-6000km back. Maybe there was bad battery or some repairs, dont know. But then there is fault media player 1 cannot be reached. I checked all fuses, both sides of dash panel and back of the car was also some fuses, fuses was good. I didnt have WD but i didnt saw any blowen fuses. Radio works fine, the MMI screen sometimes shuts down when you have driven about hour or more, but there is the screen cable repared a long way back. Must repair again or change the wires. But Media player 1.. Evrything works fine, all features can be done what is in MMI. Can someone point me to right direction?
    Here is first autoscan.
    Friday,20,March,2020,20:18:40:19148
    Workshop Code: 358 14250 022663
    VIN: WAUZZZ4G5CN047070   License Plate: 409-GBS
    Mileage: 166957km-103742mi   Repair Order: AUDIA7
    Chassis Type: 4G-AU57 (4G0)
    Scan: 01 02 03 05 08 09 0E 10 15 16 17 19 20 28 30 36 3B 3C 42 44
              46 52 53 55 5F 62 6C 6D 72 8F 90
    VIN: WAUZZZ4G5CN047070   Mileage: 166957km-103742miles
    0E-Media Player 1 -- Status: Cannot be reached 0100
    8F-Pretens. Frt Left -- Status: Malfunction 0010
    90-Pretens. Frt Right -- Status: Cannot be reached 0100
    Address 01: Engine (J623-CLAB)       Labels:. 059-907-401-V2.clb
       Part No SW: 4G0 907 311 G    HW: 4G0 907 401
       Component: 3.0TDI EDC17  H37 0003
       Revision: 53H37---
       Coding: 1A034012042401020800
       Shop #: WSC 02311 785 00200
       ASAM Dataset: EV_ECM30TDI0114G0907311G 001003
       ROD: EV_ECM30TDI0114G0907311G.rod
       VCID: 270BFB8BBF69B8FFA8F-8072
       Part No SW: 4G2 927 155 E    HW: 0AW 927 156 K
       Component: 0AW 30TDI RdW H04 0003
       Revision: --H04---    Serial number: 0000000458
       ASAM Dataset: EV_TCMVL381 A02433
       ROD: EV_TCMVL381.rod
       VCID: 2F3B13AB9799E0BF60F-807A
       Part No SW: 4G0 907 379 F    HW: 4G0 907 379 F
       Component: ESP PREMIUM   H09 0250
       Coding: 07A18703E085E1C0DB00
       Shop #: WSC 00864 461 104432
       ASAM Dataset: EV_ESPPremiAU57X 004017
       VCID: 34311CC77EBFC3671DD-8060
    0674 - Function Restricted due to Missing Message(s)
              U1111 00 [008] - -
              [ComScl_PDU_LH_EPS_02_Timeout]
                        Reset counter: 120
                        Mileage: 166509 km
                        Date: 2020.03.07
                        Time: 21:19:26
                        VzRef: 00
                        Bit Info 1: 00
                        Bit Info 2: 40
                        Bit Info 3: 02
                        Bit Info 4: 1F
                        F-Path: 00
                        F-Type: D3
                        Uz: B4
    0469 - Function Restricted due to Missing Message(s)
              U1111 00 [008] - -
              [ComScl_PDU_LH_EPS_03_Timeout]
                        Reset counter: 120
                        Mileage: 166509 km
                        Date: 2020.03.07
                        Time: 21:19:26
                        VzRef: 00
                        Bit Info 1: 00
                        Bit Info 2: 40
                        Bit Info 3: 02
                        Bit Info 4: 1F
                        F-Path: 00
                        F-Type: D4
                        Uz: B4
    0601 - Function Restriction due to Faults in Other Modules
              U1113 00 [008] - -
              [Dst_EpsCommError]
                        Reset counter: 120
                        Mileage: 166457 km
                        Date: 2020.03.06
                        Time: 17:02:33
                        VzRef: 0A
                        Bit Info 1: 00
                        Bit Info 2: 40
                        Bit Info 3: 26
                        Bit Info 4: 1F
                        F-Path: 02
                        F-Type: 0D
                        Uz: B5
       Part No SW: 4H0 907 064 BN    HW: 4H0 907 064 BN
       Component: BCM2 2.0      H31 0330
       Coding: 01AA3000000000000000
       VCID: 76B5E6CF28C39177E39-8022
       Component: J764 ELV MLB  H39 0046
       Serial number: 2311000154769008
    02823 - Requirements for Locking the Steering Column Lock not met
                        Reset counter: 250
                        Mileage: 161934 km
                        Date: 2019.11.06
                        Time: 15:49:34
    Address 08: Auto HVAC (J255)       Labels:* None
       Part No SW: 4G0 820 043 C    HW: 4G0 820 043 C
       Component: KLIMA 4 ZONEN H11 0054
       Serial number: 16031000030050
       Coding: 3603007888
       Shop #: WSC 06745 128 28888
       ASAM Dataset: EV_AirCondiComfoUDS 002027
       VCID: 1F1BE36BE739703FD0F-804A
    7 Faults Found:
    0182 - Temperature Sensor for Left Footwell Vent
              B1083 15 [009] - Open or Short to Plus
                        Reset counter: 249
                        Mileage: 161929 km
                        Date: 2019.11.05
                        Time: 12:27:29
                        Voltage terminal 30: 11.35 V
                        Outside air temperature: 11.5 °C
                        Vehicle speed: 0.00 km/h
    0194 - Position Sensor in Left Center Vent
              B10E1 15 [008] - Open or Short to Plus
                        Reset counter: 121
                        Mileage: 166568 km
                        Date: 2020.03.09
                        Time: 21:20:31
                        Voltage terminal 30: 11.97 V
                        Supply voltage for external components: 5.02 V
    0196 - Position Sensor in Right Center Vent
              B10E2 15 [008] - Open or Short to Plus
                        Reset counter: 121
                        Mileage: 166568 km
                        Date: 2020.03.09
                        Time: 21:20:31
    0275 - Development code 1
              B2F01 00 [008] - -
              [PTC–Zusatzheizung dauerhaft leistungsreduziert Entwicklungscode 2]
                        Reset counter: 103
                        Mileage: 165208 km
                        Date: 2020.02.18
                        Time: 01:59:06
                        Voltage terminal 30: 13.44 V
                        Outside air temperature: 5.5 °C
                        Energy management heat output control status: Stage 2
                        Electric auxiliary air heater: stage: 1
    0317 - Function Restricted due to Missing Message(s)
              U1111 00 [008] - -
              [Steuergerät für Klima hinten: kein Signal / Kommunikation]
                        Fault Frequency: 178
                        Reset counter: 129
                        Mileage: 161929 km
                        Date: 2019.11.05
                        Time: 12:27:29
                        Engine speed: 0 /min
    0384 - Functional Limitation due to Energy Management
              B10CD 00 [008] - -
                        Reset counter: 103
                        Mileage: 165206 km
                        Date: 2020.02.18
                        Time: 01:55:58
                        Voltage terminal 30: 11.78 V
                        Engine speed: 914 /min
    0518 - Function Restriction due to Faults in Other Modules
              U1113 00 [009] - -
              [Sensor für Luftfeuchte aussen: unplausibles Signal]
                        Reset counter: 249
                        Mileage: 161929 km
                        Date: 2019.11.05
                        Time: 12:27:29
                        Voltage terminal 30: 11.34 V
       Part No SW: 4H0 907 063 CG    HW: 4H0 907 063
       Revision: 11012002    Serial number: 00000001250060
       Coding: 0907201009749FE01181008300001800CF9CC7082E080301000108546F01
       Shop #: WSC 06443 128 28888
       VCID: 6FBBD3AB5799A0BF20F-803A
       Subsystem 1 - Part No SW: 4G8 955 119 D    HW: 4G8 955 119   Labels: 1KX-955-119.CLB
       Component: WWS57X 090715  H32 0051
       Serial number: 90B01114100208103030
       Coding: 0045F7
       Component: RLS  H04 0003
       Serial number: 11609095
       Coding: 02562B
       Subsystem 3 - Part No SW: 4G0 941 531 E    HW: 4G0 941 531 E
       Component: E1 - LDS  H07 0044
       Serial number: 09 08 2011  00000384
       Subsystem 4 - Part No SW: 4G0 907 472     HW: 4G0 907 472
       Component: A31 LED Mod1L  H01 0001
       Serial number: 00000000001006243169
       Subsystem 5 - Part No SW: 4G0 907 472     HW: 4G0 907 472
       Component: A27 LED Mod1R  H01 0001
       Serial number: 00000000001005283398
       Subsystem 6 - Part No SW: 4G0 907 658 A    HW: 4G0 907 658 A
       Component: Humidity_Sens  H02 0002
       Serial number: EE288EB5000000000001
    00379 - Terminal 58s
                        Fault Status: 00101100
                        Reset counter: 121
                        Mileage: 166568 km
                        Date: 2020.03.09
                        Time: 21:20:00
    01229 - A/C Humidity Sensor (G260)
                        Reset counter: 249
                        Mileage: 161929 km
                        Date: 2019.11.05
                        Time: 12:27:00
    03608 - Humidity Sensor in Fresh Air Intake Duct
                014 - Defective
                        Fault Status: 01101110
                        Reset counter: 249
                        Mileage: 161929 km
                        Date: 2019.11.05
                        Time: 12:27:00
                        Fault Status: 01100101
                        Reset counter: 249
                        Mileage: 161929 km
                        Date: 2019.11.05
                        Time: 12:27:00
                        Reset counter: 120
                        Mileage: 166509 km
                        Date: 2020.03.07
                        Time: 21:19:00
    03816 - Left Low Beam Headlamp: Electrical Current Coding Implausible
                        Fault Frequency: 27
                        Reset counter: 129
                        Mileage: 162228 km
                        Date: 2019.11.25
                        Time: 11:19:00
    Address 0E: Media Player 1
       Part No SW: 4H0 919 475 H    HW: 4H0 919 475 C
       Component: PARKHILFE ACC H06 0030
       Revision: 11001001    Serial number: --------------
       Coding: 300303
       ASAM Dataset: EV_EPHVA18AU57X0000 001002
       ROD: EV_EPHVA18AU57X0000_001.rod
       VCID: 372B2BCB6FC9287F38F-8062
       Component: Airbag10.43   H40 0040
       Revision: --------    Serial number: 003JG003WGDG
       Coding: 30314530323130303133554A305234473853
       Shop #: WSC 02391 785 00200
       VCID: 363526CF68C3D177239-8062
       Serial number: 3575HRB40650NI36D9MC
       Serial number: 3585HRB405P0P13E71C1
       Serial number: 3515JRB405L0M98E514Z
       Serial number: 3525JRB405D0M98EFH3A
       Serial number: 3554VRB40550M8GE4PEV
       Serial number: 3564VRB40550M8GE7P9U
       Revision: 00000000    Serial number: 20111114000677
       Coding: 000034
       Shop #: WSC 66666 000 00000
       VCID: 303910D78A27FF47795-8064
       Subsystem 1 - Part No SW: 8U0 951 528 C    HW: 8U0 951 528 C
                        Fault Frequency: 21
                        Reset counter: 125
                        Mileage: 162137 km
                        Date: 2019.11.20
                        Time: 17:08:39
       Part No SW: 4G8 920 930 G    HW: 4G8 920 930 G
       Component: TDieRdw   Nv  H30 0307
       Revision: 10003051    Serial number: 658120210593643
       Coding: 03A601020B0300080D0100
       ASAM Dataset: EV_RBD4K 004033
       ROD: EV_RBD4K_AU57.rod
       VCID: 313F15D381ADF64F76B-8064
    16776978 - Function Restricted due to Missing Message(s)
              U1111 00 [008] - -
              [LH_EPS_01 keine Kommunikation]
                        Reset counter: 120
                        Mileage: 166509 km
                        Date: 2020.03.07
                        Time: 21:19:26
       Part No SW: 4G0 907 468 C    HW: 4G0 907 468 A
       Component: J533--Gateway H08 0204
       Revision: --------    Serial number: 00000000004173
       Coding: 00CD077D00
       ROD: EV_GatewUDS_AU57.rod
       VCID: 303910D78AA7FF47795-8064
       Voltage stabilizer:
       Subsystem 1 - Part No SW: 8K0 959 663     HW: 8K0 959 663
       Serial number: 11220001085021200181
    5088 - Rear A/C control module
              U1072 00 [008] - No communication
                        Fault Frequency: 52
                        Reset counter: 129
                        Mileage: 161929 km
                        Date: 2019.11.05
                        Time: 12:27:29
                        Voltage terminal 30: 11.4 V
                        Voltage terminal 15: 11.4 V
                        Control Module temperature: 19 °C
                        System status: Terminal 15 on
                        Engine running: OFF
                        IN ZAS_Te_X: On
                        Terminal 15 status: On
                        Datenfeld: 0
    4906 - Power Steering Control Module
              U101D 00 [008] - No Communication
                        Reset counter: 120
                        Mileage: 166509 km
                        Date: 2020.03.07
                        Time: 21:19:26
                        Voltage terminal 30: 14.0 V
                        Voltage terminal 15: 13.9 V
                        Control Module temperature: 22 °C
                        Engine running: On
                        IN ZAS_Te_X: On
                        Datenfeld: 0
    5081 - Front Right belt tensioner control module
              U107D 00 [009] - No communication
              [Steuergerät für RGS Rechts Keine Kommunikation]
                        Reset counter: 249
                        Mileage: 161929 km
                        Date: 2019.11.05
                        Time: 12:27:29
                        Engine running: OFF
                        IN ZAS_Te_X: On
                        Datenfeld: 0
    6656 - Control unit for battery monitoring
              U1050 00 [009] - No Communication
                        Reset counter: 249
                        Mileage: 161929 km
                        Date: 2019.11.05
                        Time: 12:27:29
                        Engine running: OFF
                        IN ZAS_Te_X: On
                        Datenfeld: 0
    6232 - Media player in position 1
              U105E 00 [009] - No Communication
              [Mediaplayer Position 1 Keine Kommunikation]
                        Reset counter: 249
                        Mileage: 161929 km
                        Date: 2019.11.05
                        Time: 12:27:28
                        Voltage terminal 30: 11.5 V
                        Engine running: OFF
                        IN ZAS_Te_X: On
                        Datenfeld: 0
       Part No SW: 8K0 857 511 E    HW: 8K0 857 511 A
       Component: FLA           H04 Y132
       Revision: AA001002
       Coding: 04018E64747464545425363E00
       VCID: 33331FDB7B31C45F047-8066
       Part No SW: 4G0 919 158     HW: 4G0 919 158
       Component: KLIMA FOND    H06 0054
       Serial number: 10120900031864
       Coding: 00
       ASAM Dataset: EV_ClimaContrUnitRearUDS 002010
       VCID: 6C81C4A7660F5BA705D-8038
    0075 - Button or Switch in Operating Unit
              B10C7 07 [008] - Mechanical Failure
                        Reset counter: 112
                        Mileage: 165850 km
                        Date: 2020.02.28
                        Time: 23:40:11
                        Outside air temperature: -6.0 °C
                        Left rear vent temperature: 32.4 °C
    0080 - Function Restricted due to Missing Message(s)
              U1111 00 [008] - -
              [Steuergerät im Schalttafeleinsatz Kein Signal/keine Kommunikation]
                        Fault Frequency: 10
                        Reset counter: 112
                        Mileage: 165850 km
                        Date: 2020.02.28
                        Time: 23:41:07
                        Voltage terminal 30: 14.04 V
                        Engine speed: 1340 /min
                        Vehicle speed: 44.00 km/h
    0105 - Combination / Chassis CAN Bus (SAE Bus D)
              U0056 00 [008] - Performance
                        Reset counter: 121
                        Mileage: 156911 km
                        Date: 2019.06.18
                        Time: 18:53:48
                        Voltage terminal 30: 13.89 V
                        Outside air temperature: 21.5 °C
                        Engine speed: 1596 /min
    0106 - Combination / Chassis CAN Bus (SAE Bus D)
              U0055 00 [008] - Malfunction
                        Reset counter: 119
                        Mileage: 165248 km
                        Date: 2020.02.18
                        Time: 11:09:38
                        Voltage terminal 30: 13.73 V
       Part No SW: 4H0 907 440     HW: 4H0 907 440
       Component: STS           H06 0030
       Revision: S0H06000    Serial number: 00000000018023
       Coding: 01010101000000000001000203
       VCID: 6491AC878E5F13E74DD-8030
       Component: MEM-FS        H03 0154
       Revision: AA000000    Serial number: 00000004742330
       Coding: 0058130000006001000001010101102030303232203232
       VCID: 77ABEBCB2FC9E87FF8F-8022
                        Reset counter: 249
                        Mileage: 161929 km
                        Date: 2019.11.05
                        Time: 12:27:29
                        Reset counter: 249
                        Mileage: 161929 km
                        Date: 2019.11.05
                        Time: 12:27:30
       Part No SW: 4G0 907 637     HW: 4G0 907 637
       Component: SARA 3D       H02 0004
       Revision: --------    Serial number: EJ1BPA3200G79V0
       ASAM Dataset: EV_SARA 006014
       ROD: EV_SARA_006.rod
       VCID: 6B83C7BB63015C9F0C7-803E
    Address 3C: Lane Change        Labels: Redir Fail!
       Part No SW: 4G0 907 566     HW: 4H0 907 566
       Component: J769  SWA MasterH02 0010
       Revision: 00H02000    Serial number: 6PZ 010 287-02
       Coding: 0000103
       Shop #: WSC 02729 823 28888
       VCID: 6C81C4A76A8F5BA705D-8038
       Subsystem 1 - Part No: 4G0 907 568
       Component: J770  SWA Slave H01 0010
       Subsystem 2 - Serial number: 6PZ 010 287-22
       Subsystem 3 - Serial number: 5F27.11.0900H010003C720870’
       Subsystem 4 - Serial number: 720870’
    02856 - Sensing Area for Control Module 2 Blocked
                        Reset counter: 118
                        Mileage: 166260 km
                        Date: 2020.03.03
                        Time: 21:21:00
    02853 - Warning Lamp for Lane Change Assistance (in left exterior mirror) (K233)
                        Fault Status: 00101010
                        Fault Frequency: 14
                        Reset counter: 120
                        Mileage: 162227 km
                        Date: 2019.11.22
                        Time: 12:44:18
       Part No SW: 4G8 959 793 B    HW: 4G8 959 793
       Component: TSG FA        H04 0210
       Coding: 011C5F625000628002080002
       VCID: 3FDB43EB4779103FF0F-806A
                        Fault Status: 01101100
                        Fault Frequency: 82
                        Reset counter: 59
                        Mileage: 161939 km
                        Date: 2019.11.10
                        Time: 16:50:58
       Part No SW: 4G0 909 144 G    HW: 4G0 909 144 G
       Component: RCEPS         H33 0005
       Revision: 00001000    Serial number: 0014067153
       Coding: 101001010000
       ASAM Dataset: EV_RCEPS 005004
       ROD: EV_RCEPS_005.rod
       VCID: 2D0709A39D9592AF523-8078
    3158336 - Function Restricted due to Missing Message(s)
              U1111 00 [009] - -
              [Ausfall der FlexRay-PDU "PDU_HCA_01" des BVS-Steuergeräts]
                        Reset counter: 91
                        Mileage: 161929 km
                        Date: 2019.11.05
                        Time: 12:27:29
                        Write only channel
       Revision: 00002001    Serial number: 0156487604
       Coding: 0139062220B9B40003220A04000100000000000000000000000000000000
       Subsystem 2 - Part No SW: 4G8 959 252     HW: 4G8 959 252
       Component: HSP-SG  H08 0027
       Serial number: WA090917000000012227
    00230 - Transmission Park Selector Switch (F305)
                        Fault Frequency: 12
                        Reset counter: 103
                        Mileage: 162043 km
                        Date: 2019.11.13
                        Time: 12:18:57
       Part No SW: 4G8 959 792 B    HW: 4G8 959 792
       Component: TSG BF        H04 0210
       VCID: 3E253EEF40731937FB9-806A
       Revision: --------    Serial number: 00000000128145
       ROD: EV_ParkiBrake_VW51.rod
       VCID: 2A0D02BFAC7B8597B71-807E
       Part No SW: 4H0 907 357 A    HW: 4H0 907 357 A
       Serial number: 111215-0001-031
       Coding: 112296101000A300
       Shop #: WSC 66666 123 12345
       ROD: EV_HeadlRegulBasic.rod
       VCID: 2C0104A7A68F9BA745D-8078
       Part No SW: 4G0 035 192 B    HW: 4G0 035 192
       Component: RMC Nav Plus  H41 0530
       Coding: 0100040001415FCF422B060301010000000000
       VCID: 211FE593D1CD46CFE6B-8074
       Subsystem 1 - Part No: 8X0 919 884 H
       Component: P28-50-14.06  0001
       Subsystem 2 - Part No SW: 4G0 919 603     HW: 4G0 919 603
       Component: DU6 Basic  H41 0084
       Serial number: 9464AE0A0002723
       Subsystem 3 - Part No SW: 4G1 919 612 K    HW: 4G1 919 612 A
       Component: E380 BDT C7  H07 0120
       Serial number: 90349JB300023
    7 Faults Found:
                        Reset counter: 91
                        Mileage: 166901 km
                        Date: 2020.03.20
                        Time: 15:37:09
                        Voltage: 12.30 V
                        Reset counter: 249
                        Mileage: 161929 km
                        Date: 2019.11.05
                        Time: 12:27:33
                        Bin. Bits: 00000000 00000000
                        Bin. Bits: 00000001 00010000
    03787 - Rotation Mechanism for Display Module Front
                        Fault Status: 00100011
                        Fault Frequency: 32
                        Reset counter: 129
                        Mileage: 166509 km
                        Date: 2020.03.07
                        Time: 21:59:45
                        Voltage: 12.00 V
    03788 - Rotation Mechanism for Display Module Front; Play Protection Activated
                        Reset counter: 129
                        Mileage: 166509 km
                        Date: 2020.03.07
                        Time: 22:04:10
                        Voltage: 13.90 V
    02259 - Information Display and Control Head (Front) (J685)
                        Fault Frequency: 6
                        Reset counter: 129
                        Mileage: 166568 km
                        Date: 2020.03.09
                        Time: 20:25:03
    02071 - Local Databus
                        Fault Frequency: 78
                        Reset counter: 131
                        Mileage: 166923 km
                        Date: 2020.03.20
                        Time: 18:41:20
                        Bin. Bits:       01
                        Fault Status: 00101011
                        Fault Frequency: 26
                        Reset counter: 129
                        Mileage: 166568 km
                        Date: 2020.03.09
                        Time: 21:33:49
                        Voltage: 11.60 V
       Part No SW: 4G8 959 795 B    HW: 4G8 959 795
       Component: TSG HL        H02 0210
       Coding: 01081D624000628002080002
       VCID: 41DF4513318D66CF86B-8014
       Part No SW: 4G0 907 441 A    HW: 4H0 907 441
       Component: SG Rueckfahrkamera  0050
       Revision: --H03---    Serial number: 525PA8-J01D0BE
       Coding: 1020013
       Shop #: WSC 06745 128 46587
       VCID: 2517F183C9E5AAEF9A3-8070
       Part No SW: 4G8 959 107     HW: 4G8 959 107
       Component: HDSG-Modul    H12 0032
       Revision: 09145329    Serial number: 333900029
       Coding: 0A2305C000
       Shop #: WSC 00070 000 00000
       ASAM Dataset: EV_HDSGAu573 001014
       ROD: EV_HDSGAu571.rod
       VCID: 72BDDADF442B8D57CF1-8026
       Component: TSG HR        H02 0210
       Coding: 00060000031F030000030800424CDA010000
       Shop #: WSC 12345 123 12345
       ASAM Dataset: EV_RGS_L 002004
       ROD: EV_RGS_L.rod
    12583695 - Function Restricted due to Missing Message(s)
              U1111 00 [009] - -
                        Reset counter: 249
                        Mileage: 161929 km
                        Date: 2019.11.05
                        Time: 12:27:29
    12589824 - Data Set Implausible
              B2012 00 [009] - -
              [Implausible Datase]
                        Reset counter: 249
                        Mileage: 161929 km
                        Date: 2019.11.05
                        Time: 12:33:05
    Address 90: Pretens. Frt Right
    End----------(Elapsed Time: 02:11, VBatt start/end: 14.1V/14.0V)-----------
    And then I erased fault and readed again
    Friday,20,March,2020,20:24:44:19148
    Mileage: 166957km-103742mi   Repair Order: AUDIA71
    28-HVAC, Rear -- Status: Malfunction 0110
       Revision: 53H37---
       Coding: 3603007888
                        Reset counter: 91
                        Mileage: 166957 km
                        Date: 2020.03.20
                        Time: 20:19:55
                        Outside air temperature: -0.5 °C
              U1111 00 [009] - -
                        Reset counter: 91
                        Mileage: 166957 km
                        Date: 2020.03.20
                        Time: 20:19:55
                        Engine speed: 749 /min
              U1113 00 [009] - -
                        Reset counter: 91
                        Mileage: 166957 km
                        Date: 2020.03.20
                        Time: 20:19:56
                        Voltage terminal 30: 14.00 V
                        Engine speed: 750 /min
       Coding: 0045F7
       Coding: 02562B
                        Reset counter: 91
                        Mileage: 166957 km
                        Date: 2020.03.20
                        Time: 20:19:00
                014 - Defective
                        Reset counter: 91
                        Mileage: 166957 km
                        Date: 2020.03.20
                        Time: 20:19:00
                        Reset counter: 91
                        Mileage: 166957 km
                        Date: 2020.03.20
                        Time: 20:19:00
       Coding: 300303
       Coding: 000034
       Coding: 00CD077D00
       Voltage stabilizer:
              U1072 00 [009] - No communication
                        Reset counter: 91
                        Mileage: 166957 km
                        Date: 2020.03.20
                        Time: 20:21:02
                        Voltage terminal 15: 14.0 V
                        Control Module temperature: 28 °C
                        Engine running: On
                        IN ZAS_Te_X: On
                        Datenfeld: 0
                        Reset counter: 91
                        Mileage: 166957 km
                        Date: 2020.03.20
                        Time: 20:21:02
                        Engine running: On
                        IN ZAS_Te_X: On
                        Datenfeld: 0
       Revision: AA001002
                        Reset counter: 91
                        Mileage: 166957 km
                        Date: 2020.03.20
                        Time: 20:19:53
                        Reset counter: 91
                        Mileage: 166957 km
                        Date: 2020.03.20
                        Time: 20:19:54
       Coding: 0000103
              U1111 00 [009] - -
                        Reset counter: 91
                        Mileage: 166957 km
                        Date: 2020.03.20
                        Time: 20:19:55
                        Write only channel
                        Reset counter: 91
                        Mileage: 166957 km
                        Date: 2020.03.20
                        Time: 20:19:53
                        Voltage: 13.80 V
                        Reset counter: 91
                        Mileage: 166957 km
                        Date: 2020.03.20
                        Time: 20:19:57
       Coding: 1020013
       Coding: 0A2305C000
       ROD: EV_RGS_L.rod
              U1111 00 [009] - -
                        Reset counter: 91
                        Mileage: 166957 km
                        Date: 2020.03.20
                        Time: 20:19:55
    End----------(Elapsed Time: 02:11, VBatt start/end: 14.0V/14.0V)-----------
    I think there is maybe bigger problem cause rear AC screen dont work and there is few CM that also cannot be reached and there is still electrical faults in system. Have to get WD then it will be easier to check
    But thanks!
    On an only somewhat similar car (a 2012 A6), Media Player 1 is:
    Address 0E: Media Player 1 (R41)       Labels: None
       Part No SW: 8X0 035 110 B    HW: 8X0 035 110
       Component: CDC-MP3-Pana  H41 0480
       Revision: 00000007
    I suspect that's the CD changer in the glovebox. Does this car have one of those? Does it work?
  3. Likes Dana liked this post
    Tartu, Estonia
    This car is a mess.
    I might be able to check VIN if this car has a dvd changer, but right now it's missing communication. It either doesn't have it or has MOST- loop installed.
    Also Battery module cannot be reached. Same goes for Pretensioner Front Right. Left one seems to be replaced, but not coded/svm correctly?
    The world is my oyster...
  5. Likes Uwe, Dana liked this post
    Feb 2019
    @golfi_vend And I need dealer To code pret. Front right? If it is swm coding?
    Feb 2019
    @Uwe I can check if it work later today. Thanks!
    Feb 2019
    Cd changer In glove box works.
    United States
    Hmm, the PR code is 7A7 without CD changer and PL24 shows it isn't installed (not black and bold). Temp photo link here:
    https://media.trillian.im/media/?m=a...2FkQxwAg%3D%3D
    If the VIN is WAUZZZ4G5CN047070 then I suspect it was a retrofit. Either way, I'd pull it to see what the part number is.
    Edit, in regards to the Address 90: Pretens. Frt Right; Yes, when you get that online it will need dealer SVM config.
  10. Likes Uwe liked this post
  11. #8
    United States
    PR-Code list for WAUZZZ4G5CN047070
    If the OP doesn't want this VIN specific info posted online we can delete this post but it should be helpful IMO.
    Vehicle Identification No. WAUZZZ4G5CN047070
    Model Audi A7 Sportback TDI 3.0 A7
    Date of production 26.09.2011
    Model year 2012
    Sales type 4GA0NH
    Engine Code CLAB
    Transmission Code NKP
    Axle drive SA
    Equipment QE
    Roof color A2
    Carpet color code
    Exterior color / Paint Code A2 / Y9B
    Seat combination no.
    Number of Z-Orders
    Special editions E0A Without special action equipment
    Lockable wheel bolts 1PD Wheel bolts with anti-theft protection (unlockable)
    Vehicle class differentiation powertrains/platform parts 7JV Vehicle class differentiation -4G0/4G8-
    Tailpipes 0P0 Rear exhaust tailpipe (standard)
    Emission standard 7MG Emission standard EU5
    Trailer hitch 1D0 Without trailer hitch
    airbag 4UF Airbag for driver and front passenger with front passenger airbag deactivation
    Activated carbon canister/gasoline particulate filter 1E0 Without activated carbon canister
    Label for central electric system 0W2 Label for central electric system English-speaking countries
    Storage compartment package QE0 Without storage compartment package/box
    Exterior mirror adjustment 6XG Exterior mirrors with memory feature, power-adjustable/heated
    Follow-on warranty EA0 Without subsequent warranty
    Left exterior mirror 5SJ Left exterior mirror, convex
    Right exterior mirror 6TS Right exterior mirror, aspherical, large viewing field
    Alternative drive system 0K0 Without alternative drive system
    Drive type 1X0 Front-wheel drive
    Multimedia/video/DVD/notebook connection 9WC Without "Multimedia" in vehicle
    Equipment lines A8S Standard equipment
    Rear brakes 1KW Disc brakes in rear
    batteries J0B Battery 520 A (92 Ah)
    Front brakes 1LA Disc brakes in front
    Components with special surface 6FA Components without special surface appearance
    Handset (telephone) QF0 Without receiver (car phone)
    Battery/alternator capacities NY0 Standard battery/alternator capacity
    Component sets for country-specific prescriptive standards B0N Component parts set, complying with vehicle type for Great Britain, various parts
    vehicle tools and jack 1S1 vehicle tools and jack
    Brake systems 1AS Electronic stability control (ESC)
    Front passenger seat control 4V0 Without front passenger seat control
    Owner's manuals 0VF Information kit in English
    Operating voltage 9Z0 Operating voltage 12 V
    CD changer/CD player 7A7 without CD changer
    General operating license additions C05 Operating permit, alteration
    CO2 variant 0C0 Standard
    Cd-enhancing underbody panel 2D0 Without cd enhancing underbody panel
    Shock absorption/suspension system 1BE Sports suspension/shock absorption
    Roof rails/roof rack 3S0 Without roof rails/roof load rack
    2-DIN/dual-view display 2T5 Without dual-view display
    Roof insert/convertible top 3FA Without roof insert (standard roof)
    Decorative films/emblems 6F1 Emblems
    Load-through hatch/ski bag 3X0 without load through system
    Eco feature for driver profile and driving mode selection EF1 ECO function
    Theft protection system 7AL Anti-theft alarm system, interior monitoring, backup horn and towing protection
    Inserts 5TG Decorative inserts, brushed, matte aluminum
    Scuff plates 7M8 Scuff plates in door apertures
    Input medium for multimedia UJ0 Input medium for multimedia
    Park distance control 7X2 Park distance control in front and rear
    Extended safety system 7W0 Without extended safety system
    Electric interface for external use UF7 Electric interface for external use
    Power-operated door (power latching) GZ0 Manually operated doors
    Differentiation for manufacturing process 0FA Standard manufacturing sequence
    Color of dashboard/door trim panel and side trim panel 6RB Dashboard and door trim panel two-piece, single-color, multi-colored
    Headlight activation 8K4 Separate daytime running light -- NAR --
    Fresh air intake for vehicle interior (with particle filter) 2V5 Fresh air intake system with combination filter
    Parking brake UH2 Parking brake
    Vehicle tracking system 7G9 Interface for locating assistant
    Night vision 9R0 without night-vision system
    Alternators 9G3 Alternator 120-180 A
    Transmission types/gear shift mechanisms 0G7 tiptronic
    Weight category for rear axle 0YJ Weight range 9 installation control only, no requirement forecast
    Noise cancellation EP0 No noise cancellation
    Weight category for front axle 0JH Weight category front axle weight range 8
    Base engine TF1 6-cylinder diesel engine 3.0 l unit 059.H
    Tie down straps/net/pocket 6M0 Without tie down straps/net/pocket
    cruise control system 8T1 Cruise control system (CCS)
    Garage door opener VC0 without Garage door opener
    Transmission specification G0Z Variable gearing ratio
    rear axle differential GH0 Without rear axle differential
    Rear trim panel 6V1 Rear trim panel (ECE)
    Manufacturer A51 Audi AG
    Rear spoiler 5J2 Rear spoiler (type 2)
    Molded headliner 6NQ Standard molded headliner
    Rear seats 3NJ Rear bench seat, not split, split backrest, folding
    Heating system/air conditioning system 9AK Climatronic with impact pressure control, CFC-free
    Main headlamps 8BP Bi-functional headlamp with gas discharge lamp
    Head-up display KS0 Without head-up display
    Customized installation FC1 Customized installation
    Dashboard inserts U1B Instrument cluster with mph speedometer, clock, tachometer and trip odometer
    Breakaway interior rearview mirror 4L6 Breakaway interior rearview mirror, auto-dimming
    Body forms K8R Sportsback
    Camera/distance sensor QK0 Without camera without distance sensor (driver assistance system)
    Luggage compartment floor covering 6SS Luggage compartment floor covering
    Fuel tank volume 0M0 Fuel tank
    Climate zones 0Y1 Standard climatic zones
    Compass/road sign display QR8 without road sign recognition
    Seat ventilation/massage seat 4D0 Without seat ventilation/massage seat
    Fuel filling volume 1Z5 Increase in initial standard fuel filling
    Fuel quality 0U2 Fuel quality < 50 ppm
    Fuel systems 0F3 Fuel system for diesel engine
    Body measures 5C0 Without special body measures
    Child seat anchors in front 3G1 Child seat anchors, front left (ISOFIX)
    Camera systems/surround sensors KA0 without camera systems/environment sensors
    License plate carrier in front 6W6 License plate carrier in front
    Paint preservation/transport protection 5K5 Transport protection film with additional transport protection measures
    Luggage/load compartment floor in rear 3GA Without luggage compartment floor
    Lighting package (lighting) QQ1 With additional lights (interior lighting)
    Steering system setup L0R Right-hand drive
    Steering system QZ7 Power steering
    Lumbar support in backrests 7P1 Power-adjustable lumbar support in front seats
    steering wheels 1XX Leather-wrapped multi-function sports steering wheel with tiptronic
    Driving on the left/right side AV0 Driving on the left
    Loudspeaker installation 9VD active loudspeakers
    Steering column systems 2C5 Axial and vertical adjustable steering column
    Leather parts 7HA Without leather trim
    Headlight range control 8Q3 Dynamic headlight range control (self-adjusting while driving)
    Center armrest 6E3 Center armrest in front
    Variants FM0 Basic equipment variant
    Multi-function display/trip computer 9Q8 Multi-function display/trip computer
    Center console 3D1 Center console
    Engine cooling 8Z5 not hot country
    Engine specification D1Q 6-cyl. turbo dies. eng. 3.0 l/150 kW (24V), base engine is T41/TF1/TH1
    Navigation system 7T2 Navigation system (LOW)
    Platform group class 7PB Platform group class 2
    Audi Sport/ Quattro GmbH FQ1 Wheels of Audi Sport/ Quattro GmbH
    Quality class AQ0 Standard-production quality
    Wheels CE5 Alloy wheels 9J x 20
    Radios 8DP Radio "LOW II"
    Smoker's/non-smoker's version 9JA Non smoker version
    Tire pressure monitoring system 7K6 Tire pressure monitoring system
    tire HL9 Tires 265/35 R20 99Y XL
    Spare wheel/breakdown kit 1G5 Space-saving spare wheel, same size (same rolling circumference) as original equipment tires
    Type of tire VG6 Type of tire: design 2
    PQ6 Audi exclusive cast aluminium alloy wheels, 5 segment-spoke design, size 9J x 20, with 265/35 R 20 tyres
    PQD PACK_SPORT_DESIGN
    WQR
    Gearshift knob/gearshift handle 7F9 Gearshift knob/handle in plastic/leather
    Self pick-up/special control A00 No self-collection
    Special labels 2KR Labels in English and German
    Tail lamp assemblies 8SK Taillight assemblies with diodes (LED)
    Closing/opening mechanism tailgate/trunk lid/rear gate 4E7 Tailgate/trunk lid power closing
    Bumper systems 2K7 bumper reinforced
    Seat belt reminder 9P3 Seat belt reminder, electric contact in buckle
    seat covers N1V Seat trim covers in leather
    Seat adjustment 3L4 Power seats in front, driver seat with memory feature
    seat heater 4A3 seat heating for front seats separat controlable
    Safety certificates 0LL With special labels safety certificates for England
    Start-stop system/regenerative braking 7L8 Start-stop system with regenerative braking
    Lane change system/lane keeping system 7Y0 no lane change assistant
    Side and rear windows 4KC Side and rear windows in heat-insulating glass
    Sun blind for rear/side windows 3Y0 without roller blind
    Control of production/pre-production FA0 Control of series production
    Headlamp washer system 8X1 Headlamp washer system
    Intermittent windshield wiper control/ light/rain sensor 8N6 Windshield wiper intermittent control with light/rain sensor
    Special approval measures 3M3 Passenger car design
    Nameplate set 0NB Nameplate set in basic style
    Thermal insulation insert (beverage holder) KT0 Without thermal insulation insert (cup holder)
    Door and tailgate/trunk lid locking mechanism 4K4 Central locking w/ radio remote control
    Type-approval testing countries/ countries with specific requirements B09 Type approval country GB/Northern Ireland
    Carrier frequency for remote control 5D7 Carrier frequency 868 MHz without panic button
    Transport protection NT1 Transit coating (type 2)
    TV reception/digital radio reception QV3 digital radio reception
    Installation parts for engines (engine mount system) 1VH Installation parts for six-cylinder engine
    Front-end underbody cladding 1SA Without additional front underbody guard
    Identification labels 1EX Special identification label for EC for M1 passenger vehicles
    Type signs 2Z1 Type sign at rear and "Quattro" nameplates respectively
    First aid kit/warning triangle 1T2 warning triangle
    Front seats Q1D Sports front seats
    Telephone/telematics 9ZF preperation for mobile phone with hands free teleph.
    Maintenance contract EW0 Without maintenance contract
    Thermal energy storage system/auxiliary heater 7E6 Electric auxiliary air heater
    Windshield 4GQ Windshield in heat-insulating glass
    Central display and control unit QW1 Central control unit in front
    floor mats 0TD Front and rear floor mats
    Decorative trims 4ZB Bright decorative trims
    Additional body protective covers, side 6EA Without additional side body covers (stone guard)
    Additional child seat anchorage 3B4 Child seat anchors for child seat system ISOFIX
    Ignition locking system/electronic steering column lock 0RC Starter switch locking system
    Auxiliary heater 9M0 Without auxiliary heater/parking heater
