Hi all! Audi A4 B8 headlight range control error.
AP92
New Member
Adelaide
Hi all!
My names Anthony from South Australia,
I recently bought a 2009 Audi A4 B8 Sline with Xenon headlights. I removed the driver's light to replace lens. Apon reinstalling I received a error on my dash stating headlight range control defective. When I scanned with a friends VCDS is came up with the code 01771 control module for headlight range (J431)
004-No signal / Communication.
I've tried a known working headlight module from a friends A5, a another headlight with no luck. Only solution I have come up with was disconnecting battery then after a few hours reinstalling it. The error is off the dash but still comes up in scans.
I've also checked the level sensors and the wiring seems good.
Any suggestions would be appreciated!
Please post one of the scans that shows the error - see my signature for a How-To.
AP92
New Member
Adelaide
Unfortunately being my mates scan tool I just screen shot the laptop screen ��*♂️
VCDS automatically saves all scans, so you can ask your mate to either email you the scan file or copy it onto a memory stick. He should look in the C:\Ross-Tech\VCDS\Scans folder
Have him e-mail the scan to you. If an Auto-Scan was done, it will have been saved for posterity in the Scans sub-folder.
AP92
New Member
Adelaide
Sunday,15,March,2020,22:06:53:42203
Chassis Type: 8T0
Scan: 01 03 05 08 09 10 15 16 17 19 42 46 47 52 53 55 56 62 72 77
   Mileage: 105900km-65803miles
01-Engine -- Status: Cannot be reached 1100
04-Steering Angle -- Status: Cannot be reached 1100
10-Park/Steer Assist -- Status: Cannot be reached 1100
15-Airbags -- Status: Cannot be reached 1100
55-Headlight Range -- Status: Cannot be reached 1100
Address 01: Engine
   Part No SW: 8K0 907 379 AF    HW: 8K0 907 379 AF
   Component: ESP8 quattro  H04 0210
   Coding: 070500
   Shop #: WSC 06325 000 00000
   VCID: 7DA7FFC91DFB235FA23-8028
   Part No SW: 8K0 907 064 AL    HW: 8K0 907 064 AL
   Component: BCM2 1.1      H80 0145
   Coding: 071100
   VCID: 7AADF4D50CD51467871-802E
   Subsystem 1 - Part No SW: 8K0 905 852 D    HW: 8K0 905 852 D
   Serial number: 0208000086710002
00193 - Rear Right Door Handle Touch Sensor (G418)
                    Fault Status: 01101011
                    Reset counter: 237
                    Mileage: 105904 km
                    Date: 2008.05.27
                    Time: 00:02:14
   Part No SW: 8T2 820 043 S    HW: 8T2 820 043 S
   Component: KLIMA 3 ZONEN H06 0150
   Revision: D0000000    Serial number: 01211020080257
   Coding: 64046000
   VCID: 42DD4C3524859CA79F1-8016
                    Fault Status: 01101101
                    Reset counter: 22
                    Mileage: 105905 km
                    Date: 2020.03.15
                    Time: 17:58:23
            008 - Implausible Signal
                    Fault Status: 01101000
                    Reset counter: 237
                    Mileage: 105904 km
                    Date: 2008.05.27
                    Time: 00:01:28
   Part No SW: 8K0 907 063 C    HW: 8K0 907 063 C
   Revision: 04022001    Serial number: 00000000149197
   Coding: 260050154034AF010001000000001D0D4F1D030800010141000000
   VCID: 2F3B1581871701CF60F-807A
   Subsystem 1 - Part No SW: 8K2 955 119 A    HW: 8T2 955 119   Labels: 1KX-955-119.CLB
   Component: WWS 311008  H05 0070
   Serial number: SWF08100310020
   Coding: 00FD11
   Component: RLS  H04 0003
   Serial number: 10300275
   Coding: 025028
   Subsystem 3 - Part No SW: 8K0 941 531 AA    HW: 8K0 941 531 AA
   Component: E1 - LDS  H07 0080
   Serial number: 00000000002010081279
                    Reset counter: 237
                    Mileage: 105905 km
                    Date: 2020.03.15
                    Time: 17:58:00
            014 - Defective
                    Fault Status: 01101110
                    Reset counter: 22
                    Mileage: 105905 km
                    Date: 2020.03.15
                    Time: 17:58:00
Address 10: Park/Steer Assist
Address 15: Airbags
   Component: Lenks.Modul   H13 0013
   Revision: --------    Serial number: 90304HK10006Q
   Coding: 000016
   VCID: 3D273FC95D7BE35FE23-8068
   Part No SW: 8K0 920 900     HW: 8K0 920 900
   Component: KOMBIINSTR.   H17 0224
   Revision: 00000000    Serial number: 9DL33ZTA8
   Coding: A305090002000008810000
   VCID: 678BBDA16F67998F68F-8032
   Part No SW: 8T0 907 468 M    HW: 8T0 907 468 H
   Component: GW-BEM 5CAN   H06 0095
   Revision: GB300043    Serial number: 4300G08A17820F
   Coding: 000303
   VCID: 4BC3611113CF5DEF6C7-801E
   Component: J367-BDM  H04 0150
   Serial number: 1804E665021008
                    Reset counter: 237
                    Mileage: 105905 km
                    Date: 2020.03.15
                    Time: 17:58:24
   Revision: 00002001    Serial number: 0115465758
   Coding: 0100062200390441003001
   Shop #: WSC 50620 822 75810
Address 47: Sound System (J525)       Labels:. 8T0-035-223-BOC.clb
   Part No SW: 8T0 035 223 S    HW: 8T0 035 223 B
   Component: DSP Prem      H13 0210
   Revision: 00013001    Serial number: 34833002268405
   Coding: 0203010302
   VCID: 3E2538C5507DF847FB9-806A
Address 52: Door Elect, Pass.
Address 53: Parking Brake
Address 55: Headlight Range
   Part No SW: 8T2 035 195 H    HW: 8T2 035 195 H
   Component: Symphony3     H02 0210
   Revision: 00000004    Serial number: AUZ5Z4H1048345
   Coding: 0503008201018D00837B070000
   Subsystem 1 - Part No SW: 8T0 919 603 A    HW: 8T0 919 603 A
   Component: Display
Address 62: Door, Rear Left
Address 72: Door, Rear Right
   Part No SW: 8T0 862 335 C    HW: 8T0 862 335 C
   Component: FSE_256x BT     H33 0550
   Revision: 00000000    Serial number: 00000005041255
   Coding: 0010320
   VCID: 3A2D34D54055D467C71-806E
End----(Elapsed Time: 00:59, VBatt start/end: 11.7V/11.7V. VIgn 0.0V)------
There's a whole lot of stuff in that scan that's off-line ("Cannot be reached") including 55-Headlight Range. Based on "VIgn 0.0V", I suspect the ignition was not on when that scan was done, which makes it rather difficult to work with.
AP92
New Member
Adelaide
I'm fairly sure it was on, I'll double check other scans.
AP92
New Member
Adelaide
VIN: WAUZZZ8K19A164854   License Plate:
Chassis Type: 8K-AU48 (8T0)
VIN: WAUZZZ8K19A164854   Mileage: 105900km-65803miles
Address 01: Engine (MA---CDNC)       Labels:| 06H-907-115-CAB.clb
   Part No SW: 8K2 907 115 P    HW: 8K2 907 115 D
   Component: 2.0l R4/4V TF H14 0003
   Revision: E1H14---
   Coding: 0104000C180F0160
   ASAM Dataset: EV_ECM20TFS8K2907115P A01005
   ROD: EV_ECM20AVS.rod
   VCID: 3C2132CD46E1EA57D5D-8068
Readiness: 1110 0101
   Coding: 070500
   Coding: 071100
   Coding: 64046000
                    Reset counter: 237
                    Mileage: 105904 km
                    Date: 2008.05.28
                    Time: 14:55:20
   Coding: 00FD11
   Coding: 025028
                    Reset counter: 237
                    Mileage: 105904 km
                    Date: 2008.05.28
                    Time: 14:55:00
            014 - Defective
                    Reset counter: 237
                    Mileage: 105904 km
                    Date: 2008.05.28
                    Time: 14:55:00
Address 10: Park/Steer Assist (J446)       Labels:. 8K0-919-475.clb
   Part No SW: 8K0 919 475 E    HW: 8K0 919 475 A
   Component: PARKHILFE 8K  H06 0020
   Revision: 11001001    Serial number: 52840829101022
   Coding: 100003
   VCID: 3B2331D1436FED6FDC7-806E
   Part No SW: 8K0 959 655 B    HW: 8K0 959 655 B
   Serial number: 0038JD1C580Q
   Coding: 30373435363030303030554A3052384B3053
   Serial number: 6334MSME424246612
   Serial number: 6344MSME4213557AB
   Serial number: 6352QSME78102F02C
   Serial number: 6362QSME12103D3AB
   Serial number: 63732SME27120506M
   Serial number: 63832SME7E120A3E8
   Coding: 000016
   Coding: 000303
                    Reset counter: 237
                    Mileage: 105904 km
                    Date: 2008.05.28
                    Time: 14:55:22
   Part No SW: 8K0 959 793 C    HW: 8K0 959 793 A
   Component: TSG FA        H10 0170
   Revision:             Serial number: 0000007926269
   Coding: 011002204101410001
   VCID: 40D9463D2A898EB7895-8014
   Coding: 0203010302
   Part No SW: 8K0 959 792 D    HW: 8K0 959 792 D
   Revision:             Serial number: 0000007889596
   Coding: 011C12204D01410001
   Part No SW: 8K0 907 801 F    HW: 8K0 907 801 F
   Component: EPB Audi B8   H06 0070
   Revision: 00000003    Serial number: 10000000123549
   VCID: 323D1CF594252C270F1-8066
   Component: Display
   Part No SW: 4F0 959 795 N    HW: 8K0 959 795 C
   Revision:             Serial number: 0000007902393
   Coding: 010C12204001210001
   VCID: 44D14A2D3E919297ADD-8010
   Revision:             Serial number: 0000007903252
   Coding: 0010320
End----(Elapsed Time: 01:18, VBatt start/end: 11.5V/11.5V. VIgn 11.5V)-----
OK, now with the ignition on (VIgn 11.5V), we are down to the 55 - Headlight Range module being off-line.
I would say it's time to get out the Wiring Diagrams for this car and check power, ground, and the CAN bus connections to that module.
