Results 1 to 10 of 10
Thread: Hi all! Audi A4 B8 headlight range control error.
    New User
    Mar 2020
    Adelaide
    Hi all!
    My names Anthony from South Australia,
    I recently bought a 2009 Audi A4 B8 Sline with Xenon headlights. I removed the driver's light to replace lens. Apon reinstalling I received a error on my dash stating headlight range control defective. When I scanned with a friends VCDS is came up with the code 01771 control module for headlight range (J431)
    004-No signal / Communication.
    I've tried a known working headlight module from a friends A5, a another headlight with no luck. Only solution I have come up with was disconnecting battery then after a few hours reinstalling it. The error is off the dash but still comes up in scans.
    I've also checked the level sensors and the wiring seems good.
    Any suggestions would be appreciated!
    Please post one of the scans that shows the error - see my signature for a How-To.
  3. Likes Uwe liked this post
    New User
    Mar 2020
    Adelaide
    Unfortunately being my mates scan tool I just screen shot the laptop screen ��*♂️
    Quote Originally Posted by AP92 View Post
    VCDS automatically saves all scans, so you can ask your mate to either email you the scan file or copy it onto a memory stick. He should look in the C:\Ross-Tech\VCDS\Scans folder
    Have him e-mail the scan to you. If an Auto-Scan was done, it will have been saved for posterity in the Scans sub-folder.
  7. Likes PetrolDave liked this post
    New User
    Mar 2020
    Adelaide
    Sunday,15,March,2020,22:06:53:42203
    Chassis Type: 8T0
    Scan: 01 03 05 08 09 10 15 16 17 19 42 46 47 52 53 55 56 62 72 77
       Mileage: 105900km-65803miles
    01-Engine -- Status: Cannot be reached 1100
    04-Steering Angle -- Status: Cannot be reached 1100
    10-Park/Steer Assist -- Status: Cannot be reached 1100
    15-Airbags -- Status: Cannot be reached 1100
    55-Headlight Range -- Status: Cannot be reached 1100
    Address 01: Engine
       Part No SW: 8K0 907 379 AF    HW: 8K0 907 379 AF
       Component: ESP8 quattro  H04 0210
       Coding: 070500
       Shop #: WSC 06325 000 00000
       VCID: 7DA7FFC91DFB235FA23-8028
       Part No SW: 8K0 907 064 AL    HW: 8K0 907 064 AL
       Component: BCM2 1.1      H80 0145
       Coding: 071100
       VCID: 7AADF4D50CD51467871-802E
       Subsystem 1 - Part No SW: 8K0 905 852 D    HW: 8K0 905 852 D
       Serial number: 0208000086710002
    00193 - Rear Right Door Handle Touch Sensor (G418)
                        Fault Status: 01101011
                        Reset counter: 237
                        Mileage: 105904 km
                        Date: 2008.05.27
                        Time: 00:02:14
       Part No SW: 8T2 820 043 S    HW: 8T2 820 043 S
       Component: KLIMA 3 ZONEN H06 0150
       Revision: D0000000    Serial number: 01211020080257
       Coding: 64046000
       VCID: 42DD4C3524859CA79F1-8016
                        Fault Status: 01101101
                        Reset counter: 22
                        Mileage: 105905 km
                        Date: 2020.03.15
                        Time: 17:58:23
                008 - Implausible Signal
                        Fault Status: 01101000
                        Reset counter: 237
                        Mileage: 105904 km
                        Date: 2008.05.27
                        Time: 00:01:28
       Part No SW: 8K0 907 063 C    HW: 8K0 907 063 C
       Revision: 04022001    Serial number: 00000000149197
       Coding: 260050154034AF010001000000001D0D4F1D030800010141000000
       VCID: 2F3B1581871701CF60F-807A
       Subsystem 1 - Part No SW: 8K2 955 119 A    HW: 8T2 955 119   Labels: 1KX-955-119.CLB
       Component: WWS 311008  H05 0070
       Serial number: SWF08100310020
       Coding: 00FD11
       Component: RLS  H04 0003
       Serial number: 10300275
       Coding: 025028
       Subsystem 3 - Part No SW: 8K0 941 531 AA    HW: 8K0 941 531 AA
       Component: E1 - LDS  H07 0080
       Serial number: 00000000002010081279
                        Reset counter: 237
                        Mileage: 105905 km
                        Date: 2020.03.15
                        Time: 17:58:00
                014 - Defective
                        Fault Status: 01101110
                        Reset counter: 22
                        Mileage: 105905 km
                        Date: 2020.03.15
                        Time: 17:58:00
    Address 10: Park/Steer Assist
    Address 15: Airbags
       Component: Lenks.Modul   H13 0013
       Revision: --------    Serial number: 90304HK10006Q
       Coding: 000016
       VCID: 3D273FC95D7BE35FE23-8068
       Part No SW: 8K0 920 900     HW: 8K0 920 900
       Component: KOMBIINSTR.   H17 0224
       Revision: 00000000    Serial number: 9DL33ZTA8
       Coding: A305090002000008810000
       VCID: 678BBDA16F67998F68F-8032
       Part No SW: 8T0 907 468 M    HW: 8T0 907 468 H
       Component: GW-BEM 5CAN   H06 0095
       Revision: GB300043    Serial number: 4300G08A17820F
       Coding: 000303
       VCID: 4BC3611113CF5DEF6C7-801E
       Component: J367-BDM  H04 0150
       Serial number: 1804E665021008
                        Reset counter: 237
                        Mileage: 105905 km
                        Date: 2020.03.15
                        Time: 17:58:24
       Revision: 00002001    Serial number: 0115465758
       Coding: 0100062200390441003001
       Shop #: WSC 50620 822 75810
    Address 47: Sound System (J525)       Labels:. 8T0-035-223-BOC.clb
       Part No SW: 8T0 035 223 S    HW: 8T0 035 223 B
       Component: DSP Prem      H13 0210
       Revision: 00013001    Serial number: 34833002268405
       Coding: 0203010302
       VCID: 3E2538C5507DF847FB9-806A
    Address 52: Door Elect, Pass.
    Address 53: Parking Brake
    Address 55: Headlight Range
       Part No SW: 8T2 035 195 H    HW: 8T2 035 195 H
       Component: Symphony3     H02 0210
       Revision: 00000004    Serial number: AUZ5Z4H1048345
       Coding: 0503008201018D00837B070000
       Subsystem 1 - Part No SW: 8T0 919 603 A    HW: 8T0 919 603 A
       Component: Display
    Address 62: Door, Rear Left
    Address 72: Door, Rear Right
       Part No SW: 8T0 862 335 C    HW: 8T0 862 335 C
       Component: FSE_256x BT     H33 0550
       Revision: 00000000    Serial number: 00000005041255
       Coding: 0010320
       VCID: 3A2D34D54055D467C71-806E
    End----(Elapsed Time: 00:59, VBatt start/end: 11.7V/11.7V. VIgn 0.0V)------
    There's a whole lot of stuff in that scan that's off-line ("Cannot be reached") including 55-Headlight Range. Based on "VIgn 0.0V", I suspect the ignition was not on when that scan was done, which makes it rather difficult to work with.
  10. Likes PetrolDave liked this post
  11. #8
    New User
    Mar 2020
    Adelaide
    I'm fairly sure it was on, I'll double check other scans.
  12. #9
    New User
    Mar 2020
    Adelaide
    VIN: WAUZZZ8K19A164854   License Plate:
    Chassis Type: 8K-AU48 (8T0)
    VIN: WAUZZZ8K19A164854   Mileage: 105900km-65803miles
    Address 01: Engine (MA---CDNC)       Labels:| 06H-907-115-CAB.clb
       Part No SW: 8K2 907 115 P    HW: 8K2 907 115 D
       Component: 2.0l R4/4V TF H14 0003
       Revision: E1H14---
       Coding: 0104000C180F0160
       ASAM Dataset: EV_ECM20TFS8K2907115P A01005
       ROD: EV_ECM20AVS.rod
       VCID: 3C2132CD46E1EA57D5D-8068
    Readiness: 1110 0101
       Coding: 070500
       Coding: 071100
       Coding: 64046000
                        Reset counter: 237
                        Mileage: 105904 km
                        Date: 2008.05.28
                        Time: 14:55:20
       Coding: 00FD11
       Coding: 025028
                        Reset counter: 237
                        Mileage: 105904 km
                        Date: 2008.05.28
                        Time: 14:55:00
                014 - Defective
                        Reset counter: 237
                        Mileage: 105904 km
                        Date: 2008.05.28
                        Time: 14:55:00
    Address 10: Park/Steer Assist (J446)       Labels:. 8K0-919-475.clb
       Part No SW: 8K0 919 475 E    HW: 8K0 919 475 A
       Component: PARKHILFE 8K  H06 0020
       Revision: 11001001    Serial number: 52840829101022
       Coding: 100003
       VCID: 3B2331D1436FED6FDC7-806E
       Part No SW: 8K0 959 655 B    HW: 8K0 959 655 B
       Serial number: 0038JD1C580Q
       Coding: 30373435363030303030554A3052384B3053
       Serial number: 6334MSME424246612
       Serial number: 6344MSME4213557AB
       Serial number: 6352QSME78102F02C
       Serial number: 6362QSME12103D3AB
       Serial number: 63732SME27120506M
       Serial number: 63832SME7E120A3E8
       Coding: 000016
       Coding: 000303
                        Reset counter: 237
                        Mileage: 105904 km
                        Date: 2008.05.28
                        Time: 14:55:22
       Part No SW: 8K0 959 793 C    HW: 8K0 959 793 A
       Component: TSG FA        H10 0170
       Revision:             Serial number: 0000007926269
       Coding: 011002204101410001
       VCID: 40D9463D2A898EB7895-8014
       Coding: 0203010302
       Part No SW: 8K0 959 792 D    HW: 8K0 959 792 D
       Revision:             Serial number: 0000007889596
       Coding: 011C12204D01410001
       Part No SW: 8K0 907 801 F    HW: 8K0 907 801 F
       Component: EPB Audi B8   H06 0070
       Revision: 00000003    Serial number: 10000000123549
       VCID: 323D1CF594252C270F1-8066
       Component: Display
       Part No SW: 4F0 959 795 N    HW: 8K0 959 795 C
       Revision:             Serial number: 0000007902393
       Coding: 010C12204001210001
       VCID: 44D14A2D3E919297ADD-8010
       Revision:             Serial number: 0000007903252
       Coding: 0010320
    End----(Elapsed Time: 01:18, VBatt start/end: 11.5V/11.5V. VIgn 11.5V)-----
  13. #10
    OK, now with the ignition on (VIgn 11.5V), we are down to the 55 - Headlight Range module being off-line.
    I would say it's time to get out the Wiring Diagrams for this car and check power, ground, and the CAN bus connections to that module.
