Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
Thread: Audi Q5 8R sound actor retrofit
    Sep 2018
    Algeria
    Ohm.. SQ5 is 3.0 V6 biturbo TDI.
    So youíre trying to retrofit the SQ5 exhaust sound booster to a 190hp 4 cylinder TDI? Iím pretty sure it has the same vehicle and engine type protection as the inside borne sound actuator.
    Easier would be to get the sound booster from Kufatec.
    I get harness from k-electronic so they give me pdf installation guide also using elsa and SQ5 exhaust from ebay but nothing works maybe problem with C0 module 4G0 could be 8R0 works
  2. #12
    Don,
    Could it be this thing that he's retrofit?
    Address C0: Act. for Ext. Noise (J943)       Labels: 4G0-907-160.clb
       Part No SW: 4G0 907 160 B    HW: 4G0 907 160 B
       Component: SAS-GEN 2 AGA H09 0007
       Serial number: 180214201444
       VCID: 2411EF8D1E56F6B78DF-8070
    I don't really understand why someone would fit an actuator for exterior noise. Those are used on PHEVs and BEVs to warn pedestrians that a vehicle is approaching because those vehicles are "too quiet" without them. But this does not appear to a vehicle capable of "silent running".
    Uwe: clearly you are correct. I was responding to the title heading on the thread - but there's a problem with the definition of terms: "Soundakator" versus "Sound Booster"
  3. Likes Uwe, downtime liked this post
  4. #13
    May 2017
    Quote Originally Posted by isilvation View Post
    Your problem is the engine type. These modules are married to a certain engine type and if it does not match, it results in the error you're having at the moment. There is no way you can change it unless you can fool the sound booster module to think you have SQ5 engine.
    Many have tried to retrofit the internal sound aktuator and those fail in the same way if the engine type does not match.
    Edit :
    I would guess this kit is what would work for your car : https://www.kufatec.com/en/audi/q5/q...di-q5-8r-41380
    Not original VAG product.
  5. Likes PetrolDave, golfman liked this post
