Results 1 to 9 of 9
Thread: 2012 VW Tiguan Rear Left Door Module
    Mar 2015
    Hi guys. i've been reading through this forum and i seem to have the same problem. MY rear passenger door non responsive. however the window is work from the rear switch but not from driver switch .On the dash panel the door open all the time , interface cannot even access the door module! this is what comes up:
    Pleas look on my full scan with any help pleas .
    Thanks
    Saturday,21,March,2020,13:28:35:58365
    VCDS Version: 19.6.2.2
    VIN: WVGBV7AX5CW545803   License Plate:
    Mileage: 84040km-52220mi   Repair Order:
    Chassis Type: AX-VW36 (7N0)
    Scan: 01 02 03 05 08 09 15 16 17 19 22 25 2B 2E 36 37 42 44 46 47
              4C 4F 52 53 55 56 69 6C 72 77
    VIN: WVGBV7AX5CW545803   Mileage: 84040km-52220miles
       Part No SW: 06J 997 029 P    HW: 06J 907 309 A
       Component: MED17.5.2 TFSI 2    1519
       Revision: P3H07---    Serial number:
       Coding: 0423010A190F0160
       Shop #: WSC 39411 001 1048576
       VCID: 448CFDB00778226FC1-8010
    005703 - Check Coding of ECUs on Powertrain Data Bus
                   P1647 - 000 -  - MIL ON
                        Fault Status: 11100000
                        Mileage: 84043 km
                        Date: 2014.08.12
                        Time: 03:18:30
                        RPM: 708 /min
                        Load: 21.2 %
                        Temperature: 65.0C
                        Temperature: 12.0C
                        Absolute Pres.: 1020.0 mbar
                        Voltage: 14.478 V
    Readiness: 1110 0101
       Part No SW: 09G 927 750 LR    HW: 09G 927 750 LR
       Component: AQ 250 6F           1971
       Revision: 00H90000    Serial number:
       Coding: 0000840
       VCID: 0C1C15906FA8AA2FC9-8058
    Address 03: ABS Brakes        Labels: 5N0-614-109-C6.clb
       Part No SW: 5N0 614 109 AP    HW: 5N0 614 109 AP
       Component: J104   C6 450M VDB7 0005
       Revision: --H07---    Serial number: 00000005029145
       Coding: 0005161
       VCID: 79F25C44303AAF87E2-802C
       Part No SW: 5K0 959 434 B    HW: 5K0 959 434 B
       Revision: 00085000    Serial number: 0158565923
       Coding: 030C0C
       VCID: 346CAD709FD892EF71-8060
       Part No SW: 5K0 907 044 FE    HW: 5K0 907 044 FE
       Component: Climatronic   H18 1112
       Revision: 00001004
       Coding: 0000001002
       VCID: 73EE6E6CDA56D5D7A8-8026
    13636096 - Supply voltage
              U1012 00 [008] - Voltage too High
                        Reset counter: 222
                        Mileage: 84043 km
                        Date: 2020.03.21
                        Time: 03:10:07
       Part No SW: 5K0 937 086 N    HW: 5K0 937 086 N
       Component: BCM PQ35 M    021 0064
       Revision: BJ021001
       Coding: 6F180A1B88232EC4008800C134000D4448550006576D8DF0E4840000A040
       VCID: 3F86F25CAE9E41B79C-806A
       Subsystem 1 - Part No SW: 5N1 955 119     HW:              Labels: 1KX-955-119.CLB
       Component: Wischer 21111  013 0203
       Serial number: N1955119   203!
       Coding: 009795
       Component: RLS 091111 05  54  0403
       Coding: 02304D
       Part No SW: 5N0 959 655 P    HW: 5N0 959 655 P
       Component: J234__204 VW10 HI   1918
       Revision: 23016000    Serial number: 003GJPQ3HYU1
       Coding: 0012340
       VCID: 4A90D388255CF41F3B-801E
       Subsystem 1 - Part No: 5N0 959 339 B
       Component: BF-Gewichtsens. 003 0001
       Subsystem 2 - Serial number: 00000000007AZA
       Subsystem 3 - Serial number: 0013.10.110000300000630045†63
       Subsystem 4 - Serial number: 630045†6332MTS642333041 †63
       Subsystem 5 - Serial number: 33041 †6342MTS677743031 †63
       Subsystem 6 - Serial number: 43031 †6351HTS6UA8C0AKJ †63
       Subsystem 7 - Serial number: C0AKJ †6361HTS6UAIJV9KR †63
       Subsystem 8 - Serial number: JV9KR †63727TS6PSJG1AKJ †63
       Subsystem 9 - Serial number: G1AKJ †63827TS69K9O1AKJ
       Subsystem 10 - Serial number: O1AKJ
       Part No SW: 5K0 953 569 AL    HW: 5K0 953 569 AL
       Revision: --X01---    Serial number: 20190815100369
       Coding: 7982A00000
       Shop #: WSC 01286 386 08256
       VCID: 02003BA895ECEC5FB3-8056
       Subsystem 1 - Part No SW: 5K0 959 542 A    HW: 5K0 959 542 A  Labels: 3C8-959-537.CLB
       Component: E221__MFL-TAS  H09 0013
       Serial number: 0713206
       Coding: 820000
    147464 - Terminal 15
              B1148 29 [009] - Signal Implausible
                        Reset counter: 183
                        Mileage: 84043 km
                        Date: 2020.03.21
                        Time: 03:19:07
    227355 - Windshield Wiper/Washer Switch
              B1149 13 [009] - Open Circuit
                        Reset counter: 182
                        Mileage: 84043 km
                        Date: 2020.03.21
                        Time: 03:19:07
       Part No SW: 5N0 920 972 E    HW: 5N0 920 972 E
       Component: KOMBI         H04 0617
       Coding: 211F01
       VCID: 356A907494A28BE746-8060
       Part No SW: 7N0 907 530 P    HW: 1K0 907 951
       Component: J533  Gateway H40 1623
       Revision:   H40       Serial number: 101111F2001787
       Coding: 356002
       VCID: 3D7A8854A49253A78E-8068
       Part No SW: 0AY 907 554 E    HW: 0AY 907 554 E
       Component: Haldex 4Motion      0043
       Coding: 0000005
       VCID: 4D9AD894D432E3271E-8018
       Component: IMMO          H04 0617
       Coding: 000007
       VCID: 6AD073088D9C141F1B-803E
       Part No SW: 5K0 905 861 A    HW: 5K0 905 861 A
       Component: ELV-PQ35      H20 0230
       Revision: 00000000    Serial number: 11000220881002
       Coding: 4900000000000000
       ROD: EV_ELVMarquMPVW36X.rod
       VCID: 2E58BF1871F4B83F07-807A
       Revision: A1001003    Serial number: 7661315134
       VCID: 29524C04401ADF07D2-807C
       Part No SW: 561 959 760 A    HW: 561 959 760 A
       Component: MEM-FS        H04 0181
       Revision: AA000000    Serial number: 00000015901790
       Coding: 00581B0000000000000001010101202020202121202020
       VCID: 21425424382A17478A-8074
    00532 - Supply Voltage B+
                        Fault Status: 00100001
                        Reset counter: 222
                        Mileage: 84043 km
                        Date: 2014.08.12
                        Time: 03:10:07
       Part No SW: 3C8 035 684 E    HW: 3C0 035 684 E
       Component: RNS-MID       H61 3690
       Revision: AB001001    Serial number: VWZ6Z7L4320034
       Coding: 0405000201000086000C
       Shop #: WSC 23320 444 105100
       VCID: 2D5AB81474F2C3273E-8078
       Part No SW: 5N0 959 701 G    HW: 3C0 959 793 C
       Component: TUER-SG FT    002 0503
       Revision: 12110009    Serial number: 0003879431
       Coding: 0015BE
       VCID: 39729C44B8BA6F87A2-806C
    65538 - Local Data Bus
              U10BA 00 [009] - No Communication
                        Reset counter: 183
                        Mileage: 84043 km
                        Date: 2020.03.21
                        Time: 03:21:48
       Part No SW: 5N1 909 144 M    HW: 5N1 909 148 G
       Component: J500__APA-BS KL.286 1002
       Revision: 1AH03836    Serial number: 00113190504201
       Coding: 0000258
       Shop #: WSC 46140 001 1048576
       VCID: 3C7C85507F885AAFB9-8068
       Part No SW: 5K0 035 456 B    HW: 5K0 035 456 B
       Component: KonzernAmp 8K H07 0368
       Revision: --------    Serial number: EAA085A0003230
       VCID: 29524C04481ADF07D2-807C
    9463315 - Rear Left Treble Speaker
              B1066 13 [009] - Open Circuit
                        Reset counter: 182
                        Mileage: 84043 km
                        Date: 2020.03.21
                        Time: 03:10:08
    13893888 - Function Restricted due to Excessive Voltage
              U1401 00 [008] - -
                        Reset counter: 222
                        Mileage: 84043 km
                        Date: 2020.03.21
                        Time: 03:10:06
       Component: EZE_2         H40 1623
       Coding: 050B0500
       VCID: 6FE6621CBE7EF1374C-803A
       Subsystem 1 - Part No SW: 8R0 959 591 A    HW: 8R0 959 591
       Component: J245EE20SKB13  H03 0220
       Component: J394EE20SKB13  H03 0220
       Part No SW: 5N0 959 702 G    HW: 3C0 959 792 C
       Component: TUER-SG BT    002 0503
       Revision: 14110009    Serial number: 0003853095
       Coding: 0015BE
       VCID: 3A708348BDBC649FAB-806E
       Slave Passenger:
       Subsystem 1 - Part No SW: 5N0 959 704 G    HW: 3C0 959 795 D  Labels: 1K0-959-70X-GEN4.CLB
       Component: J389__TSG-HR  007 1504
       Serial number: 00000006142734
       Coding: 000490
    66821 - Position Sensor for Mirror Adjustment
              B11FA 29 [009] - Signal Implausible
                        Reset counter: 183
                        Mileage: 84043 km
                        Date: 2020.03.21
                        Time: 03:23:09
       Part No SW: 3AA 907 801 G    HW: 3AA 907 801 G
       Component: J540 EPB4  VW-64783 0009
       Revision:   H19       Serial number: 00000000424438
       Coding: 0026156
       VCID: 356A90745CA28BE746-8060
       Coding: 041A00010B000400
       VCID: 37769A7C8EAE79F754-8062
       Subsystem 1 - Part No: 4H0 941 329   Labels: 3D0-941-329.CLB
       Subsystem 2 - Part No: 4H0 941 329   Labels: 3D0-941-329.CLB
    5275927 - Power Output Module for Left Headlamp
              C1081 17 [008] - Voltage Too High
                        Reset counter: 222
                        Mileage: 84043 km
                        Date: 2020.03.21
                        Time: 03:10:07
    5276183 - Power Output Module for Right Headlamp
              C1082 17 [008] - Voltage Too High
                        Reset counter: 222
                        Mileage: 84043 km
                        Date: 2020.03.21
                        Time: 03:10:07
       Part No SW: 1K0 907 383 F    HW: 1K0 907 383 F
       Revision: 3A001001    Serial number: 00000162080663
       Coding: 420D000100000000
       VCID: 3064A16063C0AECF15-8064
       Part No SW: 5N0 907 441 A    HW: 5N0 907 441 A
       Component: J772__Rearview      0030
       Revision: 00H09000    Serial number: 525PA8-J196566
       Coding: 0110010
       VCID: 2D5AB814B4F2C3273E-8078
       Part No SW: 5K0 035 730 E    HW: 5K0 035 730 E
       Component: TELEFON       H09 2902
       Revision: 1B001001    Serial number: 00007661332690
       Coding: 0A10040000010100
       ASAM Dataset: EV_UHVNA A01719
       ROD: UHVNA.rod
       VCID: 27564A3C5E0EE977C4-8072
    End-------------------------(Elapsed Time: 04:09)--------------------------
    Hi and welcome.
    Rear door modules on this vehicle are not directly addressable; instead they are "slaves" of the respective front door modules. See for example your right (passenger) side:
       Coding: 0015BE
       Slave Passenger:
       Coding: 000490
    I've highlighted the rear module on that side. But on the other side you've got:
       Coding: 0015BE
    This means the front module has no communications with the rear module. Since you say the rear window works from the switch in that door, it would seem the module is not "dead", but that the most likely problem is a break in the LIN bus wire that the front module uses to communicate with the rear.
  3. Likes PetrolDave, downtime, Fredrick Awuor, Dana liked this post
    Verified VCDS User Danners74's Avatar
    Jun 2016
    Hi and welcome.
       Coding: 0015BE
       Slave Passenger:
       Coding: 000490
       Coding: 0015BE
    Spot on. These are getting to that age where the door harnesses are breaking up.
    Mar 2015
    Thanks my friends .will check all wires on the doors .
    Mar 2015
    Hello. No luck steel the problem .
    Can you guys tell me , if the latch is bad ,can it make can bus communication problems?
    I tried on the passenger front door change the coding .then i getting same code like on the left door Powertrain Data Bus .
    The LIN is wired in daisy chain so it should be checked using DVOM and load tested not a coding issue by WD in RTFB.
    http://wiki.ross-tech.com/wiki/index...ir_Information
  8. Likes Uwe, Dana liked this post
    United States
    Quote Originally Posted by alexG View Post
    No, I can't say I've ever had bad door latch take down Comfort CAN. I think you have a wiring issue as per Danners74's suggestion.
    You will need to check a wiring diagram as per Jack's suggestion but I want to make sure I understand your testing correctly. You removed the Right Front #52-Passenger module and plugged in into the Left (Driver) front door harness. The scan in that condition showed the same Local Data Bus DTC under address 52 at that point correct?
    If so, the problem is not with the #42 front module IMO. Rather, there is likely an issue with the LIN from front to rear and that could be in either harness but I would check the front closely since that gets opened and closed far more frequently. Another possibility is that the left rear module is faulty.
    Edit; If in fact you have swapped the left/right front modules and still have door panels removed you might plug the #42 module into the right side of the car to verify the rear slave communicates. Doing so should confirm that the 42 module is OK in regards to LIN. You could even do the same with the rears but I don't know if you want to pull all 4 panels.
  10. #8
    Mar 2015
    Thanks . I have 3 rear door modules from recycle cars and all 3 modules akting the same Window working but lock is dad on rear left and not showing door open on the dush
  11. Likes Dana liked this post
  12. #9
    United States
    OK, as long as they were all compatible then it sounds like you have ruled out a left rear module specific problem.
    Swapping the front units left/right is still an option but your time may be better spent checking that LIN wiring in each left side door.
  13. Likes Uwe, PetrolDave liked this post
