Chassis Type: NE-SK37 (5Q0)
Scan: 01 03 05 08 09 10 15 16 17 19 20 2B 42 44 52 55 5F
VIN: TMBAM7NE4F0040869 Mileage: 196636km-122183miles
Address 01: Engine (J623-CPWA) Labels:. 04E-907-309-V1.clb
Part No SW: 04E 906 016 N HW: 04E 907 309 E
Component: 1.4l TSI CNG H12 7572
Revision: WIH12---
Coding: 01190072232401081000
Shop #: WSC 73430 031 00121
ASAM Dataset: EV_ECM14CSI01104E906016N 001006
ROD: EV_ECM14CSI_VW37.rod
VCID: 2D06FE797D9D00EF51F-8078
CAN Converter 01:
7 Faults Found:
15361 - Oxygen (Lambda) Sensor Signal B1 S2
P2271 00 [096] - too Rich
Mileage: 195851 km
Date: 2019.07.08
Time: 09:37:28
Engine speed: 1971.50 /min
Normed load value: 8.2 %
Vehicle speed: 44 km/h
Coolant temperature: 63 °C
Intake air temperature: 26 °C
Voltage terminal 30: 14.630 V
Unlearning counter according OBD: 10
Oxygen sensor 2 bank 1 internal resistance limit value: 130320 Ohm
Mass flow through throttle valve: 13.7 kg/h
10204 - Misfire detected during Nat.Gas Operation
P3361 00 [104] - -
Mileage: 196394 km
Date: 2019.07.14
Time: 06:45:42
Engine speed: 1373.50 /min
Normed load value: 55.7 %
Coolant temperature: 54 °C
Intake air temperature: 37 °C
Voltage terminal 30: 12.863 V
Mass flow through throttle valve: 44.3 kg/h
Engine operating condition: Part. load
Engine operating condition-Test_Program_Channel 87: 6
10195 - Cylinder 1 Misfire detected during Nat.Gas Operation
P3362 00 [104] - -
Mileage: 196394 km
Date: 2019.07.14
Time: 06:46:41
Engine speed: 2080.00 /min
Normed load value: 65.5 %
Vehicle speed: 17 km/h
Voltage terminal 30: 12.627 V
Unlearning counter according OBD: 38
Mass flow through throttle valve: 117.8 kg/h
10199 - Cylinder 3 Misfire detected during Nat.Gas Operation
P3364 00 [104] - -
Mileage: 196394 km
Date: 2019.07.14
Time: 06:46:41
10201 - Cylinder 4 Misfire detected during Nat.Gas Operation
P3365 00 [104] - -
Fault Frequency: 7
Mileage: 196413 km
Date: 2019.07.14
Time: 20:03:19
10197 - Cylinder 2 Misfire detected during Nat.Gas Operation
P3363 00 [104] - -
Mileage: 196394 km
Date: 2019.07.14
Time: 06:46:41
4116 - Oxygen (Lambda) Sensor B1 S1
P2196 00 [237] - Signal too High (Rich)
Mileage: 196148 km
Date: 2019.07.11
Time: 22:08:13
Engine speed: 1918.50 /min
Normed load value: 16.5 %
Vehicle speed: 57 km/h
Coolant temperature: 87 °C
Intake air temperature: 32 °C
Voltage terminal 30: 13.994 V
Oxygen sensor 1 bank 1 fast offset adaptation counter: 12
Part No SW: 5Q0 907 379 K HW: 5Q0 907 379 F
Component: ESC H31 0371
Revision: 00000000 Serial number: 61754000000244
Coding: 1A076A912424116C007F060641CC295856248800608294F000230070C002
Shop #: WSC 73430 031 00063
ROD: EV_Brake1UDSContiMK100ESP_033_VW37.rod
VCID: 44D0BBDDCE17E1A7AE1-8010
0297 - Steering angle sensor
B1168 16 [008] - Voltage Too Low
Reset counter: 105
Mileage: 151708 km
Date: 2016.10.31
Time: 00:19:15
8277 - Databus
[FCAN: EPS_DSR_Status signal is invalid]
Fault Frequency: 205
Reset counter: 50
Mileage: 154010 km
Date: 2017.02.04
Time: 21:09:23
16401 - Tire Pressure Warning
C102D 00 [008] - -
Reset counter: 48
Mileage: 195051 km
Date: 2019.06.22
Time: 20:38:30
Revision: 00021000 Serial number: 0338552084
Coding: 030C0C
Shop #: WSC 73430 790 00121
VCID: 3A2CC525BCD3A757C4D-806E
Part No SW: 5E0 907 044 N HW: 5E0 907 044 N
Component: Climatronic H03 0907
Revision: 00001K06
Coding: 01010004000100011005000100101000
VCID: 3038E70D6AAF6D077A9-8064
328199 - Position Sensor for Right Temperature Flap Motor
B1095 15 [008] - Open or Short to Plus
Reset counter: 38
Mileage: 196267 km
Date: 2019.07.13
Time: 09:02:54
Voltage terminal 30: 13.9 V
Outside air temperature: 19.5 °C
Interior temperature: 27.6 °C
Right temperature flap: actual value: 53
Right temperature flap: actual value: 12.0 %
Right temperature flap: specified value: 53
Address 09: Cent. Elect. (J519) Labels:| 5Q0-937-08X-HV1.clb
Part No SW: 5Q0 937 084 AJ HW: 5Q0 937 084 AJ
Component: BCM MQBAB H H18 0134
Serial number: 01011417400836
Coding: 0C010B66424722FB07A04082B11C07080800000000000000000000000000
ROD: EV_BCMBOSCH_013.rod
VCID: 005877CD9A8F3D87CA9-8054
Subsystem 1 - Part No SW: 5E1 955 119 HW: 5E1 955 119 Labels: 5QX-955-119-V1.CLB
Component: WWS371 140623 041 0570
Serial number: 140625101810
Coding: 065DDD
Subsystem 2 - Part No SW: 5Q0 955 547 A HW: 5Q0 955 547 A Labels: 5Q0-955-547.CLB
Component: RLHS 037 0059
Serial number: S4Y14M07D03H00M43S54
Coding: 00885D
Subsystem 3 - Part No SW: 5Q0 951 171 HW: 5Q0 951 171
Component: Sensor, DWA 005 0315
Serial number: 000000000ZY140974T23
Subsystem 4 - Part No SW: 5Q0 951 605 HW: 5Q0 951 605
Component: Sirene, DWA 004 0311
Serial number: 00000000000030072804
5898 - Bulb for Rear Left Side Turn Signal
B12D0 15 [008] - Open or Short to Plus
Reset counter: 39
Mileage: 196377 km
Date: 2019.07.13
Time: 19:29:12
Address 10: Park/Steer Assist (J791) Labels:| 5Q0-919-294.clb
Part No SW: 5Q0 919 294 E HW: 5Q0 919 294 A
Component: PARKHILFE 8K H03 0048
Revision: -------- Serial number: 39331417805554
Coding: 0031051041
Shop #: WSC 73430 790 00063
VCID: 3D26CE39ADFD906FE1F-8068
Part No SW: 3Q0 959 655 AC HW: 3Q0 959 655 AC
Component: Airbag VW20 012 0189
Revision: -------- Serial number: 003P4PC2N9HY
ROD: EV_AirbaVW20TS6VW48X.rod
VCID: 7F5AF431E771427FB33-802A
Subsystem 1 - Part No SW: ----------- HW: 454 001 506 14
Serial number: 3576U000000E282CFF0X
Subsystem 2 - Part No SW: ----------- HW: 454 001 506 14
Serial number: 3586U0000003D62CFF0W
Subsystem 3 - Part No SW: ----------- HW: 454 802 506 14
Component: SideSensor_Dr 111 0148
Serial number: 3516RC774F3030000007
Subsystem 4 - Part No SW: ----------- HW: 454 802 506 14
Component: SideSensor_Pr 111 0148
Serial number: 3526RE39DEF03000000S
Subsystem 5 - Part No SW: ----------- HW: 454 801 905 14
Component: FrontSensor_D 114 0149
Serial number: 3556V61459F030000007
Part No SW: 5Q0 953 507 EE HW: 5Q0 953 549 C
Component: Lenks. Modul 002 0110
Revision: -------- Serial number: 29061404401688
Coding: 1400
VCID: 7DA60E39ED7D506FA1F-8028
Part No SW: 5E0 920 752 HW: 5E0 920 752
Component: KOMBI 304 4280
Coding: 07A401102980000801086A001000000000000000
VCID: 639258416BD9869FB7B-8036
13639427 - Databus
[Steuergerät für Motor: bitte Fehlerspeicher auslesen]
Reset counter: 48
Mileage: 196315 km
Date: 2019.07.13
Time: 12:47:47
Part No SW: 5Q0 907 530 T HW: 5Q0 907 530 F
Component: GW MQB High 128 1188
Revision: -------- Serial number: 0002195691
Coding: 030100042F085700EF00024A080F00010001050000000000000000000000
ASAM Dataset: EV_GatewLear 011016
ROD: EV_GatewLear_011.rod
VCID: 42DCBDC5D403EF979CD-8016
Subsystem 2 - Part No SW: 5E0 919 719 A HW: 5E0 919 719 A
Component: E221__MFL-PR6 H04 0130
Serial number: 000000000A0072180614
Subsystem 3 - Part No SW: 5Q0 915 181 E HW: 5Q0 915 181 E
Component: J367-BDMHella H03 8043
Serial number: 2347573603
Address 20: High Beam Assist. (J844) Labels:| 8X0-857-511.clb
Part No SW: 5G0 857 511 D HW: 5G0 857 511
Component: FLA H04 0002
Revision: AA001001
Coding: 02018F6B74745D545420363E01
VCID: 2B02F06143890EDF4FB-807E
Component: ELV-MQBA H01 0120
Revision: 00000000 Serial number: 14000155014002
Coding: 5500000000000000
ROD: EV_ELVMarquMQB.rod
VCID: 3430EB1D9EB751271E1-8060
Part No SW: 5Q4 959 593 B HW: 5Q4 959 593 B
Component: TSG FS 009 0014
Serial number: 0000108803497
Coding: 00150020D000040000001100
Serial number: 00000000000003021067
Coding: 010200
Part No SW: 5Q0 909 144 P HW: 5Q0 909 144 P
Component: EPS_MQB_ZFLS 123 1043
Coding: 0102
ROD: EV_SteerAssisMQB_010.rod
VCID: 41DEB2C9D105F48F857-8014
Part No SW: 5Q4 959 592 B HW: 5Q4 959 592 B
Component: TSG BFS 009 0014
Serial number: 0000108960853
VCID: 43D2B8C1CB19E69F97B-8016
Serial number: 00000000000003077930
Coding: 190200
Part No SW: 7P6 907 357 D HW: 7P6 907 357 A
Component: AFS-ECU H07 0090
Coding: 03DA02003F000000
VCID: 40D8B7CDDA0FFD878A9-8014
Subsystem 1 - Part No SW: 1T0 941 329 B HW: 1T0 941 329 B Labels: 3D0-941-329.CLB
Component: LeiMo links H06 0009
Coding: 3E0000
Subsystem 2 - Part No SW: 1T0 941 329 B HW: 1T0 941 329 B Labels: 3D0-941-329.CLB
Component: LeiMo rechts H06 0009
Coding: 3E0000
Address 5F: Information Electr. (J794) Labels:| 5E0-035-MIB-STD1.clb
Part No SW: 5E0 035 864 A HW: 5E0 035 864 A
Component: MU-S-N-ER 041 0435
Serial number: S3F02906140753
Coding: 03730101FF00000011110001000800002F0000840100010046
ROD: EV_MUStd4CPASE_VW37.rod
VCID: 25160659256D38AF99F-8070
Subsystem 1 - Part No SW: 5E0 919 605 D HW: 5E0 919 605 D
Component: ABT_Std_Nav H60 0030
Serial number: SKZ8Z9PT3002UF
Subsystem 2 - Part No SW: 5E0 051 236 E HW: -----------
Component: ECE 2014/15 --- 0040
