Results 1 to 4 of 4
Thread: Parking heater Climatronic settings. T6-California 2018
    Mar 2020
    Hi all, totally new here.
    Got my T6 California just 2 month ago, bought a HEX-V2 to do some changes like auto-lock and CH/LH on fogs.
    My question concerns the auxillary heater.
    I upgraded it to a parking heater using a plug and play solution. (https://www.cum-cartec-shop.de/VW-T6...Plug-Play.html)
    (It's a sort of Can-gateway)
    Everything works fine, exept
    1: The (fresh) air blower starts already 3 minutes after the heater starts
    2: The main problem: it starts with the Climatronic on Auto, 22deg, and blower on max., draining the battery.
    I read in a German forum that in some cars the Climatronic starts on the last used settings. Is this somehow posibble in VCDS?
    I would be nice if the blower starts at a certain water temperature, but that not the most important
    Thanks!
    Jaap
    Autoscan is added
    Thursday,19,March,2020,19:30:35:04391
    VIN: WV2ZZZ7HZJH0XXXXX   License Plate:
    Mileage: 24900km-15472mi   Repair Order:
    Chassis Type: 7H-VN75 (7E0)
    Scan: 01 03 04 08 09 10 13 14 15 17 18 19 25 3C 55 5F 61 69 0B
    VIN: WV2ZZZ7HZJH0XXXXX   Mileage: 24900km-15472miles
    Address 01: Engine (2D2D2-CXEB)       Labels:. 04L-907-309-V2.clb
       Part No SW: 04L 906 056 LB    HW: 04L 907 445 A
       Component: R4 2.0l BTD   H03 6177
       Revision: 23101001
       Coding: 0019401C435401080000
       Shop #: WSC 02739 790 50316
       ASAM Dataset: EV_ECM20BTD03004L906056LB 004008
       ROD: EV_ECM20BTD03004L906056KT.rod
       VCID: 78A9EEA1025259B7F15-802C
    Readiness: N/A
    Address 03: ABS Brakes (J104)       Labels: 7E0-907-37x-MK100ESC.clb
       Part No SW: 7E0 907 379 P    HW: 7E0 907 379 M
       Component: ESC           H06 0133
       Revision: 00000000    Serial number: 63157000001821
       Coding: 617E4098656B848086790278A68721D278F500
       ROD: EV_Brake1ESCCONTIVN75XGP2_011.rod
       VCID: 3FDB45BD67FCAE8FF0F-806A
       Component: LENKW.SENSOR  H07 0070
       Serial number: 10111713470690
       Coding: 01
       ROD: EV_LWSKLOVW25X.rod
       VCID: 7EA5F8B920766787BB9-802A
    Address 08: Auto HVAC (J255)       Labels:| 7E5-907-040.clb
       Part No SW: 7E0 907 040 R    HW: 7E0 907 040 R
       Component: ClimatronicT5 H04 0613
       Revision: 00001K04
       Coding: 0000018123
       ASAM Dataset: EV_ClimatronicT5 A01003
       ROD: EV_ClimaAutoT5Basis.rod
       VCID: 323D1C89A4AE73E70F1-8066
       Slave 1:
       Subsystem 1 - Part No SW: 7E0 907 049 A    HW: 7E0 907 049 A
       Component: Heckbedienung  H04 0044
       Serial number: PAG00227101700010113
    Address 09: Cent. Elect. (J519)       Labels:. 7E0-937-BCM-V1.clb
       Part No SW: 7E0 937 090 C    HW: 7E0 937 090 C
       Component: BCM PQ25 Max4 H82 0752
       Revision: B9082001    Serial number: 4000 317170381
       Coding: B8A839B84B61341293284F406D8B8BDCC094738960CD79703304003F0860
       Shop #: WSC 02739 534 196175
       VCID: 2B0301ED8304222F4C7-807E
       Subsystem 1 - Part No: 5K7 955 559 C  Labels: 5K7-955-559.CLB
       Component: RLS 251017 04  47  0106
       Coding: 0228DD
       Subsystem 2 - Part No SW: 7E0 959 801 N    HW: 7E0 959 801 N  Labels: 7E0-959-80X-V2.CLB
       Component: J386__TSG_FT  004 0653
       Serial number: KU0KU008111773121316
       Coding: 0400A1
       Subsystem 3 - Part No SW: 7E0 959 802 R    HW: 7E0 959 802 R  Labels: 7E0-959-80X-V2.CLB
       Component: J387__TSG_BT  005 0653
       Serial number: KU0KU001111773051090
       Coding: 1400A1
       Subsystem 4 - Part No: 7E1 951 172
       Subsystem 5 - Part No: 1K0 951 605 F
       Component: LIN BACKUP HO  H01 0008
       Subsystem 6 - Part No: 7E1 951 172
       Subsystem 7 - Part No SW: 7E0 959 442 A    HW: 7E0 959 442 A  Labels: 3C8-959-537.CLB
       Component: E221__MFL-DC1  H02 0103
       Serial number: 29170002189300077437
       Coding: B4FFFF
    Address 10: Park/Steer Assist (J446)       Labels:| 7E0-919-475.clb
       Part No SW: 7E0 919 475 AA    HW: 7N0 919 475
       Component: PARKHILFE 8K  H06 0212
       Revision: --------    Serial number: 28231729905015
       Coding: 31800C
       ASAM Dataset: EV_VW75XParkAssis8K 001012
       ROD: EV_VW75XParkAssis8K_001_VN75.rod
       VCID: 71BFD385612808FF36B-8024
    Address 13: Auto Dist. Reg (J428)       Labels:| 7N0-907-572.clb
       Part No SW: 7N0 907 572 C    HW: 7E0 907 572
       Component: ACC Bosch PQx H03 0211
       Serial number: 1411170440AAE5
       Coding: 00004800FE0779
       Shop #: WSC 01383 790 50316
       ASAM Dataset: EV_ACCBEGVW361 001006
       ROD: EV_ACCBEGVW361_VW32.rod
       VCID: 3635209948C66FC7239-8062
       Revision: 00000000    Serial number: 16101700550001
       Coding: 000180
       Shop #: WSC 02759 790 00000
       VCID: 270BFDDD9FEC064FA8F-8072
       Part No SW: 7E0 959 655 H    HW: 7E0 959 655 H
       Component: VW10Airbag01R H08 0018
       Revision: --------    Serial number: 003V40041527
       Coding: 000000000000000000000000000000003152
       Shop #: WSC 02734 790 50316
       ASAM Dataset: EV_AirbaVW10BPAVW12X 001028
       VCID: 3B2331AD73E4B2AFDC7-806E
       Serial number: 3495ZRB400I5BMP6P9BF
       Serial number: 3505ZRB400I5BMP699P5
       Part No SW: 7E0 920 880 S    HW: 7E0 920 880 S
       Component: KOMBI         H04 1109
       Coding: 140F010300
       ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A05733
       VCID: 3A2D34A97CDE8BA7C71-806E
    Address 18: Aux. Heat (J364)       Labels:| 7E0-963-27X-18.clb
       Part No SW: 7E0 963 273 A    HW: 7E0 963 273 A
       Component: STH-T5GP2     003 0009
       Coding: 4101
       ASAM Dataset: EV_AuxilParkiHeateWOST5G2 001013
       ROD: EV_AuxilParkiHeateWOST5G2.rod
       VCID: 2B0301ED8384222F4C7-807E
    Address 19: CAN Gateway (J533)       Labels:. 7E0-909-901.clb
       Part No SW: 7E0 909 901     HW: 7E0 937 090 C
       Component: GW-K-CAN TP20 H82 0752
       Revision: B9082001
       Coding: 04220F
       VCID: 6889BEE15272C937615-803C
       Component: IMMO          H04 1109
       VCID: 6A8DC4E94CFEFB27771-803E
       Part No SW: 7E0 907 566 C    HW: 4H0 907 566 F
       Component: SWA Master    H08 0030
       Serial number: 0459912795
       Coding: 030321
       ROD: EV_LaneChangAssis_VN75.rod
       VCID: 30391681AAA241F7795-8064
       Lane Change Assistant 2:
       Subsystem 1 - Part No SW: 7E0 907 568 C    HW: 4H0 907 568 F
       Component: SWA Slave  H08 0030
       Serial number: 0457529406
       Coding: 030321
    Address 55: Headlight Range (J431)       Labels:. 6R0-907-357.clb
       Part No SW: 6R0 907 357 C    HW: 6R0 907 357 B
       Component: AFS-ECU       005 0050
       Coding: 0FC2020001000000
       Shop #: WSC 02757 790 50316
       ASAM Dataset: EV_HeadlRegulVWLWRCC 002006
       ROD: EV_HeadlRegulVWLWRCC.rod
       Part No SW: 5C0 035 680 G    HW: 5C0 035 680 G
       Component: MU-S-ND-ER    H41 0468
       Serial number: VWZAZ2T5464584
       Coding: 06570001FF00000011111101008808031F0100D4002001004F
       ROD: EV_MUStd4CTSAT_VW36.rod
       VCID: 2517F7D5E560145F9A3-8070
       Subsystem 1 - Part No SW: 5NA 919 866 AR    HW: -----------
       Component: ECE AS 20/21  --- 1430
       Part No SW: 7E0 907 534     HW: 7E0 937 090 C
       Component: Batt.regelung H82 0752
       Coding: 530B1A73
       Shop #: WSC 02739 790 00000
       Subsystem 1 - Part No SW: 7E0 915 181 K    HW: 7E0 915 181 K
       Serial number: 758857000017103102F2
       Part No SW: 1K0 907 383 H    HW: 1K0 907 383 G
       Component: Anhaenger     H12 0130
       Revision: 3B001001    Serial number: 00000459581863
       Coding: 410D000103000000
       VCID: 323D1C89A42E73E70F1-8066
    Address 0B: Sec. Air Heating        Labels: None
       Part No: 7E0 819 006 M
       Component: J604  Standheizung  0401
       Revision: L100400A    Serial number: 00000000000000
       VCID: 313F1385AD3848FF76B-513C
    End----------(Elapsed Time: 02:21, VBatt start/end: 12.2V/12.1V)-----------
    I don't see anything like that in your 08-HVAC, but in 18-Aux Heater, there should be an Adaptation Channel that might be interesting to look at:
    IDE06691-MAS05069 -- Parking heat control parameters - Temperature threshold for activation of fresh air blower (C)
    Mar 2020
    Thanks Uwe,
    I saw that, will try to change the temperature and see what happens.
    I noticed settings for heated seats and recirculation where last settings can be stored.
    Was hoping this exists also for the blower.
    Jaap
    Mar 2020
    Unfortunately, this didn't change the behaviour.
    Climatronic still starts after 3 minutes, 22degr, blower on 4.
    As the auxillary heater is switched on through his sevice channel, I assume there must be an adaptation in the Can Bus. But I can't find it
    Jaap
