Chassis Type: AA-VW12 (6N0)
Scan: 01 03 09 10 13 15 17 19 25 44 56 AD
VIN: TMBZZZAAZCD604647   Mileage: 132920km-82592miles
AD-Brake Sensors -- Status: OK 0000
Address 01: Engine (J623-CHYA)       Labels:. 04C-906-020-CHY.clb
   Part No SW: 04C 906 020 K    HW: 04C 907 309 D
   Component: 1.0l R3 MPI   H01 6470
   Revision: U7H01---    Serial number:
   Coding: 00110012022400000000
   Shop #: WSC 44028 000 1048576
   ASAM Dataset: EV_ECM10MPI01104C906020K 001010
   ROD: EV_ECM10MPI01104C906020.rod
   VCID: 231218412B59C69FF47-8076
Readiness: 0010 0101
Address 03: ABS Brakes (J104)       Labels: 1S0-614-517.clb
   Part No SW: 1S0 614 517 C    HW: 1S0 614 517 C
   Component: EBC 460 ESP   H08 0004
   Serial number: 0102923
   Coding: 32BF247189AD02F54C0024F991B0404058B000
   Shop #: WSC 31414 790 00001
   ASAM Dataset: EV_Brake1UDSESP 015024
   ROD: EV_Brake1UDSESP.rod
   VCID: 2F3AE471779172FF60F-807A
Address 09: Cent. Elect. (J519)       Labels:. 1S0-937-09x-V1.clb
   Part No SW: 1S0 937 087     HW: 1S0 937 087
   Component: PQ25 BCM      H57 0512
   Revision: -9------    Serial number: 1009069000
   Coding: 24B8290000010000000000042C28ACD000C0400C60020000200000420100
   VCID: 76B41115C8CB0337E39-8022
                    Reset counter: 165
                    Mileage: 132922 km
                    Date: 2014.08.07
                    Time: 20:50:39
Address 10: Park/Steer Assist (J446)       Labels:| 1Sx-919-475.clb
   Part No SW: 1ST 919 475     HW: 1Q0 919 475
   Component: PARKHILFE 3K  H03 0005
   Revision: --------    Serial number: 32961210101054
   Coding: 100001
   ASAM Dataset: EV_EPHVA14SK1200000 001001
   ROD: EV_EPHVA14SK1200000.rod
   VCID: 1B6220A11329FE5F3C7-804E
   Part No SW: 1S0 959 655     HW: 1S0 959 655
   Component: VW10Airbag009 H03 0005
   Revision: --------    Serial number: 003G3002872+
   ASAM Dataset: EV_AirbaVW10BPAVW12X 001001
   VCID: 7BA20021F3695E5F9C7-802E
   Serial number: 3575HRB405D1AP5S79Q-
   Serial number: 3585HRB405J1BBH28HBA
   Serial number: 3555NRB40064UFMUB1TG
9445417 - Key switch for deactivation of passenger-side airbag
          B1020 29 [137] - Signal Implausible
                    Fault Frequency: 18
                    Mileage: 132922 km
                    Date: 2020.03.16
                    Time: 21:12:21
Address 17: Instruments (J285)       Labels:| 1Sx-920-xxx-17.clb-SRI1
   Part No SW: 1ST 920 860 E    HW: 1ST 920 860 E
   Component: KOMBI         H08 0021
   Revision: X0008006    Serial number: 00000000000000
   Coding: 114A00
   ASAM Dataset: EV_KombiUDSMM9RM10 A04708
   ROD: EV_KombiUDSMM9RM10_A04_VW12.rod
   VCID: 56F47195288B6337C39-8002
   Part No SW: 6N0 909 901     HW: 1S0 937 087
   Component: GW-K-CAN TP20 H57 0512
   Revision: -9------
   Coding: 031000
   VCID: 70B8270DAAAF2D07395-8024
Address 25: Immobilizer (J334)       Labels:. 5K0-920-xxx-25.clb
   Part No SW: 5K0 953 234     HW: 1ST 920 860 E
   Component: IMMO          H08 0021
   ASAM Dataset: EV_ImmoUDSMM9RM10 A01702
   ROD: EV_ImmoUDSMM9RM10_VW12.rod
   VCID: 6A8C35658CF3D7D7771-803E
Address 44: Steering Assist (J792)       Labels:| 1Sx-909-144-44.clb
   Part No SW: 1S1 909 144 G    HW: 1S1 909 144 G
   Component: EPS_ECU       H30 1503
   Coding: 0001000101000000
   ASAM Dataset: EV_SteerAssisNSK 009004
   ROD: EV_SteerAssisNSK_009.rod
   VCID: 372ADC118FC1BA3F38F-8062
   Part No SW: 1ST 035 156     HW: 1ST 035 156
   Component: Radio         H35 0045
   Revision: R0000000    Serial number: SKZAZ1M2928676
   Coding: 0000020801
   VCID: 0C4053FDA64769E7A5D-8058
Address AD: Brake Sensors (J939)       Labels: 1S0-907-201.clb
   Part No SW: 1S0 907 201     HW: 1S0 907 201
   Component: CV-SENSOR     H06 0450
   ASAM Dataset: EV_CVSen 001001
   ROD: EV_CVSen.rod
   VCID: 678A4C519FE1EABF68F-8032
0004 - Function Restricted due to Insufficient Voltage
          U1400 00 [008] - -
                    Reset counter: 165
                    Mileage: 132919 km
                    Date: 2020.03.14
                    Time: 01:31:52
End----------(Elapsed Time: 00:45, VBatt start/end: 12.2V/12.2V)-----------
