Chassis Type: NP-SK48 (5Q0)
Scan: 01 02 03 05 08 09 10 13 14 15 16 17 19 2B 36 42 44 52 55 5F
          6D A5 BB BC
VIN: TMBJH9NP9H7502063   Mileage: 119425km-74207miles
Address 01: Engine (J623-CRLB)       Labels:. 04L-907-309-V1.clb
   Part No SW: 04L 906 026 ET    HW: 04L 907 309 R
   Component: R4 2.0l TDI   H23 1990
   Revision: B5H23---
   Coding: 011D0012036401087000
   Shop #: WSC 33361 790 00143
   ASAM Dataset: EV_ECM20TDI01104L906026ET 002002
   ROD: EV_ECM20TDI01104L906026ET_002_SK48.rod
   VCID: 005877CD9A8F3D87C95-8054
18109 - Oxygen (Lambda) Sensor B1 S1: Heating Circuit
          P0031 00 [032] - Short to Ground
                    Mileage: 119397 km
                    Date: 2020.03.11
                    Time: 12:53:24
                    Coolant temperature: 24 °C
                    Intake air temperature: 20 °C
                    Voltage terminal 30: 10.120 V
                    Oxyg.sens.bank 1 before oxi cat: sign. qual. pump curr.regul.: 13
                    Oxyg.sensor bank 1 before oxi cat: signal quality temp regulat.: 13
                    O2 sen. bank 1 upstrm oxi cat: elec. correct. pump current: 0.0000000 A
                    Oxygen sensor bank 1 before oxi cat: heater activation: 0.000 %
                    Oxygen sensor bank 1 before oxi cat: adjustable resistor: 0.0 Ohm
                    Oxyg.sensor bank 1 before oxi cat: curr.pump curr.adaptation: 1.0100
20000 - Oxygen (Lambda) Sensor B1 S2: Heating Circuit
          P0037 00 [032] - Short to Ground
                    Mileage: 119397 km
                    Date: 2020.03.11
                    Time: 12:53:24
                    Oxyg.sens.bank 1 after oxi cat: signal qual.pump current regul.: 13
                    Oxyg.sensor bank 1 after oxi cat: signal quality temp regulator: 13
                    O2 bank 1 dwnstrm. of oxi cat: elec. corrected pump current: 0.0000000 A
                    Oxygen sensor bank 1 after oxi cat: heater activation: 0.000 %
                    O2 sensor bank 1 dwnstrm oxi cat: adjustable resistor value: 0.0 Ohm
                    Oxyg.sens.bank 1 after oxi cat: curr.pump curr.adaptat.: 1.0222
20001 - Oxygen (Lambda) Sensor B1 S2: Heating Circuit
          P0036 00 [032] - Malfunction / Open Circuit
                    Mileage: 119397 km
                    Date: 2020.03.11
                    Time: 12:53:24
                    Voltage terminal 30: 9.980 V
                    Oxyg.sens.bank 1 after oxi cat: signal qual.pump current regul.: 14
4631 - ECM Power Relay Load Circuit
          P068B 00 [032] - Opens Too Late
   Part No SW: 0D9 300 041 H    HW: 02E 927 770 AQ
   Component: DQ250-6F MQB  H54 4905
   Revision: 06354004    Serial number: TFK01607121419
   ROD: EV_TCMDQ250021.rod
   VCID: 1D662EB90D3DF06FC23-8048
   Part No SW: 5Q0 614 517 BK    HW: 5Q0 614 517 AH
   Component: ESC           H62 0736
   Revision: 00000000    Serial number: 62116000000877
   Coding: 1E076A9C34200B6E4777060641C64978562CD0E2608292751861F0F8C20202
   ROD: EV_Brake1UDSContiMK100IPB_035_SK48.rod
   VCID: 7BA20021F3695E5F9C7-802E
16401 - Tire Pressure Warning
          C102D 00 [008] - -
                    Reset counter: 122
                    Mileage: 116497 km
                    Date: 2020.01.22
                    Time: 14:32:35
   Part No SW: 3Q0 959 435 E    HW: 3Q0 959 435 E
   Component: VWKESSYMQB    036 0811
   Revision: 00036000    Serial number: 0413452209
   Coding: 032C0C0F03
   VCID: 3C20C33DB6E79967D5D-8068
   Subsystem 1 - Part No SW: 3AA 962 243 G    HW: 3AA 962 243 G
   Component: GEB.F.Heckoef  H16 0903
   Serial number: 84417299
          U1400 00 [008] - -
                    Fault Frequency: 37
                    Reset counter: 154
                    Mileage: 114518 km
                    Date: 2019.12.29
                    Time: 09:14:07
                    ZAT_pressed: OFF
                    Park selector lever position: Not engaged and not locked
                    Control Module Voltage: 8.971 V
                    Vehicle speed: 0.0 km/h
                    Engine speed: 125.0 /min
                    Coding information: coded
                    Coding information: Not coded
                    Driver door: closed
                    Front Passenger Door: closed
                    Left rear door: closed
                    Right rear door: closed
                    Active_LF_scans: Init
                    SPN_Byte 0: 00
                    SPN_Byte 1: 00
                    SPN_Byte 2: 00
133124 - Databus
          [Message Klemmen_status_01 missing]
                    Reset counter: 151
                    Mileage: 115866 km
                    Date: 2020.01.21
                    Time: 11:09:03
                    Terminal_15_Kessy_specified_value: OFF
                    Terminal_15_Kessy_actual_value: OFF
                    Terminal_15_central electric_actual_value: Timeout
                    Terminal_15red_Kessy_specified_value: OFF
                    Terminal_15red_Kessy_actual_value: OFF
                    Terminal_S_Kessy_specified_value: OFF
                    Terminal_S_Kessy_actual_value: OFF
                    Terminal_S_central electric_actual_value: Timeout
                    Terminal_50_Kessy_specified_value: On
                    Terminal_50_Kessy_actual_value: On
                    ZAT_pressed: On
                    Request active: Condition met
                    Enabling immobilizer: Condition not met
                    Control Module Voltage: 11.822 V
                    Engine speed: 0.0 /min
                    Driver door: Open
                    Active_LF_scans: GO_Scan_1
                    SPN_Byte 0: 00
                    SPN_Byte 1: 00
                    SPN_Byte 2: 00
   Part No SW: 3V0 907 044 BC    HW: 3V0 907 044 BC
   Component: AC Automat    H34 4003
   Revision: 20K06000    Serial number: 00000B00195663
   Coding: 1201010400211001100510000010100A
   ASAM Dataset: EV_ACClimaPrehVW37X 002014
   ROD: EV_ACClimaPrehVW37X.rod
   VCID: 76B41115C84B0337E39-8022
   Subsystem 1 - Part No SW: 3V0 907 049 B    HW: 3V0 907 049 B
   Component: E265KlimaHeck  H02 0101
   Serial number: 00000000000000000000
263425 - Air Quality Sensor
          B10AF 04 [008] - Internal System Fault
                    Fault Frequency: 59
                    Reset counter: 154
                    Mileage: 114127 km
                    Date: 2019.12.22
                    Time: 14:38:23
                    Outside air temperature: 14.0 °C
                    Voltage terminal 30: 13.3 V
                    System run time-Engine running time: 253 s
                    System run time-Terminal 15 on: 253 s
                    Air quality status: ERROR
393474 - Air Blower
          B10BE 1D [008] - Current Implausible
          [ZSB Gebläse/Regler (LIN) - Gebläsereglerstatus - Kurzschluss oder blockiert]
                    Reset counter: 153
                    Mileage: 119397 km
                    Date: 2020.03.11
                    Time: 12:53:09
                    Voltage terminal 30: 10.6 V
                    Interior temperature: 16.7 °C
                    Blower voltage: specified value: 0.0 V
                    Blower voltage: actual value: 25.4 V
1048836 - Blower Output Reduction due to Energy Management
          B10CE 00 [008] - -
                    Reset counter: 154
                    Mileage: 119425 km
                    Date: 2020.03.12
                    Time: 15:37:59
                    Voltage terminal 30: 11.2 V
                    Blower reduction: No switch-off: no reduction
          P1719 00 [008] - -
          [PTC-Reduzierung durch MSG]
                    Fault Frequency: 75
                    Reset counter: 152
                    Mileage: 114225 km
                    Date: 2019.12.25
                    Time: 20:27:56
                    Voltage terminal 30: 14.5 V
                    Auxiliary heater: in stages-Act.val.: 2
   Serial number: 02001621704183
   ROD: EV_BCMBOSCH_017.rod
   VCID: 7EA40935E07B4B77BB9-802A
   Subsystem 1 - Part No SW: 3V1 955 119     HW: 3V1 955 119   Labels: 5QX-955-119-V1.CLB
   Component: 48x LL 160712  032 0121
   Serial number: 00000001607110300993
   Coding: 165DDD
   Component: RLHS  042 0105
   Serial number: S3Y16M08D06H02M40S46
   Coding: 00084D
   Serial number: 000000000ZY161961C8L
   Serial number: 00000000000035828226
0531 - Footwell Illumination
          B11FF 01 [008] - Electrical Failure
                    Fault Frequency: 68
                    Reset counter: 122
                    Mileage: 115915 km
                    Date: 2020.01.22
                    Time: 07:29:49
   Part No SW: 5Q0 919 294 L    HW: 5Q0 919 294 A
   Component: PARKHILFE 8K  H03 0056
   Revision: --------    Serial number: 39331621809194
   Coding: 0071051851
   VCID: 44D0BBDDCE17E1A7ADD-8010
   Component: ACC BOSCH MQB H04 0194
   Coding: 320067C251FFC428949C8045
   ROD: EV_ACCBOSCHVW48X.rod
   VCID: 3430EB1D9EB751271DD-8060
2072 - Databus
          [FAULT_DRIVER_DOOR_STATE_INIT]
                    Reset counter: 153
                    Mileage: 119397 km
                    Date: 2020.03.11
                    Time: 12:53:15
                    Control Module temperature: 18 °C
                    Voltage terminal 15: 10.6 V
                    Longitudinal_acceleration_vehicle_reference: 0.00 m/s˛
1236 - Databus
          [FAULT_TIMEOUT_BV1_POSITION]
                    Fault Frequency: 19
                    Reset counter: 153
                    Mileage: 114378 km
                    Date: 2019.12.26
                    Time: 17:40:55
                    Control Module temperature: 22 °C
                    Voltage terminal 15: 13.3 V
                    Velocity_vehicle_reference: 6.59 m/s
                    Longitudinal_acceleration_vehicle_reference: 0.09 m/s˛
1389 - Function Restricted due to Insufficient Voltage
          U1400 00 [008] - -
          [FAULT_VBAT_BUSMON_LOW]
                    Reset counter: 154
                    Mileage: 119425 km
                    Date: 2020.03.13
                    Time: 15:39:15
                    Voltage terminal 15: 10.0 V
   Serial number: 26071641350382
   ROD: EV_DRCONTITEMIC_VW37.rod
   VCID: 3828DF2D82DFB547315-806C
   Part No SW: 5Q0 959 655 AE    HW: 5Q0 959 655 AE
   Component: AirbagVW21    005 0130
   Serial number: 003NSR20G2KZ
   Coding: 98FCC0C0000000005C5400CF004800000065
   ASAM Dataset: EV_AirbaVW20SMEVW37X 002146
   ROD: EV_AirbaVW20SMEVW37X.rod
   VCID: 035278C18B99269FD47-8056
   Subsystem 1 - Part No SW: -----------    HW: 480 000 508 16
   Serial number: 35700000000A39155D1J
   Subsystem 2 - Part No SW: -----------    HW: 480 000 508 16
   Serial number: 35800000000339155D1D
   Subsystem 3 - Part No SW: -----------    HW: 480 402 607 16
   Serial number: 3510002AD2095075A18
   Subsystem 4 - Part No SW: -----------    HW: 480 401 807 16
   Serial number: 3520002A7211FA34928+
   Subsystem 5 - Part No SW: -----------    HW: 480 402 607 16
   Serial number: 3550002AD2095071415T
   Part No SW: 3Q0 953 521 EF    HW: 5Q0 953 569 A
   Revision: FF035035    Serial number: 20160818500913
   Coding: 6410
   ROD: EV_SMLSVALEOMQB.rod
   VCID: 78A81F2DC25F7547F15-802C
   Part No SW: 3V0 920 751 A    HW: 3V0 920 751 A
   Component: KOMBI         304 8311
   Coding: 07A5091A3F84000801886B011000000000000000
   Shop #: WSC 73430 031 00143
   ROD: EV_DashBoardVDDMQBAB_SK48.rod
   VCID: 323CED0564A35F170F1-8066
   Revision: --------    Serial number: 13081610800444
   Coding: 030100045F087300EB00025A9C0F00010001070000000000000000000000
   Shop #: WSC 33361 790 00132
   ROD: EV_GatewConti_013.rod
   VCID: 7CA0033DF667596795D-8028
   Subsystem 2 - Part No SW: 3V0 919 719 A    HW: 3V0 919 719 A
   Component: E221__MFL-PR6  H02 0150
   Serial number: 000000000A0234080816
   Serial number: 2208830604
   Serial number: 16000167110009
   Coding: 0800000000000000
   ROD: EV_ELVMarquMQBB.rod
   VCID: 71BE2209A125240F36B-8024
   Component: Sitzmemory    H08 0020
   Serial number: Y0006PH912130
   Coding: 0010000000000500018280808080000000008181000000D400
          U1400 00 [008] - -
          [Funktionseinschränkung durch Unterspannung --> funktionelle Einschränkungen aufgrund vorübergehender Unterspannung in der Versorgung.]
                    Reset counter: 126
                    Mileage: 117856 km
                    Date: 2020.02.04
                    Time: 17:50:01
   Serial number: 0000214006273
   Coding: 001D0820DE00040000001100
   VCID: 47CAACD1FF21CABF48F-8012
   Part No SW: 5Q0 909 143 M    HW: 5Q0 909 143 E
   Component: MQB_PP_APA    204 2041
   Revision: 00000000    Serial number: 0000963591
   Coding: 01000010005001
   ASAM Dataset: EV_SteerAssisVWBSMQBA 008028
   ROD: EV_SteerAssisVWBSMQBA_008_VW41.rod
   VCID: 3D26CE39ADFD906FE23-8068
   Serial number: 0000213518499
   Coding: 001D0220DE00040000001100
   VCID: 46D4A1D5F82BD3B7B39-8012
          B122D 29 [009] - Signal Implausible
                    Reset counter: 50
                    Mileage: 114011 km
                    Date: 2019.12.20
                    Time: 15:13:20
   Coding: 06D202003F010000
   VCID: 40D8B7CDDA0FFD87895-8014
   Subsystem 1 - Part No SW: 8U0 941 329     HW: 8U0 941 329   Labels: 3D0-941-329.CLB
   Component: LeiMo links  H01 0006
   Coding: B20000
   Subsystem 2 - Part No SW: 8U0 941 329     HW: 8U0 941 329   Labels: 3D0-941-329.CLB
   Component: LeiMo rechts  H01 0006
   Coding: B20000
Address 5F: Information Electr. (J794)       Labels:| 3V0-035-MIB-HGH2.clb
   Part No SW: 3V0 035 043 C    HW: 3V0 035 043
   Component: MU-H-N-EU     H50 0702
   Serial number: A677G0G7502292
   Coding: 03840201FF0000005111000100000A002F0100C4012001009E
   VCID: 2B02F06143890EDF4C7-807E
   Subsystem 1 - Part No SW: 3V0 919 606     HW: 3V0 919 606
   Component: ABT_High-2  H47 1031
   Serial number: SKZ8Z9SLU009EJ
   Subsystem 2 - Part No SW: V03 959 801 JL    HW: -----------
   Component: ECE 2016/2017  --- 0153
   Component: Gracenote2---  --- 1013
   Part No SW: 5Q0 959 107 J    HW: 5Q0 959 107 J
   Component: HDSG-Modul    H13 0253
   Revision: --------    Serial number: 30866093400000
   Coding: 0D08
   ASAM Dataset: EV_DeckLidCONTIAU736 001012
   ROD: EV_DeckLidCONTIAU736_AU73.rod
   VCID: 3FDAB431A7F1827FF0F-806A
   Part No SW: 3Q0 980 654 F    HW: 3Q0 980 654
   Component: MQB_B_MFK     H04 0220
   Serial number: 05081611K22299
   Coding: 0204080200000401002223448050A10010000E100020
   VCID: 3A2CC525BCD3A757C71-806E
1275 - Unknown Error Code
          B182E F0 [024] - Unknown Error Elaboration
          Intermittent - Confirmed - Not Tested Since Memory Clear
                    Reset counter: 113
                    Mileage: 114063 km
                    Date: 2019.12.22
                    Time: 11:44:35
                    Outside air temperature: 10.5 °C
                    Vehicle speed: 38.25 km/h
                    System run time: 192.4 s
                    Voltage terminal 15: 14.4 V
                    mid: 01 62
                    Status of camera: operational
                    Engine_Running_Info: 1
                    Software_Info_4: 0
                    Software_Info_3: 2
                    Software_Info_2: 2
                    Software_Info_1: 0
   Part No SW: 5Q4 959 395 E    HW: 5Q4 959 395 B
   Component: TSG HFS       011 0031
   Serial number: 0000213773012
   Coding: 001800208000040000001100
   ASAM Dataset: EV_DCURearDriveMAXCONT 006001
   Component: TSG HBFS      011 0031
   Serial number: 0000213778808
   ASAM Dataset: EV_DCURearPasseMAXCONT 006001
End----------(Elapsed Time: 02:33, VBatt start/end: 13.8V/13.9V)-----------
