Results 1 to 4 of 4
Thread: Audi A5 2011 power steering problem. end stops not learned
    Jan 2020
    Hi guys my audi a5 have got a problem with the steering it won't learn the end stops. I had to replace the rack due to issue. It's now got the original controller on a new rack of the same part number here is the log, any help appreciated
    Saturday,21,March,2020,12:19:47:57353
    VCDS Version: 19.6.2.2 (x64)
    VIN: WAUZZZ8T8CA015129   License Plate: YF61 HJD
    Mileage: 181570km-112822mi   Repair Order:
    Chassis Type: 8T-AU48 (8R0)
    Scan: 01 02 03 05 06 08 09 15 16 17 19 20 36 42 44 46 47 52 53 56
              5F 6C
    VIN: WAUZZZ8T8CA015129   Mileage: 181570km-112822miles
    Address 01: Engine (J623-CDUC)       Labels:. 059-907-401-V2.clb
       Part No SW: 8K5 907 401 A    HW: 4G0 907 401
       Component: 3.0TDI EDC17  H37 0001
       Revision: 53H37---
       Coding: 1A254012042703020000
       Shop #: WSC 06324 000 00000
       ASAM Dataset: EV_ECM30TDI0118K5907401A 001005
       ROD: EV_ECM30TDI0118K5907401A.rod
       VCID: 2E532EB271F74C3F07-807A
       Part No SW: 8K1 927 156 Q    HW: 0B5 927 156 F
       Component: 0B5 30 TDIRdW H10 0007
       Revision: --H10---    Serial number: 0000001813
       Coding: 000001
       Shop #: WSC 06325 000 00000
       ASAM Dataset: EV_TCMDL501 A02196
       ROD: EV_TCMDL501.rod
       VCID: 43856F06CA75D157F8-8016
       Part No SW: 8K0 907 379 BS    HW: 8K0 907 379 BS
       Component: ESP8 quattro  H09 0090
       Coding: 391D4C
       VCID: 0B158726AAA55917C0-805E
       Part No SW: 8K0 907 064 EF    HW: 8K0 907 064 EF
       Component: BCM2 2.0      H10 0530
       Coding: 05B00000000000000000
       VCID: 78FFC8EACB33428F9D-802C
       Component: J764 ELV MLB  H39 0046
       Serial number: 2311000242204007
       Part No SW: 8T0 959 760 E    HW: 8T0 959 760 E
       Component: MEM-BFS       H10 0076
       Revision: AA000000    Serial number: 00000017835494
       Coding: 09237025002400001000
       VCID: 4581711ECC41EF67D6-8010
       Part No SW: 8K2 820 043 N    HW: 8K2 820 043 N
       Revision: D1000000    Serial number: 01011120111312
       Coding: 3626028000
       VCID: 34673CDA97DB66EF71-8060
       Part No SW: 8K0 907 063 DH    HW: 8K0 907 063 AH
       Component: BCM1 1.0      H14 0103
       Revision: 08014001    Serial number: 00000018692402
       Coding: 260000108074AF800081400300001D0D401D438827090201000008000400030100000034000000
       Shop #: WSC 61962 123 104857
       Subsystem 1 - Part No SW: 8T2 955 119 D    HW: 8J2 955 119   Labels: 1KX-955-119.CLB
       Component: WWS 061111  H13 0070
       Serial number: SWF11110065166
       Coding: 00FD11
       Component: G397_RLFS  H06 0001
       Serial number: 10034223
       Coding: 02005D
       Component: E1 - LDS  H03 0031
       Serial number: 00000000002810111018
       Serial number: DC18C6D5000000000001
       Component: AirbagVW-AU10 H44 0610
       Serial number: 003KFD809EGC
       Coding: 30533933363030303030554A305238543053
       VCID: 489F782AF353F20F2D-801C
       Serial number: 6334MSME67122305%
       Serial number: 6344MSME67062211%
       Serial number: 6352QSME3E5E154E.
       Serial number: 6362QSME405E2D56R
       Serial number: 63732SME63611958
       Serial number: 63832SME5B611A40
       Part No SW: 8R0 953 568 Q    HW: 8R0 953 568 Q
       Component: Lenks.Modul   H02 0171
       Revision: 00000000    Serial number: 20111109001207
       Coding: 000036
       VCID: 4FAD53361E3D25376C-801A
       Component: E221 - MFL  H03 0003
                014 - Defective
                        Fault Status: 01101110
                        Mileage: 89207 km
                        Date: 2015.10.03
                        Time: 12:34:45
                        Voltage: 14.60 V
                        Hex Value: 0x32A0
                        Speed: 9.0 km/h
                        Steering Angle: -221.46°
       Part No SW: 8T0 920 982 F    HW: 8T0 920 982 F
       Component: KOMBIINSTR.   H23 0639
       Revision: 00000000    Serial number: JS531HWAC
       Coding: 2327010003012600010000
       Shop #: WSC 06325 123 12345
       VCID: 408F600AD363CA4FE5-8014
       Part No SW: 8R0 907 468 D    HW: 8R0 907 468 D
       Component: GW-BEM 5CAN-M H10 0025
       Revision: 1Z070014    Serial number: 1441Z11A200107
       Coding: 00CF07FF00
       Component: J367-BDM  H07 0141
       Serial number: 00000000003790874478
       Serial number: 11309000025011200410
       Revision: AA001002
       Coding: 02029864747464545425363E00
       VCID: 7CF7D4FAFF0B6EAFF9-8028
       Component: MEM-FS        H10 0076
       Revision: AA000000    Serial number: 00000018079339
       Part No SW: 8T0 959 793 G    HW: 8T0 959 793 G
       Component: TSG FA        H09 0302
       Coding: 011012225001120102
       VCID: 4D91493E143117271E-8018
       Component: RCEPS         H36 0507
       Revision: 00001000    Serial number: 0009191216
       Coding: 000000000001
       Shop #: WSC 00046 123 12345
       ROD: EV_RCEPSAU48X_008.rod
       VCID: 34673CDA9FDB66EF71-8060
    5242881 - Regulation Limit Exceeded
              C10F2 F0 [137] - Unknown Error Elaboration
                        Reset counter: 233
                        Mileage: 181578 km
                        Date: 2020.03.21
                        Time: 12:14:30
                        Write only channel
    4207936 - Steering Angle Value
              C10C9 29 [137] - Signal Implausible
                        Reset counter: 233
                        Mileage: 181578 km
                        Date: 2020.03.21
                        Time: 12:14:30
                        Write only channel
                        Reset counter: 233
                        Mileage: 181578 km
                        Date: 2020.03.21
                        Time: 12:14:23
                        Write only channel
       Revision: 00002001    Serial number: 0162370339
       Coding: 011F0E8200B900818020003680000000
       Component: DSP Prem      H04 0030
       Revision: 00001001    Serial number: 94812000505204
       VCID: 2D5129BE74F137273E-8078
       Part No SW: 8T0 959 792 G    HW: 8T0 959 792 G
       Component: TSG BF        H09 0302
       Coding: 011012225C01120102
       VCID: 4C97443AEF2B1E2F09-8018
       Part No SW: 8K0 907 801 J    HW: 8K0 907 801 J
       Component: EPB-4         H01 0001
       Revision: --------    Serial number: 30000000003599
       ROD: EV_ParkiBrake_AU48.rod
       VCID: 366306D289A774FF4F-8062
       Part No SW: 4G1 035 053 E    HW: 4G1 035 053
       Component: Radio U Basic H41 0093
       Revision: AB001007    Serial number: 227J 0B7502862
       Coding: 010003010000000001
       VCID: 2149C58E3829E3478A-8074
       Part No SW: 8R2 035 670 A    HW: 8R2 035 670
       Component: H-BNT-EU      H42 0467
       Revision: --------    Serial number: 068JS0B7501013
       Coding: 130101020306A1FF41A08F5E00000403040000000100000000
       VCID: 326B3AC26DCF68DF63-8066
       Subsystem 1 - Part No: 8R0 060 884 AH
       Component: EUR 2012  1308
       Component: DU7 High  H41 0104
       Serial number: A130JG0BS048972
       Subsystem 3 - Part No SW: 8T0 919 611 C    HW: 8T0 919 611 C
       Component: E0380 Bedient  H02 0020
       Serial number: 00000000978452
       Component: CD-Database  3638
                        Reset counter: 233
                        Mileage: 181578 km
                        Date: 2020.03.21
                        Time: 12:13:26
                        Bin. Bits: 00000000 00000000
                        Bin. Bits: 00000000 00000001
       Revision: --H05---    Serial number: 525PA8-J1493G5
       Coding: 1020008
       Shop #: WSC 23312 002 1048576
       VCID: 387F08EA4BB3828F5D-806C
    End-------------------------(Elapsed Time: 03:31)--------------------------
    Have you looked at the values from the steering angle sensor?
    I suspect the rack isn't properly centered.
    Jan 2020
    I will have a look and let you know
    Jan 2020
    (Engine running)Okay so the steering angle reads but when turn and it gets to like 100 degrees it reads zero then if you turn the engine and ignition off and then start, it reads correct again then when you turn it will get to another angle let’s say 200deg and then reads zero again..
    So the sensor is intermittent for some reason but I did have a problem with the j500 and re flashed so I will try another one I have that has the wrong hardware number and doesn’t let me code it, and I’ll see if that controller reads throughout the range
