Linde forklift
colin41
C?ID=242997
I have recently been helping a friend who works at forklifts with fault code clearing and injector coding.
which VCDS does no problems
my question is, is it possible to do DPF regens with VCDS?
he mentioned that the Linde diagnostics can do this
Chassis Type: LF - Linde Fork Lifts (VW Diesel ONLY)
Scan: 01 25
Address 01: Engine (CPY)       Labels: Redir Fail!
   Part No SW: 03L 906 019 KS    HW: 03L 906 019 BA
   Component: R4 2,0L IMO 0000AG  0584
   Revision: 21H35---    Serial number: IIIIIIIIIIIIII
   Coding: 0031608
   Shop #: WSC 00017 780 00200
   VCID: 06040C4172CD3E7F9F-5120
               P0087 - 000 - Too Low
                    RPM: 1794 /min
                    Inj. Quantity: 15.1 mg/str
                    (no units): 5.0
                    Pressure: 1224.0 bar
                    Pressure: 832.0 bar
                    Temperature: 31.5°C
                    Tank Cont.: 0.0 l
054282 - Terminal 30
               U140A - 000 - Open Circuit - Intermittent
                    Voltage: 12.62 V
                    Temperature: -90.0°C
                    Absolute Pres.: 0.0 mbar
                    Torque: 0.0 Nm
Readiness: N/A
Jef
HQ
DPF regen? Hmmmmm.... You can try Security Access 27971 to enable Basic Settings and then Basic Settings group number 226 for regeneration while standing. This is an educated guess.
I'd be a bit more worried about the P0087 code. Metal shavings?
colin41
C?ID=242997
I only did the auto scan to show ECU details.
Yes apparently they need static regen.
Thanks for that! I will try and report back.
colin41
C?ID=242997
it seems like it maybe the right area but when entering basic settings 226 it shows the correct values for a second then it gives error - engine off - engine on
then some times 1.0 - PNinactive
im only trying this to workout if its possible. my friend mentioned it may not going into regen if soot levels are low?
i will retry on a forklift needing a regen
Jef
HQ
MVB group 241 should be:
  • field 1 = Particle Filter,Oil Ash Volume,Range: -380...+380 ml
  • field 2 = Soot Load(g),Calculated
  • field 3 = Soot Load(g),Measured
colin41
C?ID=242997
finally got one to try that needs a regen. unfortunately the basic setting 226 doesnt work.
i think i found the DPF values on MVB 108 field1-250ML field2-5.1 field3-6.6
any other ideas on how to start a regen?
Scan: 01 25
   Component: R4 2,0L IMO 0000AG  0231
   Coding: 0031608
   VCID: 06040C4172CD3EB638-5120
013257 - DPF Soot Load
               P33C9 - 000 - Threshold 2 Exceeded
                    RPM: 1012 /min
                        6.6
                        5.1
                    Pressure: 0 mbar
                    milliliters: 250 ml
colin41
C?ID=242997
the genuine software seems to use 40809 as a login if that helps any
NEtech
C?ID=56995
250ml Ash, I would think this is to high, and a new particulate filter is needed, for car it is 175ml.
But 108.2 Calculated soot mass and 108.3 measured soot mass, are low (to low to start regeneration).
Please post engine controller maps here.
[Applications]
[Controller Channel Map]
- Controller Address = 01
- Login or security code: Leave blank
- Function: Measuring values and Adaptations
- Output: CSV file
[Go]
File is placed in c:\Roos-Tech\Logs
Used for what ?
colin41
C?ID=242997
[Applications]
- Output: CSV file
[Go]
Used for what ?
today i was looking at my friends Linde diagnostic software in offline mode (not connected) this is where i learned the MVB. the Linde software said 500ml is 100% full. i assume they have a different DPF from a car. when looking at the DPF regen protocol at the start of the regen it said in the log. login-40809 not sure if that is of any help tho.
i will get an engine controller map as soon as i can
i do understand this isnt the usual request. its just something i am experimenting with to help my friend
colin41
C?ID=242997
do i post engine controller maps the same way as autoscans?
colin41
C?ID=242997
;SW:03L-906-019-KS   HW:03L-906-019-BA ---  Engine
;Component:R4 2,0L IMO 0000AG  0231, Coding:0031608
;Wednesday,22,April,2020,10:11:24:59923
;VCDS Version: Release 20.4.0 (x64)  Data version: 20200331 DS317.0
;VCID: 06040C4172CD3EB638-513C
Group,Field 1,Data type,Field 2,Data type,Field 3,Data type,Field 4,Data type,
1,0 /min,RPM,0.0 mg/str,Inj. Quantity,0.0 bar,Pressure,8.1°C,Temperature,
2,0 /min,RPM,0.0 %,Load, 0 00  0,Bin. Bits,8.1°C,Temperature,
3,0 /min,RPM,330.0 mg/str,Mass Air / Rev.,0.0 mg/str,Mass Air / Rev.,100.0 %,Load,
4,0 /min,RPM,0.0 °BTDC,Ign. Timing,0.0,(no units),0.0 bar,Pressure,
5,0 /min,RPM,0.0 mg/str,Inj. Quantity,1.0,(no units),8.1°C,Temperature,
6,0.0 km/h,Speed,00000000,Bin. Bits,0.0 km/h,Speed,00000000,Bin. Bits,
7,9.0°C,Temperature,19.8°C,Temperature,9.9°C,Temperature,8.1°C,Temperature,
8,0 /min,RPM,144.0 Nm,Torque,0.0 Nm,Torque,615.0 Nm,Torque,
9,0 /min,RPM,0.0 Nm,Torque,615.0 Nm,Torque,0.0 Nm,Torque,
10,0.0 mg/str,Mass Air / Rev.,1009.8 mbar,Absolute Pres.,999.6 mbar,Absolute Pres.,0.0 %,Load,
11,0 /min,RPM,1050.6 mbar,Absolute Pres.,999.6 mbar,Absolute Pres.,9.8 %,Load,
12,01010000,Bin. Bits,2.52 s,Time,12.46 V,Voltage,8.1°C,Temperature,
13,0.00 mg/str,Inj. Quantity,0.00 mg/str,Inj. Quantity,0.00 mg/str,Inj. Quantity,0.00 mg/str,Inj. Quantity,
15,0 /min,RPM,-150.0 Nm,Torque,0.00 l/h,Fuel Consump.,144.0 Nm,Torque,
16,0.0 %,Lambda, , , , ,12.46 V,Voltage,
17,0.0,(no units),0.00,(no units),0.0 l,Tank Cont.,1012 /min,RPM,
18,0 /min,RPM,9.0°C,Temperature,0.0,(no units),1.0,(no units),
19,0 /min,RPM,260.10,(no units),0.0 bar,Pressure,15872.0, ,
20,0 /min,RPM,264.0 bar,Pressure,0.0 bar,Pressure,7.1 %,Lambda,
21,0 /min,RPM,264.0 bar,Pressure,0.0 bar,Pressure,14.2 %,Lambda,
22,0 /min,RPM, 0001000,Bin. Bits, 0000000,Bin. Bits, 0111000,Bin. Bits,
23,0 /min,RPM,0.0 °BTDC,Ign. Timing,0.0,(no units),3.0,(no units),
24,0 /min,RPM,0.0 °BTDC,Ign. Timing,0.0,(no units),0.0 bar,Pressure,
25,0 /min,RPM,0.0 °BTDC,Ign. Timing,0.0,(no units),0.0 bar,Pressure,
26,0 /min,RPM,0.0 °BTDC,Ign. Timing,0.0,(no units),0.0 bar,Pressure,
27,0 /min,RPM,0.0 °BTDC,Ign. Timing,0.0,(no units),0.0 bar,Pressure,
28,0 /min,RPM,0.0 °BTDC,Ign. Timing,0.0,(no units),0.0 bar,Pressure,
29,0 /min,RPM,0.0 °BTDC,Ign. Timing,0.0,(no units),0.0 bar,Pressure,
30,0.000 V,Voltage,0.000 V,Voltage, 0 00  0,Bin. Bits,0.0 %,Load,
31,7806,Voltage,
32,0 /min,RPM,1050.6 mbar,Absolute Pres.,999.6 mbar,Absolute Pres.,4.7 %,Lambda,
33,0 /min,RPM,18.0°C,Temperature,1.00,(no units),1.00,(no units),
34,0 /min,RPM,9.8 %,Load,8.7 %,Lambda,4.7 %,Lambda,
35,0 /min,RPM,330.0 mg/str,Mass Air / Rev.,0.0 mg/str,Mass Air / Rev.,100.0 %,Load,
36,0 /min,RPM,100.0 %,Load,97.8 %,Lambda,0.0 %,Lambda,
38,0 /min,RPM,100.0 %,Load,99.4 %,Lambda,0.0 %,Lambda,
39,0 /min,RPM,0.0 mg/str,Mass Air / Rev.,9.9°C,Temperature,0.0 %,Lambda,
40,0 /min,RPM,100.0 %,Load,100.2 %,Lambda,0.0 %,Lambda,
41,200 ohms,Resistance,0.000 V,Voltage,0.01,(no units),0.0,(no units),
42,0.01,(no units),1.6 %,Lambda,3.300 V,Voltage,25.40,(no units),
43,0.0,(no units),3.6°C,Temperature,00000000,Bin. Bits,0.000 V,Voltage,
44,0 /min,RPM,11001000,Bin. Bits,0.0,(no units),0.0,(no units),
45,8.1°C,Temperature,100.0 %,Load,99.4 %,Lambda,0.0 %,Lambda,
46,3.6°C,Temperature,8.1°C,Temperature,-40.5°C,Temperature, , ,
47,94.5°C,Temperature,-40.5°C,Temperature,0.0 %,Load,99.4 %,Lambda,
48,0 /min,RPM,5865 /min,RPM,       0,Bin. Bits,1270.0 Nm,Torque,
50,0 /min,RPM,0.0 mg/str,Inj. Quantity,0.00 mg/str,Inj. Quantity,      10,Bin. Bits,
51,0 /min,RPM,0 /min,RPM,1.0,(no units),0.0°KW,Idle Stabilization,
52,0 /min,RPM,0xFF00,Hex Value,0xFF00,Hex Value,14.4°C,Temperature,
53,00000000,Bin. Bits,00000100,Bin. Bits,00000000,Bin. Bits,10000000,Bin. Bits,
54,0.0,(no units),0 /min,RPM,0.0 mg/str,Inj. Quantity,0.00 mg/str,Inj. Quantity,
57,0 /min,RPM,0.0 km/h,Speed,0.0 %,Duty Cycle, , ,
59,0 /min,RPM,-150.0 Nm,Torque,45.0 Nm,Torque,0.0 Nm,Torque,
60,45.0 Nm,Torque,-48.0 Nm,Torque,0.0 Nm,Torque,0.0 %,Lambda,
61,0 /min,RPM,19.8°C,Temperature,0.0 mm,Content,0.0 mm,Content,
62,0 /min,RPM,0.0 mg/str,Inj. Quantity,0.0,(no units),0.0,(no units),
63,0 /min,RPM,0 /min,RPM,0 /min,RPM,0 /min,RPM,
69,00000000,Bin. Bits,00000000,Bin. Bits,00000000,Bin. Bits,00000000,Bin. Bits,
70,00000000,Bin. Bits,00000000,Bin. Bits, , , , ,
71,11111110,Bin. Bits,00000000,Bin. Bits, , , , ,
72,0.00,(no units),0.00,(no units),0.00,(no units), , ,
73,0.00,(no units),0.00,(no units),0.00,(no units), , ,
74,0.00,(no units),0.00,(no units),0.00,(no units), , ,
75,0.00,(no units),0.00,(no units),0.00,(no units), , ,
80,RB8-658 14.10.14 21H35--- 1313 1079, ,
81,H2X394E03236, ,
82,0000000000000 00.00.00 78       79  <>  , ,
85,393210 km,Mileage,0,Count,0,Count,28211,Count,
86,11111011,Bin. Bits,11111111,Bin. Bits,11111111,Bin. Bits,11111111,Bin. Bits,
87,11111111,Bin. Bits,11111111,Bin. Bits,11111111,Bin. Bits, , ,
89,00000010,Bin. Bits,00001110,Bin. Bits,00000000,Bin. Bits,00000000,Bin. Bits,
90,0 /min,RPM,0.0 mg/str,Inj. Quantity,330.0 mg/str,Mass Air / Rev.,00000000,Bin. Bits,
91,323.85,(no units),-326.40,(no units),330.0 mg/str,Mass Air / Rev.,323.85,(no units),
93,00000000,Bin. Bits,3.97,(no units),0.0,(no units),0.0,(no units),
95,00000000,Bin. Bits,01010001,Bin. Bits,0.0,(no units), , ,
96,00000000,Bin. Bits,00000000,Bin. Bits,      00,Bin. Bits,12.46 V,Voltage,
97,0 mbar,Pressure,0 mbar,Pressure, , , , ,
98,0 /min,RPM,9.9°C,Temperature,0.0 mg/str,Mass Air / Rev., , ,
99,0 /min,RPM,18.0°C,Temperature,-6.0°C,Temperature,6.0°C,Temperature,
100,6.0°C,Temperature,6.0°C,Temperature,0 mbar,Pressure,0 mbar,Pressure,
101,0 /min,RPM,0.0,(no units),0.0,(no units),0.0,(no units),
102,00000000,Bin. Bits,00000001,Bin. Bits,00000000,Bin. Bits,00000000,Bin. Bits,
103,00000000,Bin. Bits,00000000,Bin. Bits,00000000,Bin. Bits,00000000,Bin. Bits,
104,0xFF01,Hex Value,0xFF10,Hex Value,00000000,Bin. Bits,00000000,Bin. Bits,
105,00000000,Bin. Bits,1.0,(no units),6.0°C,Temperature,0.0,(no units),
106, , ,30.5 l,Tank Cont.,0 km,Mileage,828.0,(no units),
107,39.3, ,30.0, ,21.0, , , ,
108,250 ml,milliliters,5.1, ,6.6, , , ,
109,00000010,Bin. Bits,00000000,Bin. Bits, , , , ,
110, , ,00000000,Bin. Bits,0.0 km/h,Speed, , ,
111,0 /min,RPM,0.0 km/h,Speed,0.00,(no units),0.0,(no units),
112,0.00,(no units),1270.0 Nm,Torque,0.0 Nm,Torque,0.0 Nm,Torque,
113,00000000,Bin. Bits,0.0,(no units),0.0,(no units),0.0,(no units),
114,255.0,(no units),255.0,(no units),0.00,(no units),0.00,(no units),
116,0.0 %,Load,-40.5°C,Temperature,193.0,(no units),0.0,(no units),
117,0.0 %,Lambda,-40.5°C,Temperature,00010100,Bin. Bits,0.0,(no units),
120,-15.8 %,Lambda,11.0 %,Lambda,00000000,Bin. Bits,0.608 V,Voltage,
121,0.0 %,Lambda,0.8 %,Lambda,00000000,Bin. Bits,0.760 V,Voltage,
123,-1.6 %,Lambda,0.8 %,Lambda,00000100,Bin. Bits,0.988 V,Voltage,
124,-0.8 %,Lambda,0.0 %,Lambda,00000000,Bin. Bits,4.560 V,Voltage,
125,Vehicle CM 1, , , , , , , ,
166,0.000°,Angle,0.018°,Angle,0.063°,Angle,0.070°,Angle,
176,0 ppm, ,200 mV, ,0.00,(no units), , ,
177,0 ppm, ,200 mV, ,0.00,(no units), , ,
180, , ,0 ppm, , , , , ,
200,0 ppm, , , ,0 ppm, , , ,
214,0.0°C,Temperature, , ,-6.0°C,Temperature,-6.0°C,Temperature,
221,1.50,(no units), , , , , , ,
222,1.00,(no units),1.00,(no units),1.07,(no units),1.00,(no units),
223,994.5 mbar,Pressure,994.5 mbar,Pressure,0.0,(no units),0.0,(no units),
225,0.0,(no units),0.0,(no units), , , , ,
245,00000000,Bin. Bits,01101010,Bin. Bits,00000001,Bin. Bits,01011110,Bin. Bits,
246,30.2 %,Load,00000011,Bin. Bits, , , , ,
247,0.0 Nm,Torque,615.0 Nm,Torque,0.0 Nm,Torque,-150.0 Nm,Torque,
248,00000001,Bin. Bits,00000001,Bin. Bits,00000000,Bin. Bits,00000000,Bin. Bits,
249,0.0,(no units),00110100,Bin. Bits,10110000,Bin. Bits,0.0,(no units),
250,1012 /min,RPM,0 /min,RPM,0 /min,RPM,0 /min,RPM,
251,1012 /min,RPM,3542 /min,RPM,1012 /min,RPM,3542 /min,RPM,
252,0.0 km/h,Speed,7.0,(no units),0.0 Nm,Torque,0.0 %,Load,
253,99.4 %,Lambda,00000000,Bin. Bits,01010001,Bin. Bits,0.0,(no units),
;Wednesday,22,April,2020,10:12:04:59923
Channel,,Field 1,Field 2,Field 3,Field 4,
01,,ERROR:,Security,access,required,
02,,ERROR:,Security,access,required,
03,,ERROR:,Security,access,required,
04,,ERROR:,Security,access,required,
05,,ERROR:,Security,access,required,
06,830,0 /min, , 0 00  0,0.0 %,
07,,ERROR:,Security,access,required,
08,,ERROR:,Channel 08,Not,Available,
09,,ERROR:,Channel 09,Not,Available,
10,,ERROR:,Channel 10,Not,Available,
11,,ERROR:,Channel 11,Not,Available,
12,,ERROR:,Channel 12,Not,Available,
13,,ERROR:,Security,access,required,
14,,ERROR:,Security,access,required,
15,,ERROR:,Security,access,required,
16,,ERROR:,Security,access,required,
17,,ERROR:,Security,access,required,
18,,ERROR:,Channel 18,Not,Available,
19,,ERROR:,Channel 19,Not,Available,
20,0, , , , ,
21,0, , , , ,
22,0, , , , ,
23,0, , , , ,
24,0, , , , ,
25,0, , , , ,
26,0, , , , ,
27,,ERROR:,Channel 27,Not,Available,
28,,ERROR:,Channel 28,Not,Available,
29,,ERROR:,Channel 29,Not,Available,
30,,ERROR:,Channel 30,Not,Available,
31,1000,0 /min,1012 /min,1012 /min,3542 /min,
32,1250,0 /min,1012 /min,1012 /min,3542 /min,
33,1500,0 /min,1012 /min,1012 /min,3542 /min,
34,1750,0 /min,1012 /min,1012 /min,3542 /min,
35,2000,0 /min,1012 /min,1012 /min,3542 /min,
36,2250,0 /min,1012 /min,1012 /min,3542 /min,
37,2500,0 /min,1012 /min,1012 /min,3542 /min,
38,8, , , ,0 /min,
39,,ERROR:,Channel 39,Not,Available,
40,H2X394E03236, , , ,0 /min,
41,327,1012 /min,1012 /min,3542 /min, ,
42,327, , , ,000 000 255,
43,210, , , ,0 km,
44,0,1012 /min,1012 /min,3542 /min,994.5 mbar,
45,0,1012 /min,1012 /min,3542 /min,00000001,
46,300,1012 /min,1012 /min,3542 /min,01010001,
47,830,0 /min,1012 /min,1012 /min,3542 /min,
48,3500,0 /min,1012 /min,1012 /min,3542 /min,
49,3500,0 /min,1012 /min,1012 /min,3542 /min,
50,,ERROR:,Channel 50,Not,Available,
51,,ERROR:,Channel 51,Not,Available,
52,,ERROR:,Channel 52,Not,Available,
53,0,1012 /min,00000000,3542 /min,1012 /min,
54,100,5.1,6.6,0 km,0 /min,
55,100,5.1,6.6,0 km,0 /min,
56,100,5.1,6.6,0 km,0 /min,
57,100, , , , ,
58,100, , 0 00  0,0.0 %,0 /min,
59,100,5.1,6.6,0 km,0 /min,
60,,ERROR:,Channel 60,Not,Available,
61,0,1012 /min,00000000,3542 /min,00000000,
62,,ERROR:,Channel 62,Not,Available,
63,100,0 /min,1012 /min,00000000,3542 /min,
64,0,0 /min,1012 /min,00000000,3542 /min,
65,,ERROR:,Channel 65,Not,Available,
66,,ERROR:,Channel 66,Not,Available,
67,,ERROR:,Channel 67,Not,Available,
68,,ERROR:,Channel 68,Not,Available,
69,,ERROR:,Channel 69,Not,Available,
70,,ERROR:,Channel 70,Not,Available,
71,A1AK6SG, , , , ,
72,A1SSAWG, , , , ,
73,AASF6EG, , , , ,
74,AAR47SG, , , , ,
75,,ERROR:,Channel 75,Not,Available,
76,,ERROR:,Channel 76,Not,Available,
77,,ERROR:,Channel 77,Not,Available,
78,,ERROR:,Channel 78,Not,Available,
79,,ERROR:,Channel 79,Not,Available,
80,,ERROR:,Channel 80,Not,Available,
81,830, , , ,0 /min,
82,830, , , ,0.0 mg/str,
83,830, , , ,0.0 bar,
84,830,0.8 %,00000000,0.760 V,8.1°C,
85,830,0.0 %,00000000,4.560 V, ,
86,830,00000100,00000010,0.988 V,0 /min,
87,830,11.0 %,00000000,0.608 V,0 /min,
88,498,0 /min,1012 /min,00000000,3542 /min,
89,249,0 /min,1012 /min,00000000,3542 /min,
90,249,0 /min,1012 /min,00000000,3542 /min,
91,,ERROR:,Channel 91,Not,Available,
92,,ERROR:,Channel 92,Not,Available,
93,,ERROR:,Channel 93,Not,Available,
94,,ERROR:,Channel 94,Not,Available,
95,,ERROR:,Channel 95,Not,Available,
96,,ERROR:,Channel 96,Not,Available,
97,,ERROR:,Channel 97,Not,Available,
98,,ERROR:,Channel 98,Not,Available,
99,,ERROR:,Channel 99,Not,Available,
100,,ERROR:,Channel 100,Not,Available,
101,3500,0 /min,1012 /min,1012 /min,3542 /min,
102,3500,0 /min,1012 /min,1012 /min,3542 /min,
103,3500,0 /min,1012 /min,1012 /min,3542 /min,
104,3500,0 /min,1012 /min,1012 /min,3542 /min,
105,3500,0 /min,1012 /min,1012 /min,3542 /min,
106,3500, , , ,8.1°C,
107,3500, , , ,0.0 mg/str,
108,0, , , , ,
109,10219, , , ,0.0,
110,,ERROR:,Channel 110,Not,Available,
111,,ERROR:,Channel 111,Not,Available,
112,,ERROR:,Channel 112,Not,Available,
113,,ERROR:,Channel 113,Not,Available,
114,,ERROR:,Channel 114,Not,Available,
115,,ERROR:,Channel 115,Not,Available,
116,,ERROR:,Channel 116,Not,Available,
117,0,1012 /min,00000000,3542 /min,-276.0°C,
118,,ERROR:,Channel 118,Not,Available,
119,,ERROR:,Channel 119,Not,Available,
120,0,-15.8 %,11.0 %,00000000,0.608 V,
121,,ERROR:,Channel 121,Not,Available,
122,,ERROR:,Channel 122,Not,Available,
123,0,-1.6 %,00000100,00000010,0.988 V,
124,0,-0.8 %,0.0 %,00000000,4.560 V,
125,0,1012 /min,00000000,3542 /min, ,
126,0,1012 /min,00000000,3542 /min, ,
127,,ERROR:,Channel 127,Not,Available,
128,,ERROR:,Security,access,required,
129,,ERROR:,Security,access,required,
130,,ERROR:,Security,access,required,
131,,ERROR:,Security,access,required,
132,,ERROR:,Security,access,required,
133,,ERROR:,Security,access,required,
134,,ERROR:,Security,access,required,
135,,ERROR:,Security,access,required,
136,,ERROR:,Security,access,required,
137,,ERROR:,Security,access,required,
138,,ERROR:,Security,access,required,
139,,ERROR:,Security,access,required,
140,,ERROR:,Security,access,required,
141,,ERROR:,Security,access,required,
142,,ERROR:,Security,access,required,
143,,ERROR:,Security,access,required,
144,,ERROR:,Security,access,required,
145,,ERROR:,Security,access,required,
146,,ERROR:,Security,access,required,
147,,ERROR:,Security,access,required,
148,,ERROR:,Security,access,required,
149,,ERROR:,Security,access,required,
150,,ERROR:,Security,access,required,
151,,ERROR:,Security,access,required,
152,,ERROR:,Security,access,required,
153,,ERROR:,Security,access,required,
154,,ERROR:,Security,access,required,
155,,ERROR:,Security,access,required,
156,,ERROR:,Security,access,required,
157,,ERROR:,Security,access,required,
158,,ERROR:,Security,access,required,
159,,ERROR:,Security,access,required,
160,,ERROR:,Security,access,required,
161,,ERROR:,Security,access,required,
162,,ERROR:,Security,access,required,
163,,ERROR:,Security,access,required,
164,,ERROR:,Security,access,required,
165,,ERROR:,Security,access,required,
166,,ERROR:,Security,access,required,
167,,ERROR:,Security,access,required,
168,,ERROR:,Security,access,required,
169,,ERROR:,Security,access,required,
170,,ERROR:,Security,access,required,
171,,ERROR:,Security,access,required,
172,,ERROR:,Security,access,required,
173,,ERROR:,Security,access,required,
174,,ERROR:,Security,access,required,
175,,ERROR:,Security,access,required,
176,,ERROR:,Security,access,required,
177,,ERROR:,Security,access,required,
178,,ERROR:,Security,access,required,
179,,ERROR:,Security,access,required,
180,,ERROR:,Security,access,required,
181,,ERROR:,Security,access,required,
182,,ERROR:,Security,access,required,
183,,ERROR:,Security,access,required,
184,,ERROR:,Channel 184,Not,Available,
185,,ERROR:,Channel 185,Not,Available,
186,,ERROR:,Channel 186,Not,Available,
187,,ERROR:,Channel 187,Not,Available,
188,,ERROR:,Channel 188,Not,Available,
189,,ERROR:,Channel 189,Not,Available,
190,,ERROR:,Channel 190,Not,Available,
191,,ERROR:,Security,access,required,
192,,ERROR:,Security,access,required,
193,,ERROR:,Security,access,required,
194,,ERROR:,Security,access,required,
195,,ERROR:,Security,access,required,
196,,ERROR:,Security,access,required,
197,,ERROR:,Security,access,required,
198,,ERROR:,Security,access,required,
199,,ERROR:,Security,access,required,
200,,ERROR:,Security,access,required,
201,,ERROR:,Channel 201,Not,Available,
202,,ERROR:,Security,access,required,
203,,ERROR:,Security,access,required,
204,,ERROR:,Security,access,required,
205,,ERROR:,Security,access,required,
206,,ERROR:,Security,access,required,
207,,ERROR:,Security,access,required,
208,,ERROR:,Security,access,required,
209,,ERROR:,Security,access,required,
210,,ERROR:,Security,access,required,
211,,ERROR:,Security,access,required,
212,,ERROR:,Security,access,required,
213,,ERROR:,Security,access,required,
214,,ERROR:,Security,access,required,
215,,ERROR:,Security,access,required,
216,,ERROR:,Security,access,required,
217,,ERROR:,Security,access,required,
218,,ERROR:,Channel 218,Not,Available,
219,,ERROR:,Security,access,required,
220,,ERROR:,Security,access,required,
221,,ERROR:,Security,access,required,
222,,ERROR:,Security,access,required,
223,,ERROR:,Security,access,required,
224,,ERROR:,Security,access,required,
225,,ERROR:,Security,access,required,
226,,ERROR:,Security,access,required,
227,,ERROR:,Security,access,required,
228,,ERROR:,Security,access,required,
229,,ERROR:,Security,access,required,
230,,ERROR:,Security,access,required,
231,,ERROR:,Security,access,required,
232,,ERROR:,Security,access,required,
233,,ERROR:,Security,access,required,
234,,ERROR:,Security,access,required,
235,,ERROR:,Security,access,required,
236,,ERROR:,Security,access,required,
237,,ERROR:,Security,access,required,
238,,ERROR:,Security,access,required,
239,,ERROR:,Security,access,required,
240,,ERROR:,Security,access,required,
241,,ERROR:,Security,access,required,
242,,ERROR:,Security,access,required,
243,,ERROR:,Security,access,required,
244,,ERROR:,Security,access,required,
245,,ERROR:,Security,access,required,
246,,ERROR:,Security,access,required,
247,,ERROR:,Security,access,required,
248,,ERROR:,Security,access,required,
249,,ERROR:,Security,access,required,
250,,ERROR:,Security,access,required,
251,,ERROR:,Security,access,required,
252,,ERROR:,Security,access,required,
253,,ERROR:,Security,access,required,
254,,ERROR:,Security,access,required,
255,,ERROR:,Security,access,required,
NEtech
C?ID=56995
Thank you very much.
If possible, it could be interesting to make adaptation controller map with the login.
[Applications]
- Login or security code: 40809
- Function: Adaptations
- Output: CSV file
[Go]
I am a little puzzled about P33C9, Threshold 2 would be 30.0
I would think there are some things explained in Linde software, what conditions for regeneration must be, they are probably no the same as for a car (e.g. no parkbrake input).
colin41
C?ID=242997
I am quite sure the conditions are met when i try regen, they are explained in the Linde software
the ecu accepts both logins so i tried the map with both
using login 27971
;SW:03L-906-019-KS   HW:03L-906-019-BA ---  Engine --- SA: 27971
;Wednesday,22,April,2020,15:09:11:59923
;VCID: 06040C4172CD3EB638-5120
20,0, , , , ,
21,0, , , , ,
22,0, , , , ,
23,0, , , , ,
24,0, , , , ,
25,0, , , , ,
26,0, , , , ,
38,8, , , ,0 /min,
43,210, , , ,0 km,
57,100, , , , ,
71,A1AK6SG, , , , ,
72,A1SSAWG, , , , ,
73,AASF6EG, , , , ,
74,AAR47SG, , , , ,
84,830,0.8 %,00000000,0.760 V,11.7°C,
106,3500, , , ,11.7°C,
108,0, , , , ,
184,,ERROR:,Security,access,required,
185,,ERROR:,Security,access,required,
186,,ERROR:,Security,access,required,
187,,ERROR:,Security,access,required,
188,,ERROR:,Security,access,required,
189,,ERROR:,Security,access,required,
190,,ERROR:,Security,access,required,
201,,ERROR:,Security,access,required,
using login 40809
;SW:03L-906-019-KS   HW:03L-906-019-BA ---  Engine --- SA: 40809
;Wednesday,22,April,2020,15:03:20:59923
13,0,250 ml,5.1,6.6,0 km,
14,0,250 ml,5.1,6.6,0 km,
15,0,250 ml,5.1,6.6,0 km,
16,0,250 ml,5.1,6.6,0 km,
20,0, , , , ,
21,0, , , , ,
22,0, , , , ,
23,0, , , , ,
24,0, , , , ,
25,0, , , , ,
26,0, , , , ,
38,8, , , ,0 /min,
43,210, , , ,0 km,
57,100, , , , ,
71,A1AK6SG, , , , ,
72,A1SSAWG, , , , ,
73,AASF6EG, , , , ,
74,AAR47SG, , , , ,
108,0, , , , ,
The DPF will have to be cleaned and remediated manually/chemically or changed at these soot levels and for the code vacated first or will not allow for it to commence.
Did you know that some lazy but creative guys fake out the DPF PSI sensors to vacate the DTC and perform the DPF Regeneration a few times, then plug them back in proper to monitor the soot levels lowered?
It would be wise to monitor the temps of exhaust if doing this and be ready to cool with water or run a fan on it during regeneration attempts to curtail a possible fire!
FYI: Both logins appear to be possible in stack for industrial or cars........
colin41
C?ID=242997
what makes you say manually cleaned? the fault code wont erase. the Linde software information for the code says to do a static regen.
im still unsure what exactly the static DPF regen basic setting is in order to initiate it
if faking the pressure sensor may work i assume i apply a certain voltage down the signal wire?
JPPSG the entire thread, pay attention to decade box and did you consider a temporary PSI signal line to fake sensor?
Don't you understand why exhaust PSI can't get to signal line or would be impaired by soot accumulation in DPF to PSI sensors?
colin41
C?ID=242997
yes a temporary signal line is what what i meant. i can try it and also check the pipes from DPF to sensor for blockage.
but i still dont know for certain the basic setting to start the regen.
