Page 1 of 3 123 LastLast
Results 1 to 10 of 22
Thread: Linde forklift
    Jun 2017
    Linde forklift
    I have recently been helping a friend who works at forklifts with fault code clearing and injector coding.
    which VCDS does no problems
    my question is, is it possible to do DPF regens with VCDS?
    he mentioned that the Linde diagnostics can do this
    Chassis Type: LF - Linde Fork Lifts (VW Diesel ONLY)
    Scan: 01 25
    Address 01: Engine (CPY)       Labels: Redir Fail!
       Part No SW: 03L 906 019 KS    HW: 03L 906 019 BA
       Component: R4 2,0L IMO 0000AG  0584
       Revision: 21H35---    Serial number: IIIIIIIIIIIIII
       Coding: 0031608
       Shop #: WSC 00017 780 00200
       VCID: 06040C4172CD3E7F9F-5120
    000135 - Fuel Rail/System Pressure
                   P0087 - 000 - Too Low
                        RPM: 1794 /min
                        Inj. Quantity: 15.1 mg/str
                        (no units): 5.0
                        Pressure: 1224.0 bar
                        Pressure: 832.0 bar
                        Temperature: 31.5C
                        Tank Cont.: 0.0 l
    054282 - Terminal 30
                   U140A - 000 - Open Circuit - Intermittent
                        Voltage: 12.62 V
                        Temperature: -90.0C
                        Temperature: -90.0C
                        Absolute Pres.: 0.0 mbar
                        Torque: 0.0 Nm
    Readiness: N/A
    HQ
    DPF regen? Hmmmmm.... You can try Security Access 27971 to enable Basic Settings and then Basic Settings group number 226 for regeneration while standing. This is an educated guess.
    I'd be a bit more worried about the P0087 code. Metal shavings?
    Jef
  3. Likes Uwe, Jack@European_Parts liked this post
    Jun 2017
    I only did the auto scan to show ECU details.
    Yes apparently they need static regen.
    Thanks for that! I will try and report back.
    Jun 2017
    it seems like it maybe the right area but when entering basic settings 226 it shows the correct values for a second then it gives error - engine off - engine on
    then some times 1.0 - PNinactive
    im only trying this to workout if its possible. my friend mentioned it may not going into regen if soot levels are low?
    i will retry on a forklift needing a regen
    HQ
    MVB group 241 should be:
    • field 1 = Particle Filter,Oil Ash Volume,Range: -380...+380 ml
    • field 2 = Soot Load(g),Calculated
    • field 3 = Soot Load(g),Measured
    Jef
  7. Likes Uwe, Jack@European_Parts liked this post
    Jun 2017
    finally got one to try that needs a regen. unfortunately the basic setting 226 doesnt work.
    i think i found the DPF values on MVB 108 field1-250ML field2-5.1 field3-6.6
    any other ideas on how to start a regen?
    Scan: 01 25
       Component: R4 2,0L IMO 0000AG  0231
       Coding: 0031608
       VCID: 06040C4172CD3EB638-5120
    013257 - DPF Soot Load
                   P33C9 - 000 - Threshold 2 Exceeded
                        RPM: 1012 /min
                            6.6
                            5.1
                        Pressure: 0 mbar
                        milliliters: 250 ml
    Jun 2017
    the genuine software seems to use 40809 as a login if that helps any
  10. #8
    Quote Originally Posted by colin41 View Post
    250ml Ash, I would think this is to high, and a new particulate filter is needed, for car it is 175ml.
    But 108.2 Calculated soot mass and 108.3 measured soot mass, are low (to low to start regeneration).
    Please post engine controller maps here.
    [Applications]
    [Controller Channel Map]
    - Controller Address = 01
    - Login or security code: Leave blank
    - Function: Measuring values and Adaptations
    - Output: CSV file
    [Go]
    File is placed in c:\Roos-Tech\Logs
    Used for what ?
  11. Likes Uwe, Jack@European_Parts liked this post
  12. #9
    Jun 2017
    [Applications]
    - Output: CSV file
    [Go]
    Used for what ?
    today i was looking at my friends Linde diagnostic software in offline mode (not connected) this is where i learned the MVB. the Linde software said 500ml is 100% full. i assume they have a different DPF from a car. when looking at the DPF regen protocol at the start of the regen it said in the log. login-40809 not sure if that is of any help tho.
    i will get an engine controller map as soon as i can
    i do understand this isnt the usual request. its just something i am experimenting with to help my friend
  13. #10
    Jun 2017
    do i post engine controller maps the same way as autoscans?
