Results 1 to 5 of 5
Thread: 2019 Jetta 13 Auto Dist Reg Basic Setting
    Dec 2017
    2019 Jetta had radar unit unplugged during body repair, when car was started and moved. Now has the codes below that will not clear.
    Ive searched the forums but find limited information in this area.
    I've tried to log in to module with 14117 to do basic settings, but login is apparently not correct.
    Thanks for any pointers
    Heres my Auto Scan using Hex-net
     Chassis Type: BU-VW37 (3Q0)
    Scan: 01 03 08 09 13 15 17 19 3C 42 44 52 5F
    VIN: 3VWN57BU4KM050283   Mileage: 30815km-19147miles
    Address 01: Engine (J623-DGXA)       Labels:. 04E-907-309-V1.clb
       Part No SW: 04E 906 024 D    HW: 04E 907 309 BT
       Component: R4 1.4l TSI   H20 5700
       Revision: D4H20000
       Coding: 01190012232410082000
       Shop #: WSC 00066 790 00389
       ASAM Dataset: EV_ECM14TFS01104E906024D 001003
       ROD: EV_ECM14TFS01104E906024D.rod
       VCID: A2084164B515185F13-80F6
    Readiness: 1110 0101
       Part No SW: 5Q0 614 517 CT    HW: 5Q0 614 517 AG
       Component: ESC           H62 0653
       Revision: 00000000    Serial number: 51168000003406
       Coding: 70FB6AA12425216C45790208A0C6250E562484A24005A4301023F054C082430B00000012121212B835351919323200
       Shop #: WSC 01383 790 50316
       VCID: 85423AF804FBCF6716-80D0
       Part No SW: 5GM 907 426 H    HW: 5GM 907 426 H
       Component: AC Manuell    H03 2007
       Revision: 00001K06
       Coding: 01020004200110000000000000010004
       ASAM Dataset: EV_ACManueBHBVW37X 004134
       ROD: EV_ACManueBHBVW37X_004.rod
       VCID: CDD2C2D89C0BF7279E-8098
       Part No SW: 5Q0 937 087 AR    HW: 5Q0 937 087 AN
       Component: BCM PQ37BOSCH 034 0246
       Revision: --------    Serial number: C86418051803FV
       ROD: EV_BCMBOSCH_018.rod
       VCID: 8B560CC0229FB91740-80DE
       Steering Column Switch:
       Subsystem 1 - Part No SW: 5Q1 953 521 AJ    HW: 5Q1 953 569
       Component: Lenks.Modul  H03 0120
       Serial number: 0100110520180C100238
       Part No SW: 5Q0 907 572 N    HW: 3QF 907 572
       Component: ACC BOSCH MQB H10 0681
       Coding: 2A00008111FFC428949C810500301600000000000000000004
       ASAM Dataset: EV_ACCBOSCHVW416 002008
       VCID: C2C8E1E45555385F73-8096
    0267 - Sensor for Automatic Distance Regulation; Incorrectly Positioned
              C1103 00 [009] - -
              [FAULT_ALIGNMENT_NOT_OK]
                        Reset counter: 187
                        Mileage: 30815 km
                        Date: 2020.03.19
                        Time: 18:37:28
                        Control Module temperature: 40 °C
                        Voltage terminal 15: 12.1 V
    0791 - Sensor for Automatic Distance Regulation; Incorrectly Positioned
              C1103 00 [009] - -
              [FAULT_MISALIGNMENT_VERTICAL]
                        Reset counter: 187
                        Mileage: 30815 km
                        Date: 2020.03.19
                        Time: 18:37:28
       Part No SW: 5Q0 959 655 AG    HW: 5Q0 959 655 AG
       Component: AirbagVW21    004 0336
       Serial number: 003NUM093B6L
       Coding: 8CCCFC00000000005000001AC20800000065
       ROD: EV_AirbaVW20SMEVW37X.rod
       Occupant Detection:
       Serial number: IBH0000000000099QRH5
       Coding: 303445
       Subsystem 2 - Part No SW: -----------    HW: 480 001 704 18
       Serial number: 357000000001047D5E2I
       Subsystem 3 - Part No SW: -----------    HW: 480 001 704 18
       Serial number: 358000000007B96C5D2
       Subsystem 4 - Part No SW: -----------    HW: 480 403 004 18
       Serial number: 3510001BD29B6A83C6ET
       Subsystem 5 - Part No SW: -----------    HW: 480 400 805 18
       Serial number: 3520001A529F7C95169F
       Subsystem 6 - Part No SW: -----------    HW: 480 400 505 18
       Serial number: 3550001C929E65D4828K
       Front Sensor Passenger:
       Subsystem 7 - Part No SW: -----------    HW: 480 400 505 18
       Component: FrontSensor_P  000 6149
       Serial number: 3560001C929E65D551AK
       Part No SW: 17A 920 840     HW: 17A 920 840
       Component: KOMBI         208 0310
       Coding: 09B401022388CF05028823095000000000000000
       Shop #: WSC 33716 002 1048576
       VCID: E08C0B6CFB994A4F45-80B4
       Component: GW MQB High   518 5323
       Serial number: 15051800842230
       Coding: 0101000830085708FB000008080F00000001070000000000000000000000
       Shop #: WSC 00066 790 00016
       ROD: EV_GatewNF.rod
       VCID: B83C830C0389628FDD-80EC
       Subsystem 2 - Part No SW: 5G0 959 442 AA    HW: 5G0 959 442 AA  Labels: 3C8-959-537.CLB
       Component: E221__MFL-DC1  H17 0052
       Serial number: 28180000752280091439
       Coding: 28FFFF
    Address 3C: Lane Change (J1086)       Labels:* None
       Part No SW: 2Q0 907 686 A    HW: 2Q0 907 686 A
       Component: HRE3_Kl15_Mst H03 0052
       Serial number: 00000480057148
       Coding: 5000C500
       ASAM Dataset: EV_HREntryHellaGen3Kl15 001009
       ROD: EV_HREntryHellaGen3Kl15_001_VW37.rod
       Part No SW: 5Q4 959 393 E    HW: 5Q4 959 393 B
       Serial number: 7038814901568
       Coding: 00200B200000028000000000
       VCID: C5C2FAF8447B0F6756-8090
       Subsystem 1 - Part No SW: 5Q4 959 811 F    HW: 5Q4 959 811 F  Labels: 5QX-959-81X-V1.CLB
       Component: Fond FHSG DRV  010 0004
       Serial number: 00000000000000411700
       Coding: 011000
       Part No SW: 5QM 909 144 B    HW: 5QM 909 144 B
       Component: EPS_MQB_ZFLS  172 1081
       Coding: 010A0000
       ROD: EV_SteerAssisMQB_015.rod
       VCID: D0ECDBAC8B39DACFF5-8084
       Part No SW: 5Q4 959 392 E    HW: 5Q4 959 392 B
       Serial number: 8038814300065
       Coding: 002003200000028000000000
       VCID: C4C4E7FC4F41366F41-8090
       Subsystem 1 - Part No SW: 5Q4 959 812 F    HW: 5Q4 959 812 F  Labels: 5QX-959-81X-V1.CLB
       Component: Fond FHSG PSG  010 0004
       Serial number: 00000000000000411934
       Coding: 091000
    Address 5F: Information Electr. (J794)       Labels:| 5G0-035-MIB-ENT2.clb
       Part No SW: 17A 035 868     HW: 17A 035 868
       Component: MU-E--ER      680 8740
       Serial number: 29031800020174
       Coding: 02730100AA00000041220001001000009F0000D40000010000
       ASAM Dataset: EV_MUEnt4CGen2LGE 001041
       ROD: EV_MUEnt4CGen2LGE_VW37.rod
       VCID: E79E10701EB73D7784-80B2
    End----------(Elapsed Time: 01:09, VBatt start/end: 12.1V/12.1V)-----------
    I suspect this is going to need a full calibration, which is done on an alignment rack, with precision measuring equipment and targets, like this:
    Dec 2017
    I understand the purpose of that and have access to that setup from a friend.
    But I would still need to log in the module for basic settings I believe.
    Others here have accomplished this without going thru all that on MK7 Golfs. But the module is a different part number.
    Quote Originally Posted by vwcrzy View Post
    I don't have those details or a procedure for this, sorry.
    ^^^vwcrzy -I'm in the same position as Uwe, but have you tried 20103 as a SA? I'm guessing of course - but it's a multi module security code on MQB platform vehicles
