- Joined
- Mar 18, 2020
- Messages
- 13
- Reaction score
- 0
- Location
- Chicago, USA
- VCDS Serial number
- C?ID=181824
000769 - Cylinder 1 P0301 - 000 - Misfire Detected
Here is my engine fault code:I have a VW Jetta Wagon 2.0T FSI and I am having a cylinder 1 misfire.
The car misfires when idle and when I'm driving it the misfire goes away!I have a VW Jetta Wagon 2.0T FSI and I am having a cylinder 1 misfire.
I have check the spark plugs and the coils!I have a VW Jetta Wagon 2.0T FSI and I am having a cylinder 1 misfire.
The cables look ok! Seem to have a vacuum leak so changing the Engine Crankcase Vent Valve but I still think something is wrong! Is it my fuel injector or do I have a bent valve. I check the compression on all cylinders and got 90 PSI on 2, 3, and 4 but 1 only had 60 PSI. I need to know if I should take out the head and check the injector and walnut blast the valves?I have a VW Jetta Wagon 2.0T FSI and I am having a cylinder 1 misfire.
Is the cam worn!?I have a VW Jetta Wagon 2.0T FSI and I am having a cylinder 1 misfire.
There is no coolant in my oil so I don't have a cracked head!I have a VW Jetta Wagon 2.0T FSI and I am having a cylinder 1 misfire.
The car starts to vibrate after sitting there idle then I get the code P0301. It misfires and I can clear the code and the car is fine again!I have a VW Jetta Wagon 2.0T FSI and I am having a cylinder 1 misfire.
Checked my FUEL RAIL and the pressure increased after and I turned the car off! I can't get this figured out. What is wrong with this car!?I have a VW Jetta Wagon 2.0T FSI and I am having a cylinder 1 misfire.
