Results 1 to 10 of 16
Thread: P0301
    Mar 2020
    Chicago, USA
    P0301
    000769 - Cylinder 1 P0301 - 000 - Misfire Detected
    Mar 2020
    Chicago, USA
    I have a VW Jetta Wagon 2.0T FSI and I am having a cylinder 1 misfire.
    Mar 2020
    Chicago, USA
    Quote Originally Posted by eman View Post
    Here is my engine fault code:
    Address 01: Engine (CBF) Labels: 06J-907-115-CBF.clb
    Part No SW: 1K0 907 115 AF HW: 1K0 907 115 AD
    Component: 2.0l R4/4V TFSI 0010
    Revision: E3H12--- Serial number: VWX7Z0H82460LT
    Coding: 0403010818070160
    VCID: 6A8ECB7AE074EB4793D-803E
    000769 - Cylinder 1
    Mileage: 120453 km
    Time: 09:07:14
    RPM: 2985 /min
    Load: 16.5 %
    Speed: 26.0 km/h
    Temperature: 93.0C
    Temperature: 29.0C
    Absolute Pres.: 1000.0 mbar
    Voltage: 13.716 V
    Readiness: 0110 1101
    Mar 2020
    Chicago, USA
    The car misfires when idle and when I'm driving it the misfire goes away!
    Mar 2020
    Chicago, USA
    I have check the spark plugs and the coils!
    Mar 2020
    Chicago, USA
    The cables look ok! Seem to have a vacuum leak so changing the Engine Crankcase Vent Valve but I still think something is wrong! Is it my fuel injector or do I have a bent valve. I check the compression on all cylinders and got 90 PSI on 2, 3, and 4 but 1 only had 60 PSI. I need to know if I should take out the head and check the injector and walnut blast the valves?
  7. #7
    Mar 2020
    Chicago, USA
    Is the cam worn!?
  8. #8
    Mar 2020
    Chicago, USA
    There is no coolant in my oil so I don't have a cracked head!
  9. #9
    Mar 2020
    Chicago, USA
    The car starts to vibrate after sitting there idle then I get the code P0301. It misfires and I can clear the code and the car is fine again!
  10. #10
    Mar 2020
    Chicago, USA
    Checked my FUEL RAIL and the pressure increased after and I turned the car off! I can't get this figured out. What is wrong with this car!?
