Results 1 to 8 of 8
Thread: 2017 Touareg TPMS pressure set points
    Mar 2020
    I am trying to change the rear tires set point of 42 PSI that is indicated on the TPMS display. The front tires have a set point of 33 PSI. I believe the rear tires are set that high due to the fact that the Touareg comes factory equipped with a trailer hitch. I would like to lower that pressure for normal driving conditions.
    When accessing controller 65 for the tire pressures, all the the values shown for both front and rear tires show 255. I expected to see possibly bar settings instead of pressures so I'm not sure what 255 indicates. Any thoughts?
    Thursday,19,March,2020,10:30:33:39655
    VIN: WVGGF7BP3HD002566   License Plate:
    Chassis Type: BP-VW52 (7P6)
    Scan: 01 02 03 05 08 09 10 13 15 16 17 19 36 3C 42 46 47 52 53 55
              56 5F 62 65 69 6C 6D 72 85 8B 8E
    VIN: WVGGF7BP3HD002566   Mileage: 24162km-15013miles
    Address 01: Engine (J623-CGRA)       Labels:. 03H-907-309-V1.clb
       Part No SW: 03H 906 023 DD    HW: 03H 907 309 E
       Component: VR6 3.6l FSI  H17 3178
       Revision: M7H17---
       Coding: 002A0012437600000000
       Shop #: WSC 31414 790 00001
       ASAM Dataset: EV_ECM36FSI01103H906023DD 002001
       ROD: EV_ECM36FSI01103H906023DD_002.rod
       VCID: 678BBD2CFFE47A4F68F-8032
    Address 02: Auto Trans (J217)       Labels: 0C8-927-755.clb
       Part No SW: 0C8 927 755 F    HW: 0C8 927 755
       Component: AL1000 AISIN  130 2885
       Coding: 010200000C008400000000000000000000000000
       ASAM Dataset: EV_TCMAL991031 003118
       ROD: EV_TCMAL991031_003.rod
       VCID: 34311A60FEB2C1D71DD-8060
    Address 03: ABS Brakes (J104)       Labels:* 7P0-907-379.clb
       Part No SW: 7P0 907 379 R    HW: 7P0 907 379 A
       Component: MK25A         H37 0521
       Revision: --------    Serial number: 42446443982834
       Coding: 5B7613C349246F55DAF9C89992D8F660F701
       ASAM Dataset: EV_MK25AXT 010001
       ROD: EV_ESPMK25A01000.rod
       VCID: 4CC162808642B91765D-8018
       Part No SW: 4H0 907 064 JK    HW: 4H0 907 064 JK
       Component: BCM2 2.0      H43 0582
       Coding: 0D860016000000000000
       VCID: 7BA3F15C93ECCEAF9C7-802E
       Subsystem 1 - Part No SW: 4H0 905 852 B    HW: 4H0 905 852 B
       Serial number: 3215000198837010
    02823 - Requirements for Locking the Steering Column Lock not met
                        Reset counter: 206
                        Mileage: 23655 km
                        Date: 2020.02.25
                        Time: 11:05:48
       Part No SW: 7P6 907 040 DA    HW: 7P6 907 040 DA
       Component: Klima 2 Zonen H23 1608
       Coding: 4686200A80
       VCID: 76B5E068A84E93C7E39-8022
       Part No SW: 4H0 907 063 DA    HW: 4H0 907 063 AA
       Revision: 22020001    Serial number: 00001479918201
       Coding: 26000096963C5D010020480480005D4C431C6608A2014265800000008040110000000000000000
       VCID: 6A8DC418EC764727771-803E
       Component: WWS    160824  033 0021
       Serial number: 90243400160912062944
       Coding: 004DBD
       Subsystem 2 - Part No SW: 7P0 955 559 E    HW: 7P0 955 559 E  Labels: 8K0-955-559.CLB
       Component: RLFS  H10 0020
       Serial number: 80908212
       Coding: 025223
       Subsystem 3 - Part No SW: 7P6 941 431 AC    HW: 7P6 941 431 AC
       Component: E1 - LDS  H02 0040
       Serial number: 00000000000809160031
       Component: USHL4.2  H30 0030
       Serial number: 00000000095Z0259390B
       Subsystem 5 - Part No SW: 8K0 959 772 E    HW: 8K0 959 772
       Component: SLR-B8  H06 0007
       Serial number:           0210575373
       Coding: 952F00
       Subsystem 6 - Part No SW: 4H0 907 705 K    HW: 4H0 907 705 C
       Component: EVLS-SG  H08 0300
       Serial number: WA122555000017816728
       Coding: 010300
    03607 - Control Module for Electrically Adjustable Steering Column
                        Fault Status: 01100101
                        Reset counter: 102
                        Mileage: 19753 km
                        Date: 2019.11.18
                        Time: 09:40:32
    Address 10: Park/Steer Assist (J446)       Labels:| 7P6-919-475.clb
       Part No SW: 7P6 919 475 D    HW: 7N0 919 475
       Component: PARKHILFE 8K  H06 0030
       Revision: --------    Serial number: 28261623702428
       Coding: 510D04
       ASAM Dataset: EV_VW526ParkiAssis2 001013
       ROD: EV_VW526ParkiAssis2.rod
       VCID: 44D14AA0AE127157ADD-8010
       Part No SW: 7P6 907 561 C    HW: 7P6 907 561
       Component: ACC3          H21 0400
       Coding: 3701010101
       ASAM Dataset: EV_AdaptCruisContrVW526 002012
       ROD: EV_AdaptCruisContrVW526_002.rod
       VCID: 3C213240D6E20997D5D-8068
    10240 - Sensor for Automatic Distance Control
              [FAULT_BLR_BLK8_31]
                        Fault Frequency: 12
                        Reset counter: 215
                        Mileage: 22018 km
                        Date: 2019.12.25
                        Time: 10:17:25
                        Voltage terminal 15: 14.636 V
                        Velocity_vehicle_reference: 29.61 m/s
    11264 - Sensor for Automatic Distance Regulation
              C110B 49 [008] - Internal electronic failure
              [FAULT_UAR_NVK8_31]
                        Reset counter: 219
                        Mileage: 24120 km
                        Date: 2020.03.10
                        Time: 12:52:26
                        Voltage terminal 15: 12.282 V
                        Velocity_vehicle_reference: -0.02 m/s
                        Longitudinal_acceleration_vehicle_reference: -0.01 m/s²
    92416 - Function Restriction due to Faults in Other Modules
              U1113 00 [008] - -
              [FAULT_CIS_LRRS_FAIL]
                        Reset counter: 219
                        Mileage: 24120 km
                        Date: 2020.03.10
                        Time: 12:52:23
                        Control Module temperature: 18 °C
                        Voltage terminal 15: 11.891 V
       Part No SW: 7P0 959 655 F    HW: 7P0 959 655 F
       Component: VW10Airbag02F H10 0044
       Revision: --------    Serial number: 003S8004358G
       Coding: 000000000000000000000000000000003246
       ASAM Dataset: EV_AirbaVW10BPAVW526 002001
       ROD: EV_AirbaVW10BPAVW526_002_VW52.rod
       Subsystem 1 - Part No SW: 7P6 959 339     HW: 7P6 959 339
       Component: BF-Gewichtss.  003 0005
       Serial number: 5850000R167060SZUS
       Serial number: 3575LRB406343GQ88O4D
       Serial number: 3585LRB405B45CG69GOK
       Serial number: 3517ARB405V44QG038SL
       Serial number: 3527ARB405V44QG0B903
       Serial number: 3557BRB404V46MSCL09
       Serial number: 3567BRB404V46MSCHOU.
       Part No SW: 4H0 953 568 M    HW: 7P6 953 507 AJ
       Component: Lenks.Modul   H06 0010
       Revision: --------    Serial number: 01374PIH0003L
       Coding: 000CDD
       VCID: 3D273F44CD78009FE23-8068
       Subsystem 1 - Part No SW: 7P6 959 542 A    HW: 7P6 959 542 A
       Component: E221__MFL-TAS  H04 0028
       Serial number: 0136727 TRW 20160829
       Part No SW: 7P6 920 983 M    HW: 7P6 920 983 M
       Component: Kombi         H13 0607
       Revision: 13240312    Serial number: 658070916592016
       Coding: 8B5732026F08CF05020004
       ASAM Dataset: EV_KombiUDSRBVW526 001030
       ROD: EV_KombiUDSRBVW526.rod
       VCID: 49CF5B948930AC3F5EB-801C
       Part No SW: 7P6 907 530 R    HW: 7P6 907 530 G
       Component: GW-CAN-L-FR-M H15 6051
       Revision: --------    Serial number: 00000002360126
       Coding: 0021035600
       ASAM Dataset: EV_GatewVW526UDS 001008
       ROD: EV_GatewUDS_VW52.rod
       VCID: 47CB5DAC9F245A4F48F-8012
       Subsystem 1 - Part No SW: 7P0 915 181 C    HW: 7P0 915 181 C
       Component: Batt_Sensor  H07 0270
       Serial number: 33251F08015811574544
       Part No SW: 4H0 959 760 E    HW: 4H0 959 760 E
       Component: MEM-FS        H08 0156
       Revision: AA000000    Serial number: 00000215647525
       Coding: C0581B0015004001000001010101202020202121202020
       VCID: 35372764F548D8DF2A3-8060
       Part No SW: 7P6 907 566 A    HW: 4H0 907 566 F
       Component: SWA Master    H08 0030
       Serial number: 0414614434
       Coding: 030221
       ROD: EV_LaneChangAssis_VW51.rod
       VCID: 3FDB454CC7F4128FF0F-806A
       Lane Change Assistant 2:
       Subsystem 1 - Part No SW: 7P6 907 568 A    HW: 4H0 907 568 F
       Component: SWA Slave  H08 0030
       Serial number: 0415495379
       Coding: 030221
       Part No SW: 4H0 959 793 AC    HW: 4H0 959 793 P
       Component: TSG FA        H03 0306
       Revision: --------    Serial number: 0000219100308
       Coding: 011D17205E00453005080001
       VCID: 7AADF4589CD6F7A7871-802E
    02127 - Exterior Door Handle Light / Mirror Light
                        Fault Status: 00101100
                        Reset counter: 185
                        Mileage: 23032 km
                        Date: 2020.01.19
                        Time: 17:16:29
       Revision: 00002001    Serial number: 0417066479
       Coding: 0187123A68B9509580B00620210A18000000000000000000000000000000
       Subsystem 1 - Part No SW: 7P6 959 719 A    HW: 7P6 959 719 A
       Component: GTO BT  H20 0059
       Serial number: 068168336
       Subsystem 3 - Part No SW: 7P0 959 591 D    HW: 6R0 959 591 D
       Component: J245 PS30.408  H03 0004
       Serial number: 0000FST0016CXR700000
       Coding: 191100
       Subsystem 4 - Part No SW: 7P0 959 591 E    HW: 8V3 959 591 A
       Component: J394 PS30.408  H03 0004
       Serial number: 0000FST0016NRWH00000
       Coding: 191100
       Subsystem 5 - Part No SW: 3AA 962 243 E    HW: 3AA 962 243 E
       Component: GEB.F.Heckoef  H16 0813
       Serial number: 65066819
       Part No SW: 7P6 035 466     HW: 7P6 035 466
       Component: DSP Prem      H02 0090
       Revision: 00002001    Serial number: 10813003513002
       VCID: 75B7E764B5C898DFEA3-8020
       Part No SW: 4H0 959 792 S    HW: 4H0 959 792 M
       Component: TSG BF        H03 0306
       Revision: --------    Serial number: 0000219188462
       Coding: 011D17205E00453005080000
       VCID: 48C95E9092BA5537415-801C
       Part No SW: 7P0 907 801 G    HW: 7P0 907 801 G
       Component: EPB           H51 1201
       Revision: 00000000    Serial number: C1691100360
       Coding: 01040200
       ROD: EV_ParkbA7.rod
       VCID: 372B2D6CEFC42ACF38F-8062
       Slave 3:
       Component: AFS-ECU       H01 0120
       Coding: 012A02010B000400
       ROD: EV_HeadlRegulAFSMQBMLB.rod
       Subsystem 1 - Part No SW: 8U0 941 329     HW: 8U0 941 329   Labels: 3D0-941-329.CLB
       Component: LeiMo links  H01 0006
       Coding: B00000
       Subsystem 2 - Part No SW: 8U0 941 329     HW: 8U0 941 329   Labels: 3D0-941-329.CLB
       Component: LeiMo rechts  H01 0006
       Coding: B00000
       Part No SW: 4G0 035 082 H    HW: 4G0 035 082
       Component: Radio U SIRIU H66 0138
       Revision: AB001007    Serial number: 156I.0G2730444
       Coding: 020007010000000001
       VCID: 2517F72445E8A85F9A3-8070
       Part No SW: 7P6 035 664 M    HW: 7P6 035 664 A
       Component: H-BN-NA       H42 1024
       Revision: --------    Serial number: 606I70G7526980
       Coding: 020200050040E9EF79022B0E00000003F00001030000000000
       VCID: 42DD4CB8B4867F679F1-8016
       Subsystem 1 - Part No: 7P6 060 884 F
       Component: NAR 2016/2017  1402
       Subsystem 2 - Part No SW: 7P6 919 603 L    HW: 7P6 919 603 L
       Component: DU8 SV Touch  H56 0046
       Serial number: VWZ8Z9SGG00C9R
       Subsystem 3 - Part No SW: 7P6 919 603 L    HW: 7P6 919 603 L
       Component: CD-Database  6890
       Part No SW: 4H0 959 795 P    HW: 4H0 959 795 J
       Component: TSG HL        H04 0306
       Revision: --------    Serial number: 0000218833402
       Coding: 011817200000253005080000
    Address 65: Tire Pressure (J502)       Labels: 3Y0-907-273.clb
       Part No SW: 7P6 907 273 L    HW: 5Q0 907 273
       Component: RDKBERU30     H04 0003
       Serial number: 30000000048156
       ASAM Dataset: EV_RDKBERU30 005005
       ROD: EV_RDKBERU30_005.rod
       VCID: 45D757A4A528485FBA3-8010
    Address 69: Trailer (J345)       Labels:| 4H0-907-383-V2.clb
       Part No SW: 4H0 907 383 M    HW: 4H0 907 383 K
       Component: Anhaenger     H20 0160
       Revision: 7C001003    Serial number: 0415915328
       Coding: 0200000200000000
       ROD: EV_TrailFunctGener2Hella_VW52.rod
    Address 6C: Back-up Cam. (J928)       Labels:| 7P6-907-441-V1.clb
       Part No SW: 7P6 907 441 G    HW: 7P6 907 441 G
       Component: TopView       H09 0115
       Revision: 11001001    Serial number: 82330JG0193657
       Coding: 0100000000010000010102000000
       ASAM Dataset: EV_CamerSysteTopViewVW 001014
       ROD: EV_CamerSysteTopViewVW.rod
       VCID: 3D273F44CDF8009FE23-8068
       Part No SW: 7P6 959 107 C    HW: 7P6 959 107
       Component: HDSG-Modul    H10 0043
       Revision: 22010001    Serial number: 253600881
       Coding: 0533314003
       ASAM Dataset: EV_HeckkTouar 202142
       ROD: EV_HeckkTouar.rod
       Component: TSG HR        H04 0306
       Revision: --------    Serial number: 0000218838848
       Part No SW: 7P6 907 217 B    HW: 7P6 907 217
       Component: DPC-SG        H26 0035
       Coding: 69020000
       ASAM Dataset: EV_OnBoardCamerDTR 001001
       ROD: EV_OnBoardCamerDTR.rod
       VCID: 392F2B54D9D03CBFCEB-806C
       Slave 1:
       Subsystem 1 - Part No: 7P6 907 658
       Component: NICKRATENSENS  H02 0001
       Serial number: 000000007068806_3096
       Part No SW: 7P6 907 541 C    HW: 7P6 907 541
       Coding: 3701010101
       ASAM Dataset: EV_AdaptCruisContr2VW526 002011
       ROD: EV_AdaptCruisContr2VW526_002.rod
       VCID: 3A2D3458DCD637A7C71-806E
    Address 8E: Image Processing (J851)       Labels:| 7P6-907-107.clb
       Part No SW: 7P6 907 107 B    HW: 7P6 907 107
       Component: BV-SG         H34 0035
       Serial number: 005002473108167
       Coding: 0AA118040000
       ASAM Dataset: EV_BTR 002001
       ROD: EV_BTR_002.rod
    End----(Elapsed Time: 02:28, VBatt start/end: 11.7V/11.7V. VIgn 11.7V)-----
    Hi and welcome.
    Please make an Adaptation Channel Map from module 65 and let's see what's in there.
    There are channels that specify front and rear "Fully Loaded" pressures, "Standard" pressures, and "Comfort" pressures.
    There is also on that specifies "Load Status Selected" (Fully Loaded, Standard, Comfort). I would guess there's also a setting in the vehicle's menus somewhere that lets you specify whether the current condition is Fully Loaded, Standard, or Comfort.
    Mar 2020
    Channel 65 Adaption Map
    Hi and welcome.
    Channel map sent to support@ross-tech.com.
    There is no selection in the car's infotainment system to select between comfort,standrd or fully loaded. You can select between PSI, Bar or KPA for the readout on the display....
    Hope this is correct
    Tartu, Estonia
    Pressure profile is loaded to module via parameters. Can't be done with vcds.
    You might be able to chabge individual value in adaption.
    The world is my oyster...
  5. Likes Dana, Uwe, Jack@European_Parts liked this post
    Quote Originally Posted by Dick View Post
    Would be nice if you could post it here too (it's a text file so just copy and paste it between [code][/code] tags), so that other Touareg owners can possibly help.
  7. Likes Uwe, Dana, Jack@European_Parts liked this post
    What he sent to Support was a Measuring Value map, not an Adaptation Channel map.
  9. Likes PetrolDave liked this post
  10. #7
    United States
    We did receive another file which was an ADP map. I'll post them here so he receives suggestions from a variety of users but I believe golfi_vend is correct. I don't believe changing any of those 255 stored values is going to directly result in specified pressure changes.
    ADP
    ;SW:7P6-907-273-L   HW:5Q0-907-273 ---  Tire Pressure
    ;Component:RDKBERU30     H04 0003	 Coding:
    ;EV_RDKBERU30	5005	EV_RDKBERU30_005.rod
    ;Thursday	19	March	2020	16:02:25:39655
    ;VCDS Version: Release 19.6.2 (x64)  Data version: 20200210 DS308.0
    ;VCID: 45D757A4A528485FBA3-8010
    IDE03508-SPECIFIED pressure line selection (end of assembly line)	1	1
    IDE03511-Front-axle SPECIFIED pressure fully loaded	255	1
    IDE03512-Rear-axle SPECIFIED pressure fully loaded	255	1
    IDE03513-IDE03525-Write sensor identification number-Sensor identification number (sensor ID)	0	5
    IDE03513-IDE06104-Write sensor identification number-Wheel position	Left front 	5
    IDE03532-Load status selected	Standard 	1
    IDE08521-Front-axle SPECIFIED pressure comfort	255	1
    IDE08522-Rear-axle SPECIFIED pressure comfort	255	1
    IDE08523-Front-axle SPECIFIED pressure standard	255	1
    IDE08524-Rear-axle SPECIFIED pressure standard	255	1
    MAS02356-Type of calibration	Menu 	1
    Elapsed Time: 00:02
    MVB
    ;Thursday	19	March	2020	14:51:28:39655
    Group	Description	Actual
    IDE00019	Voltage terminal 30	12.1	 V
    IDE00075	Vehicle speed	0	 km/h
    IDE00310	Outside air temperature	21.5	 °C
    IDE00323	Security Access: Number of invalid keys	0
    IDE03529-IDE03525	Last received tire pressure sensor in reception range-Sensor identification number (sensor ID)	0
    IDE03529-IDE06104	Last received tire pressure sensor in reception range-Wheel position	Unknown
    IDE03529-MAS02818	Last received tire pressure sensor in reception range-CURRENT pressure	5.4	 bar
    IDE03529-MAS02819	Last received tire pressure sensor in reception range-CURRENT temperature	127	 °C
    IDE03529-MAS03159	Last received tire pressure sensor in reception range-Manufacturer	Unknown
    IDE03530-IDE03531	Monitoring status-Wheel/tire description	Standard
    IDE03530-IDE03532	Monitoring status-Load status selected	Standard
    IDE03530-IDE03533	Monitoring status-Front-axle SPECIFIED pressure	2.3	 bar
    IDE03530-IDE03534	Monitoring status-Rear-axle SPECIFIED pressure	2.9	 bar
    IDE03530-MAS05745	Monitoring status-Wheel / tire set	1
    IDE03535-IDE02955	System information-System status	active
    IDE03535-IDE03526	System information-Radio interference	not active
    IDE03535-MAS00080	System information-Coding information	01 00
    IDE03535-MAS00084	System information-Terminal 15 on	On
    IDE03535-MAS01561	System information-Unit	psi
    IDE03535-MAS01745	System information-Vehicle speed is not zero	OFF
    IDE03535-MAS02356	System information-Type of calibration	Menu
    IDE03535-MAS04188	System information-Transport mode	not active
    IDE03535-MAS05644	System information-Partial monitoring	not active
    IDE06105-IDE03525	Tire pressure sensor 01-Sensor identification number (sensor ID)	617449311
    IDE06105-IDE06104	Tire pressure sensor 01-Wheel position	Left front
    IDE06105-MAS02818	Tire pressure sensor 01-CURRENT pressure	2.4	 bar
    IDE06105-MAS02819	Tire pressure sensor 01-CURRENT temperature	127	 °C
    IDE06105-MAS02820	Tire pressure sensor 01-SPECIFIED pressure	2.3	 bar
    IDE06105-MAS03159	Tire pressure sensor 01-Manufacturer	HuF
    IDE06105-MAS05317	Tire pressure sensor 01-Warning pressure	25.5	 bar
    IDE06106-IDE03525	Tire pressure sensor 02-Sensor identification number (sensor ID)	609737924
    IDE06106-IDE06104	Tire pressure sensor 02-Wheel position	Right front
    IDE06106-MAS02818	Tire pressure sensor 02-CURRENT pressure	2.3	 bar
    IDE06106-MAS02819	Tire pressure sensor 02-CURRENT temperature	127	 °C
    IDE06106-MAS02820	Tire pressure sensor 02-SPECIFIED pressure	2.3	 bar
    IDE06106-MAS03159	Tire pressure sensor 02-Manufacturer	HuF
    IDE06106-MAS05317	Tire pressure sensor 02-Warning pressure	25.5	 bar
    IDE06107-IDE03525	Tire pressure sensor 03-Sensor identification number (sensor ID)	609737121
    IDE06107-IDE06104	Tire pressure sensor 03-Wheel position	Left rear
    IDE06107-MAS02818	Tire pressure sensor 03-CURRENT pressure	2.6	 bar
    IDE06107-MAS02819	Tire pressure sensor 03-CURRENT temperature	127	 °C
    IDE06107-MAS02820	Tire pressure sensor 03-SPECIFIED pressure	2.9	 bar
    IDE06107-MAS03159	Tire pressure sensor 03-Manufacturer	HuF
    IDE06107-MAS05317	Tire pressure sensor 03-Warning pressure	25.5	 bar
    IDE06108-IDE03525	Tire pressure sensor 04-Sensor identification number (sensor ID)	609737576
    IDE06108-IDE06104	Tire pressure sensor 04-Wheel position	Right rear
    IDE06108-MAS02818	Tire pressure sensor 04-CURRENT pressure	2.6	 bar
    IDE06108-MAS02819	Tire pressure sensor 04-CURRENT temperature	127	 °C
    IDE06108-MAS02820	Tire pressure sensor 04-SPECIFIED pressure	2.9	 bar
    IDE06108-MAS03159	Tire pressure sensor 04-Manufacturer	HuF
    IDE06108-MAS05317	Tire pressure sensor 04-Warning pressure	25.5	 bar
    IDE80001	Analysis 1	OFF
    IDE80002-IDE00056	Analysis 2-History data 1	03 00 00 00 00 00 00 98 9C 00 00 24 57 D9 A1 02
    IDE80002-IDE00057	Analysis 2-History data 2	03 00 00 00 00 00 00 98 9C 00 00 24 57 DB 68 03
    IDE80002-IDE00058	Analysis 2-History data 3	02 00 5E 38 0B 03 14 88 9C 00 36 24 57 DB 68 03
    IDE80002-IDE00059	Analysis 2-History data 4	02 00 5E 38 0B 03 14 88 9C 00 35 24 57 D9 A1 02
    IDE80002-IDE00060	Analysis 2-History data 5	03 00 5E 37 0A 03 14 90 84 00 00 24 CD 87 5F 00
    IDE80002-IDE00061	Analysis 2-History data 6	03 00 5E 37 0A 03 14 90 84 00 00 24 57 DC C4 01
    IDE80002-IDE00062	Analysis 2-History data 7	02 00 5E 31 09 03 14 88 9C 00 37 24 57 DC C4 01
    IDE80002-IDE00063	Analysis 2-History data 8	02 00 5E 31 09 03 14 88 9C 00 38 24 CD 87 5F 00
    IDE80002-IDE00064	Analysis 2-History data 9	03 00 5E 31 09 03 14 FF 9C 00 00 24 57 DC C4 03
    IDE80002-IDE00065	Analysis 2-History data 10	03 00 5E 31 09 03 14 FF 9C 00 00 24 CD 87 5F 00
    IDE80002-MAS03991	Analysis 2-Reception level antenna 1	530	 mV
    IDE80002-MAS04488	Analysis 2-Offset level antenna 1	260	 mV
    MAS00464-MAS00106	Standard - ambient data 1-Year	2020
    MAS00464-MAS00107	Standard - ambient data 1-Month	3
    MAS00464-MAS00108	Standard - ambient data 1-Day	19
    MAS00464-MAS00109	Standard - ambient data 1-Hours	14
    MAS00464-MAS00110	Standard - ambient data 1-Minutes	51
    MAS00464-MAS00111	Standard - ambient data 1-Seconds	33
    MAS00464-MAS00468	Standard - ambient data 1-Unlearning counter	182
    MAS00464-MAS00711	Standard - ambient data 1-Odometer reading	24162	 km
    MAS02821-MAS01853	Check tire pressure-Left front	no warning
    MAS02821-MAS01854	Check tire pressure-Right front	no warning
    MAS02821-MAS01855	Check tire pressure-Left rear	Warning
    MAS02821-MAS01856	Check tire pressure-Right rear	Warning
    MAS02821-MAS05636	Check tire pressure-Unknown position	no warning
    MAS02822-MAS01853	Flat tire-Left front	no warning
    MAS02822-MAS01854	Flat tire-Right front	no warning
    MAS02822-MAS01855	Flat tire-Left rear	no warning
    MAS02822-MAS01856	Flat tire-Right rear	no warning
    MAS02822-MAS05636	Flat tire-Unknown position	no warning
    MAS02823-MAS01853	Tire pressure too low-Left front	no warning
    MAS02823-MAS01854	Tire pressure too low-Right front	no warning
    MAS02823-MAS01855	Tire pressure too low-Left rear	no warning
    MAS02823-MAS01856	Tire pressure too low-Right rear	no warning
    MAS02823-MAS05636	Tire pressure too low-Unknown position	no warning
    MAS05645-IDE03511	Wheel / tire set 1-Front-axle SPECIFIED pressure fully loaded	2.3	 bar
    MAS05645-IDE03512	Wheel / tire set 1-Rear-axle SPECIFIED pressure fully loaded	2.9	 bar
    MAS05645-IDE03531	Wheel / tire set 1-Wheel/tire description	Standard
    MAS05645-IDE08521	Wheel / tire set 1-Front-axle SPECIFIED pressure comfort	25.5	 bar
    MAS05645-IDE08522	Wheel / tire set 1-Rear-axle SPECIFIED pressure comfort	25.5	 bar
    MAS05645-IDE08523	Wheel / tire set 1-Front-axle SPECIFIED pressure standard	2.3	 bar
    MAS05645-IDE08524	Wheel / tire set 1-Rear-axle SPECIFIED pressure standard	2.9	 bar
    MAS05646-IDE03511	Wheel / tire set 2-Front-axle SPECIFIED pressure fully loaded	25.5	 bar
    MAS05646-IDE03512	Wheel / tire set 2-Rear-axle SPECIFIED pressure fully loaded	25.5	 bar
    MAS05646-IDE03531	Wheel / tire set 2-Wheel/tire description
    MAS05646-IDE08521	Wheel / tire set 2-Front-axle SPECIFIED pressure comfort	25.5	 bar
    MAS05646-IDE08522	Wheel / tire set 2-Rear-axle SPECIFIED pressure comfort	25.5	 bar
    MAS05646-IDE08523	Wheel / tire set 2-Front-axle SPECIFIED pressure standard	25.5	 bar
    MAS05646-IDE08524	Wheel / tire set 2-Rear-axle SPECIFIED pressure standard	25.5	 bar
    MAS05647-IDE03511	Wheel / tire set 3-Front-axle SPECIFIED pressure fully loaded	25.5	 bar
    MAS05647-IDE03512	Wheel / tire set 3-Rear-axle SPECIFIED pressure fully loaded	25.5	 bar
    MAS05647-IDE03531	Wheel / tire set 3-Wheel/tire description
    MAS05647-IDE08521	Wheel / tire set 3-Front-axle SPECIFIED pressure comfort	25.5	 bar
    MAS05647-IDE08522	Wheel / tire set 3-Rear-axle SPECIFIED pressure comfort	25.5	 bar
    MAS05647-IDE08523	Wheel / tire set 3-Front-axle SPECIFIED pressure standard	25.5	 bar
    MAS05647-IDE08524	Wheel / tire set 3-Rear-axle SPECIFIED pressure standard	25.5	 bar
    MAS05648-IDE03511	Wheel / tire set 4-Front-axle SPECIFIED pressure fully loaded	25.5	 bar
    MAS05648-IDE03512	Wheel / tire set 4-Rear-axle SPECIFIED pressure fully loaded	25.5	 bar
    MAS05648-IDE03531	Wheel / tire set 4-Wheel/tire description
    MAS05648-IDE08521	Wheel / tire set 4-Front-axle SPECIFIED pressure comfort	25.5	 bar
    MAS05648-IDE08522	Wheel / tire set 4-Rear-axle SPECIFIED pressure comfort	25.5	 bar
    MAS05648-IDE08523	Wheel / tire set 4-Front-axle SPECIFIED pressure standard	25.5	 bar
    MAS05648-IDE08524	Wheel / tire set 4-Rear-axle SPECIFIED pressure standard	25.5	 bar
    MAS05649-IDE03511	Wheel / tire set 5-Front-axle SPECIFIED pressure fully loaded	25.5	 bar
    MAS05649-IDE03512	Wheel / tire set 5-Rear-axle SPECIFIED pressure fully loaded	25.5	 bar
    MAS05649-IDE03531	Wheel / tire set 5-Wheel/tire description
    MAS05649-IDE08521	Wheel / tire set 5-Front-axle SPECIFIED pressure comfort	25.5	 bar
    MAS05649-IDE08522	Wheel / tire set 5-Rear-axle SPECIFIED pressure comfort	25.5	 bar
    MAS05649-IDE08523	Wheel / tire set 5-Front-axle SPECIFIED pressure standard	25.5	 bar
    MAS05649-IDE08524	Wheel / tire set 5-Rear-axle SPECIFIED pressure standard	25.5	 bar
    MAS05650-IDE03511	Wheel / tire set 6-Front-axle SPECIFIED pressure fully loaded	25.5	 bar
    MAS05650-IDE03512	Wheel / tire set 6-Rear-axle SPECIFIED pressure fully loaded	25.5	 bar
    MAS05650-IDE03531	Wheel / tire set 6-Wheel/tire description
    MAS05650-IDE08521	Wheel / tire set 6-Front-axle SPECIFIED pressure comfort	25.5	 bar
    MAS05650-IDE08522	Wheel / tire set 6-Rear-axle SPECIFIED pressure comfort	25.5	 bar
    MAS05650-IDE08523	Wheel / tire set 6-Front-axle SPECIFIED pressure standard	25.5	 bar
    MAS05650-IDE08524	Wheel / tire set 6-Rear-axle SPECIFIED pressure standard	25.5	 bar
    MAS05651-IDE03511	Wheel / tire set 7-Front-axle SPECIFIED pressure fully loaded	25.5	 bar
    MAS05651-IDE03512	Wheel / tire set 7-Rear-axle SPECIFIED pressure fully loaded	25.5	 bar
    MAS05651-IDE03531	Wheel / tire set 7-Wheel/tire description
    MAS05651-IDE08521	Wheel / tire set 7-Front-axle SPECIFIED pressure comfort	25.5	 bar
    MAS05651-IDE08522	Wheel / tire set 7-Rear-axle SPECIFIED pressure comfort	25.5	 bar
    MAS05651-IDE08523	Wheel / tire set 7-Front-axle SPECIFIED pressure standard	25.5	 bar
    MAS05651-IDE08524	Wheel / tire set 7-Rear-axle SPECIFIED pressure standard	25.5	 bar
    MAS05652-IDE03511	Wheel / tire set 8-Front-axle SPECIFIED pressure fully loaded	25.5	 bar
    MAS05652-IDE03512	Wheel / tire set 8-Rear-axle SPECIFIED pressure fully loaded	25.5	 bar
    MAS05652-IDE03531	Wheel / tire set 8-Wheel/tire description
    MAS05652-IDE08521	Wheel / tire set 8-Front-axle SPECIFIED pressure comfort	25.5	 bar
    MAS05652-IDE08522	Wheel / tire set 8-Rear-axle SPECIFIED pressure comfort	25.5	 bar
    MAS05652-IDE08523	Wheel / tire set 8-Front-axle SPECIFIED pressure standard	25.5	 bar
    MAS05652-IDE08524	Wheel / tire set 8-Rear-axle SPECIFIED pressure standard	25.5	 bar
    MAS05653-IDE03511	Wheel / tire set 9-Front-axle SPECIFIED pressure fully loaded	25.5	 bar
    MAS05653-IDE03512	Wheel / tire set 9-Rear-axle SPECIFIED pressure fully loaded	25.5	 bar
    MAS05653-IDE03531	Wheel / tire set 9-Wheel/tire description
    MAS05653-IDE08521	Wheel / tire set 9-Front-axle SPECIFIED pressure comfort	25.5	 bar
    MAS05653-IDE08522	Wheel / tire set 9-Rear-axle SPECIFIED pressure comfort	25.5	 bar
    MAS05653-IDE08523	Wheel / tire set 9-Front-axle SPECIFIED pressure standard	25.5	 bar
    MAS05653-IDE08524	Wheel / tire set 9-Rear-axle SPECIFIED pressure standard	25.5	 bar
    MAS05654-IDE03511	Wheel / tire set 10-Front-axle SPECIFIED pressure fully loaded	25.5	 bar
    MAS05654-IDE03512	Wheel / tire set 10-Rear-axle SPECIFIED pressure fully loaded	25.5	 bar
    MAS05654-IDE03531	Wheel / tire set 10-Wheel/tire description
    MAS05654-IDE08521	Wheel / tire set 10-Front-axle SPECIFIED pressure comfort	25.5	 bar
    MAS05654-IDE08522	Wheel / tire set 10-Rear-axle SPECIFIED pressure comfort	25.5	 bar
    MAS05654-IDE08523	Wheel / tire set 10-Front-axle SPECIFIED pressure standard	25.5	 bar
    MAS05654-IDE08524	Wheel / tire set 10-Rear-axle SPECIFIED pressure standard	25.5	 bar
    MAS05655-IDE03511	Wheel / tire set 11-Front-axle SPECIFIED pressure fully loaded	25.5	 bar
    MAS05655-IDE03512	Wheel / tire set 11-Rear-axle SPECIFIED pressure fully loaded	25.5	 bar
    MAS05655-IDE03531	Wheel / tire set 11-Wheel/tire description
    MAS05655-IDE08521	Wheel / tire set 11-Front-axle SPECIFIED pressure comfort	25.5	 bar
    MAS05655-IDE08522	Wheel / tire set 11-Rear-axle SPECIFIED pressure comfort	25.5	 bar
    MAS05655-IDE08523	Wheel / tire set 11-Front-axle SPECIFIED pressure standard	25.5	 bar
    MAS05655-IDE08524	Wheel / tire set 11-Rear-axle SPECIFIED pressure standard	25.5	 bar
    Elapsed Time: 00:05
    Edit. I replied to the OP telling him that I added the maps here. If he would prefer they be removed I suggested replying to support or using the Report Post icon so they can be edited out.
    Yet another edit. I just realized this is in the New User section. I'll move it to Car Repair Support. (Tweaks may be more appropriate ... but I find it entirely relevant to tire wear and maintenance. We can move it again if needed.)
  12. #8
    <SMH>
    Why would VW bother specifying those Adaptation channels if they don't have usable values in them?
  13. Likes Jack@European_Parts, Dana, PetrolDave liked this post
