I am trying to change the rear tires set point of 42 PSI that is indicated on the TPMS display. The front tires have a set point of 33 PSI. I believe the rear tires are set that high due to the fact that the Touareg comes factory equipped with a trailer hitch. I would like to lower that pressure for normal driving conditions.
When accessing controller 65 for the tire pressures, all the the values shown for both front and rear tires show 255. I expected to see possibly bar settings instead of pressures so I'm not sure what 255 indicates. Any thoughts?
Thursday,19,March,2020,10:30:33:39655
VCDS Version: 19.6.2.2 (x64) HEX-V2 CB: 0.4508.4
VIN: WVGGF7BP3HD002566 License Plate:
Chassis Type: BP-VW52 (7P6)
Scan: 01 02 03 05 08 09 10 13 15 16 17 19 36 3C 42 46 47 52 53 55
56 5F 62 65 69 6C 6D 72 85 8B 8E
VIN: WVGGF7BP3HD002566 Mileage: 24162km-15013miles
Address 01: Engine (J623-CGRA) Labels:. 03H-907-309-V1.clb
Part No SW: 03H 906 023 DD HW: 03H 907 309 E
Component: VR6 3.6l FSI H17 3178
Revision: M7H17---
Coding: 002A0012437600000000
Shop #: WSC 31414 790 00001
ASAM Dataset: EV_ECM36FSI01103H906023DD 002001
ROD: EV_ECM36FSI01103H906023DD_002.rod
VCID: 678BBD2CFFE47A4F68F-8032
Address 02: Auto Trans (J217) Labels: 0C8-927-755.clb
Part No SW: 0C8 927 755 F HW: 0C8 927 755
Component: AL1000 AISIN 130 2885
Coding: 010200000C008400000000000000000000000000
ASAM Dataset: EV_TCMAL991031 003118
ROD: EV_TCMAL991031_003.rod
VCID: 34311A60FEB2C1D71DD-8060
Address 03: ABS Brakes (J104) Labels:* 7P0-907-379.clb
Part No SW: 7P0 907 379 R HW: 7P0 907 379 A
Component: MK25A H37 0521
Revision: -------- Serial number: 42446443982834
Coding: 5B7613C349246F55DAF9C89992D8F660F701
ASAM Dataset: EV_MK25AXT 010001
ROD: EV_ESPMK25A01000.rod
VCID: 4CC162808642B91765D-8018
Part No SW: 4H0 907 064 JK HW: 4H0 907 064 JK
Component: BCM2 2.0 H43 0582
Coding: 0D860016000000000000
VCID: 7BA3F15C93ECCEAF9C7-802E
Subsystem 1 - Part No SW: 4H0 905 852 B HW: 4H0 905 852 B
Serial number: 3215000198837010
02823 - Requirements for Locking the Steering Column Lock not met
Reset counter: 206
Mileage: 23655 km
Date: 2020.02.25
Time: 11:05:48
Address 08: Auto HVAC (J255) Labels:| 7P6-907-040.clb
Part No SW: 7P6 907 040 DA HW: 7P6 907 040 DA
Component: Klima 2 Zonen H23 1608
Coding: 4686200A80
VCID: 76B5E068A84E93C7E39-8022
Address 09: Cent. Elect. (J519) Labels:. 4H0-907-063-V2.clb
Part No SW: 4H0 907 063 DA HW: 4H0 907 063 AA
Component: BCM1 2.0 H20 0311
Revision: 22020001 Serial number: 00001479918201
Coding: 26000096963C5D010020480480005D4C431C6608A2014265800000008040110000000000000000
VCID: 6A8DC418EC764727771-803E
Subsystem 1 - Part No SW: 7P0 955 119 HW: 7P0 955 119 Labels: 1KX-955-119.CLB
Component: WWS 160824 033 0021
Serial number: 90243400160912062944
Coding: 004DBD
Subsystem 2 - Part No SW: 7P0 955 559 E HW: 7P0 955 559 E Labels: 8K0-955-559.CLB
Component: RLFS H10 0020
Serial number: 80908212
Coding: 025223
Subsystem 3 - Part No SW: 7P6 941 431 AC HW: 7P6 941 431 AC
Component: E1 - LDS H02 0040
Serial number: 00000000000809160031
Component: USHL4.2 H30 0030
Serial number: 00000000095Z0259390B
Subsystem 5 - Part No SW: 8K0 959 772 E HW: 8K0 959 772
Component: SLR-B8 H06 0007
Serial number: 0210575373
Coding: 952F00
Subsystem 6 - Part No SW: 4H0 907 705 K HW: 4H0 907 705 C
Component: EVLS-SG H08 0300
Serial number: WA122555000017816728
Coding: 010300
03607 - Control Module for Electrically Adjustable Steering Column
Fault Status: 01100101
Reset counter: 102
Mileage: 19753 km
Date: 2019.11.18
Time: 09:40:32
Address 10: Park/Steer Assist (J446) Labels:| 7P6-919-475.clb
Part No SW: 7P6 919 475 D HW: 7N0 919 475
Component: PARKHILFE 8K H06 0030
Revision: -------- Serial number: 28261623702428
Coding: 510D04
ASAM Dataset: EV_VW526ParkiAssis2 001013
ROD: EV_VW526ParkiAssis2.rod
VCID: 44D14AA0AE127157ADD-8010
Part No SW: 7P6 907 561 C HW: 7P6 907 561
Component: ACC3 H21 0400
Coding: 3701010101
ASAM Dataset: EV_AdaptCruisContrVW526 002012
ROD: EV_AdaptCruisContrVW526_002.rod
VCID: 3C213240D6E20997D5D-8068
10240 - Sensor for Automatic Distance Control
[FAULT_BLR_BLK8_31]
Fault Frequency: 12
Reset counter: 215
Mileage: 22018 km
Date: 2019.12.25
Time: 10:17:25
Control Module temperature: 19 °C
Voltage terminal 15: 14.636 V
Velocity_vehicle_reference: 29.61 m/s
11264 - Sensor for Automatic Distance Regulation
C110B 49 [008] - Internal electronic failure
[FAULT_UAR_NVK8_31]
Reset counter: 219
Mileage: 24120 km
Date: 2020.03.10
Time: 12:52:26
Voltage terminal 15: 12.282 V
Velocity_vehicle_reference: -0.02 m/s
Longitudinal_acceleration_vehicle_reference: -0.01 m/s²
92416 - Function Restriction due to Faults in Other Modules
U1113 00 [008] - -
[FAULT_CIS_LRRS_FAIL]
Reset counter: 219
Mileage: 24120 km
Date: 2020.03.10
Time: 12:52:23
Control Module temperature: 18 °C
Voltage terminal 15: 11.891 V
Address 15: Airbags (J234) Labels:| 7P0-959-655.clb
Part No SW: 7P0 959 655 F HW: 7P0 959 655 F
Component: VW10Airbag02F H10 0044
Revision: -------- Serial number: 003S8004358G
Coding: 000000000000000000000000000000003246
ASAM Dataset: EV_AirbaVW10BPAVW526 002001
ROD: EV_AirbaVW10BPAVW526_002_VW52.rod
Subsystem 1 - Part No SW: 7P6 959 339 HW: 7P6 959 339
Component: BF-Gewichtss. 003 0005
Serial number: 5850000R167060SZUS
Serial number: 3575LRB406343GQ88O4D
Serial number: 3585LRB405B45CG69GOK
Serial number: 3517ARB405V44QG038SL
Serial number: 3527ARB405V44QG0B903
Serial number: 3557BRB404V46MSCL09
Serial number: 3567BRB404V46MSCHOU.
Part No SW: 4H0 953 568 M HW: 7P6 953 507 AJ
Component: Lenks.Modul H06 0010
Revision: -------- Serial number: 01374PIH0003L
Coding: 000CDD
VCID: 3D273F44CD78009FE23-8068
Subsystem 1 - Part No SW: 7P6 959 542 A HW: 7P6 959 542 A
Component: E221__MFL-TAS H04 0028
Serial number: 0136727 TRW 20160829
Address 17: Instruments (J285) Labels:| 7P6-920-xxx-17.clb-SRI1
Part No SW: 7P6 920 983 M HW: 7P6 920 983 M
Component: Kombi H13 0607
Revision: 13240312 Serial number: 658070916592016
Coding: 8B5732026F08CF05020004
ASAM Dataset: EV_KombiUDSRBVW526 001030
ROD: EV_KombiUDSRBVW526.rod
VCID: 49CF5B948930AC3F5EB-801C
Part No SW: 7P6 907 530 R HW: 7P6 907 530 G
Component: GW-CAN-L-FR-M H15 6051
Revision: -------- Serial number: 00000002360126
Coding: 0021035600
ASAM Dataset: EV_GatewVW526UDS 001008
ROD: EV_GatewUDS_VW52.rod
VCID: 47CB5DAC9F245A4F48F-8012
Subsystem 1 - Part No SW: 7P0 915 181 C HW: 7P0 915 181 C
Component: Batt_Sensor H07 0270
Serial number: 33251F08015811574544
Part No SW: 4H0 959 760 E HW: 4H0 959 760 E
Component: MEM-FS H08 0156
Revision: AA000000 Serial number: 00000215647525
Coding: C0581B0015004001000001010101202020202121202020
VCID: 35372764F548D8DF2A3-8060
Part No SW: 7P6 907 566 A HW: 4H0 907 566 F
Component: SWA Master H08 0030
Serial number: 0414614434
Coding: 030221
VCID: 3FDB454CC7F4128FF0F-806A
Subsystem 1 - Part No SW: 7P6 907 568 A HW: 4H0 907 568 F
Component: SWA Slave H08 0030
Serial number: 0415495379
Coding: 030221
Part No SW: 4H0 959 793 AC HW: 4H0 959 793 P
Component: TSG FA H03 0306
Revision: -------- Serial number: 0000219100308
Coding: 011D17205E00453005080001
VCID: 7AADF4589CD6F7A7871-802E
02127 - Exterior Door Handle Light / Mirror Light
Fault Status: 00101100
Reset counter: 185
Mileage: 23032 km
Date: 2020.01.19
Time: 17:16:29
Revision: 00002001 Serial number: 0417066479
Coding: 0187123A68B9509580B00620210A18000000000000000000000000000000
Subsystem 1 - Part No SW: 7P6 959 719 A HW: 7P6 959 719 A
Component: GTO BT H20 0059
Serial number: 068168336
Subsystem 3 - Part No SW: 7P0 959 591 D HW: 6R0 959 591 D
Component: J245 PS30.408 H03 0004
Serial number: 0000FST0016CXR700000
Coding: 191100
Subsystem 4 - Part No SW: 7P0 959 591 E HW: 8V3 959 591 A
Component: J394 PS30.408 H03 0004
Serial number: 0000FST0016NRWH00000
Coding: 191100
Subsystem 5 - Part No SW: 3AA 962 243 E HW: 3AA 962 243 E
Component: GEB.F.Heckoef H16 0813
Serial number: 65066819
Part No SW: 7P6 035 466 HW: 7P6 035 466
Component: DSP Prem H02 0090
Revision: 00002001 Serial number: 10813003513002
VCID: 75B7E764B5C898DFEA3-8020
Part No SW: 4H0 959 792 S HW: 4H0 959 792 M
Component: TSG BF H03 0306
Revision: -------- Serial number: 0000219188462
Coding: 011D17205E00453005080000
VCID: 48C95E9092BA5537415-801C
Address 53: Parking Brake (J540-) Labels:| 7P0-907-801.clb
Part No SW: 7P0 907 801 G HW: 7P0 907 801 G
Component: EPB H51 1201
Revision: 00000000 Serial number: C1691100360
Coding: 01040200
ROD: EV_ParkbA7.rod
VCID: 372B2D6CEFC42ACF38F-8062
Slave 3:
Part No SW: 7P6 907 357 C HW: 7P6 907 357 B
Component: AFS-ECU H01 0120
Coding: 012A02010B000400
Subsystem 1 - Part No SW: 8U0 941 329 HW: 8U0 941 329 Labels: 3D0-941-329.CLB
Component: LeiMo links H01 0006
Coding: B00000
Subsystem 2 - Part No SW: 8U0 941 329 HW: 8U0 941 329 Labels: 3D0-941-329.CLB
Component: LeiMo rechts H01 0006
Coding: B00000
Part No SW: 4G0 035 082 H HW: 4G0 035 082
Component: Radio U SIRIU H66 0138
Revision: AB001007 Serial number: 156I.0G2730444
Coding: 020007010000000001
VCID: 2517F72445E8A85F9A3-8070
Part No SW: 7P6 035 664 M HW: 7P6 035 664 A
Component: H-BN-NA H42 1024
Revision: -------- Serial number: 606I70G7526980
Coding: 020200050040E9EF79022B0E00000003F00001030000000000
VCID: 42DD4CB8B4867F679F1-8016
Subsystem 1 - Part No: 7P6 060 884 F
Component: NAR 2016/2017 1402
Subsystem 2 - Part No SW: 7P6 919 603 L HW: 7P6 919 603 L
Component: DU8 SV Touch H56 0046
Serial number: VWZ8Z9SGG00C9R
Subsystem 3 - Part No SW: 7P6 919 603 L HW: 7P6 919 603 L
Component: CD-Database 6890
Address 62: Door, Rear Left (J388) Labels:. 4H0-959-795.clb
Part No SW: 4H0 959 795 P HW: 4H0 959 795 J
Component: TSG HL H04 0306
Revision: -------- Serial number: 0000218833402
Coding: 011817200000253005080000
Address 65: Tire Pressure (J502) Labels: 3Y0-907-273.clb
Part No SW: 7P6 907 273 L HW: 5Q0 907 273
Component: RDKBERU30 H04 0003
Serial number: 30000000048156
ASAM Dataset: EV_RDKBERU30 005005
ROD: EV_RDKBERU30_005.rod
VCID: 45D757A4A528485FBA3-8010
Address 69: Trailer (J345) Labels:| 4H0-907-383-V2.clb
Part No SW: 4H0 907 383 M HW: 4H0 907 383 K
Component: Anhaenger H20 0160
Revision: 7C001003 Serial number: 0415915328
Coding: 0200000200000000
ROD: EV_TrailFunctGener2Hella_VW52.rod
Address 6C: Back-up Cam. (J928) Labels:| 7P6-907-441-V1.clb
Part No SW: 7P6 907 441 G HW: 7P6 907 441 G
Component: TopView H09 0115
Revision: 11001001 Serial number: 82330JG0193657
Coding: 0100000000010000010102000000
ASAM Dataset: EV_CamerSysteTopViewVW 001014
ROD: EV_CamerSysteTopViewVW.rod
VCID: 3D273F44CDF8009FE23-8068
Address 6D: Trunk Elect. (----) Labels:| 7N0-959-107.clb
Part No SW: 7P6 959 107 C HW: 7P6 959 107
Component: HDSG-Modul H10 0043
Revision: 22010001 Serial number: 253600881
Coding: 0533314003
ROD: EV_HeckkTouar.rod
Component: TSG HR H04 0306
Revision: -------- Serial number: 0000218838848
Part No SW: 7P6 907 217 B HW: 7P6 907 217
Component: DPC-SG H26 0035
Coding: 69020000
ASAM Dataset: EV_OnBoardCamerDTR 001001
ROD: EV_OnBoardCamerDTR.rod
VCID: 392F2B54D9D03CBFCEB-806C
Slave 1:
Subsystem 1 - Part No: 7P6 907 658
Component: NICKRATENSENS H02 0001
Serial number: 000000007068806_3096
Part No SW: 7P6 907 541 C HW: 7P6 907 541
Coding: 3701010101
ASAM Dataset: EV_AdaptCruisContr2VW526 002011
ROD: EV_AdaptCruisContr2VW526_002.rod
VCID: 3A2D3458DCD637A7C71-806E
Address 8E: Image Processing (J851) Labels:| 7P6-907-107.clb
Part No SW: 7P6 907 107 B HW: 7P6 907 107
Component: BV-SG H34 0035
Serial number: 005002473108167
Coding: 0AA118040000
ASAM Dataset: EV_BTR 002001
ROD: EV_BTR_002.rod
End----(Elapsed Time: 02:28, VBatt start/end: 11.7V/11.7V. VIgn 11.7V)-----
