Results 1 to 3 of 3
Thread: C5 allroad 01V Tiptronic Recode
    Oct 2017
    The current code for my gearbox is 00001. I would like to change it to 01101 as I have retrofitted the tiptronic steering wheel. For some reason, the code doesn't change when I input it.
    Thursday,19,March,2020,15:23:28:44933
    VIN: WAUZZZ4B13N101713   License Plate:
              75 76 77
    Address 01: Engine        Labels: 059-907-401-AKE.clb
       Part No: 4Z7 907 401 B
       Component:  2.5l/4VTEDC G000AG D09
       Coding: 01016
       Shop #: WSC 02325
       VCID: 3C223CC49F715FB7D5D-4B1E
       Subsystem 1 - Part No: 00018059
       Component: 130 106EC150_1.R75138755383
       WAUZZZ4B13N101713     AUZ7Z0C2397424
    Readiness: N/A
    Address 02: Auto Trans        Labels: 01V-927-156.lbl
       Part No: 4Z7 927 156 H
       Component: AG5 01V 2.5lTDI RdW 2121
       Coding: 00001
       Shop #: WSC 12345
       VCID: 4BC06F18CADFE80F6C7-5184
    Address 03: ABS Brakes        Labels: 8D0-907-389.lbl
       Part No: 4Z7 907 389 A
       Component: ABS/ESP allrad      D56
       Coding: 06457
       VCID: 4ACE6A1CC5A5F107571-5160
    Address 08: Auto HVAC        Labels: 4B0-820-043-MY2.lbl
       Part No: 4B0 820 043 AM
       Component: A6-Klimavollautomat 0105
       Coding: 00004
       Shop #: WSC 02325
       VCID: 6594B9A04C4B3E7F5A3-2568
    Address 15: Airbags        Labels: 4B0-959-655-AI84.lbl
       Part No: 4Z7 959 655 H
       Component: Airbag 8.4EP        2000
       Coding: 0001106
       Shop #: WSC 02325 785 00200
       VCID: 54F2746412E1B7F73DD-5184
    Address 16: Steering wheel        Labels: 4B0-907-487.lbl
       Part No: 4B0 907 487 H
       Component: Lenkradelektronik   D01
       Coding: 01012
       Shop #: WSC 02325
       VCID: 313C1DF04803A2DF76B-51F2
    Address 17: Instruments        Labels: 4B0-920-xxx-17.lbl
       Part No: 4B0 920 981 J
       Component: KOMBI+WEGFAHRS. VDO D12
       Coding: 06460
       Shop #: WSC 00001
       VCID: 2D040180540BC63F523-5160
    Address 34: Level Control        Labels: None
       VCID: 55F489601C1BAEFFCA3-513C
    No Faults Found
    Address 35: Centr. Locks        Labels:. 4B0-962-258.clb
       Part No: 4B0 962 258 N
       Component: Zentralverrieg.,DWA D37
       Coding: 08187
       Shop #: WSC 12345
       VCID: 343214E4B71197F71DD-4EC8
    01560 - Passenger Door
                60-00 - Won't Safe
    01134 - Alarm Horn (H12)
                49-00 - No Communications
    Address 37: Navigation        Labels: 8E0-035-192-RNSE.clb
       Part No SW: 8E0 035 192 K    HW: 8E0 035 192 K
       Component: RNS-E HIGH EU   H72 X---
       Revision:      01S    Serial number: AUZBZ7F1151996
       Coding: 0512757
       VCID: 2C020C846A21CF3745D-50D0
    Address 45: Inter. Monitor        Labels: 4B0-951-178.lbl
       Part No: 4B0 951 178 A
       Component: Innenraumueberw.    D04
       Coding: 00102
       Shop #: WSC 02325
       VCID: 2616FEAC71CDF567939-5066
       Part No: 4Z7 907 357
       Coding: 00030
       Shop #: WSC 02325
       VCID: 04528424A731E777EDD-4AA4
    Address 56: Radio        Labels: 8E0-035-192-RNSE.clb
       Coding: 0512757
       Part No SW: 8P0 862 335 M    HW: 8P0 862 335 M
       Component: FSE_255x BT     H21 0200
       Revision: 00000001    Serial number: 00000000449355
       Coding: 0010822
       Shop #: WSC 06335 123 12345
       VCID: 40DA4834F6A93B57895-50AE
    End----(Elapsed Time: 04:45, VBatt start/end: 11.7V/11.7V. VIgn 11.5V)-----
    Thanks in advance for any help.
    Regards,
    Graham.
    Engine may not be running when you change coding on these transmissions.
    Also: Try just changing the one bit for "Tiptronic Buttons/Paddles installed".
  3. Likes Dana liked this post
    Oct 2017
    Uwe,
    changed just the one bit as you suggested, the code is now set at 01001. Funny thing is, the tiptronic buttons worked before the change but are not working now. I'm going to change it back to 00001 and leave it at that.
    Kind Regards,
    Graham.
