Results 1 to 8 of 8
Thread: EOS 3.2 6 speed swap attempt
    Mar 2020
    I am attempting this swap and I am currently at the phase of poking at the modules to see if it will allow me to do the swap. When I try to recode the ECU from 0000078 to 0000072 it rejects it and i get "Error 31: Value out of range."
    It is my understanding this ECU will need to be reflashed. How may I go about doing this.
    Wednesday,18,March,2020,17:04:08:37334
    VCDS Version: 19.6.2.2 (x64)  HEX-NET CB: 0.4508.4
    VIN: WVWFB71F07V044237   License Plate:
    Mileage: 241820km-150259mi   Repair Order:
    Chassis Type: 1F (1K0)
    Scan: 01 03 08 09 0F 15 16 17 19 1C 25 26 37 42 44 46 52 56 62 63
              65 72 73
    VIN: WVWFB71F07V044237   Mileage: 241820km-150259miles
    26-Auto Roof -- Status: Malfunction 0010
    63-Entry Assist,D -- Status: OK 0000
    73-Entry Assist, P -- Status: OK 0000
    Address 01: Engine        Labels: 022-906-032-BDB.lbl
       Part No SW: 022 906 032 CF    HW: 022 906 032 GP
       Component: MOTRONIC ME7.1.1G   9378
       Revision: --H02---    Serial number: VWX7Z0G23N98C6
       Coding: 0000078
       Shop #: WSC 00020 000 00000
       VCID: D1EA23AE48786CC7FA-8084
    001072 - Catalyst System; Bank 2
                   P0430 - 002 - Efficiency Below Threshold - MIL ON
                        Fault Status: 11100010
                        Mileage: 235838 km
                        RPM: 1470 /min
                        Load: 46.6 %
                        Speed: 66.0 km/h
                        Temperature: 85.0C
                        Temperature: 40.0C
                        Absolute Pres.: 1020.0 mbar
                        Voltage: 13.843 V
    001056 - Catalyst System; Bank 1
                   P0420 - 002 - Efficiency Below Threshold - MIL ON
                        Mileage: 235838 km
                        RPM: 1511 /min
                        Load: 24.7 %
                        Speed: 67.0 km/h
                        Temperature: 85.0C
                        Temperature: 40.0C
                        Voltage: 13.843 V
    008344 - Post-Catalyst Oxygen (Lambda) Sensor Correction; Bank 2
                   P2098 - 002 - Too Lean - Intermittent
                        Mileage: 238970 km
                        RPM: 661 /min
                        Load: 36.8 %
                        Speed: 1.0 km/h
                        Temperature: 89.0C
                        Temperature: 50.0C
                        Absolute Pres.: 1000.0 mbar
                        Voltage: 13.335 V
    000275 - Intake Air Temp. Sensor (G42)
                   P0113 - 002 - Signal too High
                        Fault Status: 01100010
                        Mileage: 241822 km
                        Load: 0.0 %
                        Temperature: 72.0C
                        Temperature: -40.0C
                        Absolute Pres.: 1010.0 mbar
                        Voltage: 11.303 V
    049409 - No Communication with Transmission Control Module
                   U0101 - 008 -
                        Fault Status: 01101000
                        Mileage: 241822 km
                        Load: 0.0 %
                        Temperature: 72.0C
                        Temperature: -40.0C
                        Voltage: 11.303 V
       Revision: 00H11001
       Coding: 0021218
       VCID: F3A6892692247ED728-80A6
       Part No SW: 1Q0 907 044 E    HW: 1Q0 907 044 E
       Component: ClimatronicPQ35 111 0202
       Revision: 00111021    Serial number: 00000000000000
       VCID: AF2E45563E8C1A378C-80FA
    01809 - Actuating Motor for Temperature Flap; Left (V158)
    01810 - Actuating Motor for Temperature Flap; Right (V159)
       Revision: 00H52000    Serial number: 00000006781724
       Coding: E58C8F0340041500470000000F00000000285D035C0001
       Shop #: WSC 00020 123 12345
       VCID: EC94925ACF1AA12FE9-80B8
       Component: Wischer 140307 020  0501
       Coding: 00038805
       Shop #: WSC 00020
       Component: RLS     201212 054  0403
       Coding: 00209069
       Shop #: WSC 00020
    Address 0F: Digital Radio        Labels: None
       Part No SW: 8E0 035 593 Q    HW: 8E0 035 593 Q
       Component: SDAR SIRIUS     H08 0160
       Revision: 00000000    Serial number: AUZ4Z7L0607781
       Coding: 0000000
       VCID: B73E7D36C6DCD2F7D4-80E2
                        Reset counter: 53
                        Mileage: 241742 km
                        Time: 17:05:32
    Address 15: Airbags        Labels: 1Q0-959-655.lbl
       Part No SW: 1Q0 959 655 A    HW: 1Q0 959 655 A
       Component: 14 Airbag VW8C      0180
       Revision: 92009018    Serial number: 003B3001NU1T
       Coding: 0012596
       VCID: BA386402F5CECF9F2B-80EE
       Subsystem 1 - Part No: 1Q0 959 339 A
       Component: BF-Gewichtsens. 007 0003
       Subsystem 2 - Serial number: 3L8HV
       Subsystem 3 - Serial number: 0001.01.00000070000000000063
       Subsystem 4 - Serial number: 0000006332SRB404C1C896763
       Subsystem 5 - Serial number: 1C89676342SRB40481882C%63
       Subsystem 6 - Serial number: 1882C%6372URB4021BAF28A63
       Subsystem 7 - Serial number: BAF28A6382URB4021BAEFAP
       Subsystem 8 - Serial number: BAEFAP
       Part No SW: 1K0 953 549 AQ    HW: 1K0 953 549 AQ
       Coding: 0012021
       VCID: 814AD3EED8985C472A-80D4
    00002 - Transmission Control Unit
       Part No SW: 1Q0 920 973 B    HW: 1Q0 920 973 B
       Revision: V0003000    Serial number: VWX7Z0G23N98C6
       Coding: 0023207
       VCID: B2284C222DBE37DFE3-80E6
       Part No SW: 1K0 907 530 K    HW: 1K0 907 951
       Component: J533__Gateway   H12 0170
       Revision:   H12       Serial number: 33001072270E53
       Coding: 3DBF23680F065000
       Shop #: WSC 00020 999 12345
                        Reset counter: 63
                        Mileage: 241822 km
                        Time: 03:31:05
       Part No SW: 1Q0 919 965     HW: 1Q0 919 965
       Component: Kompass         002 0001
       Revision: 00002000    Serial number: 1350208TKAEC02
       VCID: F9BABB0EB048048762-80AC
       Component: IMMO            VDD 1610
       Shop #: WSC 05666 444 124037
    Address 26: Auto Roof        Labels: 1Q0-959-255.clb
       Part No SW: 1Q0 959 255 B    HW: 1Q0 959 255 B
       Component: Verdecksteuergeraet 0622
       Revision: 0032000K    Serial number: 070610430
       Coding: 0655360
                        Reset counter: 103
                        Mileage: 241822 km
                        Time: 02:55:13
                        Voltage: 11.80 V
                        Voltage: 11.90 V
                        Voltage: 4.90 V
                        Error Code: 0
    Address 37: Navigation
       Part No SW: 1Q0 959 701 E    HW: 1Q0 959 701 E
       Component: Tuer-SG         006 1209
       Coding: 0001207
       VCID: B6207032C1D62BFFCF-80E2
    00131 - Outside Door Handle Illumination/mirror Light Driver Side
       Part No: 1K1 909 144 L
       Component: EPS_ZFLS Kl.071 H07 1806
       VCID: B4244A3AD7AA39EFF1-80E0
       Component:    KSG PQ35 RDK 052 0218
       Coding: 1B908A800186083F28020C0FB0080E0488DC00
       VCID: 8444DAFAC78A496F01-80D0
       Part No SW: 1Q0 959 702 E    HW: 1Q0 959 702 E
       Coding: 0001206
    Address 56: Radio
       Part No SW: 1Q0 959 703 A    HW: 1Q0 959 703 A
       Component: Tuer-SG         006 1203
       Coding: 0000128
       Shop #: WSC 00020 000 1012544
    Address 63: Entry Assist,D        Labels: 1Q0-959-790.lbl
       Part No SW: 1Q0 959 790 A    HW: 1Q0 959 790 A
       Component: J572  EASYENTRY FS  0603
       Revision: 00H02000    Serial number: 5DS008646-01--
       Component:    RDK              0440
       Coding: 0100101
    00625 - Vehicle Speed Signal
                        Reset counter: 83
                        Mileage: 241674 km
                        Time: 20:57:11
       Part No SW: 1Q0 959 704 A    HW: 1Q0 959 704 A
       Coding: 0000128
       VCID: B522773EDCD020E7C6-80E0
    Address 73: Entry Assist, P        Labels: 1Q0-959-790.lbl
       Component: J573  EASYENTRY BFS 0603
    End----(Elapsed Time: 01:42, VBatt start/end: 11.3V/11.3V. VIgn 11.2V)-----
  2. Likes Boki Ar liked this post
  3. #2
    You will need someone who does "ECU Tuning" or similar to flash MT software into it for you. That assumes that there is MT software available for this engine.
    Mar 2020
    I am told there are someone(s) lurking on these forums that can do and have done such things, but I was not provided with names.
    Nov 2014
    New Zealand
    I tried flashing manual R32 software (022 906 032 CD) onto a DSG R32 ecu (022 906 032 CE), and it wasn't sucessful. I flashed it back to DSG and it still worked, so I suspect the hardware is different, though you may have different results. My manual flash file may have had an issue or similar.
    Mine was a 2006 Immo 4A ECU - yours is 4C, so even with a brand new ECU, you'll need some additional help with immo coding.
    If you want to try manual software, you'll need a flash file from a Euro mk5 R32 with manual trans and IMMO4C (2007 onwards). Then it will only work if the ECU doesn't mind having no 4WD. Idon' think that would be an issue, but you never know! The EOS ECU part number is EOS specific.
    I'm not an expert at it, but I did do some other EEPROM changes that worked.
    I ended up buying a manual R32 ECU new from ECS for the R32 conversion in my Touran.
    I had the same fault code in the ABS, and it DID clear after installing the manual ECU.
    Allan
    The R32ran Thread
    How to post a full Auto-Scan
  6. Likes Uwe liked this post
    Jun 2014
    Quote Originally Posted by NZDubNurd View Post
    HW could be ok, but "conditions" to update not match between , so this is why failed
    99% upload BDM backup directly to CPU should work
    so the best way is do manual changes in ECU software
    or write whole dump via BDM directly to CPU from proper ECU
  8. Likes Uwe, NZDubNurd liked this post
  9. #6
    Nov 2014
    New Zealand
    I was in boot mode, but was using someone elses file, not one I'd read myself. so possible the file was corrupt.
    Allan
    The R32ran Thread
  10. #7
    Mar 2020
    I got the car to turn on and idle fine with the key in the ignition and running a wire from the starter solenoid to a 12v source. It looks like I will have to wire up my own starter relay from the ignition switch directly to bypass the lockout from the transmission not being there. Which is easy. The issue I am running into now is finding a VR6 tranny. The one that was given to me was off a 2.5 and I was hoping it would work but I also knew that was wishful thinking.
  11. #8
    Nov 2014
    New Zealand
    No, no half-assing the wiring : you need to rewire the pin from the J519 that usually goes to from the J519 to the DSG trans, and earth it, and code the J519 for manual trans (I think?). I can't recall the pin number (I'm part way through a bottle of Jim Beam Double Oak ). You will NEED wiring diagrams, because you are going to have to wire in a clutch switch too.
    You can't use a inline (4 cylinder, and US 5cyl) trans, because the bellhousing angle is different. The pattern is the same, but the VR6 is leaned forward, where the inline type is leant backwards. In the US, the MK4 had an option with 2.8 VR6 and FWD, right? One of those trans, with driveshafts that have the MK5 outer CVs fitted should work. The trans WILL, but I'm unsure which driveshaft will be the correct length. Left side MK4 should be fine with the outer swapped. RHS, I'm not 100% on. I have a 02M (MK4) trans in my Touran (MK5) conversion, but it's 4motion, so I have the angle drive and shorter RHS driveshaft - I had some dramas getting the correct shaft and ended up using a TT one with the MK5 outer CVs.
    You CAN use a 4motion trans, and leave the angle drive spinning in mid air... even cooler, building the worlds first 4motion EOS??? Mine wasn't the first 4motion Touran (I think it was the 3rd!) but it WAS the worlds first FULLY functional 4motion R32 Touran though
    Allan
    The R32ran Thread
  12. Likes PetrolDave, Uwe, D-Dub liked this post
