I am attempting this swap and I am currently at the phase of poking at the modules to see if it will allow me to do the swap. When I try to recode the ECU from 0000078 to 0000072 it rejects it and i get "Error 31: Value out of range."
It is my understanding this ECU will need to be reflashed. How may I go about doing this.
Wednesday,18,March,2020,17:04:08:37334
VCDS Version: 19.6.2.2 (x64) HEX-NET CB: 0.4508.4
VIN: WVWFB71F07V044237 License Plate:
Mileage: 241820km-150259mi Repair Order:
Chassis Type: 1F (1K0)
Scan: 01 03 08 09 0F 15 16 17 19 1C 25 26 37 42 44 46 52 56 62 63
65 72 73
VIN: WVWFB71F07V044237 Mileage: 241820km-150259miles
26-Auto Roof -- Status: Malfunction 0010
63-Entry Assist,D -- Status: OK 0000
73-Entry Assist, P -- Status: OK 0000
Address 01: Engine Labels: 022-906-032-BDB.lbl
Part No SW: 022 906 032 CF HW: 022 906 032 GP
Component: MOTRONIC ME7.1.1G 9378
Revision: --H02--- Serial number: VWX7Z0G23N98C6
Coding: 0000078
Shop #: WSC 00020 000 00000
VCID: D1EA23AE48786CC7FA-8084
001072 - Catalyst System; Bank 2
P0430 - 002 - Efficiency Below Threshold - MIL ON
Fault Status: 11100010
Mileage: 235838 km
RPM: 1470 /min
Load: 46.6 %
Speed: 66.0 km/h
Temperature: 85.0°C
Temperature: 40.0°C
Absolute Pres.: 1020.0 mbar
Voltage: 13.843 V
001056 - Catalyst System; Bank 1
P0420 - 002 - Efficiency Below Threshold - MIL ON
Mileage: 235838 km
RPM: 1511 /min
Load: 24.7 %
Speed: 67.0 km/h
Temperature: 85.0°C
Temperature: 40.0°C
Voltage: 13.843 V
008344 - Post-Catalyst Oxygen (Lambda) Sensor Correction; Bank 2
P2098 - 002 - Too Lean - Intermittent
Mileage: 238970 km
RPM: 661 /min
Load: 36.8 %
Speed: 1.0 km/h
Temperature: 89.0°C
Temperature: 50.0°C
Absolute Pres.: 1000.0 mbar
Voltage: 13.335 V
000275 - Intake Air Temp. Sensor (G42)
P0113 - 002 - Signal too High
Fault Status: 01100010
Mileage: 241822 km
Load: 0.0 %
Temperature: 72.0°C
Temperature: -40.0°C
Absolute Pres.: 1010.0 mbar
Voltage: 11.303 V
049409 - No Communication with Transmission Control Module
U0101 - 008 -
Fault Status: 01101000
Mileage: 241822 km
Load: 0.0 %
Temperature: 72.0°C
Voltage: 11.303 V
Revision: 00H11001
Coding: 0021218
VCID: F3A6892692247ED728-80A6
Part No SW: 1Q0 907 044 E HW: 1Q0 907 044 E
Component: ClimatronicPQ35 111 0202
Revision: 00111021 Serial number: 00000000000000
VCID: AF2E45563E8C1A378C-80FA
01809 - Actuating Motor for Temperature Flap; Left (V158)
01810 - Actuating Motor for Temperature Flap; Right (V159)
Address 09: Cent. Elect. Labels:. 3C0-937-049-23-H.lbl
Part No SW: 3C0 937 049 AE HW: 3C0 937 049 AE
Component: Bordnetz-SG H52 2002
Revision: 00H52000 Serial number: 00000006781724
Coding: E58C8F0340041500470000000F00000000285D035C0001
Shop #: WSC 00020 123 12345
VCID: EC94925ACF1AA12FE9-80B8
Component: Wischer 140307 020 0501
Coding: 00038805
Shop #: WSC 00020
Component: RLS 201212 054 0403
Coding: 00209069
Shop #: WSC 00020
Address 0F: Digital Radio Labels: None
Part No SW: 8E0 035 593 Q HW: 8E0 035 593 Q
Component: SDAR SIRIUS H08 0160
Revision: 00000000 Serial number: AUZ4Z7L0607781
Coding: 0000000
VCID: B73E7D36C6DCD2F7D4-80E2
Reset counter: 53
Mileage: 241742 km
Time: 17:05:32
Address 15: Airbags Labels: 1Q0-959-655.lbl
Part No SW: 1Q0 959 655 A HW: 1Q0 959 655 A
Component: 14 Airbag VW8C 0180
Revision: 92009018 Serial number: 003B3001NU1T
Coding: 0012596
VCID: BA386402F5CECF9F2B-80EE
Subsystem 1 - Part No: 1Q0 959 339 A
Component: BF-Gewichtsens. 007 0003
Subsystem 2 - Serial number: 3L8HV
Subsystem 3 - Serial number: 0001.01.000000700000000000ÿ†63
Subsystem 4 - Serial number: 000000ÿ†6332SRB404C1C8967ÿ†63
Subsystem 5 - Serial number: 1C8967ÿ†6342SRB40481882C%ÿ†63
Subsystem 6 - Serial number: 1882C%ÿ†6372URB4021BAF28Aÿ†63
Subsystem 7 - Serial number: BAF28Aÿ†6382URB4021BAEFAPÿ
Subsystem 8 - Serial number: BAEFAPÿ
Part No SW: 1K0 953 549 AQ HW: 1K0 953 549 AQ
Component: J0527 036 0070
Coding: 0012021
VCID: 814AD3EED8985C472A-80D4
Component: E0221 002 0010
00002 - Transmission Control Unit
Part No SW: 1Q0 920 973 B HW: 1Q0 920 973 B
Revision: V0003000 Serial number: VWX7Z0G23N98C6
Coding: 0023207
VCID: B2284C222DBE37DFE3-80E6
Address 19: CAN Gateway Labels:. 1K0-907-530-V2.clb
Part No SW: 1K0 907 530 K HW: 1K0 907 951
Component: J533__Gateway H12 0170
Revision: H12 Serial number: 33001072270E53
Coding: 3DBF23680F065000
Shop #: WSC 00020 999 12345
Reset counter: 63
Mileage: 241822 km
Time: 03:31:05
Part No SW: 1Q0 919 965 HW: 1Q0 919 965
Component: Kompass 002 0001
Revision: 00002000 Serial number: 1350208TKAEC02
VCID: F9BABB0EB048048762-80AC
Component: IMMO VDD 1610
Shop #: WSC 05666 444 124037
Address 26: Auto Roof Labels: 1Q0-959-255.clb
Part No SW: 1Q0 959 255 B HW: 1Q0 959 255 B
Component: Verdecksteuergeraet 0622
Revision: 0032000K Serial number: 070610430
Coding: 0655360
Reset counter: 103
Mileage: 241822 km
Time: 02:55:13
Voltage: 11.80 V
Voltage: 11.90 V
Voltage: 4.90 V
Error Code: 0
Address 37: Navigation
Part No SW: 1Q0 959 701 E HW: 1Q0 959 701 E
Component: Tuer-SG 006 1209
Coding: 0001207
VCID: B6207032C1D62BFFCF-80E2
00131 - Outside Door Handle Illumination/mirror Light Driver Side
Part No: 1K1 909 144 L
Component: EPS_ZFLS Kl.071 H07 1806
VCID: B4244A3AD7AA39EFF1-80E0
Component: KSG PQ35 RDK 052 0218
Coding: 1B908A800186083F28020C0FB0080E0488DC00
VCID: 8444DAFAC78A496F01-80D0
Part No SW: 1Q0 959 702 E HW: 1Q0 959 702 E
Coding: 0001206
Address 56: Radio
Part No SW: 1Q0 959 703 A HW: 1Q0 959 703 A
Component: Tuer-SG 006 1203
Coding: 0000128
Shop #: WSC 00020 000 1012544
Address 63: Entry Assist,D Labels: 1Q0-959-790.lbl
Part No SW: 1Q0 959 790 A HW: 1Q0 959 790 A
Component: J572 EASYENTRY FS 0603
Revision: 00H02000 Serial number: 5DS008646-01--
Component: RDK 0440
Coding: 0100101
00625 - Vehicle Speed Signal
Reset counter: 83
Mileage: 241674 km
Time: 20:57:11
Part No SW: 1Q0 959 704 A HW: 1Q0 959 704 A
Coding: 0000128
VCID: B522773EDCD020E7C6-80E0
Address 73: Entry Assist, P Labels: 1Q0-959-790.lbl
Component: J573 EASYENTRY BFS 0603
End----(Elapsed Time: 01:42, VBatt start/end: 11.3V/11.3V. VIgn 11.2V)-----
