Results 1 to 5 of 5
Thread: ABS CODING LOST, ANYONE HELP PLEASE (MK60EC1)
    Jun 2019
    Birmingham, UK
    Tuesday,17,March,2020,21:34:54:58999
    VIN: WVWZZZ1KZBW306741   License Plate:
    Mileage: 101430km-63025mi   Repair Order:
    Chassis Type: 1K-VW36 (7N0)
    Scan: 01 02 03 08 09 10 15 16 17 19 25 2E 42 44 46 52 56 62 72 77
    VIN: WVWZZZ1KZBW306741   Mileage: 101430km-63025miles
       Part No SW: 03L 906 018 AT    HW: 03L 907 309 R
       Component: R4 2.0l TDI   H23 9977
       Revision: 42H23---    Serial number: 00000000000000
       Coding: 001D0012042500080000
       Shop #: WSC 00110 210 00000
       ASAM Dataset: EV_ECM20TDI01103L906018AT 003012
       ROD: EV_ECM20TDI01103L906018_003_VW36.rod
       VCID: 7CA1F56B7665009795D-8028
    5286 - Throttle Position Sensor (G69)
              P0121 00 [237] - Implausible Signal
                        Mileage: 101261 km
                        Date: 2020.03.16
                        Time: 05:58:22
                        Engine speed: 568.50 /min
                        Coolant temperature: 63 °C
                        Intake air temperature: 16 °C
                        Voltage terminal 30: 13.300 V
                        Air mass: actual value (mg/stroke): 473.5 mg/stroke
                        Throttle valve adapter: specified value: 0.00 %
                        Throttle valve adapter: actual value: 6.93 %
                        Throttle valve adapter: offset closed: -9.44 %
                        Throttle valve adapter: status-Bits 0-7: 0
                        Throttle valve adapter: status-Bits 0-7: 8
                        Throttle valve adapter: status-Bits 0-7: 55
                        Throttle valve adapter: uncond voltage actual value: 1099.6 mV
    Readiness: 1 1 0 0 0
       Part No SW: 02E 300 054 J    HW: 02E 927 770 AL
       Component: GSG DSG AG6     511 2602
       Revision: 05351113    Serial number: 00001104050603
       VCID: 1D67D8EF81BFA99FC23-8048
       Part No SW: 1K0 907 379 BE    HW: 1K0 907 379 BE
       Component: ESP MK60EC1   H31 0108
       Revision: 00H31001
       VCID: 76B5E74348C95AC7E39-8022
                        Reset counter: 151
                        Date: 2014.08.06
                        Time: 23:37:57
                        Count: 3
                        Count: 12
                        Count: 20992
                        Count: 195
                        Count: 43008
                        Fault Status: 01100101
                        Reset counter: 151
                        Mileage: 101171 km
                        Date: 2014.08.06
                        Time: 23:37:57
                        Count: 3
                        Count: 14
                        Count: 4096
                        Count: 279
                        Count: 43008
                        Reset counter: 151
                        Mileage: 101171 km
                        Date: 2014.08.06
                        Time: 23:37:57
                        Count: 3
                        Count: 14
                        Count: 4096
                        Count: 295
                        Count: 43008
                        Reset counter: 151
                        Mileage: 101171 km
                        Date: 2014.08.06
                        Time: 23:37:57
                        Count: 3
                        Count: 14
                        Count: 4096
                        Count: 270
                        Count: 43008
       Part No SW: 7N0 907 426 K    HW: 7N0 907 426 K
       Component: AC Manuell    H17 0202
       Revision: 00012001
       Coding: 0000000002
       ROD: EV_ClimaBasis_VW36.rod
       VCID: 3C21356B36E5C097D5D-8068
       Part No SW: 1K0 937 084 D    HW: 1K0 937 084 D
       Component: BCM PQ35  B   103 0615
       Revision: 00103 AE
       Coding: 48180A3A8825F1C040080080340000E443510088536D8160648000200040
       VCID: 2F3B1227F7132B0F60F-807A
       Subsystem 1 - Part No: 5K2 955 119
       Component: Wischer 30031  26  0512
       Coding: 009795
       Component: RLS 090411 05  54  0403
       Coding: 0330AD
    01134 - Alarm Horn (H12)
                        Reset counter: 153
                        Mileage: 101171 km
                        Date: 2014.08.06
                        Time: 23:38:04
                        Voltage: 12.35 V
                            Term 50 Off
                        Reset counter: 151
                        Mileage: 101171 km
                        Date: 2014.08.06
                        Time: 23:42:13
                        Voltage: 14.15 V
                            Term 50 Off
                002 - Lower Limit Exceeded
                        Fault Status: 01100010
                        Fault Frequency: 22
                        Reset counter: 153
                        Mileage: 101171 km
                        Date: 2014.08.06
                        Time: 23:42:13
                        Voltage: 14.15 V
                            Term 50 Off
       Part No SW: 5K0 919 475 E    HW: 5K0 919 475 E
       Component: PARKHILFE 8K  H01 0012
       Revision: --------    Serial number: 12501108800790
       Coding: 108101
       VCID: 3829297B025DECB7315-806C
       Part No SW: 5C0 959 655 B    HW: 5C0 959 655 B
       Serial number: 003G5RA3RU91
       Coding: 00003948
       ROD: EV_AirbaVW10SMEVW360.rod
       VCID: 313F145FE1A73DFF76B-8064
       Serial number: 3572MSME4E08065EZZZ1
       Serial number: 3582MSME386E635DZZZ9
       Serial number: 3512QSME423F092DZZZ$
       Serial number: 3522QSME4C570A3DZZZ3
       Part No SW: 5K0 953 507 AH    HW: 5K0 953 549 B
       Revision: --------    Serial number:  90440KD8000ZY
       Coding: 1882140000
       ROD: EV_SMLSNGKUDS_A05.rod
       VCID: 76B5E74348495AC7E39-8022
       Serial number: 40000000000000316335
       Coding: E20000
    448019 - Multi-Function Switches in Steering Wheel; Left
              B114B 96 [008] - Component internal failure
                        Reset counter: 191
                        Mileage: 101171 km
                        Date: 2020.03.15
                        Time: 23:38:17
       Part No SW: 5K0 920 971 A    HW: 5K0 920 971 A
       Component: KOMBI         H20 0420
       Coding: 470B00
       VCID: 2D07082FFD9F591F523-8078
       Part No SW: 7N0 907 530 C    HW: 1K0 907 951
       Component: J533  Gateway H37 0614
       Revision:   H37       Serial number: 140411F2000089
       Coding: 350003
       VCID: 3039115BEA2D34F7795-8064
       Component: IMMO          H20 0420
       VCID: 6A8DC3330CF18E27771-803E
       Part No SW: 5N0 035 342 D    HW: 5N0 035 342 D
       Component: SG EXT.PLAYER H13 0150
       Revision: A1001003    Serial number: 7669766642
       VCID: 2809F93BD2FD7C37A15-807C
       Component: Tuer-SG         009 2120
       Coding: 0000692
       VCID: 313F145FED273DFF76B-8064
       Part No: 1K0 909 144 M
       Component: EPS_ZFLS Kl. 70     3201
       Revision: 00H20000
       VCID: 34311D4B123508D71DD-8060
                        Fault Status: 11100101
                        Mileage: 101171 km
                        Date: 2014.08.06
                        Time: 23:38:29
                        Battery Volts: 12.1 V
                            DD
                        Temperature: 12.0°C
                        Count: 3
                        Steering Angle: 0.00°
                            SteerAng n.Init
       Part No SW: 5K0 959 702 C    HW: 5K0 959 702 C
       Coding: 0000948
       VCID: 33331E57173B0FEF047-8066
       Part No SW: 3C8 035 195 A    HW: 3C8 035 195 A
       Component: Radio RCD510  041 0166
       Revision: 00000001    Serial number: VWZ1Z3L0742023
       Coding: 0100040004
       VCID: 2615F703D8E96A47939-8072
       Coding: 0000144
       Shop #: WSC 01357 011 1012552
       VCID: 3537204F194F11DF2A3-8060
       Coding: 0000144
       VCID: 3635274304491AC7239-8062
       Part No SW: 5K0 035 730 B    HW: 5K0 035 730 B
       Component: TELEFON       H09 1020
       Revision: 1B001001    Serial number: 00007669717369
       Coding: 0A01000000010101
       ASAM Dataset: UHVNA A01009
       ROD: UHVNA.rod
       VCID: 2411ED0BAE5598578DD-8070
    End----------(Elapsed Time: 01:25, VBatt start/end: 12.3V/12.3V)-----------
    HQ
    VCDS automatically saves Auto-Scans. If an Auto-Scan was performed prior to the soft coding being lost, you can retrieve that information. Details here.
    Jef
  3. Likes Uwe, Dana, Jack@European_Parts liked this post
    Jun 2019
    Birmingham, UK
    hello jef, this vehicle was not scanned before,
  5. Likes Dana liked this post
  6. #4
    United States
    I believe the factory condition 03-ABS coding of WVWZZZ1KZBW306741 was:
    163B400D09220000681202E8901A0082310000
    Vehicle Identification No. WVWZZZ1KZBW306741
    Model Golf 2,0 GOLF
    Date of production 19.04.2011
    Model year 2011
    Sales type 5K1373
    Engine Code CFFB
    Transmission Code MSV
    Axle drive 6A
    Equipment FW
    Special editions E0A Without special action equipment
    Lockable wheel bolts 1PE Wheel bolts with anti-theft protection (unlockable)
    Vehicle class differentiation units/platform components 0HA Vehicle class differentiation -1K0/5K0-
    tail pipe 0P1 Rear side exhaust tailpipe
    Hill start assist UG1 Hill start assist
    Emission standard 7MG Emission standard EU5
    Trailer hitch 1D0 Without trailer hitch
    airbag 4UP Airbag for driver and front passenger with knee airbag and front passenger airbag deactivation
    Aktivkohlebehälter / Ottopartikelfilter 1E0 Without activated carbon canister
    Aerials 8ZH Antenna for AM/FM reception, "diversity"
    Exterior mirror setting 6XG Exterior mirrors with memory feature, power-adjustable/heated
    Follow-on warranty EA0 Without subsequent warranty
    Left exterior mirror 5SJ Left exterior mirror, convex
    Right exterior mirror 5RV Right exterior mirror, aspherical
    Drive type 1X0 Front-wheel drive
    "Multimedia"video/DVD/notebook connection 9WL Jack for external audio source
    Equipment levels A8C Comfort equipment
    Brake type in rear 1KD Disc brakes in rear
    batteries J0N Battery 330 A (61 Ah)
    Brake type, front 1ZE Disc brakes in front (Geomet D)
    Components with special surface 6FF Exterior mirror housing and various attachments colour coded to vehicle
    Battery/alternator capacity NY0 Standard battery/alternator capacity
    Component part sets with country-specific design requirements B0N Component parts set, complying with vehicle type for Great Britain, various parts
    vehicle tools and jack 1S1 vehicle tools and jack
    Brake systems 1AT Electronic stability control (ESC)
    Owner's manuals 0VF Information kit in English
    Operating voltage 9Z0 Operating voltage 12 V
    Brake pad wear indicator 9U1 Brake pad wear indicator
    Heated washer nozzles 9T0 Without heated washer nozzles
    CD ROM/DVD/SD card 7QA Without CD/DVD for navigation
    CD changer/CD player 7A0 Without CD changer/CD player
    "Charism" 2H0 Without "drive select"
    Chrome package QJ1 Chrome package
    General operating permit, alterations C36 Operating permit, alteration
    Roof insert/convertible top 3FA Without roof insert (standard roof)
    Suspension system in rear 1JA Rear shock absorption, basic version 1
    Suspension system in front G07 Shock absorption in front
    Load-through hatch/ski bag 3X0 without load through system
    Insert for the filling up of unleaded fuel/fuel type 2G5 Filler neck module 1 without insert
    Installation differentiation for components 0ES Installation differentiation for transmission DQ250 -- vehicle components --
    Theft protection system 7AL Anti-theft alarm system, interior monitoring, backup horn and towing protection
    Inserts 5MB Decorative inserts
    Scuff plates 7M5 Without impact protection film for door sill
    Park distance control 7X2 Park distance control in front and rear
    Electric interface for external use UF6 Electric interface for external use (MEDIA-IN jack)
    Manufacturing sequence differentiation 0FA Standard manufacturing sequence
    window regulator 4R4 Power windows with comfort operation and circuit breaker
    fire extinguisher 6A0 without fire extinguisher
    Pedestrian protection VL1 Extended pedestrian protection measures
    Pedal cluster VF0 Standard pedal cluster
    Headlight activation 8K3 Separate daytime running light with automatic headlight control and Coming Home feature
    Alternators 8GU Alternator 140 A
    Weight category rear axle 0YC Weight range 3 installation control only, no requirement forecast
    Weight category front axle L14 Suspension range 14 installation control only, no requirement forecast
    Base engine TL4 4-cylinder diesel engine 2.0 l unit 03L.L
    Luggage netting/pocket on backrest(s) 4U5 Luggage pockets on backrest
    Luggage compartment cover 3U1 Folding trunk cover
    cruise control system 8T2 Electronic cruise control system (CCS)
    Luggage compartment trim 5A7 Comfort luggage compartment trim with service lid/snap-on cover
    Transmission specifications G1A 6-speed automatic transmission
    handle for hand brake lever 6PC Hand brake lever handle in leather
    Rear spoiler 5J0 Without rear spoiler
    Rear window wiper and washer system 8M1 Rear window wiper washer system with intermittent wipe
    Rear seats 3NU Rear bench seat, not split, split backrest, folding centre armrest
    Heating and air-conditioning system KH6 Air conditioning system with electronic control
    Headlamps 8BK Twin headlamps for driving on the left, with integrated high beam
    Customized installation FC0 Without customized installation
    Interior light in footwell 6T1 Interior light in footwell
    Instrument clusters U5B Instrument cluster, mph speedometer -Great Britain-
    Breakaway interior rearview mirror 4L6 Breakaway interior rearview mirror, auto-dimming
    Sticker (customized or special edition) 0KA Without decals and emblems
    Body style K8G Hatchback
    Refrigerator 1W2 Glove compartment cooling system
    Climatic zones 0Y1 Standard climatic zones
    Compass/road sign display QR0 Without compass/road sign display/ dynamic road sign display
    Rear head restraints 3T2 Three rear head restraints
    Head restraints 3J1 Hight-adjustable head restraints for front seats
    Fuel tank treatment 2LD Fuel tank without differentiation of special material treatment (fluorination/co-extrusion)
    Fuel quantity for initial filling 1Z2 Increase in initial standard fuel filling
    Fuel systems 0F5 Fuel system for diesel engine
    Body measures 5C0 Without special body measures
    Radiator grille 6KC Radiator grille
    License plate lighting KL0 Standard license plate lighting
    Rear license plate carrier 6P1 Rear license plate carrier (ECE)
    Front license plate carrier 6W1 Front license plate carrier (large)
    Paint preservative/transit coating 5K7 Transport protection film (minimum protection) with additional transport protection measures
    Paint coating FB0 standard paint coating
    Steering system arrangement L0R Right-hand drive
    Reading lamp 8S4 Two reading lights in front, two in rear
    steering 1N3 Speed-related variable steering assist (Servotronic)
    Backrest release 3H0 Without backrest release for front seats
    Air duct, front area VK1 Air duct, type 1
    Light control systems 8G0 Without Light Assist
    Lumbar support 7P4 Manually adjustable lumbar support in front seats
    steering wheels 2PP Leather-wrapped multi-function steering wheel
    Speaker installation 8RM 8 speakers (passive)
    Headlight range control 8Q1 Headlight range control
    Center armrest 6E3 Center armrest in front
    Marten repeller UM0 Without marten repeller
    Multi-function display/trip computer 9Q5 Multi-function display with control
    Engine cooling 8Z5 not hot country
    Engine specifications D91 4-cyl. turbo diesel engine 2.0 l/103 kW (4V) TDI common rail; Base engine: TG3/ TJ3/TU3/TU4/TL4/TP4/TM3/TW3/TR4/TS1/TN5
    Left vanity mirror 4SD Vanity mirror, left, illuminated
    Right vanity mirror 4TD Vanity mirror, right, illuminated
    Navigation device 7Q0 without navigation system
    rear fog lamp 8TD Rear fog light for driving on the left
    Front fog lamp/additional headlamp 8WA Without fog lights
    Upgrading measures GP1 Vehicles with special upgrade measures
    Rear of platform module base 4P0 Rear floor panel module, type 1
    Platform group class 7PA Platform group class 1
    Hubcaps 1NL Trims for alloy wheels
    Wheels CB9 Alloy wheels 6.5J x 16
    Radios 8AI Radio "RCD510 MP3"
    Smoker's/non-smoker's package 9JB Smoker's package, ashtrays in front and rear
    Tire pressure monitoring system 7K0 Without tyre pressure monitor
    tire HH7 Tires 205/55 R16 91V
    Tire suppliers V0A Tires without specification of tire brand
    Spare wheel/breakdown kit 1G6 Space-saving spare wheel
    Restraint systems, front 3QT 3-point seat belts in front, with pretensioner and height adjustment
    PJ8 "Pescara" - 4 alloy wheels 6.5J x 16
    PLA "Lights & Vision" Pack
    PU2 Multi-function leather steering wheel
    RHZ Radio CD "510" con lector de MP3, 4x20 W, 8 altavoces, con pantalla táctil
    W4B Power windows front and rear
    WD5 Anti-theft alarm system including single door opening
    WDA Park distance control
    WX5 Match Country: GB
    Side airbag 4X3 Side airbag in front, with curtain airbag
    Gearshift knob/handle 6Q2 Gearshift knob/handle in leather
    Special labels/plates 0SS Labels in English and French
    Tail lamp assemblies 8SA Rear combination lamp, standard design
    Locking mechanism for boot lid/cover rear 4E0 Tailgate/trunk lid unlocking from outside
    Front seat, left 3TF Comfort seat in front, left
    Front seat, right 3SF Comfort seat, front right
    Nameplate for sales name QD1 Nameplate for sales name
    Seat belt check 9P3 Seat belt reminder, electric contact in buckle
    Outer rear seat belts 3ZB 3-point seat belts, outer rear with ECE label
    Center rear seat belts 3C7 3-point seat belt for center rear seat
    seat covers N3B Seat trim covers in fabric
    Seat adjustment 3L3 Manual height adjustment for front seats
    seat heater 4A0 without seat heater
    Safety head restraint system 3K0 w/o safety head restraint system
    Side lights 7R3 Side turn signals (white)
    Start-stop system/regenerative braking 7L3 Without start-stop system without regenerative braking
    Horns 8Y1 Two-tone horn
    Side and rear windows 4KC Side and rear windows in heat-insulating glass
    power outlet 7B2 12 volt socket in luggage compartment
    Bumper 2JB Standard bumpers
    Rear stabilizer bar 0BD Rear stabilizer bar
    Front stabilizer bar 0AD Front stabilizer bar
    Drawers under front seats QN0 Without drawers under front seats
    Heavy-duty/sports version 2UA Standard design
    Headlamp washer system 8X0 Without headlamp washer system
    Windshield wiper intermittent control/ light/rain sensor 8N3 intermittent windscreen wiper with rain sensor
    Special approval measures 3M0 Without special measures
    Nameplate set 1DG Nameplate set "TDI"
    Mass damper for steering wheels 1Q1 Mass damper for steering wheel, 26.5 Hz
    Door and lid locking system 4K3 Central locking w/ radio remote control, interior controls and SAFELOCK
    Type approval countries/countries with special requirements B09 Type approval country GB/Northern Ireland
    Carrier frequency for remote control 5D1 Carrier frequency 433.92 to 434.42 Mhz
    Partition 3CA without partition
    Door and side trim panels 4AF Door and side trim panel in foam film and woven fabric
    doors 0A2 4 doors
    TV reception/digital radio reception QV3 digital radio reception
    Identification plates 1EX Special identification label for EC for M1 passenger vehicles
    Delivery equipment 2A0 Without delivery equipment
    First aid kit / warning triangle 1T0 Without first aid kit and warning triangle
    Two-way radio installation preparation 9D0 without prepared for two way radio system
    Telephone / telematics 9ZB Mobile phone interface High
    Additional warning lights 9TC Additional retro-reflectors (door area)
    LongLife Service Regime QG1 LongLife Service Regime
    Heat accumulator system/auxiliary heater 7E6 Electric auxiliary air heater
    Windshield Glass 4GF Windshield in heat-insulating glass
    Washer fluid level indicator 8W0 without washer water level indicator
    Additional tires (snow tires) 2WA without spare tyre
    floor mats 0TA without floor mats
    Additional body panels, side 6EA Without additional side body covers (stone guard)
    Additional child seat anchors 3B4 Child seat anchors for child seat system ISOFIX
    Auxiliary heating system 9M0 Without auxiliary heater/parking heater
    Jun 2019
    Birmingham, UK
    thank you very much dana, all sorted now with your coding.
  8. Likes Boki Ar, Uwe, PetrolDave, Dana liked this post
