Results 1 to 6 of 6
Thread: 2016 tiguan NAR to euro tail lights
    Oct 2015
    Bulgaria
    hi guys. i have some trouble...
    customer came to me with a tiguan 2016, imported from america. naturally with american taillights. turn signal and brake light are one. me, personally, i like this a lot, but here it's not allowed... so i have to convert it to euro tail lights with amber turn signals. i found out that in the connector there are swithced positions of turn signal, and nothing is connected to actual brake light. actually turn signal is connected to brake light bulb. i swithced them over and added a cable for the brake light. everything is in place now. signal for the brake light i got from the connector of the hitch, which is not used-there is no hitch module attached. and now i can not tell the bcm to separate the brake lights from the turn lights, and use the actuall brake light with the side marker light back, instead of using dialed down turn signal to complete the side marker...
    i really hope you understood my sloppy description...
    here is the autoscan of the vehicle:
    Wednesday,18,March,2020,12:37:54:50573
    VCDS Version: 19.6.2.2  HEX-V2 CB: 0.4508.4
    VIN: WVGBV7AX9GW581063   License Plate:
    Chassis Type: AX-VW36 (7N0)
    Scan: 01 02 03 05 08 09 15 16 17 19 22 25 2B 42 44 46 4C 4F 52 53
              55 5F 62 72 75
    VIN: WVGBV7AX9GW581063   Mileage: 51910km-32255miles
    Address 01: Engine (CCT)       Labels:. 06J-906-026-CCT.clb
       Part No SW: 06J 906 027 JP    HW: 06J 907 309 A
       Component: MED17.5.2 TFSI 2 07 1335
       Revision: P3H08---    Serial number:
       Coding: 0423010A190F0160
       VCID: 025D8D2CE80349C7DF1-8056
       Part No SW: 09G 927 750 NK    HW: 09G 927 750 NK
       Component: AQ 250 6F           2627
       Revision: 00H97000    Serial number:
       Coding: 0000840
       VCID: 074B9C38C3216CEF88F-8052
    Address 03: ABS Brakes        Labels: 5N0-614-109-C6.clb
       Part No SW: 5N0 614 109 BN    HW: 5N0 614 109 BN
       Component: J104   C6 450M VD3B 0021
       Revision: --H07---    Serial number: 00000009090795
       Coding: 0005161
       VCID: 78A9EFC4BEDF1317F15-802C
       Revision: 00092000    Serial number: 0390428734
       Coding: 030C0C
       VCID: 372B2CF8FFC1DC6F38F-8062
    133124 - Function Restricted due to Missing Message(s)
              U1111 00 [008] - -
              [Ausfall mBSG3-Botschaft - kein Signal/Kommunikation]
                        Reset counter: 99
                        Mileage: 51916 km
                        Date: 2020.03.18
                        Time: 10:53:47
    1069319 - Wake-Up Signal from Control Module for Access/Start Authorization
              U1093 00 [008] - Short to GND
              [Weckleitung vom Steuergerät für Zugang- und Startberechtigung Unterbrechung/Kurzschluss nach Masse]
                        Reset counter: 99
       Part No SW: 561 907 426 G    HW: 561 907 426 G
       Component: AC Manuell    H03 0506
       Revision: 00001K02
       Coding: 0010001002
       ASAM Dataset: EV_ACManuaElectGen2BHTC 001002
       ROD: EV_ACManuaElectGen2BHTC_VW36.rod
       VCID: 1F1BE4587731842FD0F-804A
    13701936 - Function Restriction due to Faults in Other Modules
              U1113 00 [008] - -
              [Steuergerät für Bordnetz - bitte Fehlerspeicher auslesen]
                        Reset counter: 99
                        Mileage: 51916 km
                        Date: 2020.03.18
                        Time: 12:13:37
       Part No SW: 5K0 937 086 AB    HW: 5K0 937 086 AB
       Component: BCM PQ35 M    122 0183
       Revision: BJ122001
       Coding: EF1A0A1B80232EC4018800C114000D4448F50006566D8DB0E4840000A040
       VCID: 74B1DBF4AEB77777DDD-8020
       Subsystem 1 - Part No SW: 5N1 955 119 B    HW: 5N1 955 119 B  Labels: 1KX-955-119.CLB
       Component: WWS316 081215  24  0664
       Coding: 009795
       Component: RLS 090116 05  54  0403
       Coding: 02304D
                010 - Open or Short to Plus
                        Fault Status: 01101010
                        Reset counter: 59
                        Mileage: 51916 km
                        Date: 2020.03.18
                        Time: 12:02:53
                        Voltage: 12.25 V
    02195 - Dimmer Switch Instrument Panel & Switch Lighting (E20)
                002 - Lower Limit Exceeded
                        Fault Status: 01100010
                        Reset counter: 59
                        Mileage: 51916 km
                        Date: 2020.03.18
                        Time: 12:02:53
                        Voltage: 12.25 V
       Part No SW: 5N0 959 655 AB    HW: 5N0 959 655 AB
       Component: J234__005 VW10 HI   5418
       Revision: 36023000    Serial number: 003MAP095SU3
       Coding: 0012341
       VCID: 7DA7FED091FD363FA23-8028
       Subsystem 1 - Part No: 5N0 959 339 B
       Subsystem 2 - Serial number: 0000000000RML1
       Subsystem 3 - Serial number: 0029.10.150000300000630130˙†63
       Subsystem 4 - Serial number: 630130˙†6332MTS687933515B˙†63
       Subsystem 5 - Serial number: 33515B˙†6342MTS615433515+˙†63
       Subsystem 6 - Serial number: 33515+˙†6351HTS6AQQP1EKJL˙†63
       Subsystem 7 - Serial number: P1EKJL˙†6361HTS6F8D53EKJL˙†63
       Subsystem 8 - Serial number: 53EKJL˙†63727TS6M4735EKRI˙†63
       Subsystem 9 - Serial number: 35EKRI˙†63827TS6R3735EKRN˙
       Subsystem 10 - Serial number: 35EKRN˙
       Part No SW: 5K0 953 501 DM    HW: 5K0 953 569 AP
       Revision: FF010042    Serial number: 20160107201427
       Coding: 110A140000
       VCID: 78A9EFC4B25F1317F15-802C
       Component: E221__MFL-TAS  H31 0037
       Serial number: 0939434
       Coding: 820000
       Part No SW: 5N0 920 973 L    HW: 5N0 920 973 L
       Component: KOMBI         H04 1008
       Coding: 211F010000
       VCID: 3D273ED0DDFDF63FE23-8068
    12664832 - Function Restricted due to Missing Message(s)
              U1111 00 [008] - -
              [Steuergerät für BCM / Bordnetz / el. ZE: keine Kommunikation]
                        Reset counter: 99
                        Mileage: 51916 km
                        Date: 2020.03.18
                        Time: 10:53:47
    13631488 - Function Restricted due to Missing Message(s)
              U1111 00 [008] - -
              [Steuergerät für Komfortsysteme: keine Kommunikation]
                        Reset counter: 99
                        Mileage: 51916 km
                        Date: 2020.03.18
                        Time: 10:53:49
       Part No SW: 7N0 907 530 BB    HW: 7N0 907 530 AM
       Component: J533  Gateway H55 1663
       Revision:   H55       Serial number: 181215F1003573
       Coding: 356032
       VCID: 71BFD2E0D1A5425F36B-8024
       Part No SW: 0AY 907 554 J    HW: 0CQ 525 130
       Component: Haldex4Motion H52 7540
       Serial number: HA1-00023.11.15
       Coding: 0001
       VCID: 52FD7D6C746319472F1-8006
       Component: IMMO          H04 1008
       Coding: 000007
       VCID: 6A8DC58CFCF3B187771-803E
       Part No SW: 5K0 905 861 D    HW: 5K0 905 861 D
       Component: ELV-PQ35      H22 0240
       Revision: 00000000    Serial number: 15000263943009
       Coding: 4900000000000000
       ROD: EV_ELVMarquMPVW36X.rod
       VCID: 313F12E011A5025F76B-8064
              U1111 00 [008] - -
              [Timeout Message mBSG_Kombi]
                        Reset counter: 99
                        Mileage: 51916 km
                        Date: 2020.03.18
                        Time: 10:53:47
                        ELV State: 0A
                        Information Clamps: 88 08
                        CoCo State: F0 01
                        WFS State: 00 1A
                        Vehicle speed: 655.35 km/h
                        Voltage: 6D
    12665089 - Function Restricted due to Missing Message(s)
              U1111 00 [008] - -
              [Timeout Message mZKE_4]
                        Reset counter: 99
                        Mileage: 51916 km
                        Date: 2020.03.18
                        Time: 10:53:48
                        ELV State: 0A
                        CoCo State: F0 01
                        WFS State: 00 1A
                        Voltage: 6D
       Part No SW: 5N0 959 701 H    HW: 3C0 959 793 H
       Component: TUER-SG FT    002 0601
       Revision: 13100010    Serial number: 0010287783
       Coding: 0004B4
       ASAM Dataset: EV_TSGFPQ35BRFVW46X A04004
       VCID: 3A2D35CCCCD3C107C71-806E
       Slave Driver:
       Subsystem 1 - Part No SW: 5N0 959 703 G    HW: 3C0 959 794 D  Labels: 1K0-959-70X-GEN4.CLB
       Component: J388__TSG-HL  010 1505
       Serial number: 00000009689169
       Coding: 000490
    68098 - Function Restricted due to Missing Message(s)
              U1111 00 [008] - -
              [Front CAN KSG]
                        Reset counter: 99
                        Mileage: 51916 km
                        Date: 2020.03.18
                        Time: 10:53:48
    68100 - Function Restricted due to Missing Message(s)
              U1111 00 [008] - -
              [Front CAN BSG]
                        Reset counter: 99
                        Mileage: 51916 km
                        Date: 2020.03.18
                        Time: 10:53:48
       Part No SW: 5N1 909 144 R    HW: 5N1 909 148 J
       Component: J500__APA-BS KL.286 1401
       Revision: 1BH04841    Serial number: 00153380092801
       Coding: 0000258
       VCID: 41DF4220AD8592DF86B-8014
       Part No SW: 7N0 907 532     HW: 7N0 907 530 AM
       Component: EZE_2         H55 1663
       Coding: 050B0500
       VCID: 6FBBD498C79154AF20F-803A
       Subsystem 1 - Part No SW: 7N0 959 591 B    HW: 7N0 959 591 B
       Component: J245EE04SKB03  H04 0090
       Subsystem 2 - Part No SW: 7N0 959 591 B    HW: 7N0 959 591 B
       Component: J394EE04SKB03  H04 0090
       Part No SW: 5N0 959 702 H    HW: 3C0 959 792 H
       Component: TUER-SG BT    002 0601
       Revision: 15100010    Serial number: 0010113629
       Coding: 0004B4
       ASAM Dataset: EV_TSGBPQ35BRFVW46X A04004
       VCID: 3B2330C8C3E9F80FDC7-806E
       Slave Passenger:
       Subsystem 1 - Part No SW: 5N0 959 704 G    HW: 3C0 959 795 D  Labels: 1K0-959-70X-GEN4.CLB
       Component: J389__TSG-HR  010 1505
       Serial number: 00000009693542
       Coding: 000490
              U1111 00 [008] - -
              [Front CAN KSG]
                        Reset counter: 99
                        Mileage: 51916 km
                        Date: 2020.03.18
                        Time: 10:53:48
              U1111 00 [008] - -
              [Front CAN BSG]
                        Reset counter: 99
                        Mileage: 51916 km
                        Date: 2020.03.18
                        Time: 10:53:48
       Part No SW: 3AA 907 801 J    HW: 3AA 907 801 J
       Component: J540 EPB4  VW-63206 0012
       Revision:   H19       Serial number: 00000001017851
       Coding: 0026156
       VCID: 38292FC4FE5FD317315-806C
       Component: AFS-ECU       H05 0111
       Coding: 041A00010B000400
       ROD: EV_HeadlRegulVWAFSPt_VW32.rod
       Subsystem 1 - Part No: 5N0 941 329   Labels: 3D0-941-329.CLB
       Subsystem 2 - Part No: 5N0 941 329   Labels: 3D0-941-329.CLB
       Part No SW: 5C0 035 684     HW: 5C0 035 684
       Component: MU-S-NS-US    H22 0245
       Serial number: VWZAZ2S3727060
       Coding: 02130602FF00000051220001001808001F0100D400200105C6
       ROD: EV_MUStd4CTSAT_VW36.rod
       VCID: 629DADAC04C3E9C7BF1-8036
       Subsystem 1 - Part No SW: 3G0 919 866 R    HW: -----------
       Component: NAR 2016  --- 0321
    2565 - GPS Antenna
              B1054 13 [008] - Open Circuit
              [GPS aerial - open circuit]
                        Fault Frequency: 83
                        Reset counter: 98
                        Mileage: 46555 km
                        Date: 2020.01.25
                        Time: 00:13:35
                        Voltage terminal 30: 12.3 V
       Part No SW: 561 035 285 A    HW: 561 035 285 A
       Component: OCULowUSA     020 0158
       Serial number: 000003554140546
       Coding: 02130602C24232107F1606020000
       ASAM Dataset: EV_OCULow 002010
       ROD: EV_OCULow_002.rod
       VCID: 1471BB748EF7D7777DD-8040
    End----------(Elapsed Time: 01:37, VBatt start/end: 12.2V/12.1V)-----------
  2. Likes Dana liked this post
  3. #2
    BCM PQ35.. Those are a PITA. You might have to get something that can edit the EEPROM.
    Oct 2015
    Bulgaria
    vcds isn't capable of doing this?
    No, it isn't.
    United States
    Uwe may be correct here but the 5N2 (Facelifted 5N chassis) does have NAR documentation for Byte 18:
    AD,Lighting: VW Tiguan (5N2/VW316) North American Region (NAR) with Halogen
    AE,Lighting: VW Tiguan (5N2/VW316) North American Region (NAR) with Xenon
    That doesn't help you because you aren't using NAR settings however both HEX AA and AB are marked (RoW) with Unknown lights. I would try both and get back to us with the results. If I was to guess I'd start with AB because of the Xenon lamps and AA is more likely IMO to be Halogen.
    If both are accepted do make sure ALL outside lights work properly. Sometimes a rear fog lamp/reverse light can swap functions with a RF DRL and similar when you have wrong Byte 18 in conjunction with wrong-market wiring.
  7. Likes Uwe liked this post
    Oct 2015
    Bulgaria
    it turned out to be way more complicated than i ever thought...
    apparently the turn signal bulb has three functions on itself. turn signal, brake light and, dimmed-rear park light. NAR vehicles has also separate side-marker, which is one totally separate little bulb on the side.
    so first task is to separate brake light from a turn signal.
    yup, uwe is right, as always-eeprom had to be rewritten.
    second challenge was to wire BCM with the separate left and right brake lights. connectors A (black) pin 26 and C (brown) 4. pins are present in the BCM (thank god for that!) but not wired in the harness. so after wiring the pins with the actual taillights comes the third task. getting the brake light to dim in order to achieve dual function-
    brake/parking light. otherwise there are parking lights only on the tailgate. not nice... side marker is restricted in it's own confinement cell and doesn't affect the overall parking light. the whole thing goes blank, with small red light on the side and lights up only with brake light.
    it was fun, so to say...
    a guy, friend of a friend of the customer came and we had long lasting sex with this BCM... but in the end it all clicked into place.
    if i may suggest-if there is even slightest possibility to make all this using vcds it will be priceless!
    murphy is an SOB... he said that if your shoes are comfortable, so they must be ugly...
    facts of life...
  9. Likes Uwe, Dana liked this post
