Results 1 to 3 of 3
Thread: VW TOUAREG 2018 LANE CHANGE FAULTS
    Oct 2015
    UAE
    Hi , i have volkswagen touareg with faults for lane change assist , proactive occupant protection , side assist . i do not know where to start , any help would be appreciated.
    Wednesday,18,March,2020,12:30:21:10836
    VCDS Version: 19.6.2.2 (x64)  HEX-NET CB: 0.4508.4
    VIN: WVGBE1CR4JD002334   License Plate: 9898
    Mileage: 38399km-23860mi   Repair Order: 77
    Chassis Type: CR-VW53 (4N4)
    Scan: 01 02 03 06 09 15 16 17 19 29 2B 36 39 3C 42 44 46 52 5F 65
              6C 6D 81 82 A5 BB BC CA CF D6 D7 DB DC DE
    VIN: WVGBE1CR4JD002334   Mileage: 38399km-23860miles
    CA-Sunroof -- Status: OK 0000
    CF-Lane Chge Asst 2 -- Status: Malfunction 0010
    DB-Frt Corner Rdar 1 -- Status: OK 0000
    DC-Frt Corner Rdar 2 -- Status: Malfunction 0010
    DE-Charger 1 for mobile dev -- Status: Malfunction 0010
    Address 01: Engine (J623-DCBE)       Labels: None
       Part No SW: 760 907 559     HW: 06M 907 309 F
       Component: V6 3.0l TFSI  H12 0003
       Revision: B7H12000
       Coding: 292A00322526050B34380000000400000000000000000000
       Shop #: WSC 05745 128 28889
       ASAM Dataset: EV_ECM30TFS011760907559 002004
       ROD: EV_ECM30TFS011760907559.rod
       VCID: 608C71327B69F74FC5-8034
    26521 - Lane change assistant control module
              U1045 00 [047] - No communication
              [Lane change assistance control moduleNo communication]
                        Fault Frequency: 77
                        Mileage: 38398 km
                        Date: 2020.03.17
                        Time: 20:52:03
                        Coolant temperature: 89 °C
                        Intake air temperature: 37 °C
                        Voltage terminal 30: 12.160 V
                        Com st X Set2 Val1-Bits 0-7: 0
                        Com st X Set2 Val2-Bits 0-7: 0
                        Com st X Set2 Val3-Bits 0-7: 0
                        Com st X Set2 Val4-Bits 0-7: 0
                        Com st X Set2 Val5-Bits 0-7: 0
                        Com st X Set2 Val6-Bits 0-7: 0
                        Com st X Set2 Val7-Bits 0-7: 0
                        Com st X Set2 Val7-Bits 0-7: 1
    Readiness: 1110 0001
    Address 02: Auto Trans (J217)       Labels:* Redir Fail!
       Part No SW: 760 927 158     HW: 0D5 927 156 N
       Component: 0D5  30TSIRdW H05 1003
       Revision: --H05---
       Coding: 100000
       ASAM Dataset: EV_TCMALX52011 002014
       ROD: EV_TCMALX52011.rod
       VCID: 5DF248C64C1BDAA7EE-8008
    Address 03: ABS Brakes (J104)       Labels: 4M0-907-379-PRE-V1.clb
       Part No SW: 4M6 907 379 N    HW: 4M6 907 379
       Component: ESP9 Premium  H05 0850
       Coding: 25A715B730A20B989EA14C94008112D2E93AE8A4A80CD0793200484B975C17
       ASAM Dataset: EV_ESP9BOSCHCMP 004011
       ROD: EV_ESP9BOSCHCMP_VW53.rod
       VCID: 48DC8992F399AF0F2D-801C
    452352 - Databus
              U1123 00 [046] - Received Error Message
              [Signal_RCTA_Status_error_(3)]
                        Fault Frequency: 37
                        Mileage: 38398 km
                        Date: 2020.03.17
                        Time: 20:59:37
       Part No SW: 4M6 959 760 B    HW: 4M6 959 760 B
       Component: MEM-BFS       009 0042
       Serial number: 00000310509220
       Coding: 0118B8000000B88188000101210100008900000707008F8F00000000015000
       Shop #: WSC 31414 245 00001
       ROD: EV_SCMPasseSideCONTIAU736_VW53.rod
       VCID: 3D32E846AC5BFAA78E-8068
       Subsystem 1 - Part No SW: 4N0 907 182     HW: 4N0 907 182
       Component: N477 VB1 BFSv  H04 0011
       Serial number: SJ800102031840258144
       Coding: BF2F00
    Address 09: Cent. Elect. (J519)       Labels:* 4N0-907-063-V2.clb
       Part No SW: 4N0 907 063 DG    HW: 4N0 907 063 AG
       Component: BCM1 MLBevo   H10 0652
       Coding: 07501140E13B0009070D1708582B0C40800B30100000009301100A007924FC019BC501B302B7C63700000100009320081802040000010100000000000000000000
       ASAM Dataset: EV_BCM1BOSCHAU651 014010
       ROD: EV_BCM1BOSCHAU651_014.rod
       VCID: 76A0376AC9ED69FF8F-8022
       Subsystem 1 - Part No SW: 761 955 113     HW: 761 955 113
       Component: WIPER 160218  010 0380
       Serial number: VZ1SKA 0100005616021
       Serial number: 21212290X81A955555A0
       Coding: 02006D
       Light switch:
       Subsystem 3 - Part No SW: 761 941 633     HW: 761 941 633
       Component: E1 - LTM  H06 0054
       Serial number: 13S15.03.1800140082
       Subsystem 4 - Part No SW: 3G0 857 511 AL    HW: 3G0 857 511 AL
       Serial number: GX1CE122111720910126
       Interior Light Module:
       Subsystem 5 - Part No SW: 760 947 105 AD    HW: 760 947 105 AD
       Component: Dachelektroni  H32 0057
       Serial number: 00000068820000000000
    196903 - Databus
              [RCTA/SWA control module: received error value in signal RCTA_status]
                        Fault Frequency: 69
                        Reset counter: 9
                        Mileage: 38398 km
                        Date: 2020.03.17
                        Time: 20:59:47
                        average_Voltage_terminals: 12.90 V
                        Outside air temperature sensor-Resistance: 0.00 kOhm
                        Outside air temperature sensor-Outside air temperature on CAN: 30.50 °C
                        interior_temperature: 24.50 °C
                        Vehicle speed: 0.00 km/h
    262179 - Lamp 1 for Ambient Lighting of Door; Front Right
              U1186 00 [009] - No Communications
                        Reset counter: 224
                        Mileage: 38398 km
                        Date: 2020.03.17
                        Time: 20:52:20
                        average_Voltage_terminals: 12.10 V
                        interior_temperature: 25.00 °C
                        System run time-Engine running time: 65535 s
                        System run time-Terminal 15 on: 0 s
    262500 - Bulb 2 for Ambient Lighting of Door; Front Right
              U1362 00 [009] - No Communication
              [Right front door ambient lighting: RGB slave 2: no signal/communication]
                        Reset counter: 224
                        Mileage: 38398 km
                        Date: 2020.03.17
                        Time: 20:52:20
       Part No SW: 4M0 959 655 J    HW: 4M0 959 655 C
       Component: AirbagVW31    H32 2710
       Serial number: 003TZM0034Z2
       Coding: 88CCC0C000800000585400EF300D01000065
       ASAM Dataset: EV_AirbaVW31SMEAU65x 001028
       ROD: EV_AirbaVW31SMEAU65x_VW53.rod
       VCID: 42C89BBAD5A5855FF3-8016
       Belt Pretensioner left:
       Subsystem 1 - Part No SW: 4N0 980 945 B    HW: 4N0 980 945 B
       Component: BeltPretRevFL  H20 0115
       Serial number: 00AH2018057008600000
       Coding: 04F001
       Belt Pretensioner right:
       Subsystem 2 - Part No SW: 4N0 980 946 B    HW: 4N0 980 946 B
       Component: BeltPretRevFR  H20 0115
       Serial number: 00AH2018058003400000
       Coding: 04F001
       Subsystem 3 - Part No SW: -----------    HW: 480 000 503 18
       Serial number: 35700000000323485B2A
       Subsystem 4 - Part No SW: -----------    HW: 480 000 503 18
       Serial number: 358000000009EB295D2
       Subsystem 5 - Part No SW: -----------    HW: 480 030 303 18
       Component: SideSensor_Dr  002 0149
       Serial number: 351001C0C3F099813B5C
       Subsystem 6 - Part No SW: -----------    HW: 480 030 303 18
       Component: SideSensor_Pr  002 0149
       Serial number: 352001C0C3F85E212D1D
       Subsystem 7 - Part No SW: -----------    HW: 480 031 312 17
       Component: FrontSensor_D  002 0189
       Serial number: 355001C08F0909105C54
       Front Sensor Passenger:
       Subsystem 8 - Part No SW: -----------    HW: 480 031 312 17
       Component: FrontSensor_P  002 0189
       Serial number: 356001C043B9B8A03B3E
    11 Faults Found:
    1069312 - Databus
              [NWD: zFAS common DTC Timeout]
                        Fault Frequency: 15
                        Reset counter: 224
                        Mileage: 38398 km
                        Date: 2020.03.17
                        Time: 20:52:22
    1073413 - Databus
              [NWD: 0xTBD MRR_HL_SensorHeader error value MRR_HL_Fehler]
                        Fault Frequency: 87
                        Reset counter: 9
                        Mileage: 38398 km
                        Date: 2020.03.17
                        Time: 20:59:40
    1073414 - Databus
              [NWD: 0xTBD MRR_HL_SensorHeader error value MRR_HL_NichtVerfuegbar]
                        Reset counter: 9
                        Mileage: 38399 km
                        Date: 2020.03.18
                        Time: 10:29:07
    1073669 - Databus
              [NWD: 0xTBD MRR_HR_SensorHeader error value MRR_HR_Fehler]
                        Fault Frequency: 23
                        Reset counter: 9
                        Mileage: 38398 km
                        Date: 2020.03.18
                        Time: 10:28:49
    1073920 - Databus
              [NWD: 0xTBD MRR_VL_SensorHeader Timeout]
                        Reset counter: 9
                        Mileage: 38398 km
                        Date: 2020.03.17
                        Time: 20:54:07
    1050633 - Databus
              [NWD: 0x322 PCR_01 error value PCR_Crashwahrscheinlichkeit]
                        Fault Frequency: 103
                        Reset counter: 9
                        Mileage: 38398 km
                        Date: 2020.03.17
                        Time: 20:59:40
    1050632 - Databus
              [NWD: 0x322 PCR_01 error value PCR_Obj_Guete]
                        Reset counter: 9
                        Mileage: 38398 km
                        Date: 2020.03.17
                        Time: 20:59:40
    1050631 - Databus
              [NWD: 0x322 PCR_01 error value PCR_Obj_TTC]
                        Reset counter: 9
                        Mileage: 38398 km
                        Date: 2020.03.17
                        Time: 20:59:40
    1050629 - Databus
              [NWD: 0x322 PCR_01 error value PCR_Obj_vx_rel]
                        Reset counter: 9
                        Mileage: 38398 km
                        Date: 2020.03.17
                        Time: 20:59:40
    1050630 - Databus
              [NWD: 0x322 PCR_01 error value PCR_Obj_vy_rel]
                        Reset counter: 9
                        Mileage: 38398 km
                        Date: 2020.03.17
                        Time: 20:59:40
    1056773 - Databus
              [NWD: 0x17F PCR_02 error value PCR_Obj_xRel]
                        Reset counter: 9
                        Mileage: 38398 km
                        Date: 2020.03.17
                        Time: 20:59:40
       Part No SW: 760 953 507     HW: 760 953 507
       Component: Lenks.Modul   H03 0006
       ROD: EV_SMLSKLOAU736_VW53.rod
       VCID: 5AF843DA5D352D9F8B-800E
       Part No SW: 761 920 790     HW: 761 920 790
       Component: FBenRDW       H12 0106
       Coding: C5A431C06A9800080108632EF0800800F4000080
       ASAM Dataset: EV_DashBoardAU65X 001011
       ROD: EV_DashBoardAU65X_VW53.rod
       VCID: 59FA5CD65833268782-800C
       Operating Unit Drive Mode Selection:
       Subsystem 1 - Part No SW: 760 927 531 F    HW: 760 927 531 F
       Component: E881 BedieFPA  001 0460
       Part No SW: 4N4 907 468 AA    HW: 4N4 907 468 A
       Component: Gateway       H07 0033
       Revision: 9D020001    Serial number: 0149D003518213
       Coding: 0301000300000E405407000000DB05324E1E0007100000000300000000000100
       ASAM Dataset: EV_GatewCONTIAU736 003150
       ROD: EV_CGateCONTIAU491_003_VW53.rod
       VCID: 7AB8235AFDF50D9FEB-802E
       Subsystem 1 - Part No SW: 5G0 959 442 AA    HW: 5G0 959 442 AA  Labels: 3C8-959-537.CLB
       Component: E221__MFL-DC1  H17 0052
       Serial number: 39170002924020098076
       Coding: 28FFFF
       Serial number: 8814307004
    131588 - Front Sensors for Driver-Assist Systems
              U13BE 00 [009] - No Communication on 2nd Bus
              [Timeout_Node_0x04_DiagAdress_A5_ZFAS]
                        Reset counter: 224
                        Mileage: 38398 km
                        Date: 2020.03.17
                        Time: 20:52:31
    131742 - Control Module for Front Corner Radar 2 (Left)
              U0232 00 [008] - No Communication
              [Timeout_Node_0x9E_DiagAdress_DC_MRR_VL]
                        Reset counter: 9
                        Mileage: 38399 km
                        Date: 2020.03.18
                        Time: 10:28:51
    Address 29: Left Light (J1018)       Labels: None
       Part No SW: 80A 907 397 D    HW: 80A 907 397 D
       Component: LCM_MLBevo    H07 0022
       ASAM Dataset: EV_LCMLeftCONTIAU426 001009
       ROD: EV_LCMLeftCONTIAU426_VW53.rod
       VCID: 302CC1726B0907CF15-8064
       Part No SW: 3Q0 905 861 A    HW: 3Q0 905 861 A
       Component: ELV-MLBevo    H05 0032
       Serial number: 18000082255015
       Coding: 8800000000000000
       Shop #: WSC 31414 030 00001
       ROD: EV_ELVMarquMQBB.rod
       VCID: 3228CB7A650535DF63-8066
       Component: MEM-FS        009 0042
       Serial number: 00000310576520
       Coding: 01189A400000B48188000101210100008900000707008F8F00000000015000
       ROD: EV_SCMDriveSideCONTIAU736_VW38.rod
       Component: N475 VB1 FSv  H04 0011
       Serial number: SJ800114021840258509
       Coding: BF2F00
    Address 39: Right Light (J1023)       Labels: None
       ASAM Dataset: EV_LCMRightCONTIAU426 001009
    Address 3C: Lane Change (J769)       Labels:* None
       Part No SW: 4N0 907 566 E    HW: 4N0 907 566 A
       Component: MRR_HR H12 0265
       Coding: 07D300
       ASAM Dataset: EV_RearRadarS1DelphAU651 001018
       ROD: EV_RearRadarS1DelphAU651_VW53.rod
       VCID: 383CF9528379DF8F5D-806C
    1179653 - FlexRay-Data bus
              U106E 00 [008] - Signal error
              [Fr_Sendcollision]
                        Fault Frequency: 26
                        Reset counter: 9
       Part No SW: 4M1 959 793 C    HW: 4M1 959 793 B
       Component: TSG FS006 0848
       Serial number: YE007RBK13084
       Coding: 003F9B00DE00048000013090
       ROD: EV_DCU2DriveSideMAXHKLO_VW53.rod
       VCID: 3FCE924EA657E8B79C-806A
       Part No SW: 4N0 909 144 D    HW: 4N0 909 144 A
       Component: EPS_MLBEVO2BS H20 0504
       Coding: 94110101000100
       ASAM Dataset: EV_EPSVWBSAU426 009015
       ROD: EV_EPSVWBSAU426_009.rod
       VCID: 312AC47660030EC71A-8064
       Part No SW: 4N0 907 064 BP    HW: 4N0 907 064 P
       Component: BCM2 MLBevo H14 0144
       Coding: 01342C00200000E8732980047C00080003034000044B02502F0400000508803F001F3154010001
       ASAM Dataset: EV_BCM2CONTIAU651 008007
       ROD: EV_BCM2CONTIAU651_008.rod
       VCID: 7EB02F4AE1DD21BFD7-802A
       Ignition key:
       Subsystem 2 - Part No SW: 3G0 962 243 C    HW: 3G0 962 243 C
       Component: GEB.F.Heckoef  H17 0906
       Serial number: >9006157
       Part No SW: 4M1 959 792 C    HW: 4M1 959 792 B
       Component: TSG BFS006 0848
       Serial number: YE007RBK21608
       ROD: EV_DCU2PasseSideMAXHCONT_VW27.rod
       VCID: 3E30EF4AA15DE1BF97-806A
       Part No SW: 760 035 067     HW: 760 035 067
       Component: MU-H-LN-RW    045 2473
       Coding: 0235060CFF00000043110001001828301F0100E401A00400DF
       ASAM Dataset: EV_MUHigGen2pALPI 001001
       ROD: EV_MUHigGen2pALPI_VW53.rod
       VCID: 52E8ABFA05C515DF43-8006
       Subsystem 1 - Part No SW: 760 919 618     HW: 760 919 618
       Component: ABT_Prem_L  H38 5141
       Serial number: VWZ6ZGV0750023
       Subsystem 2 - Part No: V03 959 805 HN
       Component: MIB2P_RW_Q317  0244
       Subsystem 3 - Part No: V03 959 800 EG
       Component: Gracenote2  4007
       Volume Control 1:
       Subsystem 4 - Part No SW: 761 927 341     HW: 761 927 341
       Component: VW536LLB  H06 0108
       Serial number: 2018030800000187
       Media socket:
       Subsystem 5 - Part No SW: 5G0 035 953 D    HW: 0
    H08 0014
    Address 65: Tire Pressure (J502)       Labels: None
       Part No SW: 3F0 907 273     HW: 4M0 907 273 B
       Component: RDKHUFVW536   H04 0003
       Serial number: 30000000002063
       ASAM Dataset: EV_RDKHUFVW536 002002
       ROD: EV_RDKHUFVW536.rod
       VCID: 65826026644B926736-8030
    Address 6C: Back-up Cam. (J772)       Labels:* Redir Fail!
       Part No SW: 4M0 980 556 A    HW: 4M0 980 556 A
       Component: RVC Compact   H12 0250
       Coding: 0135060122002011000040
       ASAM Dataset: EV_CamSysRVRVCPANAMLBEv 005010
       ROD: EV_CamSysRVRVCPANAMLBEv_005_VW53.rod
       VCID: 3326CE7E9A1F3CD768-8066
       Part No SW: 4M0 959 107 C    HW: 4M0 959 107 C
       Component: HDSG-Modul    H14 0163
       Revision: --------    Serial number: 31812697300000
       Coding: 1778
       ASAM Dataset: EV_DeckLidCONTIAU736 001015
       ROD: EV_DeckLidCONTIAU736_VW53.rod
       Part No SW: 761 713 041 A    HW: 4M1 713 041 G
       Component: GSM-LL        H10 0077
       Revision: 0L0D5012    Serial number: 18020645917192
       ROD: EV_GSMWaehlZFAU736.rod
       VCID: 0F6E628ED67738372C-805A
       Part No SW: 761 919 608     HW: 761 919 608
       Component: HeadupDisplay H12 0193
       Coding: AE40C0
       ASAM Dataset: EV_HeadUpDisplAU65X 001009
       ROD: EV_HeadUpDisplAU65X_VW53.rod
       VCID: 5F8E72CE4617C8B7FC-800A
    Address A5: Frt Sens. Drv. Assist (J1121)       Labels:* None
       Part No SW: 4KE 907 107 AB    HW: 4N0 907 107 G
       Component: zFAS Var B    H08 0291
       Coding: 040282000000000000F0060000D0042C1B995700000000000000000000000000000000000000000000000000000000000000000000000000F9C080000000000000001890000000700000000000000000008040000030
       ASAM Dataset: EV_ZFASAU516 001005
       ROD: EV_ZFASAU516_VW53.rod
       VCID: 7F4ED24EE6D728B7DC-802A
    15 Faults Found:
    2113539 - FlexRay Databus 2
              U008A 00 [009] - No Communication
              [Fr_NoCommunicationBEvent]
                        Reset counter: 224
                        Mileage: 38398 km
                        Date: 2020.03.17
                        Time: 20:52:54
                        Supply voltages-Supply voltage Terminal 30 - internal: 0.00 V
                        Supply voltages-Terminal 30: 12.00 V
                        Supply voltages-Terminal 30 local: 12.10 V
    2113913 - Databus
              [TIMEOUT_MRR_HR_SensorHeader]
                        Reset counter: 224
                        Mileage: 38398 km
                        Date: 2020.03.17
                        Time: 20:59:17
                        Supply voltages-Terminal 30: 11.90 V
                        Supply voltages-Terminal 30 local: 12.00 V
    2113883 - Databus
              [TIMEOUT_MRR_HL_SensorHeader]
                        Reset counter: 224
                        Mileage: 38398 km
                        Date: 2020.03.17
                        Time: 20:59:17
    2113853 - Databus
              [TIMEOUT_MRR_VR_SensorHeader]
                        Reset counter: 224
                        Mileage: 38398 km
                        Date: 2020.03.17
                        Time: 20:59:17
    2114881 - Databus
              [TIMEOUT_MRR_VR_Fence]
                        Reset counter: 224
                        Mileage: 38398 km
                        Date: 2020.03.17
                        Time: 20:59:17
    2113823 - Databus
              [TIMEOUT_MRR_VL_SensorHeader]
                        Reset counter: 224
                        Mileage: 38398 km
                        Date: 2020.03.17
                        Time: 20:59:17
    2114882 - Databus
              [TIMEOUT_MRR_VL_Fence]
                        Reset counter: 224
                        Mileage: 38398 km
                        Date: 2020.03.17
                        Time: 20:59:17
    2114804 - Databus
              [TIMEOUT_MRR_HR_SensorPos]
                        Reset counter: 224
                        Mileage: 38398 km
                        Date: 2020.03.17
                        Time: 20:59:20
                        Supply voltages-Terminal 30: 12.20 V
                        Supply voltages-Terminal 30 local: 12.20 V
    2114805 - Databus
              [TIMEOUT_MRR_HL_SensorPos]
                        Reset counter: 224
                        Mileage: 38398 km
                        Date: 2020.03.17
                        Time: 20:59:20
    2114806 - Databus
              [TIMEOUT_MRR_VR_SensorPos]
                        Reset counter: 224
                        Mileage: 38398 km
                        Date: 2020.03.17
                        Time: 20:59:20
    2114807 - Databus
              [TIMEOUT_MRR_VL_SensorPos]
                        Reset counter: 224
                        Mileage: 38398 km
                        Date: 2020.03.17
                        Time: 20:59:20
    2114631 - Databus
              [SWA_01_SWA_rel_Fehler]
                        Fault Frequency: 166
                        Reset counter: 224
                        Mileage: 38398 km
                        Date: 2020.03.17
                        Time: 20:54:08
    2117691 - Ethernet Databus
              U11C4 00 [008] - No Communications
              [Databus_Ethernet_no_communication]
                        Reset counter: 9
                        Mileage: 38399 km
                        Date: 2020.03.18
                        Time: 13:24:42
                        Ethernet signal quality: no link
    2117692 - Control unit for information electronics 1
              U1054 00 [008] - No Communication
              [Databus_Ethernet_missing_PDU]
                        Reset counter: 9
                        Mileage: 38399 km
                        Date: 2020.03.18
                        Time: 13:24:30
    2114915 - Databus
              [SWA_01_SWA_Status_02]
                        Fault Frequency: 155
                        Reset counter: 224
                        Mileage: 38398 km
                        Date: 2020.03.17
                        Time: 20:54:09
       Part No SW: 4M1 959 595 C    HW: 4M1 959 595 B
       Component: TSG HFS001 0848
       Serial number: YE007RC81188B
       Coding: 003E93000000048000013080
       Component: TSG HBFS001 0848
       Serial number: YE007RBE20798
       Part No SW: 4M0 907 594 G    HW: 4M0 907 594
       Coding: 688040753602
       VCID: 3A38E35ABD75CD9FAB-806E
    Address CF: Lane Chge Asst 2 (J770)       Labels:* None
       Component: MRR_HL H12 0265
       Coding: 07D300
       ASAM Dataset: EV_RearRadarS2DelphAU651 001018
       ROD: EV_RearRadarS2DelphAU651_VW53.rod
    1183789 - Databus
              [databus message missing - MRR_HR_SensorHeader_01]
                        Fault Frequency: 19
                        Reset counter: 9
                        Mileage: 38399 km
                        Date: 2020.03.18
                        Time: 10:28:52
                        Control Module temperature: 39 °C
                        Voltage terminal 30: 14.30 V
                        Terminal 15 status: On
                        Voltage terminal 15: Measured value not available
    1184001 - Databus
              [databus message missing - MRR_HR_Detection]
                        Fault Frequency: 11
                        Reset counter: 9
                        Mileage: 38398 km
                        Date: 2020.03.17
                        Time: 20:54:08
                        Control Module temperature: 53 °C
                        Voltage terminal 30: 11.70 V
    1191954 - Databus
              [databus error value received - MRR_HR_SensorHeader_MRR_HR_Fehler]
                        Fault Frequency: 22
                        Reset counter: 9
                        Mileage: 38399 km
                        Date: 2020.03.18
                        Time: 10:28:50
                        Voltage terminal 30: 14.00 V
              [Fr_Sendcollision]
                        Fault Frequency: 82
                        Reset counter: 224
    Address D6: Light Ctrl Left 2 (A31)       Labels: 7PP-941-592.clb
       Part No SW: 7PP 941 592 AA    HW: 7PP 941 592 A
       Component: LED1L         H09 4002
       ROD: EV_LEDModLeftMELCOAU736_VW41.rod
       VCID: 177E1AEEEEA7F0F774-8042
    Address D7: Light Ctrl Right 2 (A27)       Labels: 7PP-941-592.clb
       Component: LED1R         H09 4002
    Address DB: Frt Corner Rdar 1 (J1089)       Labels:* None
       Part No SW: 4N0 907 669 E    HW: 4N0 907 669 A
       Component: MRR_VR H12 0265
       Coding: 001000
       ASAM Dataset: EV_FrontCorneRadarS1AU651 001018
       ROD: EV_FrontCorneRadarS1AU651_VW53.rod
       VCID: 3C34E542B741F3AFB9-8068
    Address DC: Frt Corner Rdar 2 (J1088)       Labels:* None
       Component: MRR_VL H12 0265
       Coding: 001000
       ASAM Dataset: EV_FrontCorneRadarS2AU651 001018
       ROD: EV_FrontCorneRadarS2AU651_VW53.rod
              [Fr_Sendcollision]
                        Reset counter: 9
                        Mileage: 38399 km
                        Date: 2020.03.18
                        Time: 10:28:48
                        Control Module temperature: 35 °C
                        Voltage terminal 30: Measured value not available
                        Vehicle speed: 0.39 km/h
                        Voltage terminal 15: 14.30 V
                        Register_check_info-Register_check_info_parameter: 0
                        C1_critical_signals_info-C1_critical_signals_info_parameter: 0
                        C2_critical_signals_info-C2_critical_signals_info_parameter: 0
    Address DE: Charger 1 for mobile dev (J1146)       Labels:* 4N0-035-502.clb
       Part No SW: 4N0 035 502     HW: 4N0 035 502
       Component: WLC Front     H06 0040
       Coding: 800000
       ASAM Dataset: EV_Charg1MobilDevicAU651 004001
       ROD: EV_Charg1MobilDevicAU651.rod
       VCID: 618A74367063FE47CA-8034
    0005 - Antenna Amplifier for Charger for Mobile Devices
              B17A3 F0 [008] - Turn-On Conditions Not Met
                        Reset counter: 9
                        Mileage: 38399 km
                        Date: 2020.03.18
                        Time: 13:24:20
    End----------(Elapsed Time: 02:16, VBatt start/end: 14.4V/14.4V)-----------
    May 2017
    I would start from here, wiring issue?
       Coding: 07D300
              [Fr_Sendcollision]
                        Fault Frequency: 26
                        Reset counter: 9
  3. Likes Dana liked this post
    What's the back-story here? Has this vehicle been in an accident?
  5. Likes downtime, Dana liked this post
