Results 11 to 20 of 22
Thread: Rebuilt Passat sedan TSI 150 2016 full options
    Verified VCDS User sam1754's Avatar
    Mar 2019
    France
    Really no one???
  2. #12
    IDE00512-ESI: minimum value km-driving distance/inspection, > 15000 km
    IDE00827-ESI: minimum value of time between inspections, > 365 d
    IDE01153-SIA: maximum value of distance to service, > 15000 km
    IDE01154-SIA: maximum value of time to service, > 365 d
    IDE03350-FIX: Maximum time until next time-dependent inspection, > 730 d
    Then probably both service reset menus has to be executed.
  3. Likes Uwe, Dana, Fredrick Awuor liked this post
  4. #13
    Mar 2019
    France
    Thanks NEtech to have confirmed it,
    As the car is still under warranty, I'll wait to make it fixed by VW.
  5. #14
    Mar 2019
    France
    I noticed a new strange thing:
    I changed confort blinking cycles (3 to 5) as I have already done on five or six car with no problem. Coding accepted, working properly and for strange reasons, it comes unexpectedly back to 3 blinking... but power supply control module still keep the "5" value???
    Any idea, due to instrument(17) faulty???
  6. #15
    On my MQB car it's necessary to select the option to reset the lighting configuration on the infotainment screen for the comfort blinking number change to actually "stick". Don't know if that applies to your car?
  7. #16
    Mar 2019
    France
    Thanks PetrolDave, I think I already tried it but I'll do it again to make sure.
  8. #17
    Mar 2019
    France
    Hello, I'm asking if I can make elecric trunk working in sedan as it works in my sw. I would like to allow closing by using driver's door interior switch or key fob. Actually it works with sw but not sedan. Just opening.
    Here is the adamap:
     ;SW:5Q0-959-107-D   HW:5Q0-959-107-D ---  Trunk Elect.
    ;Component:HDSG-Modul    H12 0233, Coding:0108
    ;EV_DeckLidCONTIAU736,001009,EV_DeckLidCONTIAU736_VW37.rod
    ;Sunday,22,March,2020,12:34:12:16465
    ;VCDS Version: Release 19.6.2 (x64)  Data version: 20200210 DS308.0
    ;VCID: 392FD0DDF9DD97DFCEB-806C
    IDE00001-IDE03415-Production mode-Tone sensor,not active ,3
    IDE00001-IDE10408-Production mode-Opening height in production mode,not active ,3
    IDE00001-MAS10733-Production mode-Activation due to excessive pressure on rear lid,not active ,3
    IDE00001-MAS10734-Production mode-Activation of rear lid with reduced speed,not active ,3
    IDE00001-MAS10735-Production mode-Calibration,not active ,3
    IDE00001-MAS10736-Production mode-Checking the rear lid button,not active ,3
    IDE00001-MAS10738-Production mode-Opening and closing rear lid,not active ,3
    IDE02158-Program opening stop,1261 ,2
    IDE03435-Detection area upper,10 ,2
    IDE03776-Offset for maximum programmable opening stop,40 ,2
    IDE09510-IDE02111-Tailgate reverse path-Reverse path when opening,1 ,4
    IDE09510-IDE02113-Tailgate reverse path-Reverse path when closing,224 ,4
    IDE09511-Minimum opening height of tailgate,400 ,2
    IDE09512-Deactivation of tailgate,active ,1
    IDE09514-MAS01871-Deactivation of tailgate while in trailer operation-Rear lid lock button in luggage compartment,active ,2
    IDE09514-MAS06265-Deactivation of tailgate while in trailer operation-Release button in rear lid handle,active ,2
    IDE09514-MAS09010-Deactivation of tailgate while in trailer operation-Sensor for rear lid opening,active ,2
    IDE09514-MAS09042-Deactivation of tailgate while in trailer operation-Using button to close lock. mechanism in tailgate handle,active ,2
    IDE09514-MAS09043-Deactivation of tailgate while in trailer operation-Remote ctrl: opening with button for tailgate unlock. mechan.,not active ,2
    IDE09514-MAS09044-Deactivation of tailgate while in trailer operation-Remote ctrl: closing with button for tailgate unlock. mechan.,not active ,2
    IDE09514-MAS09045-Deactivation of tailgate while in trailer operation-Using sensor to open tailgate,not active ,2
    IDE09514-MAS09046-Deactivation of tailgate while in trailer operation-Using sensor to close tailgate,not active ,2
    IDE09514-MAS09063-Deactivation of tailgate while in trailer operation-Opening with button for remote unlocking of tailgate,not active ,2
    IDE09514-MAS09064-Deactivation of tailgate while in trailer operation-Closing with remote unl.button of tailgate when using a trailer,not active ,2
    IDE09514-MAS11625-Deactivation of tailgate while in trailer operation-Button for opening rear lid in luggage compartment,active ,2
    IDE09514-MAS13754-Deactivation of tailgate while in trailer operation-Opening with button 2 for remote unlocking of rear lid,not active ,2
    IDE09514-MAS13755-Deactivation of tailgate while in trailer operation-Closing with remote unlock.butt.2 of rear lid when using trail.,not active ,2
    IDE09520-Offset for opening height after basic setting,0 ,2
    IDE10408-Opening height in production mode,60 %,2
    IDE10695-Dectivation of the luggage compartment cover,not active ,1
    IDE10703-Luggage compartment cover: tolerance of the block counter,0 ,2
    IDE10704-Luggage compartment cover: maximum no. of block drives,0 ,2
    IDE10705-Luggage compartment cover: number bloom drives,0 ,2
    IDE10706-MAS01875-Luggage compartment cover: reverse path after obstacle recogn.-Open,0 ,4
    IDE10706-MAS01876-Luggage compartment cover: reverse path after obstacle recogn.-Close,0 ,4
    IDE10707-IDE03434-Luggage compartment cover: detection area-Detection area lower,0 ,4
    IDE10707-IDE03435-Luggage compartment cover: detection area-Detection area upper,0 ,4
    IDE10708-Luggage compartment cover: adjust. track tolerance,0 ,2
    IDE10709-Luggage compartment cover: excess limitation in exclusion area,not active ,1
    ENG131232-MAS01911-Ausstattungen aktivieren-Tone sensor,not active ,2
    ENG131232-MAS01947-Ausstattungen aktivieren-Clamping strip 1,not active ,2
    ENG131232-MAS01948-Ausstattungen aktivieren-Clamping strip 2,not active ,2
    ENG131232-MAS01949-Ausstattungen aktivieren-Clamping strip 3,not active ,2
    ENG131232-MAS01950-Ausstattungen aktivieren-Clamping strip 4,not active ,2
    ENG131232-MAS04266-Ausstattungen aktivieren-Temperature sensor 1,active ,2
    ENG131232-MAS04267-Ausstattungen aktivieren-Temperature sensor 2,active ,2
    ENG131232-MAS08212-Ausstattungen aktivieren-Engine 2,not active ,2
    ENG131232-MAS09001-Ausstattungen aktivieren-Closing Assist Motor,active ,2
    ENG131232-MAS11624-Ausstattungen aktivieren-Motor 2: sensor system,not active ,2
    Elapsed Time: 00:06
    and blockmap:
    ;Sunday,22,March,2020,12:34:05:16465
    Group,Description,Actual
    IDE00019,Voltage terminal 30,11.43, V
    IDE00030,Status of actuator test,not active,
    IDE00075,Vehicle speed,0.00, km/h
    IDE00322,Status of basic setting,was not yet started,
    IDE00323,Security Access: Number of invalid keys,0,
    IDE00542,Excessive temperature protection,not active,
    IDE02010,Motor 1 for rear lid: activation,0, %
    IDE02011,Motor 1 for tailgate: current,0.00, A
    IDE02013,Motor 2 for rear lid: activation,0, %
    IDE02014,Motor 2 for tailgate: current,0.00, A
    IDE02017,Rear lid position: relative,0, %
    IDE02018,Rear lid position: absolute,0,
    IDE02019-MAS08993,Position programmable opening stop-Upper end pos.: relative,94, %
    IDE02019-MAS08994,Position programmable opening stop-Upper end pos.: absolute,1261,
    IDE02049,Trailer detected,not recognized,
    IDE02093-MAS09014,Status of rear lid lock-Safety catch,closed,
    IDE02093-MAS09015,Status of rear lid lock-Main catch,closed,
    IDE02093-MAS09016,Status of rear lid lock-Rear lid lock,closed,
    IDE02094-MAS09057,Status of closing assist-Limit switch for pull-shut assist.,operated,
    IDE02095-MAS01947,Status of pinch protection-Clamping strip 1,not activated,
    IDE02095-MAS01948,Status of pinch protection-Clamping strip 2,not activated,
    IDE02095-MAS01949,Status of pinch protection-Clamping strip 3,not activated,
    IDE02095-MAS01950,Status of pinch protection-Clamping strip 4,not activated,
    IDE02171-MAS01913,Terminals for closing assist-Pull-shut asst.,not locked,
    IDE02171-MAS01943,Terminals for closing assist-Terminal 1,Open,
    IDE02171-MAS01944,Terminals for closing assist-Terminal 2,Open,
    IDE03427-MAS08995,Upper end stop: maximum value-Max. upper end position,1298,
    IDE03615-MAS02672,Version-Start-stop,2,
    IDE03906-MAS01947,Pinch protection voltage supply status-Clamping strip 1,OFF,
    IDE03906-MAS01948,Pinch protection voltage supply status-Clamping strip 2,OFF,
    IDE03906-MAS01949,Pinch protection voltage supply status-Clamping strip 3,OFF,
    IDE03906-MAS01950,Pinch protection voltage supply status-Clamping strip 4,OFF,
    IDE05229-MAS09002,Reason for cancellation of rear lid procedure-Last reason,END,
    IDE05229-MAS09003,Reason for cancellation of rear lid procedure-second last reasons,END,
    IDE05229-MAS09004,Reason for cancellation of rear lid procedure-third last reason,END,
    IDE05229-MAS09005,Reason for cancellation of rear lid procedure-fourth last reason,END,
    IDE05229-MAS09006,Reason for cancellation of rear lid procedure-fifth last reason,END,
    IDE05584,Rear lid basic setting status,Unknown (7),
    IDE09491-IDE03434,Lock-in area-Detection area lower,350,
    IDE09491-IDE03435,Lock-in area-Detection area upper,10,
    IDE09492-MAS06165,Temperatures-Processor,23.00, C
    IDE09492-MAS08858,Temperatures-Outside air temperature on CAN,18.00, C
    IDE09492-MAS08996,Temperatures-Internal temp. on CAN,0.00, C
    IDE09492-MAS08997,Temperatures-Output stage for tailgate motor,23.00, C
    IDE09492-MAS08998,Temperatures-Tailgate motor left,18.00, C
    IDE09492-MAS08999,Temperatures-Tailgate motor right,18.00, C
    IDE09492-MAS09001,Temperatures-Closing Assist Motor,-146.00, C
    IDE09492-MAS09051,Temperatures-Output stage for tailgate motor: calculated,23.00, C
    IDE09492-MAS09053,Temperatures-Output stage for pull-shut assist.: calc.,-146.00, C
    IDE09492-MAS11205,Temperatures-Luggage compartment cover motor,0.00, C
    IDE09492-MAS11206,Temperatures-Output stage for luggage comp. cover: calc.,-38.50, C
    IDE09493,Status of basic tailgate setting,Basic setting not active,
    IDE09494-MAS09002,Cancellation reason of basic tailgate setting-Last reason,Cancel,
    IDE09494-MAS09003,Cancellation reason of basic tailgate setting-second last reasons,Cancel,
    IDE09494-MAS09004,Cancellation reason of basic tailgate setting-third last reason,Cancel,
    IDE09494-MAS09005,Cancellation reason of basic tailgate setting-fourth last reason,Cancel,
    IDE09494-MAS09006,Cancellation reason of basic tailgate setting-fifth last reason,Cancel,
    IDE09495,Status of tailgate initialization,initialized,
    IDE09496-MAS09002,Reason for loss of tailgate initialization-Last reason,Position overrun,
    IDE09496-MAS09003,Reason for loss of tailgate initialization-second last reasons,Reset,
    IDE09496-MAS09004,Reason for loss of tailgate initialization-third last reason,Reset,
    IDE09496-MAS09005,Reason for loss of tailgate initialization-fourth last reason,Reset,
    IDE09496-MAS09006,Reason for loss of tailgate initialization-fifth last reason,Reset,
    IDE09498-MAS01871,Status of control points-Rear lid lock button in luggage compartment,not activated,
    IDE09498-MAS01872,Status of control points-Rear lid remote release button,not activated,
    IDE09498-MAS06265,Status of control points-Release button in rear lid handle,not activated,
    IDE09498-MAS06446,Status of control points-Remote radio control: button for luggage compartment unlocking,not activated,
    IDE09498-MAS09010,Status of control points-Sensor for rear lid opening,not activated,
    IDE09498-MAS09072,Status of control points-Locking mechanism button in the rear lid,ERROR,
    IDE09498-MAS13753,Status of control points-Button 2 for rear lid remote release,not activated,
    IDE09499-IDE01991,Motors for tailgate: activation-Motor 1 for tailgate: status,OFF,
    IDE09499-IDE02012,Motors for tailgate: activation-Motor 2 for tailgate: status,OFF,
    IDE09499-MAS09001,Motors for tailgate: activation-Closing Assist Motor,OFF,
    IDE09499-MAS11205,Motors for tailgate: activation-Luggage compartment cover motor,ERROR,
    IDE09500-MAS09012,Motors for tailgate: RPM-Rear lid motor 1,0.00, Hz
    IDE09500-MAS09013,Motors for tailgate: RPM-Rear lid motor 2,0.00, Hz
    IDE09500-MAS11205,Motors for tailgate: RPM-Luggage compartment cover motor,0.00, Hz
    IDE09501-MAS09001,Motors for tailgate: elec. current-Closing Assist Motor,0.00, A
    IDE09501-MAS09012,Motors for tailgate: elec. current-Rear lid motor 1,0.00, A
    IDE09501-MAS09013,Motors for tailgate: elec. current-Rear lid motor 2,0.00, A
    IDE09501-MAS11205,Motors for tailgate: elec. current-Luggage compartment cover motor,0.57, A
    IDE09502-IDE02097,Tailgate angle sensor: absolute value-Position Sensor 1,0,
    IDE09502-IDE02098,Tailgate angle sensor: absolute value-Position sensor 2,0,
    IDE09502-IDE10697,Tailgate angle sensor: absolute value-Luggage compartment cover: position,0,
    IDE09503-IDE02017,Tailgate angle sensor: relative value-Rear lid position: relative,0, %
    IDE09503-MAS11205,Tailgate angle sensor: relative value-Luggage compartment cover motor,0, %
    IDE09504,Status of clutch test,not active,
    IDE09505-IDE02078,Tailgate actuation counter-Activations of rear lid closing button,2592,
    IDE09505-IDE02079,Tailgate actuation counter-Activations of rear lid unlocking button,2393,
    IDE09505-IDE02080,Tailgate actuation counter-Activations of rear lid remote unlocking switch,351,
    IDE09505-IDE02081,Tailgate actuation counter-Activation of remote key button rid lid opening,113,
    IDE09505-IDE02082,Tailgate actuation counter-Opening cycle counter,2613,
    IDE09505-IDE02083,Tailgate actuation counter-Closing cycle counter,2353,
    IDE09505-IDE02084,Tailgate actuation counter-Counter obstruction detected,291,
    IDE09505-IDE02085,Tailgate actuation counter-Counter of selectable opening stop adapted,3,
    IDE09505-IDE02087,Tailgate actuation counter-Counter for function limitation due to insufficient voltage,0,
    IDE09505-IDE02088,Tailgate actuation counter-Counter for function limitation due to excessive voltage,0,
    IDE09505-IDE02090,Tailgate actuation counter-Counter for function limitation due to excessive temperature,0,
    IDE09505-IDE02174,Tailgate actuation counter-Counter of flap opening angle basic settings,3,
    IDE09505-IDE03774,Tailgate actuation counter-Counter for closing operations canceled by lock-up,98,
    IDE09505-MAS08873,Tailgate actuation counter-Resets to hardware watchdog,0,
    IDE09505-MAS08874,Tailgate actuation counter-Resets due to software watchdog,0,
    IDE09505-MAS09017,Tailgate actuation counter-Counter tailgate lock: implausible,374,
    IDE09505-MAS09018,Tailgate actuation counter-Counter pull-shut asst. implausible,0,
    IDE09505-MAS09019,Tailgate actuation counter-Play protection counter active,0,
    IDE09505-MAS09058,Tailgate actuation counter-Counter Hall sensor in motor 1 for tailgate implausible,0,
    IDE09505-MAS09059,Tailgate actuation counter-Counter Hall sensor in motor 2 for tailgate implausible,0,
    IDE09505-MAS09060,Tailgate actuation counter-Wake-up events button for closing rear lid in lugg.compartment,425,
    IDE09505-MAS09061,Tailgate actuation counter-Wake-up events Hall sensor in motor for tailgate,296,
    IDE09505-MAS09062,Tailgate actuation counter-Wake-up events in data bus,17370,
    IDE09505-MAS09076,Tailgate actuation counter-Activating tailgate button for locking,0,
    IDE09505-MAS09077,Tailgate actuation counter-Activating sensor for tailgate opening,366,
    IDE09505-MAS09078,Tailgate actuation counter-Wake-up events button for unlocking tailgate,0,
    IDE09505-MAS09482,Tailgate actuation counter-Current limitation active,0,
    IDE09505-MAS10783,Tailgate actuation counter-Closing assist.counter: aborted by operating unit,13,
    IDE09505-MAS11977,Tailgate actuation counter-Emergency running counter after terminal 30 reset,13,
    IDE09505-MAS11978,Tailgate actuation counter-Play protection counter for closing aid active,0,
    IDE09505-MAS12517,Tailgate actuation counter-Reset via timeout monitoring watchdog,0,
    IDE09505-MAS12518,Tailgate actuation counter-Reset via network management monitoring watchdog,0,
    IDE09505-MAS13753,Tailgate actuation counter-Button 2 for rear lid remote release,0,
    IDE09506,Tailgate play protection,not active,
    IDE09519-MAS09054,Status of hall sensor in motor for tailgate-Motor 1 for tailgate: Hall sensor voltage supply,OFF,
    IDE09519-MAS09055,Status of hall sensor in motor for tailgate-Motor 2 for tailgate: Hall sensor voltage supply,OFF,
    IDE09519-MAS09066,Status of hall sensor in motor for tailgate-Motor 1: Sensor 1,00000000 ,
    IDE09519-MAS09067,Status of hall sensor in motor for tailgate-Motor 1: Sensor 2,00000000 ,
    IDE09519-MAS09068,Status of hall sensor in motor for tailgate-Motor 2: Sensor 1,00000000 ,
    IDE09519-MAS09069,Status of hall sensor in motor for tailgate-Motor 2: Sensor 2,00000000 ,
    IDE09519-MAS11207,Status of hall sensor in motor for tailgate-Motor for luggage comp. cover: sensor 1,00000000 ,
    IDE09519-MAS11209,Status of hall sensor in motor for tailgate-Motor for luggage compartment cover: Hall sensor voltage supply,OFF,
    IDE10697-MAS01471,Luggage compartment cover: position-lower stop,0,
    IDE10697-MAS01472,Luggage compartment cover: position-upper stop,0,
    IDE10697-MAS02282,Luggage compartment cover: position-Position,0,
    IDE10698-IDE03774,Luggage compartment cover: counter-Counter for closing operations canceled by lock-up,0,
    IDE10698-MAS09020,Luggage compartment cover: counter-Down adjustment,0,
    IDE10698-MAS09021,Luggage compartment cover: counter-Up adjustment,0,
    IDE10698-MAS09023,Luggage compartment cover: counter-Total number of adjustments,0,
    IDE10698-MAS09024,Luggage compartment cover: counter-Shutdowns by excess force limiter,0,
    IDE10698-MAS09025,Luggage compartment cover: counter-Blocking bottom mechan. stop,0,
    IDE10698-MAS09026,Luggage compartment cover: counter-Blocking upper mechan. stop,0,
    IDE10698-MAS09027,Luggage compartment cover: counter-Re-initializationn in bottom mechan. stop,0,
    IDE10698-MAS09028,Luggage compartment cover: counter-Re-initialization in upper mechan. stop,0,
    IDE10698-MAS09029,Luggage compartment cover: counter-Number of re-initializations,0,
    IDE10699-MAS00342,Status of luggage compartment cover initialization-Initializing,not initialized,
    IDE10700-MAS09002,Reason for loss of luggage compartment cover initialization-Last reason,Not yet initialized,
    IDE10700-MAS09003,Reason for loss of luggage compartment cover initialization-second last reasons,Not yet initialized,
    IDE10700-MAS09004,Reason for loss of luggage compartment cover initialization-third last reason,Not yet initialized,
    IDE10700-MAS09005,Reason for loss of luggage compartment cover initialization-fourth last reason,Not yet initialized,
    IDE10700-MAS09006,Reason for loss of luggage compartment cover initialization-fifth last reason,Not yet initialized,
    IDE10804,Easing of rear lid,not active,
    IDE11033,Motor for luggage compart. cover: excess. temp: protection,not active,
    IDE11036,Pull-shut asst.: play protec.,not active,
    IDE80005-MAS09012,Analysis 5-Rear lid motor 1,0.00, A
    IDE80005-MAS09013,Analysis 5-Rear lid motor 2,0.00, A
    MAS00080-ENG04253,Coding information-5V Ausgangstreiber,not installed,
    MAS00080-ENG98333,Coding information-Absolute sensor 1,not installed,
    MAS00080-ENG98357,Coding information-Absolute sensor 2,not installed,
    MAS00080-ENG04252,Coding information-Eingang fuer 2. Taster,installed,
    MAS00080-ENG04247,Coding information-Eingang fuer Einklemmleiste 1,not installed,
    MAS00080-ENG04248,Coding information-Eingang fuer Einklemmleiste 2,not installed,
    MAS00080-ENG04249,Coding information-Eingang fuer Einklemmleiste 3,not installed,
    MAS00080-ENG04250,Coding information-Eingang fuer Einklemmleiste 4,not installed,
    MAS00080-ENG04251,Coding information-Eingang fuer Sensor Motor 2,not installed,
    MAS00080-ENG124472,Coding information-Temp sensor 1,installed,
    MAS00080-ENG124473,Coding information-Temp sensor 2,installed,
    MAS00080-ENG04244,Coding information-Treiber fuer 2 motorige Ansteuerung,not installed,
    MAS00080-ENG04245,Coding information-Treiber fuer LRA Ansteuerung,not installed,
    MAS00080-ENG04246,Coding information-Treiber fuer Tongeber Ansteuerung,not installed,
    MAS00080-ENG04243,Coding information-Treiber fuer ZZH bidirektional,not installed,
    MAS00080-ENG04242,Coding information-Treiber fuer ZZH unidirektional,installed,
    MAS00972,Decoration variant,1,
    ENG105522,Clutch_check,Test not started,
    Elapsed Time: 00:06
  9. #18
    Mar 2019
    France
    Ok, problem solved, until this car, I didn't know personalization BAP functions. I made a "reset" for all drivers and all works fine!
  10. Likes PetrolDave liked this post
  11. #19
    Mar 2019
    France
    No one to help me for the trunk???
  12. #20
    Mar 2019
    France
    Ok, for the lid, it's not a coding issue. It's not a button single push as for sw. You have to push several seconds to close it on sedan. Sorry for my bad english!!!
  13. Likes PetrolDave liked this post
