Below is the full VCDS scan of my car. I've checked the tire pressure when the warning light comes on in my dash and all 4 tires are within 1 psi of each other. Is there a way to zero in on the abs fault to know what part is failing?
TIA,
Tom
Tuesday,17,March,2020,12:24:35:43668
VCDS Version: 19.6.2.2 (x64)
VIN: WVWPF7AJ5CW203125 License Plate:
Mileage: 223110km-138634mi Repair Order: 031720
Chassis Type: AJ-VW36 (7N0)
Scan: 01 03 05 08 09 15 16 17 19 22 25 2B 2E 37 42 44 46 47 52 55
56 62 72 77
VIN: WVWPF7AJ5CW203125 Mileage: 223110km-138634miles
Address 01: Engine (CRZ) Labels:. 06F-907-115-CDL.clb
Part No SW: 5K0 907 115 M HW: 8P0 907 115 B
Component: 2.0l R4/4V TFSI 0020
Revision: 5BH20--- Serial number:
Coding: 0403010A180F0160
VCID: 346D5E405791FBEF71-8060
Readiness: 0000 0001
Part No SW: 1K0 907 379 BJ HW: 1K0 907 379 BJ
Component: ESP MK60EC1 H31 0121
Revision: 00H31001
Coding: 144B800C492200FD280C01E6921E0041B70000
VCID: 7BFFB57CFA4FF497F0-802E
02214 - Tire Pressure Warning
Reset counter: 147
Mileage: 222997 km
Date: 2014.08.06
Time: 16:05:44
Count: 32768
Count: 12800
Count: 16401
Count: 51712
Count: 254
Address 05: Acc/Start Auth. (J518) Labels:| 5K0-959-434.clb
Part No SW: 5K0 959 434 B HW: 5K0 959 434 B
Revision: 00085000 Serial number: 0159214123
Coding: 030C0C
VCID: 346D5E409F91FBEF71-8060
Part No SW: 35D 907 044 B HW: 35D 907 044 B
Component: Climatronic H03 0303
Revision: 00001K02
Coding: 0000001002
Shop #: WSC 54321 321 54321
ROD: EV_ACClimaBHBVW411_VW36.rod
VCID: 2649B408594D997FFF-8072
B10A4 15 [009] - Open or Short to Plus
Fault Frequency: 8
Reset counter: 108
Mileage: 222923 km
Date: 2020.03.14
Time: 19:05:29
Part No SW: 1K0 937 084 G HW: 1K0 937 084 G
Component: BCM PQ35 B 110 0651
Revision: 00110 AC
Coding: 6F180A3B90252AC4108800C170000C4449052186574D8DB0E48420248040
Shop #: WSC 25568 001 1048576
VCID: 326158586D85F5DF63-8066
Subsystem 1 - Part No: 5K1 955 119 Labels: 1KX-955-119.CLB
Component: Wischer 21111 26 0512
Coding: 009795
Part No SW: 5K0 959 655 H HW: 5K0 959 655 H
Component: AirbagVW10G 013 0724
Serial number: 003GVRA10NL3
Coding: 00003131
ROD: EV_AirbaVW10SMEVW360.rod
VCID: 3F87016CA6D728B79C-806A
Subsystem 1 - Part No SW: 5K0 959 339 B HW: 5K0 959 339 B
Component: BF-Gewichtss. 006 0001
Serial number: ---0000R--00002ZD500
Serial number: 3572MSME2D2B6466ZZZ0
Serial number: 3582MSME1521064AZZZN
Serial number: 3512QSME520B660AZZZV
Serial number: 3522QSME7C156625ZZZ-
Serial number: 35527SME56674F29ZZZU
Serial number: 35627SME295E4F29ZZZ.
Part No SW: 5K0 953 521 BR HW: 5K0 953 569 E
Revision: FF010040 Serial number: 20111128200980
Coding: 100A140000
ROD: EV_SMLSNGVOLWS.rod
VCID: 7DFBBB64EC5BFAA7CE-8028
Subsystem 1 - Part No SW: 5K0 959 542 A HW: 5K0 959 542 A Labels: 3C8-959-537.CLB
Component: E221__MFL-TAS H09 0013
Coding: 820000
Part No SW: 5K6 920 972 E HW: 5K6 920 972 E
Component: KOMBI H04 0617
Coding: 270F01
VCID: 38756A7083F91F8F5D-806C
Part No SW: 7N0 907 530 M HW: 1K0 907 951
Component: J533 Gateway H42 1623
Revision: H42 Serial number: 281111F1000547
Coding: 350002
VCID: 3A717078B5F50D9FAB-806E
Address 22: AWD Labels: None
Part No SW: 563 tun ere l HW: 563 tun ere l
Component: Haldex 4Motion T303
Coding: 0000001
VCID: 1D3B9BE4C41B5AA7AE-8048
Component: IMMO H04 0617
Coding: 000007
VCID: 6AD180388DD57D1F1B-803E
Address 2B: Steer. Col. Lock (J764) Labels:* 5K0-905-861.clb
Part No SW: 5K0 905 861 A HW: 5K0 905 861 A
Component: ELV-PQ35 H20 0230
Revision: 00000000 Serial number: 11000264696002
Coding: 4100000000000000
ROD: EV_ELVMarquMPVW36X.rod
VCID: 2E594C2871BDD13F07-807A
Part No SW: 5N0 035 342 E HW: 5N0 035 342 E
Revision: A1001003 Serial number: 7661353363
Coding: 020000
VCID: 2953BF344053B607D2-807C
Part No SW: 3C0 035 684 J HW: 3C8 035 684 E
Component: RNS-MID H61 4366
Revision: AB001001 Serial number: VWZ6Z7M8099123
Coding: 00070402000000800000
Shop #: WSC 12345 123 12345
VCID: 2A5140384555BD1FDB-807E
Component: NAR V11 8407
Reset counter: 108
Mileage: 197272 km
Part No SW: 5K0 959 701 B HW: 5K0 959 701 B
Component: Tuer-SG 009 2119
Coding: 0001204
VCID: 31635754A883CEC71A-8064
Part No: 1K0 909 144 M
Component: EPS_ZFLS Kl. 251 3201
Revision: 00H20000
Part No SW: 5K0 035 456 B HW: 5K0 035 456 B
Component: KonzernAmp 8K H07 0368
Revision: -------- Serial number: EAA085A0005773
VCID: 2953BF344853B607D2-807C
Part No SW: 5K0 959 702 B HW: 5K0 959 702 B
Coding: 0001204
VCID: 32615858AD85F5DF63-8066
Component: AFS-Steuergeraet 0148
Coding: 1479708
Subsystem 1 - Part No: 7L6 941 329 B Labels: 3D0-941-329.CLB
Component: AFS-Lst.-Modul l 0005
Coding: 00000022
Subsystem 2 - Part No: 7L6 941 329 B Labels: 3D0-941-329.CLB
Component: AFS-Lst.-Modul r 0005
Coding: 00000022
Reset counter: 108
Mileage: 197272 km
Part No SW: 5K0 959 703 D HW: 5K0 959 703 D
Component: Tuer-SG 007 2101
Coding: 0001168
Shop #: WSC 01357 011 1012552
VCID: 356B63445CEBE2E746-8060
Part No SW: 5K0 959 704 D HW: 5K0 959 704 D
Coding: 0001168
VCID: 3669644841EDE9FF4F-8062
Part No SW: 5K0 035 730 D HW: 5K0 035 730 D
Component: TELEFON H13 2902
Revision: 1B001001 Serial number: 00007661838103
Coding: 0A00000000000000
ASAM Dataset: EV_UHVNA A01719
ROD: UHVNA.rod
9458195 - Control Module for Cellular Telephone
B1052 13 [009] - Open Circuit
Reset counter: 108
Mileage: 223113 km
Date: 2020.03.17
Time: 12:14:47
U1014 00 [009] - -
Reset counter: 108
Mileage: 223113 km
Date: 2020.03.17
Time: 12:14:49
End-------------------------(Elapsed Time: 03:03)--------------------------
TIA,
Tom
