Page 1 of 3 123 LastLast
Results 1 to 10 of 26
Thread: ABS fault for 2012 Golf R
    Aug 2015
    CNY, USA
    Below is the full VCDS scan of my car. I've checked the tire pressure when the warning light comes on in my dash and all 4 tires are within 1 psi of each other. Is there a way to zero in on the abs fault to know what part is failing?
    Tuesday,17,March,2020,12:24:35:43668
    VCDS Version: 19.6.2.2 (x64)
    VIN: WVWPF7AJ5CW203125   License Plate:
    Mileage: 223110km-138634mi   Repair Order: 031720
    Chassis Type: AJ-VW36 (7N0)
    Scan: 01 03 05 08 09 15 16 17 19 22 25 2B 2E 37 42 44 46 47 52 55
              56 62 72 77
    VIN: WVWPF7AJ5CW203125   Mileage: 223110km-138634miles
    Address 01: Engine (CRZ)       Labels:. 06F-907-115-CDL.clb
       Part No SW: 5K0 907 115 M    HW: 8P0 907 115 B
       Revision: 5BH20---    Serial number:
       Coding: 0403010A180F0160
       VCID: 346D5E405791FBEF71-8060
    Readiness: 0000 0001
       Revision: 00H31001
       Coding: 144B800C492200FD280C01E6921E0041B70000
       VCID: 7BFFB57CFA4FF497F0-802E
    02214 - Tire Pressure Warning
                        Reset counter: 147
                        Mileage: 222997 km
                        Date: 2014.08.06
                        Time: 16:05:44
                        Count: 32768
                        Count: 12800
                        Count: 16401
                        Count: 51712
                        Count: 254
       Part No SW: 5K0 959 434 B    HW: 5K0 959 434 B
       Revision: 00085000    Serial number: 0159214123
       Coding: 030C0C
       VCID: 346D5E409F91FBEF71-8060
       Part No SW: 35D 907 044 B    HW: 35D 907 044 B
       Component: Climatronic   H03 0303
       Revision: 00001K02
       Coding: 0000001002
       Shop #: WSC 54321 321 54321
       ROD: EV_ACClimaBHBVW411_VW36.rod
       VCID: 2649B408594D997FFF-8072
    9479189 - Signal Line for Air Quality Sensor
              B10A4 15 [009] - Open or Short to Plus
                        Reset counter: 108
                        Mileage: 222923 km
                        Date: 2020.03.14
                        Time: 19:05:29
       Part No SW: 1K0 937 084 G    HW: 1K0 937 084 G
       Component: BCM PQ35  B   110 0651
       Revision: 00110 AC
       Coding: 6F180A3B90252AC4108800C170000C4449052186574D8DB0E48420248040
       Shop #: WSC 25568 001 1048576
       VCID: 326158586D85F5DF63-8066
       Component: Wischer 21111  26  0512
       Coding: 009795
       Serial number: 003GVRA10NL3
       Coding: 00003131
       ROD: EV_AirbaVW10SMEVW360.rod
       VCID: 3F87016CA6D728B79C-806A
       Serial number: ---0000R--00002ZD500
       Serial number: 3572MSME2D2B6466ZZZ0
       Serial number: 3582MSME1521064AZZZN
       Serial number: 3512QSME520B660AZZZV
       Serial number: 3522QSME7C156625ZZZ-
       Serial number: 35527SME56674F29ZZZU
       Serial number: 35627SME295E4F29ZZZ.
       Part No SW: 5K0 953 521 BR    HW: 5K0 953 569 E
       Revision: FF010040    Serial number: 20111128200980
       Coding: 100A140000
       ROD: EV_SMLSNGVOLWS.rod
       VCID: 7DFBBB64EC5BFAA7CE-8028
       Coding: 820000
       Part No SW: 5K6 920 972 E    HW: 5K6 920 972 E
       Coding: 270F01
       VCID: 38756A7083F91F8F5D-806C
       Revision:   H42       Serial number: 281111F1000547
       Coding: 350002
       VCID: 3A717078B5F50D9FAB-806E
       Part No SW: 563 tun ere l    HW: 563 tun ere l
       Component: Haldex 4Motion      T303
       VCID: 1D3B9BE4C41B5AA7AE-8048
       Coding: 000007
       VCID: 6AD180388DD57D1F1B-803E
       Part No SW: 5K0 905 861 A    HW: 5K0 905 861 A
       Component: ELV-PQ35      H20 0230
       Revision: 00000000    Serial number: 11000264696002
       Coding: 4100000000000000
       ROD: EV_ELVMarquMPVW36X.rod
       VCID: 2E594C2871BDD13F07-807A
       Revision: A1001003    Serial number: 7661353363
       Coding: 020000
       VCID: 2953BF344053B607D2-807C
       Part No SW: 3C0 035 684 J    HW: 3C8 035 684 E
       Component: RNS-MID       H61 4366
       Revision: AB001001    Serial number: VWZ6Z7M8099123
       Coding: 00070402000000800000
       VCID: 2A5140384555BD1FDB-807E
       Subsystem 1 - Part No: 7L6 919 859
       Component: NAR V11  8407
                        Reset counter: 108
                        Mileage: 197272 km
       Coding: 0001204
       VCID: 31635754A883CEC71A-8064
       Part No: 1K0 909 144 M
       Component: EPS_ZFLS Kl. 251    3201
       Revision: 00H20000
       Part No SW: 5K0 035 456 B    HW: 5K0 035 456 B
       Component: KonzernAmp 8K H07 0368
       Revision: --------    Serial number: EAA085A0005773
       VCID: 2953BF344853B607D2-807C
       Coding: 0001204
       VCID: 32615858AD85F5DF63-8066
       Coding: 1479708
       Coding: 00000022
       Coding: 00000022
                        Reset counter: 108
                        Mileage: 197272 km
       Coding: 0001168
       Shop #: WSC 01357 011 1012552
       VCID: 356B63445CEBE2E746-8060
       Coding: 0001168
       VCID: 3669644841EDE9FF4F-8062
       Part No SW: 5K0 035 730 D    HW: 5K0 035 730 D
       Component: TELEFON       H13 2902
       Revision: 1B001001    Serial number: 00007661838103
       Coding: 0A00000000000000
       ASAM Dataset: EV_UHVNA A01719
       ROD: UHVNA.rod
    9458195 - Control Module for Cellular Telephone
              B1052 13 [009] - Open Circuit
                        Reset counter: 108
                        Mileage: 223113 km
                        Date: 2020.03.17
                        Time: 12:14:47
              U1014 00 [009] - -
                        Reset counter: 108
                        Mileage: 223113 km
                        Date: 2020.03.17
                        Time: 12:14:49
    End-------------------------(Elapsed Time: 03:03)--------------------------
    TIA,
    Tom
    HQ
    Are all 4 tires 100% matching? Same size? Brand? Tread depth? Does it not reset after holding in the TPMS button in the glove box?
    Jef
    Aug 2015
    CNY, USA
    All 4 tires are the same and almost brand new with ~ 2K miles on them. The TPMS button does reset the dash light but why is it being triggered in the first place?
    If the tires are good, it's possible you have an ABS wheel speed sensor, or encoder ring, or even a wheel bearing that's slightly dodgy.
  5. Likes Dana liked this post
    Did you try adding 10 PSI per tire more for each tire, since we are close to drastic temp changes with spring/winter transition?
    Aug 2015
    CNY, USA
    Adding 10 psi? I hope you're not serious as this would put the pressure above the rating for the tires. I'm guessing it's a ABS wheel speed sensor but was hoping VCDS could tell me this and which one was bad.
    Considering a lower limit is exceeded and sporadically, did you cross check your actual PSI to another gauge for accuracy?
    Did you see a statement, I thought I only asked you questions?
    By all means did you tear it all down & measure value's of all mechanical components yet?
    Did you consider the cost deviations and that when tires are cold they deflate since temperature is also relative?
  9. #8
    Quote Originally Posted by B5crazy View Post
    VCDS can only tell you what the car knows. The car isn't aware of an obvious problem with a wheel speed sensor. However, it would not hurt to log the four wheel speed sensors while driving straight ahead to see if one might be a bit divergent from the others.
  11. #9
    I think Uwe has a great idea here.
    I would add that do you realize OP that tire PSI raises significantly related to temperature or how a vehicle is being driven in the turns or conditions met, so why dismiss my questions, seriously?
  12. #10
    HQ
    Will point out, odds are once you hit about 20km/h, the ABS module will drop communication.... don't panic, ABS modules do this by design.
    Jef
  13. Likes Uwe, Jack@European_Parts liked this post
