Results 1 to 10 of 11
Thread: HEX+CAN Dual K & CAN <-> USB Not Working on 2012 A6 C7 - Unsupported Vehicle
    Aug 2019
    Los Angeles, USA
    I am getting an "Unsupported Vehicle - Please upgrade to a current Ross-Tech Interface" when i connect my VAGCOM (HEX+CAN Dual K & CAN <-> USB) to my 2012 A6 C7. I have 19.6.2 version of VCDS installed.
    I have had the car and the VAGCOM since 2011/2012. I have been using this without a problem until last week .
    My understanding is that HEX+CAN will not work on 2019+ models. I have tried reinstalling VCDS with no luck. My battery energy management system is active and I need to change the car battery now.
    Please assist.
    Raghu
    Oct 2014
    Arandjelovac, Serbia
    Consider upgrade. Click here, please.
    Aug 2019
    Los Angeles, USA
    I haven't changed anything since last week...Same Car, Same Interface, Same Laptop...Why is it saying the vehicle is unsupported? What changed?
    I used the VCDS and Cable to check the battery condition last week. Now, Measuring Blocks, Adaptation and other advanced features that were active before are disabled.
    VCDS Tech Support. Please help.
    Raghu
    Sounds like it wasn't able to pick up the VIN from the car.
    Post an Auto-Scan please.
    https://forums.ross-tech.com/showthread.php?101
    Quote Originally Posted by Boki Ar View Post
    For a 2012? Why?
    Aug 2019
    Los Angeles, USA
    Hello Uwe,
    Here is the auto scan
    Tuesday,17,March,2020,20:38:16:44085
    VCDS Version: 19.6.2.2 (x64)
    VIN: WAUHGAFC2CN037402   License Plate: D136B0
    Mileage: 135138km-83970mi   Repair Order:
    Chassis Type: FC-AU57 (4G0)
    Scan: 01 02 03 05 08 09 0E 10 15 16 17 19 28 36 3B 3C 42 44 46 47
              52 53 55 56 5F 62 6C 72 8F 90
    VIN: WAUHGAFC2CN037402   Mileage: 135138km-83970miles
    Address 01: Engine (J623-CGXB)       Labels:. 06E-907-551-CGW.clb
       Part No SW: 4G0 907 551 A    HW: 4G0 907 551 A
       Component: 3.0l V6 TFSIH07 0010
       Revision: --H07---
       Coding: 0A2A0034052600060000
       Shop #: WSC 02311 785 00200
       ASAM Dataset: EV_ECM30TFS0214G0907551A 003011
       ROD: EV_ECM30TFS0214G0907551A_003.rod
       VCID: 275D37A25E412177C4-8072
       Part No SW: 4G0 927 158 P    HW: 0BK 927 156 R
       Component: 0BK 30TFSIUSA H08 1006
       Revision: --H08---
       Coding: 000002
       ASAM Dataset: EV_TCMAL551211 002018
       VCID: 3B75FBD2B2C99597B0-806E
       Part No SW: 4G0 907 379 F    HW: 4G0 907 379 F
       Component: ESP PREMIUM   H09 0250
       Coding: 44A70F0122E5F0804B00
       ASAM Dataset: EV_ESPPremiAU57X 004017
       VCID: 3467D0EE9F975AEF71-8060
       Part No SW: 4H0 907 064 BR    HW: 4H0 907 064 BR
       Component: BCM2 2.0      H31 0330
       Coding: 0D882006000000000000
       VCID: 7AFB3ED6F5736C9FEB-802E
       Component: J764 ELV MLB  H39 0046
       Serial number: 2311000142050013
    00956 - Key 2
                002 - Lower Limit Exceeded
                        Fault Status: 01100010
                        Reset counter: 138
                        Mileage: 134993 km
                        Date: 2020.03.13
                        Time: 15:00:32
       Part No SW: 4G0 820 043 L    HW: 4G0 820 043 L
       Component: KLIMA 4 ZONEN H11 0064
       Serial number: 25071100040801
       Coding: 6601207A48
       Shop #: WSC 22163 444 179379
       VCID: 285F349E535F2E0FCD-807C
       Part No SW: 4H0 907 063 BG    HW: 4H0 907 063
       Component: BCM1 2.0      H12 0100
       Revision: 11012002    Serial number: 00000001152386
       Coding: 09072091073C9FE081000884A0003800CF9CD208A20801258001085C3B00
       VCID: 6ED30286B93B303F47-803A
       Component: WWS57X 110707  H35 0051
       Serial number:         110713175754
       Coding: 0045F7
       Component: RLS  H04 0003
       Serial number: 11578669
       Coding: 02512B
       Subsystem 3 - Part No SW: 4G0 941 531 E    HW: 4G0 941 531 E
       Component: E1 - LDS  H07 0044
       Serial number: 28 07 2011  00000101
       Component: USHL4.2  H30 0030
       Serial number: 0000002274555R0J8V02
       Subsystem 5 - Part No SW: 8K0 959 772 C    HW: 8K0 959 772
       Component: SLR-B8  H05 0006
       Serial number:           0010965537
       Coding: 853000
       Serial number: 00000006071100010791
       Coding: 110000
       Subsystem 7 - Part No SW: 4H0 907 472 B    HW: 4H0 907 472 B
       Serial number: 00000004071100010005
       Coding: 110000
       Subsystem 8 - Part No SW: 4H0 907 705 J    HW: 4H0 907 705 C
       Component: EVLS-SG  H08 0280
       Serial number: WA102278000000354993
       Coding: 020300
       Subsystem 9 - Part No SW: 4H0 907 658     HW: 4H0 907 658
       Serial number: 62684DB5000000000001
    Address 0E: Media Player 1 (R41)       Labels: Redir Fail!
       Part No SW: 8X0 035 110 C    HW: 8X0 035 110
       Component: CDC-MP3-Pana  H41 0490
       Revision: 00000007
       VCID: 2D51C58A74BD0B273E-8078
       Part No SW: 4H0 919 475 L    HW: 4H0 919 475 C
       Component: PARKHILFE ACC H07 0043
       Revision: 11001001    Serial number: 55901121001259
       Coding: 280106
       Shop #: WSC 22145 444 13987
       ROD: EV_EPHVA18AU57X0000_002_AU57.rod
       Part No SW: 4G0 959 655 A    HW: 4G0 959 655 A
       Component: Airbag10.43   H31 0032
       Revision: --------    Serial number: 003D8001BEDK
       Coding: 303234373131303030314A55304C34473053
       VCID: 3365D3F29A995DD768-8066
       Serial number: 6940000Y160001GF430D
       Serial number: 3575HRB405H0NLV24PD5
       Serial number: 3585HRB405F0IRE26858
       Serial number: 3515JRB405B0KSEGJ0S1
       Serial number: 3525JRB405P0LCOQD8A5
       Serial number: 3554VRB40530LMIQG8NH
       Serial number: 3564VRB40530LMIQKOQ+
       Revision: 00000000    Serial number: 20110729001204
       Coding: 000034
       VCID: 306FDCFE638F66CF15-8064
       Component: E221 - MFL  H07 0009
       Part No SW: 4G8 920 982     HW: 4G8 920 982
       Component: TBenUsa       H71 0375
       Revision: 26181114    Serial number: 658010811592016
       Coding: 03EF09040B01D705020000
       Shop #: WSC 10141 002 104857
       ASAM Dataset: EV_RBD4K 004040
       ROD: EV_RBD4K_AU57.rod
       VCID: 71E919FAA0052FC75A-8024
       Part No SW: 4G0 907 468 E    HW: 4G0 907 468 A
       Component: J533--Gateway H08 0213
       Revision: --------    Serial number: 00000000204252
       Coding: 00C1033000
       ROD: EV_GatewUDS_AU57.rod
       VCID: 326BD6F6658354DF63-8066
       Component: J367-BDM  H07 0140
       Serial number: 00000000005650149558
              U140B 00 [008] - -
                        Fault Frequency: 12
                        Reset counter: 187
                        Mileage: 133910 km
                        Date: 2020.02.18
                        Time: 08:49:50
                        Voltage terminal 30: 12.0 V
                        Voltage terminal 15: 0.0 V
                        Control Module temperature: 40 °C
                        Engine running: OFF
                        IN ZAS_Te_X: OFF
                        Terminal 15 status: OFF
                        Datenfeld: 1
       Part No SW: 4G0 919 158 C    HW: 4G0 919 158 C
       Component: KLIMA FOND    H07 0064
       Serial number: 01081100040368
       Coding: 00
       VCID: 2F6DDF8276B179370C-807A
       Part No SW: 4G8 959 760 A    HW: 4G8 959 760 A
       Component: MEM-FS        H03 0153
       Revision: AA000000    Serial number: 00000010099159
       Coding: C0581B008F002001000001010101102030303232203232
       VCID: 387FE4DE8BFFBE8F5D-806C
       Part No SW: 4G0 907 637 B    HW: 4G0 907 637 B
       Component: SARA 6D       H02 0004
       Revision: --------    Serial number: EJ1BPA4201LP6A0
       ASAM Dataset: EV_SARA 006014
       ROD: EV_SARA_006.rod
       VCID: 2D51C58A7CBD0B273E-8078
       Part No SW: 4G0 907 566 D    HW: 4G0 907 566
       Component: J769  SWA MasterH01 0020
       Revision: 00H01000    Serial number: 6PZ 010 287-03
       VCID: 306FDCFEA38F66CF15-8064
       Subsystem 1 - Part No: 4G0 907 568 D
       Component: J770  SWA Slave H01 0020
       Subsystem 2 - Serial number: 6PZ 010 287-23
       Subsystem 3 - Serial number: 5F29.07.1100H010003CF20972˙
       Subsystem 4 - Serial number: F20972˙
    02854 - Warning Lamp for Lane Change Assistance (in right exterior mirror) (K234)
                        Fault Status: 00100111
                        Reset counter: 174
                        Mileage: 134876 km
                        Date: 2020.03.11
                        Time: 14:00:42
    02851 - Switch for Lane Change Assistance (E530)
                        Reset counter: 187
                        Mileage: 135138 km
                        Date: 2020.03.17
                        Time: 20:30:30
       Part No SW: 4G8 959 793 E    HW: 4G8 959 793 A
       Component: TSG FA        H05 0212
       Coding: 011F17205E00628002000012
       VCID: 428B8636DD23E45FF3-8016
       Component: RCEPS         H33 0010
       Revision: 00001000    Serial number: 0027128296
       Coding: 101000010000
       ASAM Dataset: EV_RCEPS 009008
       ROD: EV_RCEPS_009.rod
    18689 - Terminal 30
              U140A 00 [008] - Open Circuit
                        Reset counter: 186
                        Mileage: 135138 km
                        Date: 2020.03.17
                        Time: 14:58:58
                        Write only channel
       Revision: 00002001    Serial number: 0155123981
       Coding: 0106023A00FA448580B00880020500000000000000000000000000000000
       Component: GTO BF  H01 0070
       Serial number: 00000000000000041872
       Subsystem 3 - Part No SW: 7P5 959 591     HW: 4H0 959 591
       Component: J245 PS40.033  H07 0006
       Serial number:     WOO12718384
       Coding: 001F00
       Subsystem 4 - Part No SW: 4G0 947 135 G    HW: 4G0 947 135
       Serial number: 0000000AP00000370262
    02615 - Fuel Tank Cap; Lock
                009 - Open or Short to Ground
                        Fault Status: 01101001
                        Reset counter: 78
                        Mileage: 133462 km
                        Date: 2020.02.10
                        Time: 18:32:38
    02616 - Fuel Tank Cap; Unlock
                        Reset counter: 78
                        Mileage: 133462 km
                        Date: 2020.02.10
                        Time: 18:33:00
       Revision: CJ007000    Serial number: 00000000016956
       Coding: 030000
       Shop #: WSC 04935 002 1048576
       VCID: 1D31154A041DFBA7AE-8048
       Part No SW: 4G8 959 792 E    HW: 4G8 959 792 A
       Component: TSG BF        H05 0212
       Coding: 011F17205E00628002000002
       VCID: 4189893AD825FF47EA-8014
       Revision: --------    Serial number: 00000000115347
       ROD: EV_ParkiBrake_VW51.rod
       VCID: 2A5BCE964D531C1FDB-807E
       Serial number: 110717-0004-038
       Coding: 1221A6601002A400
       ROD: EV_HeadlRegulBasic.rod
       VCID: 2C57C88E47A7022F29-8078
       Part No SW: 4G0 035 080 G    HW: 4G0 035 080
       Component: Radio U SIRIU H52 0133
       Revision: AB001007    Serial number: 158HT0B7503032
       Coding: 020007010000000001
       VCID: 224B26B63D63C45F93-8076
       Part No SW: 4G0 035 746 H    HW: 4G0 035 746
       Component: H-BNT-NA      H48 0902
       Revision: --------    Serial number: 031HT0B7512069
       Coding: 050200000003E1EF55128B2E00000003100001000000000000
       VCID: 2C57C88E4FA7022F29-8078
       Component: NAR 2011  0505
       Subsystem 2 - Part No SW: 4G0 919 605 A    HW: 4G0 919 605 A
       Serial number: AUZ8ZDB13012AQD
       Subsystem 3 - Part No SW: 4G1 919 610 C    HW: 4G1 919 610 A
       Component: E380 BDT C7  H08 0204
       Serial number: 90349KGS000OF
       Component: CD-Database  3371
                        Fault Frequency: 15
                        Reset counter: 173
                        Mileage: 134830 km
                        Date: 2020.03.11
                        Time: 11:51:54
                        Bin. Bits: 00001000 00000000
                        Bin. Bits: 00000000 00000000
       Part No SW: 4G8 959 795 E    HW: 4G8 959 795 A
       Component: TSG HL        H04 0212
       Coding: 010F17204000628002000002
       VCID: 4487802EC737EA6FC1-8010
       Revision: --H04---    Serial number: 525 PA8J19G8PP
       Coding: 1080004
       VCID: 26433AA6914B387FFF-8072
    02203 - Audio / Video Input 1
                        Fault Status: 00101011
                        Fault Frequency: 12
                        Reset counter: 173
                        Mileage: 133770 km
                        Date: 2020.02.15
                        Time: 15:17:52
                            Reverse ON
                        Count: 4
    02283 - Video Connection to Output [End Unit]
                        Reset counter: 149
                        Mileage: 134286 km
                        Date: 2020.02.28
                        Time: 06:53:13
                            Reverse OFF
                        Count: 3
       Component: TSG HR        H04 0212
       Part No SW: 4H0 980 945     HW: 4H0 980 945
       Component: RGS-VL        H05 0070
       ASAM Dataset: EV_RGS_L 002004
       ROD: EV_RGS_L.rod
       VCID: 6FED1F82B63139374C-803A
       Part No SW: 4H0 980 946     HW: 4H0 980 946
       Component: RGS-VR        H05 0070
       ASAM Dataset: EV_RGS_R 002004
       ROD: EV_RGS_R.rod
       VCID: 70EF1CFEAB0F26CF55-8024
    End-------------------------(Elapsed Time: 05:56)--------------------------
  7. Likes Boki Ar liked this post
    Oct 2014
    For a 2012? Why?
    I believe this message:
    would not appear with the next generation of interfaces.
    Furthermore, I know very well that Ross Tech offers a very good conditions for replacement but that is (still) just my opinion.
  9. #8
    Quote Originally Posted by RaghuAudi View Post
    Hello Uwe,
    That scan worked fine. Nothing about "Unsupported Vehicle" in there. I'm sticking with my original theory. For some reason, VCDS didn't pick up the VIN of the car when you saw that message. Please see if you can give us the exact sequence needed to reproduce it.
  10. #9
    I believe this message: would not appear with the next generation of interfaces.
    Sure, but this is hardly an essential feature. People got along just fine for years before that feature existed.
  11. Likes Boki Ar liked this post
  12. #10
    Aug 2019
    Los Angeles, USA
    I will try and reproduce problem. Another question. I am connected to 19-CAN Gateway module. Shouldn't the measuring blocks option be available to select and not greyed out? I remember being able to query 18/19/20 for battery status values. Am i missing something here?
