19' GLI Autobahn help! Just got ABS Module recoded but missing some key componants
Cryan19
Wilmington, DE, USA
C?ID=365507
Hey everyone!
So yeah, I messed my car up pretty bad with OBDEleven and got rid of it and purchased Ross-Tech for the support and more advanced system in general. When I factory reset (I know now, stupid) my ABS long coding other things stopped working correctly as well and hoping someone or some of you have a way to get me back to running correctly without these 3 specific dash light I am getting.
1. Error: Electronic Stabilization Control (ESC)
2. Error: Hill Start Assist
3. Front Assist not available
These are the only issues that are creating dash lights. But going through the faults on other modules, I see that there is quite a bit more that I need some help fixing as well. Much appreciated for any support and thank you in advance. I am pretty new to this stuff and loving it, minus the idiotic NEWB mistakes made previously.
- Craig
Tuesday,17,March,2020,15:18:44:48820
VCDS Version: 19.6.2.2 (x64)  HEX-NET CB: 0.4508.4
VIN: 3VW5T7BU2KM265571   License Plate:
Chassis Type: BU-VW37 (3Q0)
Scan: 01 03 05 08 09 13 15 17 19 2B 32 36 3C 42 44 47 52 5F 75 A9
          C0 CA 8107
VIN: 3VW5T7BU2KM265571   Mileage: 20242km-12577miles
05-Acc/Start Auth. -- Status: Not registered 0001
C0-Act. for Ext. Noise -- Status: Cannot be reached 0100
CA-Sunroof -- Status: OK 0000
8107-Antenna -- Status: Cannot be reached 0100
Address 01: Engine (J623-DKFA)       Labels: None
   Part No SW: 5G0 906 259 Q    HW: 06K 907 425 J
   Component: R4 2.0l TFSI  H13 0005
   Revision: --H13---
   Coding: 091900122424002F3000
   Shop #: WSC 00066 790 00387
   ASAM Dataset: EV_ECM20TFS0205G0906259Q 001006
   ROD: EV_ECM20TFS0205G0906259Q.rod
   VCID: 3C3427F3B7D513AFB9-8068
17922 - Databus
          U1122 00 [032] - Implausible Message
                    Mileage: 20084 km
                    Date: 2020.03.16
                    Time: 22:28:13
                    Coolant temperature: 95 °C
                    Intake air temperature: 36 °C
                    Voltage terminal 30: 12.773 V
                    ACC variants: ACC
                    CCS Switch: CCS operating unit
                    Cruise control switch actuation-Main switch hardware: not activated
                    Cruise control switch actuation-Main switch CAN: not activated
                    ACC variants (coding): CCS
                    Engine: operating status: ES
Readiness: 0000 0100
   Part No SW: 5Q0 614 517 EB    HW: 5Q0 614 517 BR
   Component: ESC           H82 0108
   Revision: 00000000    Serial number: 52469000001286
   Coding: 70FB6BA150260971457C020760C4A90ED60A90A2400695361043F055D0894B0B0000000012121212B835351919323200
   Shop #: WSC 00066 790 00176
   ASAM Dataset: EV_Brake1UDSContiMK100IPB 038007
   ROD: EV_Brake1UDSContiMK100IPB_038.rod
   VCID: 75A2F2D7D47F82E786-8020
0338 - ABS/ESP Control Module
          U10C5 00 [137] - No or Incorrect Basic Setting
          [inlet valve calibration data missing]
                    Reset counter: 8
                    Mileage: 19836 km
                    Date: 2020.03.13
                    Time: 23:57:20
8277 - Databus
          U1122 00 [009] - Implausible Message
          [FCAN: EPS_DSR_Status signal is invalid]
                    Reset counter: 15
                    Mileage: 20084 km
                    Date: 2020.03.17
                    Time: 11:33:20
   Part No SW: 3Q0 959 435 N    HW: 3Q0 959 435 N
   Component: VWKESSYMQB    037 1307
   Revision: 00037000    Serial number: 0522207389
   Coding: 132C1C0623
   ASAM Dataset: EV_KessyHellaMQBAB 004052
   VCID: 45C24217C41F5267D6-8010
   Part No SW: 5GM 907 044 R    HW: 5GM 907 044 R
   Component: Climatronic   H05 2009
   Revision: 00001K04
   Coding: 01020014200118010004004012111016
   ASAM Dataset: EV_ACClimaBHBVW37X 006148
   VCID: 53E66C4F3A4BFCD748-8006
   Part No SW: 5Q0 937 087 BB    HW: 5Q0 937 087 BB
   Component: BCM PQ37BOSCH 036 0265
   Revision: --------    Serial number: C86414091904FN
   Shop #: WSC 00066 790 00244
   ASAM Dataset: EV_BodyContrModul1UDSBosc 019001
   ROD: EV_BCMBOSCH_019_VW37.rod
   VCID: 7CB4E7F3F755D3AFF9-8028
   Subsystem 1 - Part No SW: 5Q0 955 547 C    HW: 5Q0 955 547 C  Labels: 5Q0-955-547.CLB
   Component: RLHS  051 0206
   Serial number: SAY19M07D18H07M37S11
   Coding: 0218DD
   Steering Column Switch:
   Subsystem 3 - Part No SW: 5Q1 953 521 AS    HW: 5Q1 953 569
   Component: Lenks.Modul  H03 0170
   Serial number: 0300120920190C202031
   Subsystem 4 - Part No SW: 3G0 963 345     HW: 3G0 963 345
   Component: SysNameFanLin  014 0101
   Serial number: ESE1483980
   Subsystem 5 - Part No SW: 3G0 963 345     HW: 3G0 963 345
   Serial number: ESE1486561
   Subsystem 6 - Part No SW: 3G0 963 345     HW: 3G0 963 345
   Serial number: ESE1500910
   Subsystem 7 - Part No SW: 3G0 963 345     HW: 3G0 963 345
   Serial number: ESE1500719
   Part No SW: 5Q0 907 572 P    HW: 3QF 907 572 A
   Component: ACC BOSCH MQB H11 0682
   Coding: 2B00008119FF440D949C81C500001400000000000000000014
   Shop #: WSC 12345 123 61029
   ASAM Dataset: EV_ACCBOSCHVW416 002008
   VCID: 44C45F13CF256B6FC1-8010
0267 - Sensor for Automatic Distance Regulation; Incorrectly Positioned
          C1103 00 [009] - -
          [FAULT_ALIGNMENT_NOT_OK]
                    Reset counter: 8
                    Mileage: 19836 km
                    Date: 2020.03.14
                    Time: 00:23:01
                    Control Module temperature: 50 °C
                    Voltage terminal 15: 14.2 V
201219 - Control Module Incorrectly Coded
          U1014 00 [009] - -
          [FAULT_CODING2SWAP_GRP_AWV_TYPE]
                    Reset counter: 15
                    Mileage: 20084 km
                    Date: 2020.03.16
                    Time: 23:08:20
                    Control Module temperature: 42 °C
                    Voltage terminal 15: 14.4 V
201224 - Control Module Incorrectly Coded
          U1014 00 [009] - -
          [FAULT_CODING_NOAWV]
                    Reset counter: 15
                    Mileage: 20084 km
                    Date: 2020.03.16
                    Time: 23:08:20
   Part No SW: 5Q0 959 655 BM    HW: 5Q0 959 655 BM
   Component: AirbagVW21    008 0403
   Serial number: 003FGM05G0JA
   Coding: 8CCCFC00000000005000001AC20800000065
   ASAM Dataset: EV_AirbaVW20SMEVW37X 002164
   ROD: EV_AirbaVW20SMEVW37X.rod
   VCID: 0C54B733A7F5E32FC9-8058
   Occupant Detection:
   Component: BF-Gewichtss.  H14 0022
   Serial number: IBH00000000000C7PIM1
   Coding: 30344B
   Subsystem 2 - Part No SW: -----------    HW: 480 002 607 19
   Serial number: 35700000000022B07E3B
   Subsystem 3 - Part No SW: -----------    HW: 480 002 607 19
   Serial number: 35800000000CC5B07E3.
   Subsystem 4 - Part No SW: -----------    HW: 480 402 007 19
   Component: SideSensor_Dr  005 6149
   Serial number: 3510001C2EFE72542348
   Subsystem 5 - Part No SW: -----------    HW: 480 401 107 19
   Component: SideSensor_Pr  005 6149
   Serial number: 3520001A6F08AF88F54T
   Subsystem 6 - Part No SW: -----------    HW: 480 400 908 19
   Component: FrontSensor_D  005 6149
   Serial number: 35500019CF029AA425CI
   Front Sensor Passenger:
   Subsystem 7 - Part No SW: -----------    HW: 480 400 908 19
   Component: FrontSensor_P  005 6149
   Serial number: 35600019CF029AA407BI
   Part No SW: 17A 920 890 A    HW: 17A 920 890 A
   Component: KOMBI         509 1701
   Coding: 01AC091226A0CF05028B772150000008A0000000
   ASAM Dataset: EV_DashBoardVDDMQBA0 001026
   ROD: EV_DashBoardVDDMQBA0_VW37.rod
   VCID: 2600E59B5959B97FFF-8072
6 Faults Found:
          U1014 00 [009] - -
                    Reset counter: 15
                    Mileage: 20084 km
                    Date: 2020.03.16
                    Time: 22:32:11
1246802 - Interface Module for Vehicle Position/Orientation System
          B1306 52 [009] - Not activated
                    Fault Frequency: 7
                    Reset counter: 15
                    Mileage: 19836 km
                    Date: 2020.03.14
                    Time: 00:45:07
16776987 - Databus
          [STS_01 keine Kommunikation]
                    Reset counter: 8
                    Mileage: 19836 km
                    Date: 2020.03.13
                    Time: 23:57:27
16776996 - Databus
          [FCW_01 keine Kommunikation]
                    Reset counter: 15
                    Mileage: 20084 km
                    Date: 2020.03.16
                    Time: 22:28:13
16776985 - Databus
          [Quersperre_04 keine Kommunikation]
                    Reset counter: 15
                    Mileage: 20084 km
                    Date: 2020.03.16
                    Time: 22:28:13
16777060 - Function Restricted due to Interrupted Communications
          U1110 00 [009] - -
          [BAP_StartStopReasons_0x39 keine Kommunikation]
                    Reset counter: 15
                    Mileage: 20084 km
                    Date: 2020.03.16
                    Time: 23:25:02
   Part No SW: 3Q0 907 530 AA    HW: 3Q0 907 530 C
   Component: GW MQB High   521 5366
   Serial number: 19091900841461
   Coding: 0101000830085900FB0002A9080F00000001070000000000000000000000
   ROD: EV_GatewNF.rod
   VCID: 6E90DDBBB129B13F47-803A
   Component: 1-00-0d-00-04
   Subsystem 2 - Part No SW: 5G0 959 442 AD    HW: 5G0 959 442 AD  Labels: 3C8-959-537.CLB
   Component: E221__MFL-MD9  H12 0052
   Serial number: 29190001323530079236
   Coding: 28FFFF
131684 - Actuator for External Sound
          U1147 00 [009] - No Communications
          [Timeout Knoten 0x64 / C0 - Aktuator für Aussengeräusch]
                    Fault Frequency: 34
                    Reset counter: 15
                    Mileage: 19836 km
                    Date: 2020.03.13
                    Time: 23:57:29
                    Supply voltage: Terminal 30: 14.3 V
                    Terminal 15: On
131770 - No Communications with Undefined Control Module
          U1126 00 [009] - -
          [Timeout Knoten 0xBA]
                    Fault Frequency: 34
                    Reset counter: 15
                    Mileage: 19836 km
                    Date: 2020.03.13
                    Time: 23:57:29
                    Terminal 15: On
66304 - Databus
          U1124 00 [009] - Additional Installations Detected
          [Mehrverbau CAN]
                    Fault Frequency: 145
                    Reset counter: 15
                    Mileage: 19836 km
                    Date: 2020.03.13
                    Time: 23:57:29
                    Terminal 15: On
   Part No SW: 2Q0 905 861 A    HW: 2Q0 905 861 A
   Component: ELV-MQBB      H08 0021
   Serial number: 19000209021016
   ROD: EV_ELVMarqMQBA0_VW37.rod
   VCID: 312A06C76097EEC71A-8064
Address 32: Differential Locks (J492)       Labels:* 0CQ-907-554.clb
   Part No SW: 0CQ 907 554 P    HW: 0CQ 907 554 P
   Component: Quersperre    H55 8043
   Serial number: HA1-00022.03.19
   Coding: 0005
   ASAM Dataset: EV_LockElectHA1VW37X 001007
   ROD: EV_LockElectHA1VW37X.rod
   VCID: 52E8694B0551F5DF43-8006
   Part No SW: 5Q0 959 760 E    HW: 5Q0 959 760 E
   Component: Sitzmemory    H09 0026
   Serial number: Y0007SFR34905
   Coding: 0010000200000400018280808000000000008101000000F400
   Shop #: WSC 01383 790 50316
   ASAM Dataset: EV_SeatMemorDriveSide 002022
   VCID: 3FCE50FFA6C308B79C-806A
          U1400 00 [008] - -
          [Funktionseinschränkung durch Unterspannung --> funktionelle Einschränkungen aufgrund vorübergehender Unterspannung in der Versorgung.]
                    Reset counter: 55
                    Mileage: 19847 km
                    Date: 2020.03.14
                    Time: 12:10:27
Address 3C: Lane Change (J1086)       Labels:* None
   Part No SW: 2Q0 907 686 A    HW: 2Q0 907 686 A
   Component: HRE3_Kl15_Mst H05 0052
   Serial number: 00000523342915
   Coding: 5000C500
   ASAM Dataset: EV_HREntryHellaGen3Kl15 001009
   ROD: EV_HREntryHellaGen3Kl15_001_VW37.rod
   VCID: 383C3BE383ED3F8F5D-806C
   Part No SW: 5Q4 959 593 M    HW: 5Q4 959 593 F
   Component: TSG FS        006 0247
   Serial number: 42038915401924
   Coding: 003D1B204200028000000000
   VCID: 4FEE603F166398376C-801A
   Subsystem 1 - Part No SW: 5Q4 959 811 F    HW: 5Q4 959 811 F  Labels: 5QX-959-81X-V1.CLB
   Component: Fond FHSG DRV  010 0004
   Serial number: 00000000000004137416
   Coding: 011000
   Part No SW: 5QN 909 144 B    HW: 5QN 909 144 A
   Component: EPS_MQB_ZFLS  507 5082
   Coding: 800A0100
   ROD: EV_SteerAssisMQB_015.rod
   VCID: 51EA664700578EC77A-8004
Address 47: Sound System (J525)       Labels:| 5Q0-035-456.clb
   Part No SW: 5F0 035 456     HW: 5F0 035 456
   Component: KonzernAmp12K H03 2109
   Revision: --------    Serial number: A1126A00120176
   Coding: 0203000002AAAAAA000000000000
   ASAM Dataset: EV_AMPCAN12C4PASE 001002
   ROD: EV_AMPCAN12C4PASE.rod
   VCID: 6288B98B75F1055FD3-8036
0535 - Loudspeaker 2 in Double-Subwoofer
          B130D 12 [009] - Short to Plus
                    Fault Frequency: 11
                    Reset counter: 15
                    Mileage: 20084 km
                    Date: 2020.03.16
                    Time: 22:05:05
                    Voltage terminal 30: 14.3 V
0537 - Loudspeaker 1 in Double-Subwoofer
          B130C 13 [009] - Open Circuit
                    Reset counter: 15
                    Mileage: 20084 km
                    Date: 2020.03.17
                    Time: 00:11:10
                    Voltage terminal 30: 12.5 V
0575 - Double Bass Speaker 1; Front Left
          B1345 13 [009] - Open Circuit
                    Reset counter: 15
                    Mileage: 20084 km
                    Date: 2020.03.17
                    Time: 00:11:10
   Part No SW: 5Q4 959 592 M    HW: 5Q4 959 592 F
   Component: TSG BFS       006 0247
   Serial number: 46038924501138
   Coding: 003F13200E00028000000000
   VCID: 4ED07D3B1169913F67-801A
   Subsystem 1 - Part No SW: 5Q4 959 812 F    HW: 5Q4 959 812 F  Labels: 5QX-959-81X-V1.CLB
   Component: Fond FHSG PSG  010 0004
   Serial number: 00000000000004124807
   Coding: 091000
   Part No SW: 3Q0 035 844 B    HW: 3Q0 035 844 B
   Component: MU-S-S-US     724 0890
   Coding: 09730100AA00000041220003001C08409F0513F40180040002
   ROD: EV_MUStd4CDELP_VW37.rod
   VCID: 2E101DBB71A9F13F07-807A
   Subsystem 1 - Part No SW: 5G6 919 605 C    HW: 5G6 919 605 C
   Component: ABT_Std-2  254 8130
   Serial number: VWZ6ZMW2625810
1543 - Control Module Incorrectly Coded
          U1014 00 [009] - -
                    Reset counter: 15
                    Mileage: 20084 km
                    Date: 2020.03.16
                    Time: 23:26:45
                    Voltage terminal 30: 14.5 V
                    Byte_Coding_Condition-byte_0_condition: ERROR
                    Byte_Coding_Condition-byte_1_condition: OK
                    Byte_Coding_Condition-byte_10_condition: ERROR
                    Byte_Coding_Condition-byte_11_condition: ERROR
                    Byte_Coding_Condition-byte_12_condition: ERROR
                    Byte_Coding_Condition-byte_13_condition: ERROR
                    Byte_Coding_Condition-byte_14_condition: ERROR
                    Byte_Coding_Condition-byte_15_condition: ERROR
                    Byte_Coding_Condition-byte_16_condition: ERROR
                    Byte_Coding_Condition-byte_17_condition: ERROR
                    Byte_Coding_Condition-byte_18_condition: ERROR
                    Byte_Coding_Condition-byte_19_condition: ERROR
                    Byte_Coding_Condition-byte_2_condition: OK
                    Byte_Coding_Condition-byte_20_condition: ERROR
                    Byte_Coding_Condition-byte_21_condition: ERROR
                    Byte_Coding_Condition-byte_22_condition: ERROR
                    Byte_Coding_Condition-byte_23_condition: ERROR
                    Byte_Coding_Condition-byte_24_condition: ERROR
                    Byte_Coding_Condition-byte_25_condition: ERROR
                    Byte_Coding_Condition-byte_26_condition: ERROR
                    Byte_Coding_Condition-byte_27_condition: ERROR
                    Byte_Coding_Condition-byte_3_condition: OK
                    Byte_Coding_Condition-byte_4_condition: OK
                    Byte_Coding_Condition-byte_5_condition: OK
                    Byte_Coding_Condition-byte_6_condition: OK
                    Byte_Coding_Condition-byte_7_condition: OK
                    Byte_Coding_Condition-byte_8_condition: OK
                    Byte_Coding_Condition-byte_9_condition: OK
   Component: OCULowMQBUS   009 0570
   Coding: 02730102C2823A017F1E06000000
   ROD: EV_OCULowMQB.rod
   VCID: 43C65C0FCA2B6C57F8-8016
   Part No SW: 5G0 907 159 F    HW: 4H0 907 159 A
   Component: SAS-GEN 2     H07 0004
   Serial number: 190321202559
Address C0: Act. for Ext. Noise
   Part No SW: 4K0 907 594 AD    HW: 4K0 907 594
   Component: SAD_STG_1     006 0002
   Coding: 00800073710B
   ASAM Dataset: EV_SunRoofCONTIAU736 009011
   ROD: EV_SunRoofCONTIAU736_009_VW37.rod
   VCID: 76A0F5DBC97989FF8F-8022
Address 8107: Antenna
End----------(Elapsed Time: 01:32, VBatt start/end: 14.4V/14.4V)-----------
Jef
HQ
[insert Stewie hitting kid with baseball bat then saying "what did you learn?" meme here]
Ouch. Well I don't have good news to offer, that type of ABS coding is.... crazy complex.
I would suggest to contact your dealer that you purchased the car from, go to the sales person you haggled with. Ask him/her/it/helicopter to look for the "paperless report" or whatever it is called the days. When a car is dropped off the truck at a dealer, a tech will do a PDI and part of that is using the factory scan tool to run a system scan on the car. These scans get uploaded to VW's mothership. Any dealer can view these reports and within them should be the original long gibberish ABS coding value. It can be printed off, or maybe even copied and saved onto a thumb drive so that you can then copy/paste the long gibberish value right back using VCDS.
DV52
C?ID=194404
Cyan: Hi. Most certainly - do as Jeff suggests, but to satiate my curiosity - where did you get the replacement code-string for the hex03 module after the factory reset?
incidentally, while I entirely understand your comment about OBD11, I'm not sure if it's anymore difficult to avoid doing the same thing with VCDS - IMHO, the software in both devices need to warn users of the consequence of proceeding before the go-process.
Cryan19
Wilmington, DE, USA
C?ID=365507
Thank you, I got a majority of it handled with help from Deb!
Cryan19
Wilmington, DE, USA
C?ID=365507
This was coding given to me to try via email from Deb with support at Ross-Tech for 03-ABS. I imagine this will not work for everyone and should for sure use cation - 2019 GLI Autobahn MT6. But got a ton of issues handled for me! Just finishing up on the rest ��
"Deb". You keep using that name. I think you mean "Dana". ;)
I guarantee you it will not be accepted by any other car. These ABS systems use a VIN-specific coding scheme.
Cryan19
Wilmington, DE, USA
C?ID=365507
Dana! Yes Dana is a Godsend, sheesh! I also have been able to get ALMOST everything done, my bf has same model and year with same build date. Most of his coding worked or was easy to compare to see where my misses were.
and THANK YOU DANA! :)
New List that I hope to have finished by today...
Wednesday,18,March,2020,08:07:23:48820
Gateway Installation List: 3Q0 907 530 AA
