Results 1 to 7 of 7
Thread: Edc17 cp44 Audi A6 injector coding
    New User
    Mar 2020
    RO
    Hello.
    I have a problem coding new injectors.
    Basicaly I swapped my original injectors for bigger ones.
    Now ecu does not accept the ASCII code from the new ones.
    Mesage îs Request out of range .
    Basicaly almost same issue as here
    https://forums.ross-tech.com/showthr...i-Q7-EDC17CP44
    Does somebody have some advices?
    Could be that this ecu has some defined range of codes to accept ?
    Please post a full unedited VCDS Auto-Scan of your A6 - see my signature for a link to a How-To
  3. Likes Dana liked this post
    New User
    Mar 2020
    RO
    Tuesday,17,March,2020,11:33:22:59543
    VCDS Version: 19.6.2.2 (x64)
    VIN: WAUZZZ4G7CN145016   License Plate:
    Chassis Type: 4G-AU57 (4G0)
    Scan: 01 02 03 05 08 09 10 15 16 17 19 28 3B 42 44 46 52 53 55 56
              5F 62 6C 6D 72 85 8E 8F 90
    VIN: WAUZZZ4G7CN145016   Mileage: 270597km-168141miles
    Address 01: Engine (J623-CLAA)       Labels:. 059-907-401-V2.clb
       Part No SW: 4G0 907 311 E    HW: 4G0 907 401
       Component: 3.0TDI EDC17  X37 0001
       Revision: 53X37---
       Coding: 12254012042601020000
       ASAM Dataset: EV_ECM30TDI0114G0907311E 001001
       ROD: EV_ECM30TDI0114G0907311E.rod
       VCID: 254A13C524099167F6-8070
       Part No SW: 4G1 927 156 C    HW: 0B5 927 156 F
       Component: 0B5 30 TDIRdW H10 0006
       Revision: --H10---    Serial number: 0000000315
       Coding: 000001
       ASAM Dataset: EV_TCMDL501 A02206
       ROD: EV_TCMDL501.rod
       VCID: 2D5AEBE57CF9A9273E-8078
       Coding: 07A68701E065E180DB00
       VCID: 3668C48989AFEAFF4F-8062
       Part No SW: 4H0 907 064 BP    HW: 4H0 907 064 BP
       Coding: 05A92F06000000000000
       VCID: 78F40AB1CB3BDC8F9D-802C
       Part No SW: 4G0 820 043 K    HW: 4G0 820 043 K
       Component: KLIMA 4 ZONEN H12 0064
       Serial number: 03031200040028
       Coding: 3602007824
       VCID: 275619CD5E058377C4-8072
       Part No SW: 4H0 907 063 BN    HW: 4H0 907 063 F
       Component: BCM1 2.0      H12 0111
       Revision: 20012002    Serial number: 00000001252624
       Coding: 2600201041349FE08181008300001D0CCF9CC70826090101000008602101
       VCID: 75EA0385DC29A1E786-8020
       Component: WWS57X 120207  H35 0080
       Serial number:         120222200814
       Coding: 0045F7
       Component: RLS  H04 0003
       Serial number: 12012025
       Coding: 02512B
       Subsystem 3 - Part No SW: 4G0 941 531 E    HW: 4G0 941 531 E
       Component: E1 - LDS  H07 0044
       Serial number: 05 03 2012  00001004
       Serial number: E3088916000000000001
       Part No SW: 4H0 919 475 L    HW: 4H0 919 475 C
       Component: PARKHILFE ACC H07 0043
       Revision: 11001001    Serial number: 55901206201176
       Coding: 282307
       ROD: EV_EPHVA18AU57X0000_002_AU57.rod
       VCID: 3B7ED5BDB28D3797B0-806E
       Revision: --------    Serial number: 003JG007DA3S
       Coding: 30323436313330303337554A304C34473053
       Serial number: 3575HRB4061173JO6GMC
       Serial number: 3585HRB405B177542PK
       Serial number: 3515JRB400M4UHGCL0L3
       Serial number: 3525JRB400M4UHGCM17Z
       Serial number: 3554VRB404T0PLU6FHU9
       Serial number: 3564VRB404R0PLU6FOO9
       Part No SW: 4H0 953 568 G    HW: 4H0 953 568 G
       Revision: --------    Serial number: 90372LBT001N4
       Coding: 0000D5
       VCID: 3776C98D86A513F754-8062
       Subsystem 1 - Part No SW: 4G0 951 528 D    HW: 4G0 951 528 D
       Component: E221 - MFL  H09 0009
       Serial number: 31 01 2012  33186384
       Part No SW: 4G8 920 931 N    HW: 4G8 920 931 N
       Component: TDieRdw       H79 0416
       Revision: 28460
    1    Serial number: 658210212596037
       Coding: 13AF11000B150008010000
       ASAM Dataset: EV_RBD4K 004045
       ROD: EV_RBD4K_AU57.rod
       VCID: 3972CFB5B8B10587A2-806C
    1048578 - No Basic Setting
              B2010 00 [009] - -
                        Reset counter: 66
                        Mileage: 270597 km
                        Date: 2020.03.17
                        Time: 11:20:37
       Part No SW: 4G0 907 468 G    HW: 4G0 907 468 A
       Component: J533--Gateway H08 0214
       Revision: --------    Serial number: 00000000426856
       Coding: 00CD077D00
       ROD: EV_GatewUDS_AU57.rod
       VCID: 346CFE819FD3F8EF71-8060
       Component: J367-BDM  H07 0141
       Serial number: 00000000003790220912
       Voltage stabilizer:
       Serial number: 12058001393011200181
       Part No SW: 4G0 919 158 C    HW: 4G0 919 158 C
       Component: KLIMA FOND    H07 0064
       Serial number: 03031200040734
       Coding: 00
       VCID: 2F66F1ED76F5DB370C-807A
       Part No SW: 4G0 907 637 B    HW: 4G0 907 637 B
       Component: SARA 6D       H02 0009
       Revision: --------    Serial number: EJ1BPA4204264G0
       ASAM Dataset: EV_SARA 009017
       ROD: EV_SARA_009.rod
       Part No SW: 4G8 959 793 E    HW: 4G8 959 793 A
       Component: TSG FA        H05 0212
       Coding: 011F16204000628002080002
       VCID: 4280A859DD67465FF3-8016
       Component: RCEPS         H35 0010
       Revision: 00001000    Serial number: 0018385473
       Coding: 101001010000
       ASAM Dataset: EV_RCEPS 009008
       ROD: EV_RCEPS_009.rod
       VCID: 3260F89965C7F6DF63-8066
       Revision: 00002001    Serial number: 0171444693
       Coding: 01040E2020B9340183200904080304000000000000000000000000000000
       Subsystem 1 - Part No SW: 3AA 962 243 D    HW: 3AA 962 243 D
       Serial number: 93061034
       Part No SW: 4G8 959 792 E    HW: 4G8 959 792 A
       Component: TSG BF        H05 0212
       Coding: 011F16204400628002080002
       VCID: 4182A755D8615D47EA-8014
       Revision: --------    Serial number: 00000000267100
       ROD: EV_ParkiBrake_VW51.rod
       VCID: 2A50E0F94D17BE1FDB-807E
       Serial number: 120302-0002-110
       Coding: 1122A6101002A300
       ROD: EV_HeadlRegulBasic.rod
       VCID: 2C5CE6E147E3A02F29-8078
       Part No SW: 4G0 035 056 E    HW: 4G0 035 056
       Component: Radio U STD   H60 0093
       Revision: AB001007    Serial number: 230CS0C7546811
       Coding: 010003020100000001
       VCID: 234E0DDD223D6F5798-8076
       Part No SW: 4G0 035 666 G    HW: 4G0 035 666 A
       Component: H-BN-EU       H48 0484
       Revision: --------    Serial number: 426CV0C7642307
       Coding: 050100010003E1EF0D30CB3E00000003E80101020000000000
       VCID: 2C5CE6E14FE3A02F29-8078
       Subsystem 1 - Part No: 8R0 060 884 AH
       Component: EUR 2012  1308
       Subsystem 2 - Part No SW: 4G0 919 605 B    HW: 4G0 919 605 B
       Serial number: AUZ8ZDB94011J37
       Subsystem 3 - Part No SW: 4G1 919 610 C    HW: 4G1 919 610 C
       Serial number: 90349LC40006S
       Component: CD-Database  3638
       Part No SW: 4G8 959 795 E    HW: 4G8 959 795 A
       Component: TSG HL        H04 0212
       Coding: 010F14204000628002080002
       VCID: 448CAE41C773486FC1-8010
       Part No SW: 4G0 907 441 C    HW: 4H0 907 441 B
       Component: SG Rueckfahrkamera  0161
       Revision: --H05---    Serial number: 525 PA8J22G2C7
       Coding: 1080005
       VCID: 275619CD96058377C4-8072
       Part No SW: 4G9 959 107 A    HW: 4G9 959 107 A
       Component: HDSG-Modul    H03 0139
       Revision: 14003001    Serial number: 060200924
       Coding: 097205C010
       ASAM Dataset: EV_HDSGAu572 001001
       ROD: EV_HDSGAu571.rod
       Component: TSG HR        H04 0212
       Part No SW: 4G0 907 217     HW: 4H0 907 217 A
       Component: DPC-SG        H25 0036
       Coding: 62040000
       ROD: EV_OnBoardCamerDPC.rod
       VCID: 65CA53C56489516736-8030
       Part No SW: 4G0 907 107 D    HW: 4H0 907 107
       Component: BV-SG         H30 0038
       Serial number: 005000050703127
       Coding: 0440A9181111
       ASAM Dataset: EV_BC7 001001
       ROD: EV_BC7.rod
       Part No SW: 4H0 980 945 B    HW: 4H0 980 945 B
       ASAM Dataset: EV_RGS_L 002004
       ROD: EV_RGS_L.rod
       VCID: 3162F79560C1CDC71A-8064
       ASAM Dataset: EV_RGS_R 002004
       ROD: EV_RGS_R.rod
    End-------------------------(Elapsed Time: 05:13)--------------------------
    I tried also ODIS to imput the values
    no luck .
    perhaps only with an sw update could solve this
    Or if somebody has any ideeas please share .
  5. Likes Dana liked this post
  6. #4
    There are indeed newer versions of software for that ECU.
    But if you swapped the injectors for bigger ones, which are incorrect, it is entirely possible that your ECU's software may not accept the values for those.
  7. Likes PetrolDave, Dana liked this post
  8. #5
    New User
    Mar 2020
    RO
    Injectors are from.edc17cp54 !
    I did in the past many swaps even edc17 in edc16 3.0 tdi ..and newer has this issue.
    Looks like there îs somewhere a patern on what code to accept and what not ,or there might Something I am missing.
  9. #6
    United States
    As far as software updates are concerned Audi appears to have published 4 over the years but the only TPIs I could locate are related to:
    • 2036484 Sporadic idle speed fluctuations in stop-start operation, A4/A6/A7 - V6TDI MY 14 using SVM code 01A183
    • 2042993 Engine warning lamp on, glow plug 5 electric fault - V6 TDI, EA896 G2 using SVM code 01A183
    Since both use the same SVM code it may be worth attempting to run that update but I don't know if it will help with the actual injector calibration concern. Do keep us posted.
  10. Likes Uwe liked this post
  11. #7
    New User
    Mar 2020
    RO
    Problem solved!
    I did some moding in the bin.file and then I was able to write the corections.
