Results 1 to 9 of 9
Thread: Fault Code P0016 EML On
    Mar 2020
    Hi, first posting after getting VCDS up and running.
    Full scan on 2015 Skoda.
    Cleared off DTC's then took for test drive, only P0016 code has reappeared at the moment.
    Search shows possible Cam Position Sensor but also mentions Oil? The Oil Service message has just recently came up and needs changing, could that be the issue?
    Full Scan:
    Monday,16,March,2020,16:31:40:08428
    VIN: TMBMJ7NEXG0061796   License Plate: SW65FHY
    Mileage: 211774km-131590mi   Repair Order:
    Chassis Type: NE-SK37 (5Q0)
    Scan: 01 03 08 09 10 15 16 17 19 22 42 44 52 5F 69
    VIN: TMBMJ7NEXG0061796   Mileage: 211774km-131590miles
    Address 01: Engine (J623-CRMB)       Labels:. 04L-907-309-V1.clb
       Part No SW: 04L 906 026 BQ    HW: 04L 907 309 R
       Component: R4 2,0L EDC   H21 1199
       Revision: B5H21---
       Coding: 01190012032701090000
       Shop #: WSC 73430 031 00063
       ASAM Dataset: EV_ECM20TDI01104L906026BQ 002002
       ROD: EV_ECM20TDI01104L906026BN_002.rod
       VCID: 7AADF52DFC5D5717871-802E
    4794 - Mass Air Flow Sensor (G70)
              P0101 00 [101] - Implausible Signal
                        Mileage: 211487 km
                        Date: 2020.03.16
                        Time: 07:20:59
                        Engine speed: 1969.00 /min
                        Vehicle speed: 104 km/h
                        Coolant temperature: 90 °C
                        Intake air temperature: 69 °C
                        Voltage terminal 30: 14.780 V
                        Mass airflow sensor 1 bank 1 airflow: raw value: 431.2 mg/stroke
                        Standardized airflow ratio: filtered: 1.2081
                        Exhaust recirc.valve 1 bank 1: posit.feedback - Act.value: 0.16 %
                        Throttl.valve adapt. 1 bank 1: posit feedback - Act.value: 0.00 %
                        Charge air pressure specified value: 1112 hPa
                        Charge air cooler inlet: pressure sensor 1 bank 1: raw value: 1180.6 hPa
                        Mean injection quantity: 0.00 mg/stroke
    8809 - Cylinder 3 Internal Pressure Sensor
              P13D6 00 [237] - Implausible Signal
                        Mileage: 211499 km
                        Date: 2020.03.16
                        Time: 07:28:06
                        Engine speed: 1527.50 /min
                        Vehicle speed: 80 km/h
                        Intake air temperature: 53 °C
                        Cylinder head: pressure sensor 3 bank 1: raw value: 35.969 bar
                        Cyl. head: press. sens. 3 bank 1: max press. in decelerat.mode: 0.92 °
                        Cylinder_pressure_offset_cylinder_3: -1.156 bar
                        Cyl. head: press. sen 3 bank 1: error stat. combust. rm. press.-Bits 0-7: 32
                        Cylinder head: press. sensor 3 bank 1: grp. run time: 12.9 µs
    19233 - Bank 1: Camshaft A (Intake)
              P0011 00 [237] - Retard Setpoint not Reached (Over-Advanced)
                        Mileage: 211510 km
                        Date: 2020.03.16
                        Time: 08:21:21
                        Engine speed: 957.00 /min
                        Normed load value: 15.3 %
                        Vehicle speed: 22 km/h
                        Coolant temperature: 86 °C
                        Intake air temperature: 72 °C
                        Voltage terminal 30: 14.700 V
                        Camshaft adjustment intake bank 1: actual value: 43.92 °
                        Camshaft adjustment intake bank 1: specified value: 10.00 °
                        Camshaft adjustment intake bank 1: activation: 6.250 %
                        Camshaft adaptation intake bank 1: phase position: 0.00 °
                        Engine oil temperature: 86.7 °C
    4096 - Bank 1: CMP Sensor (G40) / Engine Speed Sensor (G28)
              P0016 00 [101] - Incorrect Correlation
                        Mileage: 211319 km
                        Date: 2020.03.16
                        Time: 05:31:10
                        Engine speed: 891.50 /min
                        Normed load value: 25.1 %
                        Vehicle speed: 32 km/h
                        Engine start: start synchronization: EPM_MODE_OK
                        Engine start: start synchronization-Test_Program_Epm st Op Mode State t UBYTE: 48
    Readiness: 1 2 0 0 0
       Part No SW: 3Q0 907 379 T    HW: 3Q0 907 379 C
       Component: ESC           H32 0393
       Revision: 00000000    Serial number: 51975000000347
       Coding: 1C078A912426096D007E070941C9293851249000E08294F200630070C009
       ROD: EV_Brake1UDSContiMK100ESP_034_SK37.rod
       VCID: 4BC360E9E3471E9F6C7-801E
       Part No SW: 5E0 907 044 Q    HW: 5E0 907 044 Q
       Component: Climatronic   H04 1002
       Revision: 00001K07
       Coding: 02110104000100011005000000101000
       VCID: 333318099BB7665F047-8066
       Part No SW: 5Q0 937 086 AH    HW: 5Q0 937 086 AH
       Revision: --------    Serial number: 86582307151477
       Coding: 0F020842424702FB07A04082B10407280000000000000000000000000000
       ROD: EV_BCMBOSCH_015.rod
       VCID: 005987C59A810DC7C95-8054
       Subsystem 1 - Part No SW: 5E2 955 119     HW: 5E2 955 119   Labels: 5QX-955-119-V1.CLB
       Component: WWS371 150528  041 0570
       Serial number:         150604120757
       Coding: 065DDD
       Component: RLHS  037 0059
       Serial number: S5Y15M08D10H03M14S13
       Coding: 00885D
       Subsystem 3 - Part No SW: 5Q0 951 171     HW: 5Q0 951 171
       Serial number: 000000000ZY151392PHG
       Serial number: 00000000000033009225
    12307 - License Plate Light
              B12CA 01 [009] - Electrical Failure
                        Reset counter: 100
                        Mileage: 211016 km
                        Date: 2020.03.12
                        Time: 15:53:05
       Part No SW: 5Q0 919 283 F    HW: 5Q0 919 283
       Component: PARKHILFE 4K  H10 0054
       Revision: --------    Serial number: 39231519601685
       Coding: 0001050101
       ASAM Dataset: EV_EPHVA14AU3700000 002024
       VCID: 3C213335B6E9A927D5D-8068
       Part No SW: 3Q0 959 655 AS    HW: 3Q0 959 655 AS
       Component: Airbag VW20   013 0200
       Revision: --------    Serial number: 003SQPEME91D
       Coding: 98CCC000000000005C5400CC008800000065
       Shop #: WSC 73430 790 00063
       ROD: EV_AirbaVW20TS6VW48X.rod
       VCID: 0F7BB4F9D7DF62BF40F-805A
       Subsystem 1 - Part No SW: -----------    HW: 454 002 007 15
       Serial number: 3576U0000008E858C51Q
       Subsystem 2 - Part No SW: -----------    HW: 454 002 007 15
       Serial number: 3586U000000AD758C51R
       Subsystem 3 - Part No SW: -----------    HW: 454 801 307 15
       Serial number: 3516R161E69070000000
       Subsystem 4 - Part No SW: -----------    HW: 454 801 107 15
       Serial number: 3526R073CA307000000%
       Subsystem 5 - Part No SW: -----------    HW: 454 801 106 15
       Serial number: 3556V285862070000002
       Part No SW: 5Q0 953 521 M    HW: 5Q0 953 569 A
       Revision: FF033033    Serial number: 20150729400484
       Coding: 1400
       ROD: EV_SMLSVALEOMQB.rod
       Part No SW: 5E0 920 981 B    HW: 5E0 920 981 B
       Component: KOMBI         206 7640
       Coding: 27A40800A180A60001082A001000000000000000
       ASAM Dataset: EV_DashBoardJCIMQBAB 009005
       ROD: EV_DashBoardJCIMQBAB_009_VW48.rod
       VCID: 290FFA61497B2C8FBEB-807C
    9456433 - Key
              B104B 31 [008] - No Signal
                        Reset counter: 147
                        Time: 00:00:00
    16777024 - Function Restricted due to Interrupted Communications
              U1110 00 [008] - -
              [BAP_BCME_0x23 keine Kommunikation]
                        Fault Frequency: 46
                        Reset counter: 148
                        Mileage: 211016 km
                        Date: 2020.03.12
                        Time: 15:52:55
       Part No SW: 5Q0 907 530 AE    HW: 5Q0 907 530 E
       Component: GW MQB Mid    127 1224
       Revision: --------    Serial number: 0003785005
       Coding: 030100040F087300EB000248080F00010001050000000000000000000000
       ROD: EV_GatewLear_013.rod
       VCID: 74B1DB15DE392167DDD-8020
       Subsystem 2 - Part No SW: 3V0 919 719 A    HW: 3V0 919 719 A
       Component: E221__MFL-PR6  H02 0150
       Serial number: 000000000A0226210715
       Subsystem 3 - Part No SW: 5Q0 915 181 F    HW: 5Q0 915 181 F
       Component: J367-BDM  H08 0223
       Serial number: 62195240564291405273
       Serial number: HA1-00011.06.15
       Coding: 0001
       VCID: 46D551DDF825E3F7B39-8012
       Part No SW: 5Q4 959 393 E    HW: 5Q4 959 393 B
       Serial number: 0000160369665
       Coding: 001000208001040000001100
       VCID: 45D756D1C523E8EFBA3-8010
       Serial number: 00000000000006649127
       Coding: 1D0200
       Component: EPS_MQB_ZFLS  125 1061
       Coding: 8103
       VCID: 43D348C9CB17D6DF947-8016
       Part No SW: 5Q4 959 392 E    HW: 5Q4 959 392 B
       Serial number: 0000160375511
       VCID: 44D14BD5CE19D1E7ADD-8010
       Serial number: 00000000000006846507
       Coding: 050200
    Address 5F: Information Electr. (J794)       Labels:| 3V0-035-MIB-STD2.clb
       Part No SW: 5Q0 035 842 A    HW: 5Q0 035 842 A
       Component: MU-S-D-ER     H24 0241
       Serial number: SKZAZ2R8709779
       Coding: 03730200FF00000011111201008800002F0200C60120810002
       ROD: EV_MUStd4CTSAT_VW41.rod
       VCID: 2D070E717D9330AF523-8078
       Subsystem 1 - Part No SW: 5E0 919 605 H    HW: 5E0 919 605 H
       Component: ABT_Std-2  H41 1028
       Serial number: SKZ8Z9RBS00EUP
              U11B8 00 [008] - No Communications
              [USB - communication error]
                        Reset counter: 146
                        Mileage: 211053 km
                        Date: 2020.03.13
                        Time: 09:25:48
                        Voltage terminal 30: 14.7 V
                        Interface for external media: status-Status: Open circuit
       Part No SW: 5Q0 907 383     HW: 5Q0 907 383
       Component: Anhaenger     H11 0030
       Revision: 6A001003    Serial number: 00000194382114
       Coding: 0100000200000000
       ASAM Dataset: EV_TrailFunctDemouHella 001001
       ROD: EV_TrailFunctDemouHella.rod
    End----------(Elapsed Time: 01:31, VBatt start/end: 12.4V/12.4V)-----------
    2012 Skoda Octavia II Estate 2.0Tdi 140PS Manual
    2015 Skoda Octavia III Estate 2.0Tdi 4 x 4 150PS Manual
    2017 VW Sharan 2.0Tdi SE Bluemotion 163PS Manual
    2019 Seat Alhanbra 2.0Tdi LUX Ecomotive 150PS Manual
    Does this engine use a timing belt or is it chains?
    Timing belt Uwe.....
    Oil PSI wrong lacking, belt on wrong, gear drive damaged on cams or improperly set/faulty keyways or virtual taper settings.
    Timing is retarded by oil PSI!
    Please RTFB and JPPSG and start mechanical tests before you destroy engine.
  4. Likes Uwe liked this post
    Mar 2020
    Hi Uwe, it's belt driven with engine code CRMB (confirmed by the dealer)
    Mar 2020
    Hi, thanks for your reply. It has just come up with Oil Service message on but level is ok and although I only bought the car in November I have the service history and it has been service regularly by the Skoda agent so must have used correct oil. I have used a brand in the UK called Quantum which is VAG so that is up to scratch. Nothing to suggest the Cam Belt has any attention although given the mileage was looking to get it changed shortly given the mileage the car covers in a year? Obviously given that nothing else in that area has been touched but would say sounds a bit rough and rattly today? Going to run another scan, possibly the fullest I can to see what readings come up although I have just bought VCDS so not had a lot of experience with it although there are some pretty useful videos on youtube.
    Mar 2020
    Update
    An addition to the posting.
    I have done another scan this morning and it has come up again with: P13D6 which is Number 3 Pressure sensor.
    Checking out this code it would appear that the probability is a faulty Glow Plug (as the Glow Plug Light on the dash is also on as well as the EML)
    Will order one up and fit it see if that corrects the fault.
    For info here is a copy of the latest scan:
    Tuesday,17,March,2020,10:40:45:08428
    Mileage: 211805km-131609mi   Repair Order:
    VIN: TMBMJ7NEXG0061796   Mileage: 211805km-131609miles
       Revision: B5H21---
                        Mileage: 211776 km
                        Date: 2020.03.16
                        Time: 16:55:27
                        Engine speed: 1311.50 /min
                        Vehicle speed: 45 km/h
                        Voltage terminal 30: 14.120 V
                        Mass airflow sensor 1 bank 1 airflow: raw value: 388.1 mg/stroke
                        Standardized airflow ratio: filtered: 1.2556
                        Exhaust recirc.valve 1 bank 1: posit.feedback - Act.value: 0.18 %
                        Charge air pressure specified value: 1006 hPa
                        Charge air cooler inlet: pressure sensor 1 bank 1: raw value: 1084.8 hPa
                        Mileage: 211784 km
                        Date: 2020.03.17
                        Time: 07:50:31
                        Engine speed: 1176.00 /min
                        Vehicle speed: 52 km/h
                        Coolant temperature: 91 °C
                        Intake air temperature: 55 °C
                        Voltage terminal 30: 14.840 V
                        Cylinder head: pressure sensor 3 bank 1: raw value: 35.234 bar
                        Cyl. head: press. sens. 3 bank 1: max press. in decelerat.mode: 0.86 °
                        Cylinder_pressure_offset_cylinder_3: -1.688 bar
              P0016 00 [237] - Incorrect Correlation
                        Mileage: 211774 km
                        Date: 2020.03.16
                        Time: 16:33:29
                        Engine speed: 769.50 /min
                        Normed load value: 28.2 %
                        Coolant temperature: 85 °C
                        Intake air temperature: 79 °C
                        Voltage terminal 30: 14.220 V
    Readiness: 1 2 0 0 1
       Revision: 00001K07
       Coding: 065DDD
       Coding: 00885D
                        Reset counter: 108
                        Mileage: 211777 km
                        Date: 2020.03.16
                        Time: 16:56:05
       Coding: 0001050101
       Coding: 1400
              U1110 00 [009] - -
                        Reset counter: 109
                        Mileage: 211774 km
                        Date: 2020.03.16
                        Time: 16:51:21
       Coding: 0001
       Coding: 1D0200
       Coding: 8103
       Coding: 050200
                        Reset counter: 148
                        Mileage: 211774 km
                        Date: 2020.03.16
                        Time: 16:51:23
                        Voltage terminal 30: 12.7 V
  8. Likes Dana liked this post
    Mar 2020
    Update: So bought a replacement Glow Plug, had a bit of a problem getting the cap off, the plastic was so brittle it broke, but as far as I can see the wiring is ok. The old unit came out pretty easily but had to work the new one back and forward a bit until it would go all the way in by hand before finishing off tightening it.
    It started up ok reved up for a couple of minutes then popped up another code, P13D4 Short to Plus.
    Checked all the wiring visually but my question is, does the new glow plug needed to be coded to the ECU? Didn't look to see if it did but have made a note of all the numbers on the new part
  10. #8
    United States
    New injectors need to be adapted but glow plugs do not. Feel free to post the old and new part numbers for review but the GP should have been plug and play.
  12. #9
    HARNESS SHOULD NEVER JUST BE VISUALLY INSPECTED AND ALWAYS AUTHENTICATED FOR ABILITY TO CARRY CURRENT!
    Did you know the new glow plug, plug to it or wiring harness maybe damaged at chafe point and pretty common for this engine FYI?
    Did you load light the harness yet using RTFB and WD?
    JPPSG
  13. Likes Uwe liked this post
