Results 1 to 5 of 5
Thread: Swapping back led indicators to lights with orange bulb 21w
    Apr 2015
    Bosnia and Herzegovina
    hello I have audi 8k from USA , and I need to change back lights for traffic regulations in my country (orange indicator lamps from back side )
    Does someone can help me about that . I was on 46 adress put in 16017 security access , but I do not know what excatly numbers to put in which chanel 198-208 or
    Please if someone did something like this it would be very usefull for me.
    with best regardds
    in attach there is auto scan
      Dealer/Shop Name: Auto Servis BOWELDD
    > VIN: WAUHFCFL6BN000575   License Plate:
    > Chassis Type: FL-AU48 (8T0)
    > Scan: 01 03 05 08 09 15 16 17 19 2E 36 42 46 47 52 53 55 56 62 72
    >           77
    > VIN: WAUHFCFL6BN000575   Mileage: 101810km-63261miles
    > 01-Engine -- Status: Malfunction 0010
    > 03-ABS Brakes -- Status: OK 0000
    > 04-Steering Angle -- Status: OK 0000
    > 05-Acc/Start Auth. -- Status: OK 0000
    > 08-Auto HVAC -- Status: Malfunction 0010
    > 09-Cent. Elect. -- Status: OK 0000
    > 15-Airbags -- Status: OK 0000
    > 16-Steering wheel -- Status: OK 0000
    > 17-Instruments -- Status: OK 0000
    > 19-CAN Gateway -- Status: OK 0000
    > 2E-Media Player 3 -- Status: OK 0000
    > 36-Seat Mem. Drvr -- Status: OK 0000
    > 42-Door Elect, Driver -- Status: OK 0000
    > 46-Central Conv. -- Status: OK 0000
    > 47-Sound System -- Status: OK 0000
    > 52-Door Elect, Pass. -- Status: OK 0000
    > 53-Parking Brake -- Status: OK 0000
    > 55-Headlight Range -- Status: OK 0000
    > 56-Radio -- Status: Malfunction 0010
    > 62-Door, Rear Left -- Status: OK 0000
    > 72-Door, Rear Right -- Status: OK 0000
    > 77-Telephone -- Status: OK 0000
    > Address 01: Engine (0-----CAEB)       Labels:| 06H-907-115-CAB.clb
    >    Part No SW: 8K2 907 115 AG    HW: 8K2 907 115 D
    >    Component: 2.0l R4/4V TF H17 0002
    >    Revision: E1H17---
    >    Coding: 0104010A180F0160
    >    Shop #: WSC 93009 999 04862
    >    ASAM Dataset: EV_ECM20TFS0118K2907115AG 001002
    >    ROD: EV_ECM20TFS0118K2907115AG.rod
    >    VCID: 74A42BC5DF22EDEFB1-8020
    > 2 Faults Found:
    > 4663 - Relay for Aux Coolant Pump (J496)
    >           P1926 00 [039] - Short to Ground
    >           Not Confirmed - Tested Since Memory Clear
    >              Freeze Frame:
    >                     Fault Status: 00000001
    >                     Fault Priority: 2
    >                     Fault Frequency: 1
    >                     Mileage: 101818 km
    >                     Date: 2010.04.13
    >                     Time: 03:27:38
    >                     Engine speed: 0.00 /min
    >                     Normed load value: 0.0 %
    >                     Vehicle speed: 0 km/h
    >                     Coolant temperature: 31 °C
    >                     Intake air temperature: 27 °C
    >                     Ambient air pressure: 1010 mbar
    >                     Voltage terminal 30: 11.709 V
    >                     Unlearning counter according OBD: 40
    > 9490 - Oil Pressure Regulation Valve
    >           P165F 00 [039] - Short to GND
    >              Freeze Frame:
    >                     Fault Priority: 2
    >                     Fault Frequency: 1
    >                     Mileage: 101818 km
    >                     Date: 2010.04.13
    >                     Time: 03:27:37
    > Readiness: 1110 0101
    > Address 03: ABS Brakes (J104)       Labels:. 8K0-907-379-V1.clb
    >    Part No SW: 8K0 907 379 BG    HW: 8K0 907 379 BG
    >    Component: ESP8 quattro  H04 0020
    >    Revision: --------    Serial number: --------------
    >    Coding: 070500
    >    Shop #: WSC 02391 823 56573
    >    VCID: 7F4EF4E9EE64BEB7DC-802A
    > No fault code found.
    > Address 05: Acc/Start Auth. (J393)       Labels:. 8K0-907-064-05.clb
    >    Part No SW: 8K0 907 064 CF    HW: 8K0 907 064 CF
    >    Component: BCM2 2.0      H04 0430
    >    Revision: 00002001
    >    Coding: 0B0100
    >    Shop #: WSC 02399 823 56573
    >    VCID: 76A011CDC15EFFFF8F-8022
    >    Subsystem 1 - Part No SW: 8T0 959 754 A    HW: 8T0 959 754 A
    >    Component: FBSAUDIB8 IDG  H50 0070
    >    Serial number: 0510000025987014
    >    Subsystem 2 - Part No SW: 8K0 905 852 D    HW: 8K0 905 852 D
    >    Component: J764 ELV MLB  H37 0042
    >    Serial number: 0210000069485002
    > Address 08: Auto HVAC (J255)       Labels:. 8Tx-820-043-3Z.clb
    >    Part No SW: 8T1 820 043 AQ    HW: 8T1 820 043 AQ
    >    Component: KLIMA 3 ZONEN H08 0180
    >    Revision: C1000000    Serial number: 01170520102192
    >    Coding: 64002000
    >    VCID: 004C7715939AC14FA5-8054
    > 1 Fault Found:
    > 03220 - Stop Valve for Coolant for Climatronic (N422)
    >             009 - Open or Short to Ground
    >              Freeze Frame:
    >                     Fault Status: 01101001
    >                     Fault Priority: 3
    >                     Fault Frequency: 1
    >                     Reset counter: 228
    >                     Mileage: 101818 km
    >                     Time Indication: 0
    >                     Date: 2010.04.13
    >                     Time: 03:26:54
    > Address 09: Cent. Elect. (J519)       Labels:. 8K0-907-063.clb
    >    Part No SW: 8K0 907 063 P    HW: 8K0 907 063 P
    >    Component: BCM1 1.0      H29 0380
    >    Revision: 10029001    Serial number: 00000000542150
    >    Coding: 26001096463CAF010000000300003D0D0F1C130802010141000000
    >    VCID: 3C34C3E5BFF265AFB9-8068
    >    Subsystem 1 - Part No SW: 8K1 955 119 A    HW: 8T1 955 119   Labels: 1KX-955-119.CLB
    >    Component: WWS 190510  H06 0070
    >    Serial number: SWF10050195195
    >    Coding: 00FD11
    >    Subsystem 2 - Part No SW: 8K0 955 559     HW: 8K0 955 559   Labels: 8K0-955-559.CLB
    >    Component: RLS  H04 0003
    >    Serial number: 10904577
    >    Coding: 025028
    >    Subsystem 3 - Part No SW: 8K0 941 531 AL    HW: 8K0 941 531 AL
    >    Component: E1 - LDS  H08 0090
    >    Serial number: 00000000001905090306
    > Address 15: Airbags (J234)       Labels:| 8K0-959-655.clb
    >    Part No SW: 8K0 959 655 K    HW: 8K0 959 655 K
    >    Component: AirbagVW-AU10 H41 0610
    >    Serial number: 003GLD0G1RR
    >    Coding: 30453735423030303030554A304C384B3053
    >    Shop #: WSC 02135 785 00200
    >    ASAM Dataset: EV_AirbaECUVWAUDI010 003010
    >    ROD: EV_AirbaECUVWAUDI010_003_AU48.rod
    >    VCID: 45C2A601C4382467D6-8010
    >    Crash sensor for side airbag: driver side:
    >    Serial number: 6334MSME531549099
    >    Crash sensor for side airbag: front passenger side:
    >    Serial number: 6344MSME530173182
    >    Crash sensor for side airbag: rear: driver side:
    >    Serial number: 6352QSME5C601A12E
    >    Crash sensor for side airbag: rear: passenger side:
    >    Serial number: 6362QSME565F303CR
    >    Crash sensor for front airbag: driver side:
    >    Serial number: 63732SME3F5F4636D
    >    Crash sensor for front airbag: front passenger side:
    >    Serial number: 63832SME6F603C346
    > Address 16: Steering wheel (J527)       Labels:. 8K0-953-568.clb
    >    Part No SW: 8K0 953 568 F    HW: 8K0 953 568 F
    >    Component: Lenks.Modul   H16 0014
    >    Revision: --------    Serial number: 90304JEC000A4
    >    Coding: 000016
    >    VCID: 3D32CEE1A4E86CA78E-8068
    >    Component: E221 - MFL  H02 0010
    > Address 17: Instruments (J285)       Labels:. 8T0-920-xxx-17.clb
    >    Part No SW: 8K0 920 900 M    HW: 8K0 920 900 M
    >    Component: KOMBIINSTR.   H20 0258
    >    Revision: 00100000    Serial number: EII21N75A
    >    Coding: 8B04090002000008020000
    >    VCID: 3424EBC597A2ADEF71-8060
    > Address 19: CAN Gateway (J533)       Labels:. 8T0-907-468.clb
    >    Part No SW: 8T0 907 468 AB    HW: 8T0 907 468 H
    >    Component: GW-BEM 5CAN   H06 0117
    >    Revision: GB800053    Serial number: 5300G105168302
    >    Coding: 00C303
    >    VCID: 014A72119890C847AA-8054
    >    Subsystem 1 - Part No SW: 8K0 915 181 E    HW: 8K0 915 181 E
    >    Component: J367-BDM  H07 0170
    >    Serial number: 10019F8F070510
    > Address 2E: Media Player 3 (R199)       Labels:. 8T0-035-785.clb
    >    Part No SW: 8T0 035 785 A    HW: 8T0 035 785
    >    Component: SG ext.Player H08 0290
    >    Revision: 00000000
    >    Coding: 020302
    >    VCID: 393ADAF1B0C05087A2-806C
    > Address 36: Seat Mem. Drvr (J136)       Labels:. 8T0-959-760.clb
    >    Part No SW: 8K0 959 760 D    HW: 8K0 959 760 D
    >    Component: MEM-FS        H06 0074
    >    Revision: AA000000    Serial number: 00001010134144
    >    Coding: 00581300000000000000
    >    VCID: 3B36C0F9BAFC6297B0-806E
    > Address 42: Door Elect, Driver (J386)       Labels:. 8K0-959-793.clb
    >    Part No SW: 8T0 959 793 M    HW: 8T0 959 793 D
    >    Component: TSG FA        H08 1401
    >    Coding: 011C03204E00410001
    >    VCID: 53E68859326C8AD748-8006
    > Address 46: Central Conv. (J393)       Labels:. 8K0-907-064-46.clb
    >    Revision: 00002001    Serial number: 0130524788
    >    Coding: 0106023A00FA044480B0013200000000
    >    Subsystem 1 - Part No: 1K0 951 605 C
    >    Component: LIN BACKUP HO  H05 1501
    >    Subsystem 2 - Part No SW: 8K0 959 591 A    HW: 8K0 959 591
    >    Component: J245 PS037  H06 0041
    > Address 47: Sound System (J525)       Labels:. 8T0-035-223-ASC.clb
    >    Part No SW: 8T0 035 223 AH    HW: 8T0 035 223
    >    Component: DSP STD       H07 0230
    >    Revision: S2200000
    >    Coding: 0203010102
    >    VCID: 74A42BC5D722EDEFB1-8020
    > Address 52: Door Elect, Pass. (J387)       Labels:. 8K0-959-792.clb
    >    Part No SW: 8T0 959 792 M    HW: 8T0 959 792 D
    >    Component: TSG BF        H08 1401
    >    VCID: 52E88D5D0D7683DF43-8006
    > Address 53: Parking Brake (J540)       Labels: 8K0-907-801-V1.clb
    >    Part No SW: 8K0 907 801 H    HW: 8K0 907 801 H
    >    Component: EPB Audi B8   H09 0100
    >    Revision: 00000003    Serial number: 10000000517236
    >    Shop #: WSC 00000 000 00000
    > Address 55: Headlight Range        Labels: 8K0-907-357.clb
    >    Part No: 8K5 907 357
    >    Component: Dynamische LWR  H01 0010
    >    Revision: 00000001    Serial number:
    >    Coding: 0000004
    >    Shop #: WSC 02145 785 00200
    >    VCID: 77BE1CC9065486F794-8022
    > Address 56: Radio (J503)       Labels:. 8Tx-035-1xx-56.clb
    >    Part No SW: 8T1 035 186 R    HW: 8T1 035 186 R
    >    Component: Con3 Sirius   H06 0351
    >    Revision: 00000009    Serial number: AUZ5Z6J1405030
    >    Coding: 240200020101870003D9070800
    >    VCID: 46C0A10DF13E2F7FDF-8012
    >    Subsystem 1 - Part No SW: 8T0 919 603 F    HW: 8T0 919 603 F
    >    Component: Display
    > 1 Fault Found:
    > 02635 - Tuner Not Enabled/Activated
    >             000 - -
    >              Freeze Frame:
    >                     Fault Status: 01100000
    >                     Fault Priority: 7
    >                     Fault Frequency: 1
    >                     Reset counter: 228
    >                     Mileage: 101818 km
    >                     Time Indication: 0
    >                     Date: 2010.04.13
    >                     Time: 03:27:19
    > Address 62: Door, Rear Left (J388)       Labels:. 8K0-959-795.clb
    >    Part No SW: 8T0 959 795 N    HW: 8T0 959 795 B
    >    Component: TSG HL        H06 1401
    >    Coding: 010C03204000210001
    >    VCID: 56E0714D219E9FFFAF-8002
    > Address 72: Door, Rear Right (J389)       Labels:. 8K0-959-794.clb
    >    Component: TSG HR        H06 1401
    > Address 77: Telephone        Labels: 8P0-862-335.lbl
    >    Part No SW: 8T0 862 336 E    HW: 8T0 862 336 E
    >    Component: FSE_256x BT     H42 0650
    >    Revision: 00000000    Serial number: 00000005081127
    >    Coding: 0010370
    >    Shop #: WSC 02335 785 00200
    >    VCID: 3D32CEE164E86CA78E-8068
    > End----(Elapsed Time: 01:32, VBatt start/end: 11.7V/11.6V. VIgn 11.7V)-----
    Hi and welcome.
    It might be helpful if you showed people what's in those channels currently.
    Apr 2015
    yes of course
    here is coding riht now in the 46 modul
    195 5251
    196 5283
    197 5124
    198 5156
    199 0
    200 32
    201 51202
    202 32
    203 73
    204 105
    205 13
    206 45
    207 12
    208 44
    209 12
    210 44
  4. Likes Uwe, Dana liked this post
    Apr 2015
    As I told yesterday I need coding for yellow bulbs in back lights (indicator lights)
    When I get ROW coding , I make that stop lights do not flashing any more and it is ok now, but I do not have indicator lights in led technik so I need coding for indicators with bulbs
    with best regards Dalibor BOWELDD
    United States
    I don't believe I can assist but I'm sure someone here can provide you with the RoW pre-facelift factory values.
    For instance, rlarsen has numerous posts related to BCM2 MLB based tail lights but sadly his older tinypic photo links are dead. You might try posting a Request in the Reference Scans and Maps of Non-Broken Cars section like this guy with Avant request which resulted in the needed info.
  7. Likes Uwe liked this post
