Results 1 to 5 of 5
Thread: Audi A6 2013 Steering Wheel Issue
    Verified VCDS-User
    Aug 2018
    Romania
    Hello there,
    A friend of mine just made a conversion from RHD to LHD for an AUDI A6 2013 but he got an issue with the steering wheel.
    After the conversion was finished the steering wheel is RED and i receive the errors mention in the scanning below.
    I mention that the steering rack was replaced with another one from LHD car with the same code part number.
    Anyone has an idea how to solve this?
    Monday,16,March,2020,19:57:07:32554
    VCDS Version: 19.6.2.2 (x64)  HEX-NET CB: 0.4508.4
    Workshop Code: 022 21992 002029
    VIN: WAUZZZ4G2DN023763   License Plate: A6_2013
    Mileage: 227521km-141374mi   Repair Order:
    Chassis Type: 4G-AU57 (4G0)
    Scan: 01 02 03 05 08 09 10 15 16 17 19 3B 42 44 46 47 52 53 55 56
              5F 62 72
    VIN: WAUZZZ4G2DN023763   Mileage: 227521km-141374miles
    17-Instruments -- Status: Malfunction 0110
    Address 01: Engine (J623-CGLC)       Labels:. 03L-906-018-CGL.clb
       Part No SW: 03L 906 018 LB    HW: 03L 906 018 JL
       Component: R4 2.0l TDI   H25 9978
       Revision: 45H25---
       Coding: 0A034012242401080000
       Shop #: WSC 33913 001 1048576
       ASAM Dataset: EV_ECM20TDI01103L906018LB 003012
       ROD: EV_ECM20TDI01103L906018HA.rod
       VCID: 75A21432D4BE1CE786-8020
              U1113 00 [039] - -
                        Mileage: 227521 km
                        Date: 2020.02.20
                        Time: 02:48:27
                        Coolant temperature: 78 °C
                        Intake air temperature: 25 °C
                        Voltage terminal 30: 12.400 V
                        Cruise Control System (CCS): switch position-Bits 0-7: 129
                        Cruise Control System (CCS): status-Bits 0-7: 44
                        Cruise control switch-off: irreversible-Bits 0-7: 255
                        Cruise control switch-off: reversible-Bits 0-7: 255
                        Cruise control switch-off: irreversible w. brake intervention-Bits 0-7: 0
              U1113 00 [039] - -
                        Mileage: 227521 km
                        Date: 2020.02.20
                        Time: 02:48:27
    Address 02: Auto Trans (J217)       Labels:| 0AW-927-156.clb
       Part No SW: 4G0 927 155 T    HW: 0AW 927 156 K
       Component: 0AW 20TDI RdW H04 0005
       Revision: --H04---    Serial number: 0000000739
       Coding: 000001
       ASAM Dataset: EV_TCMVL381 A02430
       ROD: EV_TCMVL381.rod
       VCID: 3C34C116B7148DAFB9-8068
       Coding: 06A187016085E180DB00
       VCID: 3620D33E893857FF4F-8062
    0697 - Function Restriction due to Faults in Other Modules
              U1113 00 [009] - -
              [SCL_EPS_Lenkmoment_Error]
                        Reset counter: 238
                        Mileage: 227521 km
                        Date: 2020.02.20
                        Time: 02:48:26
                        VzRef: 00
                        Bit Info 1: 00
                        Bit Info 2: 02
                        Bit Info 3: 02
                        Bit Info 4: 1F
                        F-Path: 02
                        F-Type: 07
                        Uz: A0
    0788 - Control Module Incorrectly Coded
              U1014 00 [137] - -
              [VarECUDSRVariantCodingIncorrect]
                        Reset counter: 238
                        Mileage: 227521 km
                        Date: 2020.02.20
                        Time: 03:04:08
                        VzRef: 00
                        Bit Info 1: 00
                        Bit Info 2: 0F
                        Bit Info 3: 02
                        Bit Info 4: 1F
                        F-Path: 01
                        F-Type: AA
                        Uz: A4
       Part No SW: 4H0 907 064 CN    HW: 4H0 907 064 CN
       Component: BCM2 2.0      H32 0421
       Coding: 01B83046000000000000
       VCID: 77BE1E3AC6B26EF794-8022
       Serial number: 2312000113803006
       Part No SW: 4G0 820 043 AC    HW: 4G0 820 043 AC
       Component: KLIMA 2 ZONEN H11 0070
       Serial number: 28061200111419
       Coding: 34010008A1
       ASAM Dataset: EV_AirCondiBasisUDS 002040
       VCID: 608C55667B3C894FC5-8034
    10 Faults Found:
    0021 - Motor for Fresh Air / Recirculated Air Flap
              B11AF 29 [009] - Signal Implausible
                        Reset counter: 238
                        Mileage: 227521 km
                        Date: 2020.02.20
                        Time: 03:00:19
                        Voltage terminal 30: 14.72 V
                        Outside air temperature: 6.5 °C
                        Interior temperature: 13.11 °C
                        Fresh air door motor-Act.val.: 10000
                        Fresh air door motor-Specified value: 9889
                        Fresh air door motor-Stop open: 11374
                        Fresh air door motor-Stop closed: 10000
    0035 - Motor for Recirculation Flap
              B1092 07 [009] - Mechanical Failure
                        Reset counter: 238
                        Mileage: 227521 km
                        Date: 2020.02.20
                        Time: 03:00:55
                        Voltage terminal 30: 14.50 V
                        Outside air temperature: 6.0 °C
                        Interior temperature: 13.17 °C
                        Recirculation flap motor-Act.val.: 10092
                        Recirculation flap motor-Specified value: 9894
                        Recirculation flap motor-Stop open: 10000
                        Recirculation flap motor-Stop closed: 10000
    0123 - Motor for Rear Right Temperature Flap
              B10D6 07 [009] - Mechanical Failure
                        Reset counter: 238
                        Mileage: 227521 km
                        Date: 2020.02.20
                        Time: 03:02:03
                        Voltage terminal 30: 14.70 V
                        Interior temperature: 13.18 °C
                        Rear temperature door motor-Act.val.: 10524
                        Rear temperature door motor-Specified value: 11515
                        Rear temperature door motor-Stop open: 10000
                        Rear temperature door motor-Stop closed: 10000
    0131 - Motor for Left Footwell Flap
              B10B9 07 [009] - Mechanical Failure
                        Reset counter: 238
                        Mileage: 227521 km
                        Date: 2020.02.20
                        Time: 03:02:18
                        Voltage terminal 30: 14.76 V
                        Interior temperature: 13.21 °C
                        Left footwell temperature flap motor-Act.val.: 11467
                        Left footwell temperature flap motor-Specified value: 13506
                        Left footwell temperature flap motor-Stop open: 10000
                        Left footwell temperature flap motor-Stop closed: 10000
    0133 - Motor for Left Footwell Flap
              B10B9 29 [009] - Signal Implausible
                        Reset counter: 238
                        Mileage: 227521 km
                        Date: 2020.02.20
                        Time: 03:00:19
                        Left footwell temperature flap motor-Act.val.: 11439
                        Left footwell temperature flap motor-Specified value: 11439
    0139 - Motor for Right Footwell Flap
              B10BA 07 [009] - Mechanical Failure
                        Reset counter: 238
                        Mileage: 227521 km
                        Date: 2020.02.20
                        Time: 03:00:22
                        Voltage terminal 30: 14.74 V
                        Interior temperature: 13.13 °C
                        Right footwell temperature flap motor-Act.val.: 11511
                        Right footwell temperature flap motor-Specified value: 14745
                        Right footwell temperature flap motor-Stop open: 10000
                        Right footwell temperature flap motor-Stop closed: 10000
    0141 - Motor for Right Footwell Flap
              B10BA 29 [009] - Signal Implausible
                        Reset counter: 238
                        Mileage: 227521 km
                        Date: 2020.02.20
                        Time: 03:00:19
                        Right footwell temperature flap motor-Act.val.: 10656
    0267 - Sensor for Refrigerant Pressure and Temperature
              B10C2 21 [009] - Signal Amplitude Too Low
                        Reset counter: 238
                        Mileage: 227521 km
                        Date: 2020.02.20
                        Time: 03:00:19
                        Compressor current: actual value: 0 mA
                        Temperature after evaporator: 32.24 °C
                        Engine speed: 842 /min
    0272 - No Basic Setting
              B2010 00 [009] - -
              [Basic settings not carried out]
                        Reset counter: 238
                        Mileage: 227521 km
                        Date: 2020.02.20
                        Time: 03:00:19
                        Basic setting of flap motors-Recirculation flap motor: OK
                        Basic setting of flap motors-Left center vent motor: ERROR
                        Basic setting of flap motors-Right center vent motor: ERROR
                        Basic setting of flap motors-Left footwell temperature flap motor: ERROR
                        Basic setting of flap motors-Right footwell temperature flap motor: ERROR
                        Basic setting of flap motors-Rear temperature door motor: ERROR
                        Basic setting of flap motors-Defroster flap motor: OK
                        Basic setting of flap motors-Left temperature flap positioning motor: OK
                        Basic setting of flap motors-Right temperature flap positioning motor: OK
                        Basic setting of flap motors-Fresh air door motor: OK
    0518 - Function Restriction due to Faults in Other Modules
              U1113 00 [009] - -
              [Sensor für Luftfeuchte aussen: unplausibles Signal]
                        Reset counter: 238
                        Mileage: 227521 km
                        Date: 2020.02.20
                        Time: 03:00:19
       Part No SW: 4H0 907 063 CF    HW: 4H0 907 063 F
       Revision: 20012002    Serial number: 00000001533283
       Coding: 2600201140349FE00181008300001D0C4F9CC30827090201000004606100
       Shop #: WSC 43536 002 104857
       VCID: 6E903B5EB9E82F3F47-803A
       Component: WWS57X 121106  H36 0080
       Serial number:         121119215029
       Coding: 0045F7
       Serial number: 20352359
       Coding: 02006D
       Subsystem 3 - Part No SW: 4G0 941 531 S    HW: 4G0 941 531 S
       Component: E1 - LDS  H07 0044
       Serial number: 04 12 2012  00000121
       Serial number: B8D88336000000000001
                013 - Check DTC Memory
                        Fault Status: 01101101
                        Reset counter: 238
                        Mileage: 227521 km
                        Date: 2020.02.20
                        Time: 02:54:00
    03608 - Humidity Sensor in Fresh Air Intake Duct
                014 - Defective
                        Fault Status: 01101110
                        Reset counter: 238
                        Mileage: 227521 km
                        Date: 2020.02.20
                        Time: 02:53:00
    Address 10: Park/Steer Assist (J791)       Labels:| 4H0-919-475-7X5.clb
       Part No SW: 4H0 919 475 AF    HW: 4H0 919 475 E
       Component: PARKHILFE PLA H06 0050
       Revision: --------    Serial number: 56261216800676
       Coding: 080306
       Shop #: WSC 00078 790 12345
       ASAM Dataset: EV_EPHVA2CAU57X0000 002011
       ROD: EV_EPHVA2CAU57X0000.rod
       VCID: 76A0133EC9B817FF8F-8022
    13637413 - Databus
              [Bremsensteuergerät - ESP_01.ESP_Systemstatus - Fehlerspeicher auslesen]
                        Reset counter: 238
                        Mileage: 227521 km
                        Date: 2020.02.20
                        Time: 02:48:25
    13679386 - Databus
              [Steuergerät für Lenkhilfe-J500 - LH_EPS_03. EPS_Berechneter_LW - Fehlerspeicher auslesen]
                        Reset counter: 238
                        Mileage: 227521 km
                        Date: 2020.02.20
                        Time: 02:48:25
    13679387 - Databus
              [Steuergerät für Lenkhilfe-J500 - LH_EPS_03.EPS_Lenkmoment - Fehlerspeicher auslesen]
                        Reset counter: 238
                        Mileage: 227521 km
                        Date: 2020.02.20
                        Time: 02:48:25
       Revision: --------    Serial number: 003JG0093G2P
       Coding: 30323436313230303235554A305234473053
       Serial number: 3575HRB40551E4S251L-
       Serial number: 3585HRB40551E4S24PMI
       Serial number: 3515JRB40104UH24NOU
       Serial number: 3525JRB400M4UH24NQ0W
       Serial number: 3554VRB400E4UH26B1BE
       Serial number: 3564VRB400E4UH26AGFX
    9442330 - Passenger's Belt Force Limiter Igniter
              B1014 1A [137] - Resistance Too Low
                        Mileage: 227521 km
                        Date: 2020.02.20
                        Time: 02:48:31
       Revision: 00000000    Serial number: 20120625000326
       Coding: 000034
       VCID: 302CE526635C79CF15-8064
       Component: E221 - MFL  H08 0009
       Part No SW: 4G8 920 983 C    HW: 4G8 920 983 C
       Component: TDieGb        H79 0515
       Revision: 28460207    Serial number: 658200612596035
       Coding: 33AF09000B410009010800
       ASAM Dataset: EV_RBD4K 004046
       ROD: EV_RBD4K_AU57.rod
       VCID: 3522D432943E5CE746-8060
    1048578 - No Basic Setting
              B2010 00 [009] - -
              [Steuergerät keine oder falsche Grundeinstellung / Adaption]
                        Reset counter: 238
                        Mileage: 227521 km
                        Date: 2020.02.20
                        Time: 03:01:55
       Part No SW: 4G0 907 468 AB    HW: 4G0 907 468 AA
       Component: J533--Gateway H10 0028
       Revision: --------    Serial number: 00000000574345
       Coding: 00CD074400
       ASAM Dataset: EV_GatewPkoUDS 001013
       VCID: 70AC2526ABDC39CF55-8024
       Component: J367-BDM  H07 0141
       Serial number: 00000000003790490016
       Voltage stabilizer:
       Serial number: 240412000000000005B9
    6151 - Instrument Cluster Control Module on Optical Bus
              U10C0 00 [009] - No Communication
              [Lost Communication With Instrument Panel Cluster (IPC) Control Module]
                        Reset counter: 238
                        Mileage: 227521 km
                        Date: 2020.02.20
                        Time: 03:02:14
                        Voltage terminal 30: 14.6 V
                        Voltage terminal 15: 14.7 V
                        Control Module temperature: 29 °C
                        System status: Terminal 15 on
                        Engine running: On
                        IN ZAS_Te_X: On
                        Terminal 15 status: On
                        Datenfeld: 0
       Component: SARA 3D       H02 0053
       Revision: --------    Serial number: EJ1BPA72002RYN
       ASAM Dataset: EV_SARA2 005011
       ROD: EV_SARA2.rod
       VCID: 3326EA2A9A4A42D768-8066
       Coding: 011F16004E00628002080002
       VCID: 47DEAEFAF6D2DE7724-8012
    03725 - Control Module for Seat Belt Tensioner; Left Front
                        Reset counter: 238
                        Mileage: 227521 km
                        Date: 2020.02.20
                        Time: 02:48:23
       Component: RCEPS         H36 0010
       Revision: 00001000    Serial number: 0013053094
       Coding: 101101010001
       Shop #: WSC 21992 022 02029
       ASAM Dataset: EV_RCEPS 009008
       ROD: EV_RCEPS_009.rod
       VCID: 3228EF2E65504BDF63-8066
    6291727 - Internal Control Module Memory Check Sum Error
              B2000 00 [137] - -
              [Hardware-Initialisierungsfehler]
                        Mileage: 211814 km
                        Date: 2019.10.28
                        Time: 00:00:00
                        Write only channel
              [Lenkungsendanschläge nicht angelernt]
                        Reset counter: 238
                        Mileage: 227521 km
                        Date: 2020.02.20
                        Time: 02:48:25
                        Write only channel
       Revision: 00002001    Serial number: 0179046005
       Coding: 011F062200B90000822008040001030F0000000000000000000000000000
    02199 - Bulb for Tail Light 2; Right (M50)
                012 - Electrical Fault in Circuit - MIL ON
                        Fault Status: 11101100
                        Reset counter: 238
                        Mileage: 227521 km
                        Date: 2020.02.20
                        Time: 03:00:39
       Revision: CJ007001    Serial number: 00000000061599
       VCID: 1D722C9204CEE4A7AE-8048
       Component: TSG BF        H03 0506
       VCID: 46C0A3FEF1D8C77FDF-8012
                        Reset counter: 238
                        Mileage: 227521 km
                        Date: 2020.02.20
                        Time: 02:48:23
       Part No SW: 4H0 907 801 F    HW: 4H0 907 801 A
       Component: EPB-4         H03 0013
       Revision: --------    Serial number: 00000000386325
       ROD: EV_ParkiBrake_VW51.rod
       VCID: 2B16F24A427A1A1720-807E
       Serial number: 120619-0001-027
       Coding: 112196101000A300
       ROD: EV_HeadlRegulBasic.rod
       VCID: 2C14F15647741D2F29-8078
    764928 - Left/Right Driving Switch-Over Active
              C1080 00 [009] - -
                        Reset counter: 238
                        Mileage: 227521 km
                        Date: 2020.02.20
                        Time: 02:48:26
       Part No SW: 4G0 035 056 J    HW: 4G0 035 056
       Component: Radio U STD   H60 0133
       Revision: AB001007    Serial number: 230K+0C7567516
       Coding: 010003020100000001
       Shop #: WSC 30198 264 98120
       VCID: 281C0D465B8C310FCD-807C
    6 Faults Found:
    00417 - Left Front DSP Mid-Bass Speaker (R101)
                        Reset counter: 238
                        Mileage: 227521 km
                        Date: 2020.02.20
                        Time: 02:48:25
                        Voltage: 11.90 V
    00418 - Front Right DSP Mid-Bass Speaker (R102)
                        Reset counter: 238
                        Mileage: 227521 km
                        Date: 2020.02.20
                        Time: 02:48:25
                        Voltage: 12.00 V
    02558 - Rear Left Mid-Range/Woofer Loudspeaker (R159)
                        Reset counter: 238
                        Mileage: 227521 km
                        Date: 2020.02.20
                        Time: 02:48:25
                        Voltage: 12.00 V
    02559 - Rear Right Mid-Range/Woofer Loudspeaker (R160)
                        Reset counter: 238
                        Mileage: 227521 km
                        Date: 2020.02.20
                        Time: 02:48:25
                        Voltage: 11.90 V
    02246 - Loudspeaker; Center
                        Reset counter: 238
                        Mileage: 227521 km
                        Date: 2020.02.20
                        Time: 02:48:25
                        Voltage: 11.90 V
    03405 - Bass Loudspeaker
                        Reset counter: 238
                        Mileage: 227521 km
                        Date: 2020.02.20
                        Time: 02:48:25
                        Voltage: 11.90 V
       Part No SW: 4G0 035 666 P    HW: 4G0 035 666 H
       Component: H-BN-EU       H49 1072
       Revision: --------    Serial number: 189JA0C7522687
       Coding: 050100000103E1ED07808B3E00000003E00001020000000000
       VCID: 3522D4329C3E5CE746-8060
       Subsystem 1 - Part No: 8R0 060 884 FC
       Component: EUR 2018  2601
       Subsystem 2 - Part No SW: 4G0 919 605 C    HW: 4G0 919 605 C
       Component: DU8 C7 SV  H43 0021
       Serial number: AUZ8ZDCD0009JJV
       Subsystem 3 - Part No SW: 4G1 919 610 C    HW: 4G1 919 610 C
       Serial number: 90349LL40000O
       Component: CD-Database  3638
                        Reset counter: 238
                        Mileage: 227521 km
                        Date: 2020.02.20
                        Time: 02:48:27
                        Text: KBD_FC7,TPE,M,0,0,5
       Component: TSG HL        H03 0506
       VCID: 49DAA8C2E0C6280732-801C
       Component: TSG HR        H03 0506
    End----------(Elapsed Time: 01:54, VBatt start/end: 12.7V/12.3V)-----------
  2. Likes Dana liked this post
  3. #2
    United States
    That B2000 - Internal Control Module Memory Check Sum Error [Hardware initialization error] may be due to a faulty used steering rack but I would want to firstly complete the G85 calibration in address 16:
    http://wiki.ross-tech.com/wiki/index...el_Electronics
    .. followed by the steps here:
    http://wiki.ross-tech.com/wiki/index...teering_Assist
    Another thing you may want to look at would be the G85 readings when the wheel is straight and compare the left and right lock (end-stop) positions to make sure this isn't an alignment problem.
  4. Likes Uwe liked this post
  5. #3
    Verified VCDS-User
    Aug 2018
    Romania
    i did this steps but the steering wheel it's still on red and it moves very hard .
  6. #4
    United States
    OK, in that case posting the G85 live data log for a second option couldn't hurt but you might also try removing Lane Assist from the 44 coding: 101100010001
    If that's accepted 03-ABS may allow you to clear:
    U1014 00 [137] - -
  7. Likes Uwe, Fredrick Awuor liked this post
  8. #5
    Verified VCDS-User
    Aug 2018
    Romania
    U1014 00 [137] - -
    I manage to solve it.
    I download the same firmware from erWIN and flash the firmware to 44 steeringwheel module with VCP Pro.
    After firmware flash the steering wheel go to yellow and after a quick ride the dashboard error indicator dissaper.
    Thanks for your help!
  9. Likes Uwe liked this post
