2014 Skoda Octavia vrs mk3 rear wiper
pistonhead
England
C?ID=385446
Help would like to activate the rear wiper so it parks when the ignition is switched of
Sunday,15,March,2020,16:30:50:52590
VIN: TMBKK7NE5F0130378   License Plate: HO 05 KEV
Chassis Type: NE-SK37 (5Q0)
Scan: 01 03 08 09 10 15 16 17 19 42 44 52 55 5F A5 A9
VIN: TMBKK7NE5F0130378   Mileage: 121586km-75550miles
Address 01: Engine (J623-CUPA)       Labels:. 04L-907-309-V1.clb
   Part No SW: 04L 906 021 EL    HW: 04L 907 309 D
   Component: R4 2,0L EDC   H22 7542
   Revision: 83H22---
   Coding: 11190012032501080000
   Shop #: WSC 56294 001 1048576
   ASAM Dataset: EV_ECM20TDI01104L906021EL 002008
   ROD: EV_ECM20TDI01104L906021EL_SK37.rod
   VCID: 73B3D8A77B39FE7FC47-8026
17158 - Databus
                    Mileage: 121230 km
                    Date: 2020.02.08
                    Time: 00:02:45
                    Coolant temperature: 17 °C
                    Intake air temperature: 14 °C
                    Voltage terminal 30: 11.720 V
                    Unlearning counter according OBD: 25
                    Drivetrain coordinator: brake fault status-Bits 0-7: 4
                    Drivetrain coordinator: brake function status-Bits 0-7: 0
                    Acceleration: 0.000 m/s²
          U0428 00 [032] - -
                    Mileage: 121230 km
                    Date: 2020.02.08
                    Time: 00:02:44
                    Intake air temperature: 13 °C
                    Voltage terminal 30: 11.420 V
   Part No SW: 3Q0 907 379 C    HW: 3Q0 907 379 C
   Component: ESC           H32 0384
   Revision: 00000000    Serial number: 63154000002520
   Coding: 1C0793915423096C007A060741CB2938C92A9000608294F400630070C009
   Shop #: WSC 73430 031 00063
   ASAM Dataset: EV_Brake1UDSContiMK100ESP 034024
   ROD: EV_Brake1UDSContiMK100ESP_034_SK37.rod
   VCID: 3A2D35831CD34F37C71-806E
0297 - Steering angle sensor
          B1168 16 [008] - Voltage Too Low
                    Reset counter: 117
                    Mileage: 121230 km
                    Date: 2020.02.08
                    Time: 00:02:45
16401 - Tire Pressure Warning
          C102D 00 [008] - -
                    Reset counter: 202
                    Mileage: 114436 km
                    Date: 2019.05.16
                    Time: 17:24:03
16412 - Display for Tire Pressure Monitoring
                    Reset counter: 117
                    Mileage: 121230 km
                    Date: 2020.02.08
                    Time: 00:02:55
16413 - Display for Tire Pressure Monitoring
                    Reset counter: 117
                    Mileage: 121230 km
                    Date: 2020.02.08
                    Time: 00:02:55
   Part No SW: 5E0 907 044 L    HW: 5E0 907 044 L
   Component: Climatronic   H03 0907
   Revision: 00001K06
   Coding: 02110104000100011005004000101000
   VCID: 2E0509D3D09B93976B9-807A
328197 - Motor for Right Temperature Flap
          B108D 54 [009] - Missing Calibration / Basic Setting
                    Reset counter: 85
                    Mileage: 121485 km
                    Date: 2020.03.06
                    Time: 16:12:10
                    Voltage terminal 30: 11.3 V
                    Outside air temperature: 10.0 °C
                    Interior temperature: 24.8 °C
                    Right temperature flap: actual value: 194
                    Right temperature flap: actual value: 96.5 %
                    Right temperature flap: specified value: 174
   Component: BCM MQBAB H   H18 0137
   Serial number: 01011431101305
   Coding: 0F500B46C2C722FB07A04082B11C07280008000000000000000000000000
   Shop #: WSC 73430 790 00218
   ROD: EV_BCMBOSCH_013.rod
   VCID: 0059876B3A8FD5E7C95-8054
   Subsystem 1 - Part No SW: 5E2 955 119     HW: 5E2 955 119   Labels: 5QX-955-119-V1.CLB
   Component: WWS371 141108  041 0570
   Serial number:         141111004836
   Coding: 0E4DFD
   Component: RLHS  037 0059
   Serial number: S5Y14M11D17H17M55S09
   Coding: 068885
   Subsystem 3 - Part No SW: 5Q0 951 171     HW: 5Q0 951 171
   Serial number: 000000000ZY1424532M4
   Serial number: 00000000000060744825
   Sun Roof:
   Subsystem 5 - Part No SW: 5E9 959 591     HW: 7P0 959 591 B
   Component: J245 PS24.011  H01 0008
   Serial number:     WOO3352534%
   Coding: 991800
   Roof Blind:
   Subsystem 6 - Part No SW: 5E9 959 591 A    HW: 7P0 959 591 C
   Component: J394 PS24.011  H01 0008
   Serial number:     WOO3374559A
   Coding: 991800
565764 - LED Light Bar
          B1664 31 [009] - No Signal
                    Reset counter: 85
                    Mileage: 121485 km
                    Date: 2020.03.06
                    Time: 16:15:54
   Part No SW: 5Q0 919 283 D    HW: 5Q0 919 283
   Component: PARKHILFE 4K  H10 0048
   Revision: --------    Serial number: 39231431801231
   Coding: 0001050001
13637426 - Databus
                    Reset counter: 117
                    Mileage: 121230 km
                    Date: 2020.02.08
                    Time: 00:02:46
   Part No SW: 3Q0 959 655 AC    HW: 3Q0 959 655 AC
   Component: Airbag VW20   012 0200
   Revision: --------    Serial number: 003P4PPP0QY
   Coding: 98CCC000000000005C5400CC008800000065
   ROD: EV_AirbaVW20TS6VW48X.rod
   VCID: 7F5B04974771AA1FB0F-802A
   Subsystem 1 - Part No SW: -----------    HW: 454 000 711 14
   Serial number: 3576U00000020730B11X
   Subsystem 2 - Part No SW: -----------    HW: 454 000 711 14
   Serial number: 3586U000000DCA5D211N
   Subsystem 3 - Part No SW: -----------    HW: 454 800 211 14
   Serial number: 3516R7E011805000000Z
   Subsystem 4 - Part No SW: -----------    HW: 454 800 711 14
   Serial number: 3526RF06E2005000000%
   Subsystem 5 - Part No SW: -----------    HW: 454 800 810 14
   Serial number: 3556VA0B0D0040000002
   Part No SW: 5Q0 953 507 AC    HW: 5Q0 953 549
   Revision: --------    Serial number: 16111404400426
   Coding: 1400
   VCID: 77ABECB76F41925FF8F-8022
   Part No SW: 5E0 920 947     HW: 5E0 920 947
   Component: KOMBI         204 4290
   Coding: 27AD09006984A60001087A021000000000000000
   Shop #: WSC 73430 031 00218
   VCID: 698FBACF29F534AF7EB-803C
   Part No SW: 5Q0 907 530 AC    HW: 5Q0 907 530 F
   Component: GW MQB High   128 1204
   Revision: --------    Serial number: 0002728356
   Coding: 030100040F087300FF00026A080F00010001050000000000000000000000
   ASAM Dataset: EV_GatewLear 011020
   ROD: EV_GatewLear_011.rod
   VCID: 72BDDDA30423F777CF1-8026
   Subsystem 2 - Part No SW: 5E0 919 719 A    HW: 5E0 919 719 A
   Component: E221__MFL-PR6  H05 0130
   Serial number: 000000000A0865221014
   Serial number: 2916174903
   Part No SW: 5Q4 959 393 B    HW: 5Q4 959 393 B
   Component: TSG FS        009 0014
   Serial number: 0000126188480
   Coding: 001E00208001040000001100
   VCID: 42DD4D63740307F79F1-8016
   Serial number: 00000000000004334680
   Coding: 1D0200
   Coding: 9103
   VCID: 372B2CB72FC1525F38F-8062
   Part No SW: 5Q4 959 392 B    HW: 5Q4 959 392 B
   Component: TSG BFS       009 0014
   Serial number: 0000125715901
   Coding: 001E00208C01040000001100
   VCID: 41DF426F71051CEF86B-8014
   Serial number: 00000000000004345909
   Coding: 050200
   Coding: 03DE02003F000000
   Shop #: WSC 73430 790 00063
   VCID: 40D9476B7A0F15E7895-8014
   Coding: 3E0000
   Coding: 3E0000
Address 5F: Information Electr. (J794)       Labels:| 5E0-035-MIB-STD1.clb
   Part No SW: 5E0 035 874 A    HW: 5E0 035 874 A
   Component: MU-S-ND-ER    041 0435
   Serial number: S7F01611140066
   Coding: 03735201FF0000001111120100A800002F0001860100010046
   ROD: EV_MUStd4CPASE_VW37.rod
   VCID: 2615F1F3F86BDBD7939-8072
   Subsystem 1 - Part No SW: 5E0 919 605 D    HW: 5E0 919 605 D
   Component: ABT_Std_Nav  H60 0030
   Serial number: SKZ8Z9PT300RRS
   Subsystem 2 - Part No SW: 5E0 051 236 G    HW: -----------
   Component:  ECE 2019  --- 0078
          B1066 13 [009] - Open Circuit
          [Hochtonlautsprecher Kanal 4: Unterbrechung]
                    Reset counter: 217
                    Mileage: 117111 km
                    Date: 2019.08.03
                    Time: 11:57:22
                    Voltage terminal 30: 11.7 V
Address A5: Frt Sens. Drv. Assist (R242)       Labels:| 5Q0-980-653.clb
   Part No SW: 5Q0 980 653 F    HW: 5Q0 980 653
   Component: MQB_MFK       H06 0052
   Serial number: 00000246882
   Coding: 0101010001030304000400000000010100
   ROD: EV_MFKBoschAU370.rod
   VCID: 3B23308713E9763FDC7-806E
6553600 - Databus
          [LH_EPS_03_BERECHN_LW_SIG_FAILURE]
                    Reset counter: 117
                    Mileage: 121230 km
                    Date: 2020.02.08
                    Time: 00:02:48
                    Control Module temperature: 28 °C
                    Outside air temperature: 9.5 °C
                    Vehicle speed: 0.00 km/h
                    Voltage terminal 15: 11.7 V
                    Terminal 15 on: 4.4 s
   Part No SW: 5E0 907 159     HW: 4H0 907 159 A
   Component: SAS-GEN 2     H06 0001
   Serial number: 140916200503
End----------(Elapsed Time: 01:41, VBatt start/end: 12.4V/12.4V)-----------
   Revision: 83H22---
17158 - Databus
                    Mileage: 121230 km
                    Date: 2020.02.08
                    Time: 00:02:45
          U0428 00 [032] - -
                    Mileage: 121230 km
                    Date: 2020.02.08
                    Time: 00:02:44
                    Reset counter: 117
                    Mileage: 121230 km
                    Date: 2020.02.08
                    Time: 00:02:45
          C102D 00 [008] - -
                    Reset counter: 202
                    Mileage: 114436 km
                    Date: 2019.05.16
                    Time: 17:24:03
                    Reset counter: 117
                    Mileage: 121230 km
                    Date: 2020.02.08
                    Time: 00:02:55
                    Reset counter: 117
                    Mileage: 121230 km
                    Date: 2020.02.08
                    Time: 00:02:55
   Revision: 00001K06
                    Reset counter: 85
                    Mileage: 121485 km
                    Date: 2020.03.06
                    Time: 16:12:10
   Coding: 0E4DFD
   Coding: 068885
   Sun Roof:
   Coding: 991800
   Roof Blind:
   Coding: 991800
                    Reset counter: 85
                    Mileage: 121485 km
                    Date: 2020.03.06
                    Time: 16:15:54
   Coding: 0001050001
13637426 - Databus
                    Reset counter: 117
                    Mileage: 121230 km
                    Date: 2020.02.08
                    Time: 00:02:46
   Coding: 1400
   Coding: 1D0200
   Coding: 9103
   Coding: 050200
   Coding: 3E0000
   Coding: 3E0000
                    Reset counter: 217
                    Mileage: 117111 km
                    Date: 2019.08.03
                    Time: 11:57:22
6553600 - Databus
                    Reset counter: 117
                    Mileage: 121230 km
                    Date: 2020.02.08
                    Time: 00:02:48
   Revision: 83H22---
17158 - Databus
                    Mileage: 121230 km
                    Date: 2020.02.08
                    Time: 00:02:45
          U0428 00 [032] - -
                    Mileage: 121230 km
                    Date: 2020.02.08
                    Time: 00:02:44
                    Reset counter: 117
                    Mileage: 121230 km
                    Date: 2020.02.08
                    Time: 00:02:45
          C102D 00 [008] - -
                    Reset counter: 202
                    Mileage: 114436 km
                    Date: 2019.05.16
                    Time: 17:24:03
                    Reset counter: 117
                    Mileage: 121230 km
                    Date: 2020.02.08
                    Time: 00:02:55
                    Reset counter: 117
                    Mileage: 121230 km
                    Date: 2020.02.08
                    Time: 00:02:55
   Revision: 00001K06
                    Reset counter: 85
                    Mileage: 121485 km
                    Date: 2020.03.06
                    Time: 16:12:10
   Coding: 0E4DFD
   Coding: 068885
   Sun Roof:
   Coding: 991800
   Roof Blind:
   Coding: 991800
                    Reset counter: 85
                    Mileage: 121485 km
                    Date: 2020.03.06
                    Time: 16:15:54
   Coding: 0001050001
13637426 - Databus
                    Reset counter: 117
                    Mileage: 121230 km
                    Date: 2020.02.08
                    Time: 00:02:46
   Coding: 1400
   Coding: 1D0200
   Coding: 9103
   Coding: 050200
   Coding: 3E0000
   Coding: 3E0000
                    Reset counter: 217
                    Mileage: 117111 km
                    Date: 2019.08.03
                    Time: 11:57:22
6553600 - Databus
                    Reset counter: 117
                    Mileage: 121230 km
                    Date: 2020.02.08
                    Time: 00:02:48
Moving to Tweaks.
DV52
C?ID=194404
^^^^ try changing IDE02711-ENG114946-Rear Window Wiper-Komfortwischen Heck > active in the BCM
pistonhead
England
C?ID=385446
I am sure I’ve seen that & it was active but I will check again thanks
TBAx
C?ID=287144
Something I always fail to understand: does parking mean it stops right where it is or does parking mean it goes the full way to it's normal inactive position.
I have noticed, that the second variant is normally done on my O3 RS, but sometimes it fails and just stops the wiper in-place. Nothing to bad, so I never checked, why this possibly happens.
langers2k
C?ID=224085
Parking in this context means it continues moving until it's in the normal resting position rather than stopping mid stroke.
pistonhead
England
C?ID=385446
I have checked the setting for Rear window wiper komfortwischen Heck & it is set to active
Looking at the list in rear wiper the only one not active is
Kein automatisches Abparken (No automatic park ) any ides anyone
DV52
C?ID=194404
pistonhead: my apology - my bad: I understood your request to be the different form of "parking" (I also share TBAx's confusion about the term).
So you want the rear wipers to park when Terminal 15 is turned-off while the wiper bade is mid sweep? I'm almost positive (but more than happy to be advised otherwise) that this is not possible on MQB platform vehicles because the rear wiper just ain't that smart!
This same function can be implemented (and often is as a factory setting) on the front wiper. But the front wiper motor is controlled by the WWS module which is a LIN slave to the BCM (see the 1st LIN module that's reported on the BCM in your autoscan). The WWS module has a long code facility - the particular software switch for the T15 parking function is Byte 2, Bit 2 (see below)
In contrast and at least in MQB platform vehicles like your MY14 Skoda, the rear wiper motor is directly wired to the BCM - so it's a dumb-slave to the hex09 module. Alas, this strongly suggests that it just isn't responsive to the state of T15 signals (I think)
pistonhead
England
C?ID=385446
Hi Don thanks for that it certainly looks like the rear wiper cannot be program to park
