Results 11 to 20 of 39
Thread: Autoscan hangs and 14.2.3 won't connect
    It's the same. This time the car was in the list first time, so that may have been user failure.
    On the autoscan, it appears to miss the ABS controller altogether, it goes straight from the transmission (02) to the Kessy (05), and fails to communicate with the Kessy. If I manually look at controller 05, the initial interrogation appears successful, it knows what the controller is, but it can't get any further. The comm status shows IC=1 TE=0 RE=0.
  2. #12
    OK, sounds like something either in the ABS controller or the Kessy is messing up that scan. It would be nice know which one. With the PC-based VCDS you can edit the AutoScan.txt file and create a custom entry for your car. Copy the line for the Phaeton, and try removing 03 and/or 05 from it. If eliminating one module form the list of modules to be scanned gets you through the rest of the car, then we'd know which module to try to get in here, and getting one module is usually a lot easier than getting a whole car, especially when the car is kinda rare.
    Quote Originally Posted by invisiblewave View Post
    Still only works in infrastructure mode with my Acer Aspire.
    Interestingly enough, the eeePC that won't find any HEX-NETs in AP mode also has an older Atheros card in it. There seems to be something about the way the way the WiFi module in the HEX-NET does AP mode that's incompatible with the Windows drivers for those old Atheros cards.
  4. #14
    It's not just those two controllers, it's everything I've tried after controller 02. It's strange, love.
  5. #15
    Understood, but our thought is that something happening with one of those modules is crashing one of the threads in the HEX-NET. Verifying that and being able to identify with certainty which module it is would be a big help.
    Ok, that doesn't seem to be the case. It successfully reads the first two controllers, then won't read any others. On the third controller, it runs quickly but then doesn't write anything to the log for that controller. On the next one, it takes much longer, fails to communicate, but writes the header part to the log. I tried deleting the ABS (03) controller first and it stopped working on the Kessy (05). I then removed the Kessy and it stopped working on the seat memory (06).
    In summary: After the first two controllers, the log skips one controller altogether, then for the following controllers displays the Address, VCID, then lists "no faults found or DTCs not supported by controller or a communication error occurred".
  7. #17
    The only three controllers I can find that I can access at all are 01, 02 and 03. If I run autoscan on just those three, it does 1 & 2 fine but doesn't write 03 to the log, nor does it display the main controller page for 03 just before the log pops up.
    I tried changing the sequence to 01,03,02 and that did the full (abbreviated) scan. If I then put 05 in there before 02, it runs the full (abbreviated) scan but logs the communications error on 05.
    If I run 01,02,05,03, it runs to the end of the scan but doesn't log 05 at all.
  8. #18
    Did you save that scan? If so, would you mind posting it?
    I didn't, but it was pretty straightforward. It looked just like it would if 05 wasn't in the list. Do you want me to run it again?
  10. #20
    Here it is:
    Tuesday,15,April,2014,15:21:47:58155
    VCDS Version: 14.4.0.3
    Data version: 20140411
    VIN: License Plate:
    Chassis Type: 3D (3D - VW Phaeton Test (2002 > 2006))
    Scan: 01 02 05 03
    VIN:
    Address 01: Engine Labels: 4D0-907-560-BGH.lbl
    Part No SW: 4D0 907 560 CS HW: 8E0 907 560
    Component: 4.2L V8/5V G 0040
    Coding: 0007873
    Shop #: WSC 25019 444 00532
    VCID: F9BAACB5B33AF9F387-5184
    Address 02: Auto Trans Labels: 09L-927-760.lbl
    Part No SW: 09L 927 760 C HW: GS1 9.0 4.1
    Component: AG6 09L 4,2L V8 1003
    Coding: 0000102
    Shop #: WSC 01065 000 00000
    VCID: B73E6A8DC5AE2F8331-5184
    Address 03: ABS Brakes Labels: 3D0-614-517.lbl
    Part No: 3D0 614 517 AK
    Component: ESP 5.7 allrad H35 0047
    Coding: 0008376
    Shop #: WSC 25019 000 00000
    VCID: EB9686FDC9665B6305-5184
    End ---------------------------------------------------------------------
