Results 1 to 2 of 2
Thread: Audi A3 8V PLATE LIGHT AND LEAVING HOME WITHOUT LIGHT SENSOR
    Sep 2019
    Croatia
    Hello all,
    I don't have AUTO lights and rain light sensor so I wanted to activate leaving home lights like this:
    I have put rear parking lights function C as interior lights. ( I believe their name is HLC10 and HRA65)
    and changed their dimming from 0 to 100.
    I also did that to front fog lights(RB5 and LB45) and it works on unlocking, but the problem is that they work always. Fog lights work on 0, on parking lights only and on full lights mode on.
    Is it possible to just have both front(not working) and rear parking lights(did that, activated) to work on unlocking with this method?
    Also, rear plate lights don't work on ignition on, they only work while the engine is working. Is it possible to make them work with ignition and engine running?
    Does anyone know which light is this one? Leuchte15AL RB44?
    And does anyone have a full list of all names for all the lights?
    Auto:scan:
    Thursday,23,January,2020,12:52:56:60999
    VIN: WAUZZZ8V8FA******   License Plate: A3NAS
    Mileage: 119935km-74524mi   Repair Order:
    Chassis Type: 8V-AU37 (5Q0)
    Scan: 01 03 08 09 10 15 16 17 19 42 44 52 55 5F
    VIN: WAUZZZ8V8FA******   Mileage: 119935km-74524miles
    Address 01: Engine (J623-CRKB)       Labels:. 04L-907-309-V1.clb
       Part No SW: 04L 906 021 FD    HW: 04L 907 309 E
       Component: R4 1.6l TDI   H22 9231
       Revision: 86H22---
       Coding: 02190012032401092000
       Shop #: WSC 45164 002 1048576
       ASAM Dataset: EV_ECM16TDI01104L906021FD 002009
       ROD: EV_ECM16TDI01104L906021FD.rod
       VCID: 6C803F8F0605131705F-8038
       Part No SW: 3Q0 907 379 F    HW: 3Q0 907 379 F
       Component: ESC           H42 0609
       Revision: 00000000    Serial number: 60405000001914
       Coding: 12F162A224230A6E0177060541C62548462450806082A4F2024100788208
       Shop #: WSC 06314 790 00021
       ASAM Dataset: EV_Brake1UDSContiMK100IPB 034027
       ROD: EV_Brake1UDSContiMK100IPB_034_AU37.rod
       VCID: 3D26C2CB2DFF4A9FE21-8068
    16401 - Tire Pressure Warning
              C102D 00 [009] - -
                        Reset counter: 168
                        Mileage: 119749 km
                        Date: 2020.01.21
                        Time: 16:12:11
    Address 08: Auto HVAC (E87)       Labels:| 8V0-820-047.clb
       Part No SW: 8V0 820 047 E    HW: 8V0 820 047 E
       Component: AC Manuell el H11 0052
       Revision: 20021000    Serial number: 00000000124514
       Coding: 03000104002000001000000000000000
       ASAM Dataset: EV_AirCondiFrontManAU37X 008018
       ROD: EV_AirCondiFrontManAU37X.rod
       VCID: 3828D3DF02DD6FB7317-806C
       Component: BCM MQBAB H   H18 0137
       Serial number: 01011504101113
       Coding: 04040A46C241205D43D44004000C07080000000000000000000000000000
       ROD: EV_BCMBOSCH_013.rod
       VCID: 00587B3F1A8DE777C97-8054
       Subsystem 1 - Part No SW: 8V1 955 119 A    HW: 8V1 955 119   Labels: 5QX-955-119-V1.CLB
       Component: WWS370 150126  042 0580
       Serial number:         150203005544
       Coding: 0A47F7
       Light switch:
       Subsystem 2 - Part No SW: 8V0 941 531 AC    HW: 8V0 941 531 AC
       Serial number: 27 09 2014  00000455
       Part No SW: 5Q0 919 283 E    HW: 5Q0 919 283
       Component: PARKHILFE 4K  H10 0051
       Revision: --------    Serial number: 39231504105168
       Coding: 0000050001
       VCID: 3B22CCD333EB44AFDC5-806E
       Serial number: 003M2R0ABL4E
       Coding: 98CCC0000C0000005C540000004800000065
       ROD: EV_AirbaVW20SMEVW37X.rod
       VCID: 4BC29C13634BF42F6C5-801E
       Subsystem 1 - Part No SW: -----------    HW: 480 001 102 15
       Serial number: 357670000002112D921G
       Subsystem 2 - Part No SW: -----------    HW: 480 001 102 15
       Serial number: 35867000000C012D921Q
       Subsystem 3 - Part No SW: -----------    HW: 480 400 502 15
       Serial number: 3516502B9196FF52F16V
       Subsystem 4 - Part No SW: -----------    HW: 480 400 502 15
       Serial number: 3526502B1196FF53528I
       Subsystem 5 - Part No SW: -----------    HW: 480 402 301 15
       Serial number: 355650299192BC74A1FU
       Pedestrian Protection Driver:
       Subsystem 6 - Part No SW: -----------    HW: 480 402 801 15
       Serial number: 2286502A9192BC75529L
       Subsystem 7 - Part No SW: -----------    HW: 480 402 801 15
       Serial number: 2296502A9192BC7263BN
       Pedestrian Protection Center:
       Subsystem 8 - Part No SW: -----------    HW: 480 402 801 15
       Serial number: 2306502A5192BC74E05C
       Part No SW: 8V0 953 521 BP    HW: 5Q0 953 549 C
       Revision: --------    Serial number: 14021504400167
       Coding: A408
       ROD: EV_SMLSKLOMQB_010_AU37.rod
       VCID: 094E661B29B7A63F9E9-805C
       Part No SW: 8V0 920 860 H    HW: 8V0 920 860 H
       Component: KOMBI         H01 4292
       Coding: 07A10A002B800008000068001000000000000000
       VCID: 3FDAB8C327F3588FF0D-806A
       Part No SW: 5Q0 907 530 AC    HW: 5Q0 907 530 F
       Component: GW MQB High   128 1204
       Revision: --------    Serial number: 0003103923
       Coding: 030000041F0876005B000248080000000001010000000000000000000000
       ASAM Dataset: EV_GatewLear 011020
       ROD: EV_GatewLear_011.rod
       VCID: 72BC21F72421C5E7CF3-8026
       Subsystem 2 - Part No SW: 5Q0 915 181 H    HW: 5Q0 915 181 H
       Component: J367-BDMConti  H02 1011
       Serial number: 74185703001501194092
       Part No SW: 5Q0 959 393 D    HW: 5Q0 959 393 B
       Serial number: 240115BAI01879
       Coding: 00100F204100040000001002
       VCID: 40D8BB3F5A0D2777897-8014
       Serial number: 00000000000005170596
       Coding: 110000
       Component: EPS_MQB_ZFLS  125 1061
       Coding: 0103
       VCID: 43D2B4334B1B3C6F945-8016
       Part No SW: 5Q0 959 392 D    HW: 5Q0 959 392 B
       Serial number: 250115BAO19798
       Coding: 001007204100040000001002
       Serial number: 00000000000005175838
       Coding: 090000
       Coding: 0188000001000000
       VCID: 75B61AEB554FD2DFEA1-8020
       Part No SW: 8V0 035 864 B    HW: 8V0 035 864 B
       Component: MU-S-N-ER     041 0420
       Serial number: A3F00902151086
       Coding: 01730301FF00000021110001000A00002F0004040100010004
       ASAM Dataset: EV_MUStd4CPASE 002018
       ROD: EV_MUStd4CPASE_VW37.rod
       VCID: 3A2CC9D73CD17DA7C73-806E
       Subsystem 1 - Part No SW: 8V0 919 866 C    HW: -----------
       Component:  ECE 2015  --- 0045
       Subsystem 2 - Part No SW: 8V0 919 603 C    HW: 8V0 919 603 C
       Component: DU Std  H49 0014
       Serial number: AUZ8Z9EY3096NE
       Multimedia Operating Unit:
       Subsystem 3 - Part No SW: 8V0 919 614 P    HW: 8V0 919 614 P
       Serial number: C1000001121400020245
    End----------(Elapsed Time: 01:03, VBatt start/end: 12.0V/12.0V)-----------
    AdMap of 09:
    HTML Code:
    https://easyupload.io/5rquic
    ib97: Hi.
    Not really sure if I understand your problem correctly - so let's proceed quietly together through the contents of your post:
    Quote Originally Posted by ib97 View Post
    Hello all,
    When you used the inner-light/Innenlicht Leuchte-command, you invoked the facility in the A3 that operates the overhead light in the cabin. So whilst the end effect may look "Leaving-Home" like, it really isn't the same as true LH. Because of the nature of the Leuchte function that you used, the front fogs will stay illuminated for the same time that the cabin dome lights are switched-on regardless the position of the rotary light switch (i.e. the LDS)
    The Leuchte-set for the number plate light is Leuchte25KZL HA59. According to your admap, this Leuchte-set will illuminate whenever the following lights are enabled:
    • Parking Lights (either, together with the main-beam, or alone)
    • Coming Home
    The number plate light as currently programmed doesn't care about the state of the engine running, it only illuminates when the Parking lights are switched-on, or CH function is envoked
    It's a cliche, but the German propensity for fine detail and strict control is alive and well in the naming convention for Leuchte-sets. For Leuchte15AL RB44, the B44 means pin#44 on socket B of the BCM. If I look at the WD for my A3, BCM pin T46b /44 is wired to V48 (Left headlight range control motor) and V49 (Right headlight range control motor)
    I'm a firm believer in allowing the person asking a question to provide the answer to that question: hint- once you know the pin/socket assignment rule for the name of Leuchte-sets, it's a relatively straight-forward task to generate a full list which identifies the light positions: Simply use the PIN-OUT for the BCM, or refer to the WD - easy peazy, lemon squeezy!!!
  3. Likes PetrolDave, Uwe liked this post
