Page 2 of 5 FirstFirst 1234 ... LastLast
Results 11 to 20 of 43
Thread: Audi S3 8v facelift 2017 LED headlights problem
    ^^^^ that's great - the long code strings are the same, the module types are the same and only 4 x different channel settings!!!!
    So..........I'll ask the obvious question: what happens to your autoscan DTC s if you plug-in the old hex55 channel settings into your new hex55 module and clear the errors ?
  2. #12
    Mar 2020
    How do I do that?
  3. #13
    hmm...... that's a fairly fundamental question for a VCDS user that's swapping modules to ask!
    Try this:
    1. Connect the VCDS cable to the OBD port - connect to your laptop and fire-up the software
    2. On the main VCDS screen click on select under Select Control Module
    3. On the Select Control Module screen, click on 55-Xenon Range
    4. On the Open Controller screen, click on Security Access-16
    5. Enter the magic number 20103 into the Enter security access key box and press Do it!
    6. Back in the Open Controller screen, click on Adaptation - 10
    7. You will then be presented with a screen like below - not the same entries, but the same layout
    8. In the box that I have labelled "1. Enter" type the Tag number for the 1st channel in your list and then select the down-arrow that I have identified as "2."
    9. Select the correct adaptation channel from your list
    10. You will then be presented with a screen like below - not the same entries, but the same layout
    11. Enter the channel setting number from your old module into the New Value box and press Do it!
    12. After acknowledging the prompts, you should see a screen that confirms the changed setting
    13. Repeat for each of the other channels and exit the module screen
    Then open the autoscan screen- I like to run an autoscan before clearing DTC s because I then have a "before" record on file.
    Press the Clear all DTCs button then run an autoscan
    PS: while I still believe that it's worthwhile trying to make the changes to your hex55 module- I'm a tad concerned by the specificity of the numbers in the adaptation channels in your list. I've not made these changes - but the T15 voltage for example, is specified to 3 x decimal places! This might be a number that is generated by a calibration process - perhaps?
  4. Likes Uwe, Bruce, Fredrick Awuor liked this post
  5. #14
    Mar 2020
    when you say Tag numbers I assume you mean the IDE numbers, i.e ENG102296? sorry for being such a newb, just want to be clear because when I added the eng number I there was nothing to select in the channel pull down menu
  6. #15
    Quote Originally Posted by pauls13 View Post
    paul: I'm sorry that my explanation of this process has become so complicated for you (I can only blame my thick Australian accent and an ageing and deeply deficient intellect) - but yes, my use of the term Tag number is synonymous with the IDE (and sometimes ENG, and sometimes MAS) number.
    As for why you can't find the channels - and without intending any offense to Ross-Tech's code-cutters, the VCDS facility is a fairly basic search engine. Anything that's typed into the search box will suffice as a search vector -so you can use any part of the adaptation channel name. Like most search engines, the shorter the the search string, the more hits will be returned in the pull-down list and conversely, the opposite will be true if you increase the characters in the search box.
    But you should have confidence that if the admap for the new hex55 module has identified a particular adaptation channel, then if you correctly enter part of that adaptation channel name into the search box - you will get at least one hit returned in the pull-down list. This certainty is up there with the inevitability of death and taxes
  7. Likes Uwe liked this post
  8. #16
    Mar 2020
    Ok, so I tried all of the channel numbers in my list, and none of them came up.
  9. #17
    hmm........ I've just had a closer look at your supposed admap:
    IDE00018,Voltage terminal 15,11.756, V
    IDE02389,Ambient brightness,126, lx
    ENG103737,Left headlight leveling control value,1024.0, mm
    ENG102296,Right headlight leveling control value,1024.0, mm
    These are not adaptation channels - they appear to be blockmap values?
    What part of my explanation below was confusing ?
    At about 2:33 minutes into the video choose different options as follows:
    Under "Function", tick Adaptations
  10. Likes Fredrick Awuor, Uwe liked this post
  11. #18
    Mar 2020
    Your instructions were clear, I just clicked the wrong option, here now is the correct option. Also, I noticed that both headlight fuses were blown in the fusebox inside of the car, I have replaced them both, but it didn't fix the issue. Below is the correct admap reading and both the old and the new were the same.
    ;SW:8V0-907-357-A   HW:7P6-907-357-B ---  Headlight Range
    ;Component:MxB-ECU       001 0230, Coding:0EEE00102B230200
    ;EV_HeadlRegulAUDIMXBAU64X,005014,EV_HeadlRegulAUDIMXBAU64X_005_AU37.rod
    ;Sunday,22,March,2020,15:40:46:42802
    ;VCDS Version: Release 19.6.2 (x64)  Data version: 20200210 DS308.0
    ;VCID: 3E253C6210FDC6D7FB9-806A
    IDE01996-SFT00041-Installation list: specified installations-Light Control Left,Yes ,1
    IDE01996-SFT00057-Installation list: specified installations-Light Control Right,Yes ,1
    IDE01996-SFT00085-Installation list: specified installations-Headlight Regulation,Yes ,1
    IDE01996-SFT00214-Installation list: specified installations-Light Control Left 2,Yes ,1
    IDE01996-SFT00215-Installation list: specified installations-Light Control Right 2,Yes ,1
    IDE03641-Presentation run dynamic AFS light,active ,1
    IDE03642-Presentation mode,not active ,1
    IDE03679-Adaptive light functions,active ,1
    IDE08418-Matrix light: total dimming,100.8 ,1
    IDE09156-Matrix headlamp: function at standstill,not active ,1
    IDE09568-MAS09833-Bit pattern of individual segment activation: left headlight-LED 1,OFF ,6
    IDE09568-MAS09834-Bit pattern of individual segment activation: left headlight-LED 2,OFF ,6
    IDE09568-MAS09835-Bit pattern of individual segment activation: left headlight-LED 3,OFF ,6
    IDE09568-MAS09836-Bit pattern of individual segment activation: left headlight-LED 4,OFF ,6
    IDE09568-MAS09837-Bit pattern of individual segment activation: left headlight-LED 5,OFF ,6
    IDE09568-MAS09838-Bit pattern of individual segment activation: left headlight-LED 6,OFF ,6
    IDE09568-MAS09839-Bit pattern of individual segment activation: left headlight-LED 7,OFF ,6
    IDE09568-MAS09840-Bit pattern of individual segment activation: left headlight-LED 8,OFF ,6
    IDE09568-MAS09841-Bit pattern of individual segment activation: left headlight-LED 9,OFF ,6
    IDE09568-MAS09842-Bit pattern of individual segment activation: left headlight-LED 10,OFF ,6
    IDE09568-MAS09843-Bit pattern of individual segment activation: left headlight-LED 11,OFF ,6
    IDE09568-MAS09844-Bit pattern of individual segment activation: left headlight-LED 12,OFF ,6
    IDE09568-MAS09845-Bit pattern of individual segment activation: left headlight-LED 13,OFF ,6
    IDE09568-MAS09846-Bit pattern of individual segment activation: left headlight-LED 14,OFF ,6
    IDE09568-MAS09847-Bit pattern of individual segment activation: left headlight-LED 15,OFF ,6
    IDE09568-MAS09848-Bit pattern of individual segment activation: left headlight-LED 16,OFF ,6
    IDE09568-MAS09849-Bit pattern of individual segment activation: left headlight-LED 17,OFF ,6
    IDE09568-MAS09850-Bit pattern of individual segment activation: left headlight-LED 18,OFF ,6
    IDE09568-MAS09851-Bit pattern of individual segment activation: left headlight-LED 19,OFF ,6
    IDE09568-MAS09852-Bit pattern of individual segment activation: left headlight-LED 20,OFF ,6
    IDE09568-MAS09853-Bit pattern of individual segment activation: left headlight-LED 21,OFF ,6
    IDE09568-MAS09854-Bit pattern of individual segment activation: left headlight-LED 22,OFF ,6
    IDE09568-MAS09855-Bit pattern of individual segment activation: left headlight-LED 23,OFF ,6
    IDE09568-MAS09856-Bit pattern of individual segment activation: left headlight-LED 24,OFF ,6
    IDE09568-MAS09857-Bit pattern of individual segment activation: left headlight-LED 25,OFF ,6
    IDE09568-MAS09858-Bit pattern of individual segment activation: left headlight-LED 26,OFF ,6
    IDE09568-MAS09859-Bit pattern of individual segment activation: left headlight-LED 27,OFF ,6
    IDE09568-MAS09860-Bit pattern of individual segment activation: left headlight-LED 28,OFF ,6
    IDE09568-MAS09861-Bit pattern of individual segment activation: left headlight-LED 29,OFF ,6
    IDE09568-MAS09862-Bit pattern of individual segment activation: left headlight-LED 30,OFF ,6
    IDE09568-MAS09863-Bit pattern of individual segment activation: left headlight-LED 31,OFF ,6
    IDE09568-MAS09864-Bit pattern of individual segment activation: left headlight-LED 32,OFF ,6
    IDE09568-MAS09865-Bit pattern of individual segment activation: left headlight-LED 33,OFF ,6
    IDE09568-MAS09866-Bit pattern of individual segment activation: left headlight-LED 34,OFF ,6
    IDE09568-MAS09867-Bit pattern of individual segment activation: left headlight-LED 35,OFF ,6
    IDE09568-MAS09868-Bit pattern of individual segment activation: left headlight-LED 36,OFF ,6
    IDE09568-MAS09869-Bit pattern of individual segment activation: left headlight-LED 37,OFF ,6
    IDE09568-MAS09870-Bit pattern of individual segment activation: left headlight-LED 38,OFF ,6
    IDE09568-MAS09871-Bit pattern of individual segment activation: left headlight-LED 39,OFF ,6
    IDE09568-MAS09872-Bit pattern of individual segment activation: left headlight-LED 40,OFF ,6
    IDE09568-MAS09873-Bit pattern of individual segment activation: left headlight-LED 41,OFF ,6
    IDE09568-MAS09874-Bit pattern of individual segment activation: left headlight-LED 42,OFF ,6
    IDE09568-MAS09875-Bit pattern of individual segment activation: left headlight-LED 43,OFF ,6
    IDE09568-MAS09876-Bit pattern of individual segment activation: left headlight-LED 44,OFF ,6
    IDE09568-MAS09877-Bit pattern of individual segment activation: left headlight-LED 45,OFF ,6
    IDE09569-MAS09833-Bit pattern of individual segment activation: right headlight-LED 1,OFF ,6
    IDE09569-MAS09834-Bit pattern of individual segment activation: right headlight-LED 2,OFF ,6
    IDE09569-MAS09835-Bit pattern of individual segment activation: right headlight-LED 3,OFF ,6
    IDE09569-MAS09836-Bit pattern of individual segment activation: right headlight-LED 4,OFF ,6
    IDE09569-MAS09837-Bit pattern of individual segment activation: right headlight-LED 5,OFF ,6
    IDE09569-MAS09838-Bit pattern of individual segment activation: right headlight-LED 6,OFF ,6
    IDE09569-MAS09839-Bit pattern of individual segment activation: right headlight-LED 7,OFF ,6
    IDE09569-MAS09840-Bit pattern of individual segment activation: right headlight-LED 8,OFF ,6
    IDE09569-MAS09841-Bit pattern of individual segment activation: right headlight-LED 9,OFF ,6
    IDE09569-MAS09842-Bit pattern of individual segment activation: right headlight-LED 10,OFF ,6
    IDE09569-MAS09843-Bit pattern of individual segment activation: right headlight-LED 11,OFF ,6
    IDE09569-MAS09844-Bit pattern of individual segment activation: right headlight-LED 12,OFF ,6
    IDE09569-MAS09845-Bit pattern of individual segment activation: right headlight-LED 13,OFF ,6
    IDE09569-MAS09846-Bit pattern of individual segment activation: right headlight-LED 14,OFF ,6
    IDE09569-MAS09847-Bit pattern of individual segment activation: right headlight-LED 15,OFF ,6
    IDE09569-MAS09848-Bit pattern of individual segment activation: right headlight-LED 16,OFF ,6
    IDE09569-MAS09849-Bit pattern of individual segment activation: right headlight-LED 17,OFF ,6
    IDE09569-MAS09850-Bit pattern of individual segment activation: right headlight-LED 18,OFF ,6
    IDE09569-MAS09851-Bit pattern of individual segment activation: right headlight-LED 19,OFF ,6
    IDE09569-MAS09852-Bit pattern of individual segment activation: right headlight-LED 20,OFF ,6
    IDE09569-MAS09853-Bit pattern of individual segment activation: right headlight-LED 21,OFF ,6
    IDE09569-MAS09854-Bit pattern of individual segment activation: right headlight-LED 22,OFF ,6
    IDE09569-MAS09855-Bit pattern of individual segment activation: right headlight-LED 23,OFF ,6
    IDE09569-MAS09856-Bit pattern of individual segment activation: right headlight-LED 24,OFF ,6
    IDE09569-MAS09857-Bit pattern of individual segment activation: right headlight-LED 25,OFF ,6
    IDE09569-MAS09858-Bit pattern of individual segment activation: right headlight-LED 26,OFF ,6
    IDE09569-MAS09859-Bit pattern of individual segment activation: right headlight-LED 27,OFF ,6
    IDE09569-MAS09860-Bit pattern of individual segment activation: right headlight-LED 28,OFF ,6
    IDE09569-MAS09861-Bit pattern of individual segment activation: right headlight-LED 29,OFF ,6
    IDE09569-MAS09862-Bit pattern of individual segment activation: right headlight-LED 30,OFF ,6
    IDE09569-MAS09863-Bit pattern of individual segment activation: right headlight-LED 31,OFF ,6
    IDE09569-MAS09864-Bit pattern of individual segment activation: right headlight-LED 32,OFF ,6
    IDE09569-MAS09865-Bit pattern of individual segment activation: right headlight-LED 33,OFF ,6
    IDE09569-MAS09866-Bit pattern of individual segment activation: right headlight-LED 34,OFF ,6
    IDE09569-MAS09867-Bit pattern of individual segment activation: right headlight-LED 35,OFF ,6
    IDE09569-MAS09868-Bit pattern of individual segment activation: right headlight-LED 36,OFF ,6
    IDE09569-MAS09869-Bit pattern of individual segment activation: right headlight-LED 37,OFF ,6
    IDE09569-MAS09870-Bit pattern of individual segment activation: right headlight-LED 38,OFF ,6
    IDE09569-MAS09871-Bit pattern of individual segment activation: right headlight-LED 39,OFF ,6
    IDE09569-MAS09872-Bit pattern of individual segment activation: right headlight-LED 40,OFF ,6
    IDE09569-MAS09873-Bit pattern of individual segment activation: right headlight-LED 41,OFF ,6
    IDE09569-MAS09874-Bit pattern of individual segment activation: right headlight-LED 42,OFF ,6
    IDE09569-MAS09875-Bit pattern of individual segment activation: right headlight-LED 43,OFF ,6
    IDE09569-MAS09876-Bit pattern of individual segment activation: right headlight-LED 44,OFF ,6
    IDE09569-MAS09877-Bit pattern of individual segment activation: right headlight-LED 45,OFF ,6
    ENG124608-Order_Reference_Run_Activation_Effect,No dependency ,1
    ENG100660-PWM to Level Scaling Factor Front,0.00 mm/%,2
    ENG103748-PWM to Level Scaling Factor Rear,0.00 mm/%,2
    ENG124607-Reference_Run_Activation_Effect,Activation effect enabled by motor start ,1
    ENG103979-Reference_Run_Start_Condition,Engine start ,1
    Elapsed Time: 00:05
  12. Likes Uwe liked this post
  13. #19
    Paul: bummer!!
    hmm......... my normal practice in this type of "interesting" diagnostic analysis is to take stock at key points in the exercise. So here's a synopsis of the situation thus far (as I understand from your posts) -ONLY as it relates to the headlights:
    First: your auto-scan indicates that the hex55 module is incorrectly coded - but you have advised that in comparing the old and new J745 module, the long-code string and the adaptation channel settings is exactly the same
    Second: The hex D6 and hex D7 modules in your auto-scan report "implausible" DTC between the A31 & A27 modules and the type of lamps in the newly installed headlight fittings. Yet your advice is that the part numbers and software versions of the old and new modules are exactly the same.
    Third: Whilst I have not asked the specific question, I assume that the actual headlight fittings are exactly the same and that no other modules were changed on the car.
    Don't get me wrong - I'm certainly not suggesting that any of your advice is incorrect (quite the opposite - I entirely accept the information provided in your responses). BUT - I'm no sure how to proceed given the 3 x facts above.
    Perhaps someone else here can suggest a way forward - maybe the crash data stored in car is implicated in the problem (I can't see why this would apply)?
  14. #20
    Mar 2020
    Thanks for your help Don you been a great help, hopefully, I'll have a light bulb moment and will get this fixed somehow without getting Audi to look at it and charge me a fortune., at least the dip beam work which means I can still drive it at night.
