Page 1 of 5 123 ... LastLast
Results 1 to 10 of 43
Thread: Audi S3 8v facelift 2017 LED headlights problem
    Mar 2020
    Hi All
    This is my first post. I have bought a crashed damaged Audi S3 8v 2017 facelift model which is coming along well but I have run into a problem when installing the headlights. my car has the LED headlights which I had to replace along with most of the ballast since the old ones were damaged. since installing the new ones I cant seem to get my adaptive headlights to work, nor can I get the main beams to work either. The DRL and indicators are fine and working. in VCDS when I try to do basic headlight settings, I get an error saying "conditions not correct or request sequence error" any help will be much appreciated.
    Chassis Type: 8V-AU37 (5Q0)
    Scan: 01 02 03 08 09 10 15 16 17 19 22 29 39 42 44 52 55 5F A9 BB
              BC D6 D7
    VIN: WAUZZZ8V5HA066631   Mileage: 109652km-68134miles
    D6-Light Ctrl Left 2 -- Status: Malfunction 0010
    D7-Light Ctrl Right 2 -- Status: Malfunction 0010
    Address 01: Engine (J623-DJHA)       Labels:. 06K-907-425-V1.clb
       Part No SW: 8V0 906 259 J    HW: 06K 907 425 B
       Revision: --H13---
       Coding: 0A2500122426010B2004
       Shop #: WSC 06314 790 00021
       ASAM Dataset: EV_ECM20TFS0208V0906259J 001004
       ROD: EV_ECM20TFS0208V0906259J.rod
       VCID: 47CB59864F27871F48F-8012
    15048 - Coolant Fan Control Circuit 1
              P0480 00 [039] - Electrical Malfunction
                        Mileage: 109652 km
                        Date: 2020.03.13
                        Time: 15:57:38
                        Coolant temperature: 9 °C
                        Intake air temperature: 13 °C
                        Voltage terminal 30: 11.015 V
                        Engine: operating status: ES
                        STATE_LS_SAE[1]: INI
                        T_AST_SAE: 0 s
                        MAP_MES_SAE: 101 kPa
                        Lambda probe voltage: bank 1: probe 1 (broadband probe): 1.997 V
                        FAC_TPS_1_SAE: 15.625000 %
                        FUP_H_SAE: 610.0 kPa
    Readiness: 1110 0001
       Part No SW: 0GC 300 011     HW: 0DE 927 711 C
       Component: GSG DQ381     H12 0403
       Revision: 00H12V32
       ASAM Dataset: EV_TCMDQ381061 001
       ROD: EV_TCMDQ381061_VW37.rod
       VCID: 5F9BA1E6F7B7EFDF90F-800A
       Part No SW: 8V0 907 379 B    HW: 8V0 907 379 B
       Component: ESC           H25 0610
       Revision: 00000000    Serial number: 62756000000350
       Coding: 329C938D549F1BAF8B970B674192694CC92AD8D1D082967702410074820812
       ASAM Dataset: EV_Brake1UDSContiMK100IPB 070001
       VCID: 43D34D967B1FAB3F947-8016
       Part No SW: 8V0 820 043 Q    HW: 8V0 820 043 Q
       Component: AC Automat    H03 0110
       Revision: 20001000    Serial number: 00000001043920
       Coding: 03100004000000011000000000001100
       ASAM Dataset: EV_AirCondiFrontVaAU37X 008021
       VCID: 40D9429A6A09B027895-8014
       Subsystem 1 - Part No SW: 4H0 907 658 B    HW: 4H0 907 658 B
       Component: AQ_Hum_Sensor  H01 0005
       Serial number: 51C88F4800PAG0MUFU03
    262658 - High Pressure Sensor
              B10AE 31 [009] - No Signal
                        Fault Frequency: 16
                        Reset counter: 234
                        Mileage: 109652 km
                        Date: 2020.03.01
                        Time: 14:09:58
                        Outside air temperature: 9.5 °C
                        Temperature after evaporator: 8.3 °C
                        System run time-Terminal 15 on: 253 s
       Serial number: 02001627901346
       ROD: EV_BCMBOSCH_017.rod
       VCID: 7EA5FC62507D06D7BB9-802A
       Subsystem 1 - Part No SW: 8V2 955 119 A    HW: 8V2 955 119   Labels: 5QX-955-119-V1.CLB
       Component: WWS370 160908  043 0580
       Serial number:         160919144514
       Coding: 0A47F7
       Serial number: 62338810
       Coding: 00006C
       Light switch:
       Subsystem 3 - Part No SW: 8V0 941 531 AR    HW: 8V0 941 531 AR
       Component: E1 - LDS MQB  H06 0032
       Serial number: 02 08 2016  00001320
       Serial number: 000000000ZY162350315
       Serial number: 00000000000067222907
       Part No SW: 5QA 919 283     HW: 5QA 919 283
       Component: PDC 4 KanalH07 0031
       Serial number: 000308419616272
       Coding: 0700040011
       ASAM Dataset: EV_EPHVA14AU3700000 009027
       ROD: EV_EPHVA14AU3700000_009.rod
       VCID: 074B99860FA7471F88F-8052
       Part No SW: 5Q0 959 655 AR    HW: 5Q0 959 655 AR
       Component: AirbagVW21    003 0315
       Serial number: 003TDR26X1M7
       ROD: EV_AirbaVW20SMEVW37X.rod
       VCID: 1079B2DA7AE900A7595-8044
       Subsystem 1 - Part No SW: -----------    HW: 480 000 710 16
       Serial number: 35700000000C688C8F1%
       Subsystem 2 - Part No SW: -----------    HW: 480 000 710 16
       Serial number: 3580000000020254FE1G
       Subsystem 3 - Part No SW: -----------    HW: 480 401 010 16
       Serial number: 3510001AD231F2B59487
       Subsystem 4 - Part No SW: -----------    HW: 480 401 010 16
       Serial number: 3520001AF231F2B351E7
       Subsystem 5 - Part No SW: -----------    HW: -----------
       Component: FrontSensor_D  --- ----
       Serial number: -------------------$
       Pedestrian Protection Driver:
       Subsystem 6 - Part No SW: -----------    HW: -----------
       Component: PedP_Sensor_D  --- ----
       Subsystem 7 - Part No SW: -----------    HW: -----------
       Component: PedP_Sensor_P  --- ----
       Subsystem 8 - Part No SW: -----------    HW: 480 001 109 16
       Serial number: I0M00000000F10884E15
       Subsystem 9 - Part No SW: -----------    HW: -----------
       Component: PedPSensor_P2  --- ----
    13 Faults Found:
                        Mileage: 109652 km
                        Date: 2020.02.29
                        Time: 17:09:45
    9437723 - Igniter for Passenger's Airbag
              B1002 1B [137] - Resistance Too High
                        Mileage: 109652 km
                        Date: 2020.02.29
                        Time: 17:09:46
    9440027 - Driver's side; side-airbag igniter
              B100B 1B [137] - Resistance Too High
                        Mileage: 109652 km
                        Date: 2020.02.29
                        Time: 17:09:46
                        Mileage: 109652 km
                        Date: 2020.02.29
                        Time: 17:09:46
              B1007 1B [137] - Resistance Too High
                        Mileage: 109652 km
                        Date: 2020.02.29
                        Time: 17:09:46
    9438491 - Igniter for Driver head airbag
              B1005 1B [137] - Resistance Too High
                        Mileage: 109652 km
                        Date: 2020.02.29
                        Time: 17:09:46
    9438235 - Igniter for Front passenger's Head Curtain Airbag
              B1004 1B [137] - Resistance Too High
                        Mileage: 109652 km
                        Date: 2020.02.29
                        Time: 17:09:46
    9440283 - Driver side knee airbag igniter
              B100C 1B [137] - Resistance Too High
                        Mileage: 109652 km
                        Date: 2020.02.29
                        Time: 17:09:46
    9443857 - Driver's Front Airbag Crash Sensor
              B101A 11 [137] - Short to Ground
                        Mileage: 109652 km
                        Date: 2020.02.29
                        Time: 17:09:47
    9443861 - Driver's Front Airbag Crash Sensor
              B101A 15 [137] - Open or Short to Plus
                        Mileage: 109652 km
                        Date: 2020.03.08
                        Time: 00:00:11
    9450005 - Pedestrian Protection Crash Sensor (driver's side)
              B1032 15 [137] - Open or Short to Plus
                        Mileage: 109652 km
                        Date: 2020.02.29
                        Time: 17:09:48
    9450261 - Pedestrian Protection Crash Sensor (passenger's side)
              B1033 15 [137] - Open or Short to Plus
                        Mileage: 109652 km
                        Date: 2020.02.29
                        Time: 17:09:48
    9735701 - Pedestrian Protection Crash Sensor 2; Passenger Side
              B148E 15 [137] - Open or Short to Plus
                        Mileage: 109652 km
                        Date: 2020.02.29
                        Time: 17:09:48
       Part No SW: 8V0 953 521 HB    HW: 5Q0 953 549 E
       Revision: --------    Serial number: 09101604400597
       Coding: A418
       VCID: 015F879E2183792FC6B-8054
       Part No SW: 8V0 920 972 Q    HW: 8V0 920 972 Q
       Component: KOMBI         H04 8316
       Coding: 27AD080A2B8026000101E8001001000000000000
       ASAM Dataset: EV_DashBoardVDDMQBAB 009054
       VCID: 4CC166AA5641644765D-8018
       Revision: --------    Serial number: 0005372068
       Coding: 030100043F085A005B0082683C0B00000001010000000000000000000000
       ROD: EV_GatewLear_013.rod
       VCID: 7CA1F66A466114C795D-8028
       Subsystem 2 - Part No SW: 81A 951 523 A    HW: 81A 951 523 A
       Component: J453 MFL  H04 0003
       Serial number: 20160916071643 20837
       Serial number: 7588600000170227017B
       Part No SW: 0CQ 907 554 C    HW: 0CQ 525 130
       Component: Haldex4Motion H52 7755
       Serial number: HA1-00008.09.16
       Coding: 0001
       VCID: 45D7538E752B950FBA3-8010
    Address 29: Left Light (J1018)       Labels: 8S0-907-397.clb
       Part No SW: 8S0 907 397 D    HW: 8S0 907 397 D
       Component: LCM_MQB       H06 0016
       ASAM Dataset: EV_LCMLeftCONTIAU426 001008
       ROD: EV_LCMLeftCONTIAU426_VW41.rod
       VCID: 42DD48926405A2379F1-8016
    Address 39: Right Light (J1023)       Labels: 8S0-907-397.clb
       ASAM Dataset: EV_LCMRightCONTIAU426 001008
       Serial number: 210916EIK14312
       Coding: 001C8A205C01040000001002
       Coding: 8107
       ROD: EV_SteerAssisMQB_013.rod
       VCID: 3A2D30720CD5EAF7C71-806E
       Serial number: 140916EID34815
       Coding: 001C82205E01040000001002
       Part No SW: 8V0 907 357 A    HW: 7P6 907 357 B
       Component: MxB-ECU       001 0230
       Coding: 0EEE00102B230200
       ASAM Dataset: EV_HeadlRegulAUDIMXBAU64X 005014
       VCID: 3E253C6210FDC6D7FB9-806A
    66881 - Databus
              U1123 00 [137] - Received Error Message
                        Reset counter: 234
                        Mileage: 109652 km
                        Date: 2020.03.13
                        Time: 15:54:55
    66882 - Databus
                        Reset counter: 234
                        Mileage: 109652 km
                        Date: 2020.03.13
                        Time: 15:54:55
              U1014 00 [137] - -
              [Steuergeraet falsch codiert]
                        Reset counter: 234
                        Mileage: 109652 km
                        Date: 2020.03.13
                        Time: 15:54:55
       Part No SW: 8V0 907 159 A    HW: 4H0 907 159 A
       Serial number: 160911200507
       Serial number: 260916EIQ00194
       Coding: 000C82204001040000001002
       Serial number: 260916EIQ00233
       Part No SW: 7PP 941 572 AC    HW: 7PP 941 572 A
       Component: LED1L         H09 0008
       VCID: 176BC9C65F07D79F18F-8042
    0019 - Headlamp Type
              C119F 00 [009] - Implausible
                        Reset counter: 234
                        Mileage: 109652 km
                        Date: 2020.03.13
                        Time: 16:01:37
       Component: LED1R         H09 0008
                        Reset counter: 234
                        Mileage: 109652 km
                        Date: 2020.03.11
                        Time: 20:04:08
    0837 - Supply Voltage for High-Beam
              C11FF 13 [008] - Open Circuit
                        Reset counter: 19
                        Mileage: 109652 km
                        Date: 2020.03.13
                        Time: 15:35:12
    End----(Elapsed T
    ^^^Pauls: difficult to be precise - but the DTC s on the hexD6 and hexD7 modules are telling (IMO)! Are you certain that the replacement headlamp fittings are compatible with the car? And the 0837 fault on hexD7 is suggestive of a wiring/connector problem (I'm guessing of course)
  3. Likes Uwe liked this post
    Mar 2020
    The headlights were the same part code as the lights that were damaged, the same with the ballast, all of them are the same part code
    Pauls: hmm........ OK. Of course anything is possible, but IMO "implausible" DTC s are always suggestive (at least in the first instance) of something physically odd with either the equipment, or the wiring/connectors to the equipment. If you are 101% certain that the old fittings had the same part numbers AND software version numbers - then was there any damage, or were there any repairs done to the headlamp wiring loom? And, have you confirmed the integrity of the wires/connectors for the right-side high-beam (related to the 0837 - Supply Voltage for High-Beam DTC)?
    I also note the U1014 DTC in the hex55 module - so the car believes that this module has been incorrectly coded. What's the history of this module - it is original - if so, what were the long-code /channel changes (look in the C:\Ross-Tech\VCDS\Debug directory on your laptop)?
  6. Likes Uwe liked this post
    Mar 2020
    Hi DV52 all the modules are replacements as the originals were all damaged in the accident. the main issue I have is the main beams are not working. If I can get that working, that would be great.
    Quote Originally Posted by pauls13 View Post
    Paul: yes - I understand the problem with the main-beam lights - we are both focused on solving the same problem!!
    But as you can see from the DTCs in the auto-scan, the principal modules that control the headlight fittings (i.e. the LCM s @ address hexD7 and hexD6) don't recognize the type of lamps that the car is asking to be controlled. So clearly, there is something very odd about the retrofit.
    It's almost certain that the "Open circuit" DTC in the right-side LCM is caused by wonky wiring, or a faulty connection (I assume the lamps are new). So, you should be able to delete this DTC by judicious tracing of the right-side main-beam wiring.
    As I have already said, IMHO implausible DTCs tend to be a special type of error that in general are suggestive of an exogenous cause: a problem outside the module (please note my deliberate use of the words "in general" and "suggestive" - this is definitely not always the case). Again IMHO, the fact that your autoscan has the same "implausible" DTC on both LCMs is also telling in your case (i.e. again, "suggestive" of an exogenous cause)- hence my question about compatibility of the new modules.
    I'm guessing of course and based on my supposition that it's useful to look elsewhere when fault-finding "implausible" errors, it's possible that these 2 x DTC s could be consequential to the incorrectly coded hex55 unit. I don't have access to the long-code helper screens for your particular range control module to confirm/rule-out this assertion. If the original hex55 module has sufficient life - perhaps you could refit the module and attempt to extract the long-code string and maybe try generating an admap? At least then, you would have first-hand baseline-data which could be replicated into the new module.
    But there are others on this forum with deity-like expertise - I'm just a rank amateur! Perhaps one (or more) of their number might proffer a more knowledgeable suggestion?
  9. Likes Uwe liked this post
  10. #7
    Mar 2020
    Question, how do I extract the coding should I get the old ballast to work?
  11. #8
    Paul: I suspect the easiest way of getting both is to generate an adaptation channel map (sometimes shortened in this forum to "admap"). Look at RT's video HERE. This video has a dual purpose, but if you start at about 2:19 minutes, you will learn how to generate an admap for individual UDS control modules like the hex 55 module
    At about 2:33 minutes into the video choose different options as follows:
    Single controller address = 55
    Under "Function", tick Adaptations
    Under "output", click the CSV file radio button
    the set-up should look like this, but use "55", instead of "09" in the pic:
    Then just press the Go button and magic stuff will happen!!
    After the process has completed - exit VCDS software and navigate to the directory C:\Ross-Tech\VCDS\Logs on your laptop. In this directory you will find the file adpmap-55-8V0-907-357_WAUZZZ8V5HA066631-date-time.CSV. Open this file with a suitable reader and the data will be there!!
  12. Likes Uwe liked this post
  13. #9
    Mar 2020
    so I did the reading and got the below output
    ;SW:8V0-907-357-A   HW:7P6-907-357-B ---  Headlight Range
    ;Component:MxB-ECU       001 0230, Coding:0EEE00102B230200
    ;EV_HeadlRegulAUDIMXBAU64X,005014,EV_HeadlRegulAUDIMXBAU64X_005_AU37.rod
    ;Wednesday,18,March,2020,20:38:18:42802
    ;VCDS Version: Release 19.6.2 (x64)  Data version: 20200210 DS308.0
    ;VCID: 3E253C6210FDC6D7FB9-806A
    Group,Description,Actual
    IDE00018,Voltage terminal 15,11.756, V
    IDE00030,Status of actuator test,not active,
    IDE00075,Vehicle speed,0.0, km/h
    IDE00322,Status of basic setting,not active,
    IDE00323,Security Access: Number of invalid keys,0,
    IDE00326,Steering wheel angle,0.0, °
    IDE01232,Supply voltage for external components,9.320, V
    IDE01714,Status reverse gear,OFF,
    IDE01943,Turn signal,not activated,
    IDE01946,ESP intervention,not active,
    IDE01992-ENG118424,Installation list: current installations-Gateway_Component_List_Present_Node_0x54,installed,
    IDE01992-ENG118425,Installation list: current installations-Gateway_Component_List_Present_Node_0x82,installed,
    IDE01992-ENG118426,Installation list: current installations-Gateway_Component_List_Present_Node_0x83,installed,
    IDE01992-ENG118427,Installation list: current installations-Gateway_Component_List_Present_Node_0x96,installed,
    IDE01992-ENG118428,Installation list: current installations-Gateway_Component_List_Present_Node_0x97,installed,
    IDE01993-ENG06597,Control module reference number-Gateway_component_list_allocation_node_0x54,Headlight Regulation,
    IDE01993-ENG06598,Control module reference number-Gateway_component_list_allocation_node_0x82,Light Control Left,
    IDE01993-ENG06599,Control module reference number-Gateway_component_list_allocation_node_0x83,Light Control Right,
    IDE01993-ENG06600,Control module reference number-Gateway_component_list_allocation_node_0x96,Light Control Left 2,
    IDE01993-ENG06601,Control module reference number-Gateway_component_list_allocation_node_0x97,Light Control Right 2,
    IDE02384-ENG118429,Status of event memory-Gateway_Component_List_dtc_Node_0x54,ERROR,
    IDE02384-ENG118430,Status of event memory-Gateway_Component_List_dtc_Node_0x82,OK,
    IDE02384-ENG118431,Status of event memory-Gateway_Component_List_dtc_Node_0x83,OK,
    IDE02384-ENG118432,Status of event memory-Gateway_Component_List_dtc_Node_0x96,ERROR,
    IDE02384-ENG118433,Status of event memory-Gateway_Component_List_dtc_Node_0x97,ERROR,
    IDE02389,Ambient brightness,126, lx
    IDE02486,Data logger triggering,not active,
    IDE02515,Low beam,OFF,
    IDE02743,High Beam,OFF,
    IDE03150-SFT00041,Readiness for bus sleep mode-Light Control Left,active,
    IDE03150-SFT00057,Readiness for bus sleep mode-Light Control Right,active,
    IDE03150-SFT00085,Readiness for bus sleep mode-Headlight Regulation,active,
    IDE03150-SFT00214,Readiness for bus sleep mode-Light Control Left 2,active,
    IDE03150-SFT00215,Readiness for bus sleep mode-Light Control Right 2,active,
    IDE03214,Engine stop using start-stop function,OFF,
    IDE03215,Engine start using start-stop function,OFF,
    IDE03602,Left front level control system sensor,-0.01, %
    IDE03604,Left rear level control system sensor,49.10, %
    IDE03616,Motor status,OFF,
    IDE03620,Front jounce travel,0.0, mm
    IDE03621,Rear jounce travel,0.0, mm
    IDE03622,Left headlight beam adjusting motor: status,no error,
    IDE03623,Right headlight beam adjusting motor: status,no error,
    IDE03630,Left headlight beam adjusting motor: specified value,0.0, mm
    IDE03631,Right headlight beam adjusting motor: specified value,0.0, mm
    IDE03632,Left-/right hand driving switch-over,OFF,
    IDE03788,Status of basic headlamp setting,no request,
    IDE03850,Left front level ctrl sys sensor: adaptation value (zero pos),Not available,
    IDE03866,Left rear level ctrl sys sensor: adaptation value (zero pos),Not available,
    IDE04343-SFT00041,Bus identification-Light Control Left,AFS/From light data bus,
    IDE04343-SFT00057,Bus identification-Light Control Right,AFS/From light data bus,
    IDE04343-SFT00085,Bus identification-Headlight Regulation,Busmaster,
    IDE04343-SFT00214,Bus identification-Light Control Left 2,AFS/From light data bus,
    IDE04343-SFT00215,Bus identification-Light Control Right 2,AFS/From light data bus,
    IDE04805-IDE02955,Driving profile selection-System status,Not available,
    IDE04805-IDE06419,Driving profile selection-Driving profile switchover,no request,
    IDE04805-MAS01447,Driving profile selection-Act.val.,00,
    IDE04805-MAS01448,Driving profile selection-Specified value,00,
    IDE04805-MAS05058,Driving profile selection-Compatibility,Yes,
    IDE05738-ENG124653,Subssystem diagnosis classes-DC0_systems,No,
    IDE05738-ENG124652,Subssystem diagnosis classes-DC1_systems,Yes,
    IDE05738-ENG124651,Subssystem diagnosis classes-DC2/DC2F_systems,No,
    IDE05738-ENG124650,Subssystem diagnosis classes-DC3_systems,Yes,
    IDE08447,Driving axis angle,NO VALUE AVAILABLE,
    IDE08516-IDE02743,LED headlights: light distribution requirement-High Beam,not requested,
    IDE08516-IDE06864,LED headlights: light distribution requirement-Daytime running lights,not requested,
    IDE08516-MAS02922,LED headlights: light distribution requirement-City light,not requested,
    IDE08516-MAS02923,LED headlights: light distribution requirement-Highway light,not requested,
    IDE08516-MAS02931,LED headlights: light distribution requirement-Rural highway light,not requested,
    IDE08516-MAS02946,LED headlights: light distribution requirement-static AFS light,not requested,
    IDE08516-MAS07013,LED headlights: light distribution requirement-All-weather lights,not requested,
    IDE08516-MAS07014,LED headlights: light distribution requirement-Tourist light,not requested,
    IDE08516-MAS07015,LED headlights: light distribution requirement-Running light,not requested,
    IDE08516-MAS07234,LED headlights: light distribution requirement-Eco mode 1,not requested,
    IDE08516-MAS07235,LED headlights: light distribution requirement-Eco mode 2,not requested,
    IDE08706-MAS06932,Actual angle of ref. segments-Horizontal angle reference segment left,NO VALUE AVAILABLE,
    IDE08706-MAS06933,Actual angle of ref. segments-Horizontal angle reference segment right,NO VALUE AVAILABLE,
    IDE08706-MAS06934,Actual angle of ref. segments-Vertical angle reference segment left,NO VALUE AVAILABLE,
    IDE08706-MAS06935,Actual angle of ref. segments-Vertical angle reference segment right,NO VALUE AVAILABLE,
    IDE08713-MAS06936,Matrix light: calculated offset values-Horizontal offset: light left,NO VALUE AVAILABLE,
    IDE08713-MAS06937,Matrix light: calculated offset values-Horizontal offset: light right,NO VALUE AVAILABLE,
    IDE08713-MAS06938,Matrix light: calculated offset values-Vertical offset: light left,NO VALUE AVAILABLE,
    IDE08713-MAS06939,Matrix light: calculated offset values-Vertical offset: light right,NO VALUE AVAILABLE,
    IDE08714-MAS06929,Axle offsets-Axle offset front,NO VALUE AVAILABLE,
    IDE08714-MAS06930,Axle offsets-Axle offset rear,NO VALUE AVAILABLE,
    IDE08715,Func. status matrix high beam,not active,
    IDE80001,Analysis 1,00 37 83 31 12 00 02 16 28 50 24 93 FF FF FF FF FF FF FF FF FF FF FF FF,
    ENG101323,Headlight leveling control state,static,
    ENG103737,Left headlight leveling control value,1024.0, mm
    ENG124613,Predictive_Route_Data_Intown_Flag,not_available,
    ENG124610,Predictive_Route_Data_Number_Of_Lanes,not_available,
    ENG124612,Predictive_Route_Data_Placename_Sign,not_available,
    ENG124611,Predictive_Route_Data_Speed_Limit,Unknown (31),
    ENG124609,Predictive_Route_Data_Street_Class,not_available,
    ENG102296,Right headlight leveling control value,1024.0, mm
    Elapsed Time: 00:07
  14. #10
    Mar 2020
    Ok so I have compared the two outputs and these are the changes
    Old ballast
    New Ballast
    IDE00018,Voltage terminal 15,11.673, V
    IDE02389,Ambient brightness,150, lx
    ENG103737,Left headlight leveling control value,-1.0, mm
    ENG102296,Right headlight leveling control value,-1.0, mm
