Audi S3 8v facelift 2017 LED headlights problem
pauls13
C?ID=172848
Hi All
This is my first post. I have bought a crashed damaged Audi S3 8v 2017 facelift model which is coming along well but I have run into a problem when installing the headlights. my car has the LED headlights which I had to replace along with most of the ballast since the old ones were damaged. since installing the new ones I cant seem to get my adaptive headlights to work, nor can I get the main beams to work either. The DRL and indicators are fine and working. in VCDS when I try to do basic headlight settings, I get an error saying "conditions not correct or request sequence error" any help will be much appreciated.
Chassis Type: 8V-AU37 (5Q0)
Scan: 01 02 03 08 09 10 15 16 17 19 22 29 39 42 44 52 55 5F A9 BB
          BC D6 D7
VIN: WAUZZZ8V5HA066631   Mileage: 109652km-68134miles
D6-Light Ctrl Left 2 -- Status: Malfunction 0010
D7-Light Ctrl Right 2 -- Status: Malfunction 0010
Address 01: Engine (J623-DJHA)       Labels:. 06K-907-425-V1.clb
   Part No SW: 8V0 906 259 J    HW: 06K 907 425 B
   Component: 2.0l R4 TFSI  H13 0002
   Revision: --H13---
   Coding: 0A2500122426010B2004
   Shop #: WSC 06314 790 00021
   ASAM Dataset: EV_ECM20TFS0208V0906259J 001004
   ROD: EV_ECM20TFS0208V0906259J.rod
   VCID: 47CB59864F27871F48F-8012
15048 - Coolant Fan Control Circuit 1
          P0480 00 [039] - Electrical Malfunction
                    Mileage: 109652 km
                    Date: 2020.03.13
                    Time: 15:57:38
                    Coolant temperature: 9 °C
                    Intake air temperature: 13 °C
                    Voltage terminal 30: 11.015 V
                    Engine: operating status: ES
                    STATE_LS_SAE[1]: INI
                    T_AST_SAE: 0 s
                    MAP_MES_SAE: 101 kPa
                    Lambda probe voltage: bank 1: probe 1 (broadband probe): 1.997 V
                    FAC_TPS_1_SAE: 15.625000 %
                    FUP_H_SAE: 610.0 kPa
Readiness: 1110 0001
   Part No SW: 0GC 300 011     HW: 0DE 927 711 C
   Component: GSG DQ381     H12 0403
   Revision: 00H12V32
   ROD: EV_TCMDQ381061_VW37.rod
   VCID: 5F9BA1E6F7B7EFDF90F-800A
   Part No SW: 8V0 907 379 B    HW: 8V0 907 379 B
   Component: ESC           H25 0610
   Revision: 00000000    Serial number: 62756000000350
   Coding: 329C938D549F1BAF8B970B674192694CC92AD8D1D082967702410074820812
   ASAM Dataset: EV_Brake1UDSContiMK100IPB 070001
   VCID: 43D34D967B1FAB3F947-8016
   Part No SW: 8V0 820 043 Q    HW: 8V0 820 043 Q
   Component: AC Automat    H03 0110
   Revision: 20001000    Serial number: 00000001043920
   Coding: 03100004000000011000000000001100
   ASAM Dataset: EV_AirCondiFrontVaAU37X 008021
   VCID: 40D9429A6A09B027895-8014
   Subsystem 1 - Part No SW: 4H0 907 658 B    HW: 4H0 907 658 B
   Serial number: 51C88F4800PAG0MUFU03
262658 - High Pressure Sensor
          B10AE 31 [009] - No Signal
                    Fault Frequency: 16
                    Reset counter: 234
                    Mileage: 109652 km
                    Date: 2020.03.01
                    Time: 14:09:58
                    Outside air temperature: 9.5 °C
                    Temperature after evaporator: 8.3 °C
   Part No SW: 5Q0 937 084 CF    HW: 5Q0 937 084 CF
   Component: BCM MQBAB M+  H34 0236
   Serial number: 02001627901346
   ROD: EV_BCMBOSCH_017.rod
   VCID: 7EA5FC62507D06D7BB9-802A
   Subsystem 1 - Part No SW: 8V2 955 119 A    HW: 8V2 955 119   Labels: 5QX-955-119-V1.CLB
   Component: WWS370 160908  043 0580
   Serial number:         160919144514
   Coding: 0A47F7
   Serial number: 62338810
   Coding: 00006C
   Component: E1 - LDS MQB  H06 0032
   Serial number: 02 08 2016  00001320
   Serial number: 000000000ZY162350315
   Component: Sirene, DWA  005 0313
   Serial number: 00000000000067222907
   Part No SW: 5QA 919 283     HW: 5QA 919 283
   Component: PDC 4 KanalH07 0031
   Serial number: 000308419616272
   Coding: 0700040011
   ASAM Dataset: EV_EPHVA14AU3700000 009027
   ROD: EV_EPHVA14AU3700000_009.rod
   VCID: 074B99860FA7471F88F-8052
   Part No SW: 5Q0 959 655 AR    HW: 5Q0 959 655 AR
   Component: AirbagVW21    003 0315
   Serial number: 003TDR26X1M7
   ROD: EV_AirbaVW20SMEVW37X.rod
   VCID: 1079B2DA7AE900A7595-8044
   Subsystem 1 - Part No SW: -----------    HW: 480 000 710 16
   Serial number: 35700000000C688C8F1%
   Subsystem 2 - Part No SW: -----------    HW: 480 000 710 16
   Serial number: 3580000000020254FE1G
   Subsystem 3 - Part No SW: -----------    HW: 480 401 010 16
   Serial number: 3510001AD231F2B59487
   Subsystem 4 - Part No SW: -----------    HW: 480 401 010 16
   Serial number: 3520001AF231F2B351E7
   Subsystem 5 - Part No SW: -----------    HW: -----------
   Component: FrontSensor_D  --- ----
   Serial number: -------------------$
   Pedestrian Protection Driver:
   Subsystem 6 - Part No SW: -----------    HW: -----------
   Component: PedP_Sensor_D  --- ----
   Subsystem 7 - Part No SW: -----------    HW: -----------
   Component: PedP_Sensor_P  --- ----
   Subsystem 8 - Part No SW: -----------    HW: 480 001 109 16
   Serial number: I0M00000000F10884E15
   Subsystem 9 - Part No SW: -----------    HW: -----------
   Component: PedPSensor_P2  --- ----
13 Faults Found:
9437211 - Igniter for Driver's Airbag
          B1000 1B [137] - Resistance Too High
                    Mileage: 109652 km
                    Date: 2020.02.29
                    Time: 17:09:45
9437723 - Igniter for Passenger's Airbag
          B1002 1B [137] - Resistance Too High
                    Mileage: 109652 km
                    Date: 2020.02.29
                    Time: 17:09:46
9440027 - Driver's side; side-airbag igniter
          B100B 1B [137] - Resistance Too High
                    Mileage: 109652 km
                    Date: 2020.02.29
                    Time: 17:09:46
9438747 - Igniter for Seat Belt Tensioner; Driver's Side
          B1006 1B [137] - Resistance Too High
                    Mileage: 109652 km
                    Date: 2020.02.29
                    Time: 17:09:46
9439003 - Igniter for Seat Belt Tensioner; Passenger's Side
          B1007 1B [137] - Resistance Too High
                    Mileage: 109652 km
                    Date: 2020.02.29
                    Time: 17:09:46
9438491 - Igniter for Driver head airbag
          B1005 1B [137] - Resistance Too High
                    Mileage: 109652 km
                    Date: 2020.02.29
                    Time: 17:09:46
9438235 - Igniter for Front passenger's Head Curtain Airbag
          B1004 1B [137] - Resistance Too High
                    Mileage: 109652 km
                    Date: 2020.02.29
                    Time: 17:09:46
9440283 - Driver side knee airbag igniter
          B100C 1B [137] - Resistance Too High
                    Mileage: 109652 km
                    Date: 2020.02.29
                    Time: 17:09:46
9443857 - Driver's Front Airbag Crash Sensor
          B101A 11 [137] - Short to Ground
                    Mileage: 109652 km
                    Date: 2020.02.29
                    Time: 17:09:47
9443861 - Driver's Front Airbag Crash Sensor
          B101A 15 [137] - Open or Short to Plus
                    Mileage: 109652 km
                    Date: 2020.03.08
                    Time: 00:00:11
9450005 - Pedestrian Protection Crash Sensor (driver's side)
          B1032 15 [137] - Open or Short to Plus
                    Mileage: 109652 km
                    Date: 2020.02.29
                    Time: 17:09:48
9450261 - Pedestrian Protection Crash Sensor (passenger's side)
          B1033 15 [137] - Open or Short to Plus
                    Mileage: 109652 km
                    Date: 2020.02.29
                    Time: 17:09:48
9735701 - Pedestrian Protection Crash Sensor 2; Passenger Side
          B148E 15 [137] - Open or Short to Plus
                    Mileage: 109652 km
                    Date: 2020.02.29
                    Time: 17:09:48
   Part No SW: 8V0 953 521 HB    HW: 5Q0 953 549 E
   Revision: --------    Serial number: 09101604400597
   Coding: A418
   VCID: 015F879E2183792FC6B-8054
   Part No SW: 8V0 920 972 Q    HW: 8V0 920 972 Q
   Component: KOMBI         H04 8316
   Coding: 27AD080A2B8026000101E8001001000000000000
   ASAM Dataset: EV_DashBoardVDDMQBAB 009054
   VCID: 4CC166AA5641644765D-8018
   Part No SW: 5Q0 907 530 AM    HW: 5Q0 907 530 F
   Component: GW MQB High   128 1265
   Revision: --------    Serial number: 0005372068
   Coding: 030100043F085A005B0082683C0B00000001010000000000000000000000
   ROD: EV_GatewLear_013.rod
   VCID: 7CA1F66A466114C795D-8028
   Subsystem 2 - Part No SW: 81A 951 523 A    HW: 81A 951 523 A
   Component: J453 MFL  H04 0003
   Serial number: 20160916071643 20837
   Serial number: 7588600000170227017B
   Part No SW: 0CQ 907 554 C    HW: 0CQ 525 130
   Component: Haldex4Motion H52 7755
   Serial number: HA1-00008.09.16
   Coding: 0001
   VCID: 45D7538E752B950FBA3-8010
Address 29: Left Light (J1018)       Labels: 8S0-907-397.clb
   Part No SW: 8S0 907 397 D    HW: 8S0 907 397 D
   Component: LCM_MQB       H06 0016
   ASAM Dataset: EV_LCMLeftCONTIAU426 001008
   VCID: 42DD48926405A2379F1-8016
Address 39: Right Light (J1023)       Labels: 8S0-907-397.clb
   ASAM Dataset: EV_LCMRightCONTIAU426 001008
   Serial number: 210916EIK14312
   Coding: 001C8A205C01040000001002
   Coding: 8107
   ROD: EV_SteerAssisMQB_013.rod
   VCID: 3A2D30720CD5EAF7C71-806E
   Serial number: 140916EID34815
   Coding: 001C82205E01040000001002
Address 55: Headlight Range (J745)       Labels:* None
   Part No SW: 8V0 907 357 A    HW: 7P6 907 357 B
   Component: MxB-ECU       001 0230
   Coding: 0EEE00102B230200
   ASAM Dataset: EV_HeadlRegulAUDIMXBAU64X 005014
   VCID: 3E253C6210FDC6D7FB9-806A
66881 - Databus
                    Reset counter: 234
                    Mileage: 109652 km
                    Date: 2020.03.13
                    Time: 15:54:55
66882 - Databus
                    Reset counter: 234
                    Mileage: 109652 km
                    Date: 2020.03.13
                    Time: 15:54:55
          U1014 00 [137] - -
          [Steuergeraet falsch codiert]
                    Reset counter: 234
                    Mileage: 109652 km
                    Date: 2020.03.13
                    Time: 15:54:55
   Part No SW: 8V0 907 159 A    HW: 4H0 907 159 A
   Component: SAS-GEN 2     H07 0001
   Serial number: 160911200507
   Serial number: 260916EIQ00194
   Coding: 000C82204001040000001002
   Serial number: 260916EIQ00233
   Part No SW: 7PP 941 572 AC    HW: 7PP 941 572 A
   Component: LED1L         H09 0008
   VCID: 176BC9C65F07D79F18F-8042
0019 - Headlamp Type
          C119F 00 [009] - Implausible
                    Reset counter: 234
                    Mileage: 109652 km
                    Date: 2020.03.13
                    Time: 16:01:37
   Component: LED1R         H09 0008
                    Reset counter: 234
                    Mileage: 109652 km
                    Date: 2020.03.11
                    Time: 20:04:08
0837 - Supply Voltage for High-Beam
          C11FF 13 [008] - Open Circuit
                    Reset counter: 19
                    Mileage: 109652 km
                    Date: 2020.03.13
                    Time: 15:35:12
End----(Elapsed T
DV52
C?ID=194404
^^^Pauls: difficult to be precise - but the DTC s on the hexD6 and hexD7 modules are telling (IMO)! Are you certain that the replacement headlamp fittings are compatible with the car? And the 0837 fault on hexD7 is suggestive of a wiring/connector problem (I'm guessing of course)
pauls13
C?ID=172848
The headlights were the same part code as the lights that were damaged, the same with the ballast, all of them are the same part code
DV52
C?ID=194404
Pauls: hmm........ OK. Of course anything is possible, but IMO "implausible" DTC s are always suggestive (at least in the first instance) of something physically odd with either the equipment, or the wiring/connectors to the equipment. If you are 101% certain that the old fittings had the same part numbers AND software version numbers - then was there any damage, or were there any repairs done to the headlamp wiring loom? And, have you confirmed the integrity of the wires/connectors for the right-side high-beam (related to the 0837 - Supply Voltage for High-Beam DTC)?
I also note the U1014 DTC in the hex55 module - so the car believes that this module has been incorrectly coded. What's the history of this module - it is original - if so, what were the long-code /channel changes (look in the C:\Ross-Tech\VCDS\Debug directory on your laptop)?
pauls13
C?ID=172848
Hi DV52 all the modules are replacements as the originals were all damaged in the accident. the main issue I have is the main beams are not working. If I can get that working, that would be great.
DV52
C?ID=194404
Paul: yes - I understand the problem with the main-beam lights - we are both focused on solving the same problem!! ;)
But as you can see from the DTCs in the auto-scan, the principal modules that control the headlight fittings (i.e. the LCM s @ address hexD7 and hexD6) don't recognize the type of lamps that the car is asking to be controlled. So clearly, there is something very odd about the retrofit.
It's almost certain that the "Open circuit" DTC in the right-side LCM is caused by wonky wiring, or a faulty connection (I assume the lamps are new). So, you should be able to delete this DTC by judicious tracing of the right-side main-beam wiring.
As I have already said, IMHO implausible DTCs tend to be a special type of error that in general are suggestive of an exogenous cause: a problem outside the module (please note my deliberate use of the words "in general" and "suggestive" - this is definitely not always the case). Again IMHO, the fact that your autoscan has the same "implausible" DTC on both LCMs is also telling in your case (i.e. again, "suggestive" of an exogenous cause)- hence my question about compatibility of the new modules.
I'm guessing of course and based on my supposition that it's useful to look elsewhere when fault-finding "implausible" errors, it's possible that these 2 x DTC s could be consequential to the incorrectly coded hex55 unit. I don't have access to the long-code helper screens for your particular range control module to confirm/rule-out this assertion. If the original hex55 module has sufficient life - perhaps you could refit the module and attempt to extract the long-code string and maybe try generating an admap? At least then, you would have first-hand baseline-data which could be replicated into the new module.
But there are others on this forum with deity-like expertise - I'm just a rank amateur! Perhaps one (or more) of their number might proffer a more knowledgeable suggestion?
pauls13
C?ID=172848
Question, how do I extract the coding should I get the old ballast to work?
DV52
C?ID=194404
Paul: I suspect the easiest way of getting both is to generate an adaptation channel map (sometimes shortened in this forum to "admap"). Look at RT's video HERE. This video has a dual purpose, but if you start at about 2:19 minutes, you will learn how to generate an admap for individual UDS control modules like the hex 55 module
At about 2:33 minutes into the video choose different options as follows:
Single controller address = 55
Under "Function", tick Adaptations
Under "output", click the CSV file radio button
the set-up should look like this, but use "55", instead of "09" in the pic:
Then just press the Go button and magic stuff will happen!!
After the process has completed - exit VCDS software and navigate to the directory C:\Ross-Tech\VCDS\Logs on your laptop. In this directory you will find the file adpmap-55-8V0-907-357_WAUZZZ8V5HA066631-date-time.CSV. Open this file with a suitable reader and the data will be there!!
pauls13
C?ID=172848
so I did the reading and got the below output
;SW:8V0-907-357-A   HW:7P6-907-357-B ---  Headlight Range
;Component:MxB-ECU       001 0230, Coding:0EEE00102B230200
;EV_HeadlRegulAUDIMXBAU64X,005014,EV_HeadlRegulAUDIMXBAU64X_005_AU37.rod
;Wednesday,18,March,2020,20:38:18:42802
;VCDS Version: Release 19.6.2 (x64)  Data version: 20200210 DS308.0
;VCID: 3E253C6210FDC6D7FB9-806A
Group,Description,Actual
IDE00018,Voltage terminal 15,11.756, V
IDE00030,Status of actuator test,not active,
IDE00075,Vehicle speed,0.0, km/h
IDE00322,Status of basic setting,not active,
IDE00323,Security Access: Number of invalid keys,0,
IDE00326,Steering wheel angle,0.0, °
IDE01232,Supply voltage for external components,9.320, V
IDE01714,Status reverse gear,OFF,
IDE01943,Turn signal,not activated,
IDE01946,ESP intervention,not active,
IDE01992-ENG118424,Installation list: current installations-Gateway_Component_List_Present_Node_0x54,installed,
IDE01992-ENG118425,Installation list: current installations-Gateway_Component_List_Present_Node_0x82,installed,
IDE01992-ENG118426,Installation list: current installations-Gateway_Component_List_Present_Node_0x83,installed,
IDE01992-ENG118427,Installation list: current installations-Gateway_Component_List_Present_Node_0x96,installed,
IDE01992-ENG118428,Installation list: current installations-Gateway_Component_List_Present_Node_0x97,installed,
IDE01993-ENG06597,Control module reference number-Gateway_component_list_allocation_node_0x54,Headlight Regulation,
IDE01993-ENG06598,Control module reference number-Gateway_component_list_allocation_node_0x82,Light Control Left,
IDE01993-ENG06599,Control module reference number-Gateway_component_list_allocation_node_0x83,Light Control Right,
IDE01993-ENG06600,Control module reference number-Gateway_component_list_allocation_node_0x96,Light Control Left 2,
IDE01993-ENG06601,Control module reference number-Gateway_component_list_allocation_node_0x97,Light Control Right 2,
IDE02384-ENG118429,Status of event memory-Gateway_Component_List_dtc_Node_0x54,ERROR,
IDE02384-ENG118430,Status of event memory-Gateway_Component_List_dtc_Node_0x82,OK,
IDE02384-ENG118431,Status of event memory-Gateway_Component_List_dtc_Node_0x83,OK,
IDE02384-ENG118432,Status of event memory-Gateway_Component_List_dtc_Node_0x96,ERROR,
IDE02384-ENG118433,Status of event memory-Gateway_Component_List_dtc_Node_0x97,ERROR,
IDE02389,Ambient brightness,126, lx
IDE02486,Data logger triggering,not active,
IDE02515,Low beam,OFF,
IDE02743,High Beam,OFF,
IDE03150-SFT00041,Readiness for bus sleep mode-Light Control Left,active,
IDE03150-SFT00057,Readiness for bus sleep mode-Light Control Right,active,
IDE03150-SFT00085,Readiness for bus sleep mode-Headlight Regulation,active,
IDE03150-SFT00214,Readiness for bus sleep mode-Light Control Left 2,active,
IDE03150-SFT00215,Readiness for bus sleep mode-Light Control Right 2,active,
IDE03214,Engine stop using start-stop function,OFF,
IDE03215,Engine start using start-stop function,OFF,
IDE03602,Left front level control system sensor,-0.01, %
IDE03604,Left rear level control system sensor,49.10, %
IDE03616,Motor status,OFF,
IDE03620,Front jounce travel,0.0, mm
IDE03621,Rear jounce travel,0.0, mm
IDE03622,Left headlight beam adjusting motor: status,no error,
IDE03623,Right headlight beam adjusting motor: status,no error,
IDE03630,Left headlight beam adjusting motor: specified value,0.0, mm
IDE03631,Right headlight beam adjusting motor: specified value,0.0, mm
IDE03632,Left-/right hand driving switch-over,OFF,
IDE03788,Status of basic headlamp setting,no request,
IDE03850,Left front level ctrl sys sensor: adaptation value (zero pos),Not available,
IDE03866,Left rear level ctrl sys sensor: adaptation value (zero pos),Not available,
IDE04343-SFT00041,Bus identification-Light Control Left,AFS/From light data bus,
IDE04343-SFT00057,Bus identification-Light Control Right,AFS/From light data bus,
IDE04343-SFT00085,Bus identification-Headlight Regulation,Busmaster,
IDE04343-SFT00214,Bus identification-Light Control Left 2,AFS/From light data bus,
IDE04343-SFT00215,Bus identification-Light Control Right 2,AFS/From light data bus,
IDE04805-IDE02955,Driving profile selection-System status,Not available,
IDE04805-IDE06419,Driving profile selection-Driving profile switchover,no request,
IDE04805-MAS01447,Driving profile selection-Act.val.,00,
IDE04805-MAS01448,Driving profile selection-Specified value,00,
IDE04805-MAS05058,Driving profile selection-Compatibility,Yes,
IDE05738-ENG124653,Subssystem diagnosis classes-DC0_systems,No,
IDE05738-ENG124652,Subssystem diagnosis classes-DC1_systems,Yes,
IDE05738-ENG124651,Subssystem diagnosis classes-DC2/DC2F_systems,No,
IDE05738-ENG124650,Subssystem diagnosis classes-DC3_systems,Yes,
IDE08447,Driving axis angle,NO VALUE AVAILABLE,
IDE08516-IDE02743,LED headlights: light distribution requirement-High Beam,not requested,
IDE08516-IDE06864,LED headlights: light distribution requirement-Daytime running lights,not requested,
IDE08516-MAS02922,LED headlights: light distribution requirement-City light,not requested,
IDE08516-MAS02923,LED headlights: light distribution requirement-Highway light,not requested,
IDE08516-MAS02931,LED headlights: light distribution requirement-Rural highway light,not requested,
IDE08516-MAS02946,LED headlights: light distribution requirement-static AFS light,not requested,
IDE08516-MAS07013,LED headlights: light distribution requirement-All-weather lights,not requested,
IDE08516-MAS07014,LED headlights: light distribution requirement-Tourist light,not requested,
IDE08516-MAS07015,LED headlights: light distribution requirement-Running light,not requested,
IDE08516-MAS07234,LED headlights: light distribution requirement-Eco mode 1,not requested,
IDE08516-MAS07235,LED headlights: light distribution requirement-Eco mode 2,not requested,
IDE08706-MAS06932,Actual angle of ref. segments-Horizontal angle reference segment left,NO VALUE AVAILABLE,
IDE08706-MAS06933,Actual angle of ref. segments-Horizontal angle reference segment right,NO VALUE AVAILABLE,
IDE08706-MAS06934,Actual angle of ref. segments-Vertical angle reference segment left,NO VALUE AVAILABLE,
IDE08706-MAS06935,Actual angle of ref. segments-Vertical angle reference segment right,NO VALUE AVAILABLE,
IDE08713-MAS06936,Matrix light: calculated offset values-Horizontal offset: light left,NO VALUE AVAILABLE,
IDE08713-MAS06937,Matrix light: calculated offset values-Horizontal offset: light right,NO VALUE AVAILABLE,
IDE08713-MAS06938,Matrix light: calculated offset values-Vertical offset: light left,NO VALUE AVAILABLE,
IDE08713-MAS06939,Matrix light: calculated offset values-Vertical offset: light right,NO VALUE AVAILABLE,
IDE08714-MAS06929,Axle offsets-Axle offset front,NO VALUE AVAILABLE,
IDE08714-MAS06930,Axle offsets-Axle offset rear,NO VALUE AVAILABLE,
IDE08715,Func. status matrix high beam,not active,
IDE80001,Analysis 1,00 37 83 31 12 00 02 16 28 50 24 93 FF FF FF FF FF FF FF FF FF FF FF FF,
ENG101323,Headlight leveling control state,static,
ENG103737,Left headlight leveling control value,1024.0, mm
ENG124613,Predictive_Route_Data_Intown_Flag,not_available,
ENG124610,Predictive_Route_Data_Number_Of_Lanes,not_available,
ENG124612,Predictive_Route_Data_Placename_Sign,not_available,
ENG124611,Predictive_Route_Data_Speed_Limit,Unknown (31),
ENG124609,Predictive_Route_Data_Street_Class,not_available,
ENG102296,Right headlight leveling control value,1024.0, mm
Elapsed Time: 00:07
pauls13
C?ID=172848
Ok so I have compared the two outputs and these are the changes
Old ballast
New Ballast
IDE00018,Voltage terminal 15,11.673, V
IDE02389,Ambient brightness,150, lx
ENG103737,Left headlight leveling control value,-1.0, mm
ENG102296,Right headlight leveling control value,-1.0, mm
DV52
C?ID=194404
^^^^ that's great - the long code strings are the same, the module types are the same and only 4 x different channel settings!!!!
So..........I'll ask the obvious question: what happens to your autoscan DTC s if you plug-in the old hex55 channel settings into your new hex55 module and clear the errors ?
pauls13
C?ID=172848
How do I do that?
DV52
C?ID=194404
hmm...... that's a fairly fundamental question for a VCDS user that's swapping modules to ask!
Try this:
  1. Connect the VCDS cable to the OBD port - connect to your laptop and fire-up the software
  2. On the main VCDS screen click on select under Select Control Module
  3. On the Select Control Module screen, click on 55-Xenon Range
  4. On the Open Controller screen, click on Security Access-16
  5. Enter the magic number 20103 into the Enter security access key box and press Do it!
  6. Back in the Open Controller screen, click on Adaptation - 10
  7. You will then be presented with a screen like below - not the same entries, but the same layout
  8. In the box that I have labelled "1. Enter" type the Tag number for the 1st channel in your list and then select the down-arrow that I have identified as "2."
  9. Select the correct adaptation channel from your list
  10. You will then be presented with a screen like below - not the same entries, but the same layout
  11. Enter the channel setting number from your old module into the New Value box and press Do it!
  12. After acknowledging the prompts, you should see a screen that confirms the changed setting
  13. Repeat for each of the other channels and exit the module screen
Then open the autoscan screen- I like to run an autoscan before clearing DTC s because I then have a "before" record on file.
Press the Clear all DTCs button then run an autoscan
PS: while I still believe that it's worthwhile trying to make the changes to your hex55 module- I'm a tad concerned by the specificity of the numbers in the adaptation channels in your list. I've not made these changes - but the T15 voltage for example, is specified to 3 x decimal places! This might be a number that is generated by a calibration process - perhaps?
pauls13
C?ID=172848
when you say Tag numbers I assume you mean the IDE numbers, i.e ENG102296? sorry for being such a newb, just want to be clear because when I added the eng number I there was nothing to select in the channel pull down menu
DV52
C?ID=194404
paul: I'm sorry that my explanation of this process has become so complicated for you (I can only blame my thick Australian accent and an ageing and deeply deficient intellect) - but yes, my use of the term Tag number is synonymous with the IDE (and sometimes ENG, and sometimes MAS) number.
As for why you can't find the channels - and without intending any offense to Ross-Tech's code-cutters, the VCDS facility is a fairly basic search engine. Anything that's typed into the search box will suffice as a search vector -so you can use any part of the adaptation channel name. Like most search engines, the shorter the the search string, the more hits will be returned in the pull-down list and conversely, the opposite will be true if you increase the characters in the search box.
But you should have confidence that if the admap for the new hex55 module has identified a particular adaptation channel, then if you correctly enter part of that adaptation channel name into the search box - you will get at least one hit returned in the pull-down list. This certainty is up there with the inevitability of death and taxes;)
pauls13
C?ID=172848
Ok, so I tried all of the channel numbers in my list, and none of them came up.
DV52
C?ID=194404
hmm........ I've just had a closer look at your supposed admap:
These are not adaptation channels - they appear to be blockmap values?
What part of my explanation below was confusing ;) ?
pauls13
C?ID=172848
Your instructions were clear, I just clicked the wrong option, here now is the correct option. Also, I noticed that both headlight fuses were blown in the fusebox inside of the car, I have replaced them both, but it didn't fix the issue. Below is the correct admap reading and both the old and the new were the same.
;Sunday,22,March,2020,15:40:46:42802
IDE01996-SFT00041-Installation list: specified installations-Light Control Left,Yes ,1
IDE01996-SFT00057-Installation list: specified installations-Light Control Right,Yes ,1
IDE01996-SFT00085-Installation list: specified installations-Headlight Regulation,Yes ,1
IDE01996-SFT00214-Installation list: specified installations-Light Control Left 2,Yes ,1
IDE01996-SFT00215-Installation list: specified installations-Light Control Right 2,Yes ,1
IDE03641-Presentation run dynamic AFS light,active ,1
IDE03642-Presentation mode,not active ,1
IDE03679-Adaptive light functions,active ,1
IDE08418-Matrix light: total dimming,100.8 ,1
IDE09156-Matrix headlamp: function at standstill,not active ,1
IDE09568-MAS09833-Bit pattern of individual segment activation: left headlight-LED 1,OFF ,6
IDE09568-MAS09834-Bit pattern of individual segment activation: left headlight-LED 2,OFF ,6
IDE09568-MAS09835-Bit pattern of individual segment activation: left headlight-LED 3,OFF ,6
IDE09568-MAS09836-Bit pattern of individual segment activation: left headlight-LED 4,OFF ,6
IDE09568-MAS09837-Bit pattern of individual segment activation: left headlight-LED 5,OFF ,6
IDE09568-MAS09838-Bit pattern of individual segment activation: left headlight-LED 6,OFF ,6
IDE09568-MAS09839-Bit pattern of individual segment activation: left headlight-LED 7,OFF ,6
IDE09568-MAS09840-Bit pattern of individual segment activation: left headlight-LED 8,OFF ,6
IDE09568-MAS09841-Bit pattern of individual segment activation: left headlight-LED 9,OFF ,6
IDE09568-MAS09842-Bit pattern of individual segment activation: left headlight-LED 10,OFF ,6
IDE09568-MAS09843-Bit pattern of individual segment activation: left headlight-LED 11,OFF ,6
IDE09568-MAS09844-Bit pattern of individual segment activation: left headlight-LED 12,OFF ,6
IDE09568-MAS09845-Bit pattern of individual segment activation: left headlight-LED 13,OFF ,6
IDE09568-MAS09846-Bit pattern of individual segment activation: left headlight-LED 14,OFF ,6
IDE09568-MAS09847-Bit pattern of individual segment activation: left headlight-LED 15,OFF ,6
IDE09568-MAS09848-Bit pattern of individual segment activation: left headlight-LED 16,OFF ,6
IDE09568-MAS09849-Bit pattern of individual segment activation: left headlight-LED 17,OFF ,6
IDE09568-MAS09850-Bit pattern of individual segment activation: left headlight-LED 18,OFF ,6
IDE09568-MAS09851-Bit pattern of individual segment activation: left headlight-LED 19,OFF ,6
IDE09568-MAS09852-Bit pattern of individual segment activation: left headlight-LED 20,OFF ,6
IDE09568-MAS09853-Bit pattern of individual segment activation: left headlight-LED 21,OFF ,6
IDE09568-MAS09854-Bit pattern of individual segment activation: left headlight-LED 22,OFF ,6
IDE09568-MAS09855-Bit pattern of individual segment activation: left headlight-LED 23,OFF ,6
IDE09568-MAS09856-Bit pattern of individual segment activation: left headlight-LED 24,OFF ,6
IDE09568-MAS09857-Bit pattern of individual segment activation: left headlight-LED 25,OFF ,6
IDE09568-MAS09858-Bit pattern of individual segment activation: left headlight-LED 26,OFF ,6
IDE09568-MAS09859-Bit pattern of individual segment activation: left headlight-LED 27,OFF ,6
IDE09568-MAS09860-Bit pattern of individual segment activation: left headlight-LED 28,OFF ,6
IDE09568-MAS09861-Bit pattern of individual segment activation: left headlight-LED 29,OFF ,6
IDE09568-MAS09862-Bit pattern of individual segment activation: left headlight-LED 30,OFF ,6
IDE09568-MAS09863-Bit pattern of individual segment activation: left headlight-LED 31,OFF ,6
IDE09568-MAS09864-Bit pattern of individual segment activation: left headlight-LED 32,OFF ,6
IDE09568-MAS09865-Bit pattern of individual segment activation: left headlight-LED 33,OFF ,6
IDE09568-MAS09866-Bit pattern of individual segment activation: left headlight-LED 34,OFF ,6
IDE09568-MAS09867-Bit pattern of individual segment activation: left headlight-LED 35,OFF ,6
IDE09568-MAS09868-Bit pattern of individual segment activation: left headlight-LED 36,OFF ,6
IDE09568-MAS09869-Bit pattern of individual segment activation: left headlight-LED 37,OFF ,6
IDE09568-MAS09870-Bit pattern of individual segment activation: left headlight-LED 38,OFF ,6
IDE09568-MAS09871-Bit pattern of individual segment activation: left headlight-LED 39,OFF ,6
IDE09568-MAS09872-Bit pattern of individual segment activation: left headlight-LED 40,OFF ,6
IDE09568-MAS09873-Bit pattern of individual segment activation: left headlight-LED 41,OFF ,6
IDE09568-MAS09874-Bit pattern of individual segment activation: left headlight-LED 42,OFF ,6
IDE09568-MAS09875-Bit pattern of individual segment activation: left headlight-LED 43,OFF ,6
IDE09568-MAS09876-Bit pattern of individual segment activation: left headlight-LED 44,OFF ,6
IDE09568-MAS09877-Bit pattern of individual segment activation: left headlight-LED 45,OFF ,6
IDE09569-MAS09833-Bit pattern of individual segment activation: right headlight-LED 1,OFF ,6
IDE09569-MAS09834-Bit pattern of individual segment activation: right headlight-LED 2,OFF ,6
IDE09569-MAS09835-Bit pattern of individual segment activation: right headlight-LED 3,OFF ,6
IDE09569-MAS09836-Bit pattern of individual segment activation: right headlight-LED 4,OFF ,6
IDE09569-MAS09837-Bit pattern of individual segment activation: right headlight-LED 5,OFF ,6
IDE09569-MAS09838-Bit pattern of individual segment activation: right headlight-LED 6,OFF ,6
IDE09569-MAS09839-Bit pattern of individual segment activation: right headlight-LED 7,OFF ,6
IDE09569-MAS09840-Bit pattern of individual segment activation: right headlight-LED 8,OFF ,6
IDE09569-MAS09841-Bit pattern of individual segment activation: right headlight-LED 9,OFF ,6
IDE09569-MAS09842-Bit pattern of individual segment activation: right headlight-LED 10,OFF ,6
IDE09569-MAS09843-Bit pattern of individual segment activation: right headlight-LED 11,OFF ,6
IDE09569-MAS09844-Bit pattern of individual segment activation: right headlight-LED 12,OFF ,6
IDE09569-MAS09845-Bit pattern of individual segment activation: right headlight-LED 13,OFF ,6
IDE09569-MAS09846-Bit pattern of individual segment activation: right headlight-LED 14,OFF ,6
IDE09569-MAS09847-Bit pattern of individual segment activation: right headlight-LED 15,OFF ,6
IDE09569-MAS09848-Bit pattern of individual segment activation: right headlight-LED 16,OFF ,6
IDE09569-MAS09849-Bit pattern of individual segment activation: right headlight-LED 17,OFF ,6
IDE09569-MAS09850-Bit pattern of individual segment activation: right headlight-LED 18,OFF ,6
IDE09569-MAS09851-Bit pattern of individual segment activation: right headlight-LED 19,OFF ,6
IDE09569-MAS09852-Bit pattern of individual segment activation: right headlight-LED 20,OFF ,6
IDE09569-MAS09853-Bit pattern of individual segment activation: right headlight-LED 21,OFF ,6
IDE09569-MAS09854-Bit pattern of individual segment activation: right headlight-LED 22,OFF ,6
IDE09569-MAS09855-Bit pattern of individual segment activation: right headlight-LED 23,OFF ,6
IDE09569-MAS09856-Bit pattern of individual segment activation: right headlight-LED 24,OFF ,6
IDE09569-MAS09857-Bit pattern of individual segment activation: right headlight-LED 25,OFF ,6
IDE09569-MAS09858-Bit pattern of individual segment activation: right headlight-LED 26,OFF ,6
IDE09569-MAS09859-Bit pattern of individual segment activation: right headlight-LED 27,OFF ,6
IDE09569-MAS09860-Bit pattern of individual segment activation: right headlight-LED 28,OFF ,6
IDE09569-MAS09861-Bit pattern of individual segment activation: right headlight-LED 29,OFF ,6
IDE09569-MAS09862-Bit pattern of individual segment activation: right headlight-LED 30,OFF ,6
IDE09569-MAS09863-Bit pattern of individual segment activation: right headlight-LED 31,OFF ,6
IDE09569-MAS09864-Bit pattern of individual segment activation: right headlight-LED 32,OFF ,6
IDE09569-MAS09865-Bit pattern of individual segment activation: right headlight-LED 33,OFF ,6
IDE09569-MAS09866-Bit pattern of individual segment activation: right headlight-LED 34,OFF ,6
IDE09569-MAS09867-Bit pattern of individual segment activation: right headlight-LED 35,OFF ,6
IDE09569-MAS09868-Bit pattern of individual segment activation: right headlight-LED 36,OFF ,6
IDE09569-MAS09869-Bit pattern of individual segment activation: right headlight-LED 37,OFF ,6
IDE09569-MAS09870-Bit pattern of individual segment activation: right headlight-LED 38,OFF ,6
IDE09569-MAS09871-Bit pattern of individual segment activation: right headlight-LED 39,OFF ,6
IDE09569-MAS09872-Bit pattern of individual segment activation: right headlight-LED 40,OFF ,6
IDE09569-MAS09873-Bit pattern of individual segment activation: right headlight-LED 41,OFF ,6
IDE09569-MAS09874-Bit pattern of individual segment activation: right headlight-LED 42,OFF ,6
IDE09569-MAS09875-Bit pattern of individual segment activation: right headlight-LED 43,OFF ,6
IDE09569-MAS09876-Bit pattern of individual segment activation: right headlight-LED 44,OFF ,6
IDE09569-MAS09877-Bit pattern of individual segment activation: right headlight-LED 45,OFF ,6
ENG124608-Order_Reference_Run_Activation_Effect,No dependency ,1
ENG100660-PWM to Level Scaling Factor Front,0.00 mm/%,2
ENG103748-PWM to Level Scaling Factor Rear,0.00 mm/%,2
ENG124607-Reference_Run_Activation_Effect,Activation effect enabled by motor start ,1
ENG103979-Reference_Run_Start_Condition,Engine start ,1
Elapsed Time: 00:05
DV52
C?ID=194404
Paul: bummer!!
hmm......... my normal practice in this type of "interesting" diagnostic analysis is to take stock at key points in the exercise. So here's a synopsis of the situation thus far (as I understand from your posts) -ONLY as it relates to the headlights:
First: your auto-scan indicates that the hex55 module is incorrectly coded - but you have advised that in comparing the old and new J745 module, the long-code string and the adaptation channel settings is exactly the same
Second: The hex D6 and hex D7 modules in your auto-scan report "implausible" DTC between the A31 & A27 modules and the type of lamps in the newly installed headlight fittings. Yet your advice is that the part numbers and software versions of the old and new modules are exactly the same.
Third: Whilst I have not asked the specific question, I assume that the actual headlight fittings are exactly the same and that no other modules were changed on the car.
Don't get me wrong - I'm certainly not suggesting that any of your advice is incorrect (quite the opposite - I entirely accept the information provided in your responses). BUT - I'm no sure how to proceed given the 3 x facts above.
Perhaps someone else here can suggest a way forward - maybe the crash data stored in car is implicated in the problem (I can't see why this would apply)?
pauls13
C?ID=172848
Thanks for your help Don you been a great help, hopefully, I'll have a light bulb moment and will get this fixed somehow without getting Audi to look at it and charge me a fortune., at least the dip beam work which means I can still drive it at night.
