Results 1 to 3 of 3
Thread: Update of 19.6.2 usb interface intermittent communications
    Jul 2017
    Yesterday my hex-v2 was operating properly.
    Today Iím trying to upgrade my vinís using a feature code. Every time I attempt to go into ďconfigĒ I get blank boxes. Once in a while the adapter will show up, then the feature code Iím using says I must have CB: 04324+. Well my interface, when operational says CB: .4508.
    Iím not sure why my interface is intermittent. I can see my interface sometimes but then I click update, and it stalls and loses comm with hex controller. I am directly connected to internet. Not WiFi, no change. Iíve switched USB ports many times with no help.
    This seems to be an update error.
    Thanks guys
    Jun 2014
    Swansea, UK
    Have you tried another USB cable, just in case?
    A standard USB printer cable will do
  3. Likes Uwe liked this post
    Quote Originally Posted by CBZGTI View Post
    Today I’m trying to upgrade my vin’s using a feature code. Every time I attempt to go into “config” I get blank boxes. Once in a while the adapter will show up, then the feature code I’m using says I must have CB: 04324+. Well my interface, when operational says CB: .4508.
    FWIW, the server thinks your VIN upgrade Feature Code has been successfully applied.
    What does VCDS say about your license/VIN status?
