Results 1 to 3 of 3
Thread: 2006 Jetta TDI 02511 Basic Settin
    Feb 2020
    Working on an 06 Jet TDI that had a number of issues we have cleaned up as you will see in the codes. We have gotten everything squared away and are down to just the 02511. After clearing the codes the light went away and prior to cycling the key you could sit in the seat and the passenger airbag light would go off. Cycle the key and the code comes back.
    Clear the code and reset the calibration for the seat sensor and the same thing. I am not sure I am letting it "reset" long enough. Should I get some kind of ok after recalibrating? I see the little spinning icon saying VCDS is communicating with the module but that seems normal. I am newer to VCDS.
    Also in looking at the measuring blocks everything looks correct. Graphing the seat pressure it goes from about 65 or so to 250 or so with an occupant so that would seem to indicate the sensor is "seeing" an occupant. Somewhat of a head scratcher that it would see the sensor and sense the difference down to as finite as hand pressure but be out of range.
    The vehicle was in an accident and had low or no voltage for an extended time. I think that was the cause of some of the other codes ie low voltage at the buss. Other issues were caused as we worked to replace the front clip.
    Any suggestions?
    Thanks Tom
    Wednesday,11,March,2020,18:34:33:10220
    VIN: 3VWCT81K16M850628   License Plate: 2006 WHITE
    Mileage: 268110km-166595mi   Repair Order:
    Chassis Type: 1K (1K0)
    Scan: 01 02 03 08 09 0F 15 16 17 19 1C 25 42 44 46 47 52 56 62 65
              72 7D
    VIN: 3VWCT81K16M850628   Mileage: 268110km-166595miles
    62-Door, Rear Left -- Status: Sporadic communication error 1000
       Part No SW: 03G 906 016 AC    HW: 028 101 223 9
       Component: R4 1,9L EDC G000DG  7551
       Revision: --H05---    Serial number: VWZ7Z0F4710137
       Coding: 0050078
       Shop #: WSC 00066 000 00000
       VCID: 6491AAD50259C1E74DD-8030
    005661 - Glowplug for Cylinder 4 (Q13)
                   P161D - 000 - Open Circuit
                        Fault Status: 01110000
                        Mileage: 267395 km
                        Time: 00:00:25
                        Load: 0.0 %
                        Voltage: 11.86 V
                        Bin. Bits: 00001000
                        Temperature: 0.0∞C
                        Bin. Bits: 00110000
    Readiness: 1 1 0 0 0
       Part No SW: 02E 300 043     HW: 02E 927 770 AE
       Component: GSG DSG         070 1126
       Revision: 04507000    Serial number: 00000608181114
       VCID: 51FF73016DEB444F16B-8004
       Revision: 00H11001
       Coding: 0021122
       VCID: 73B3D989B7B7565FC47-8026
       Part No: 1K0 820 047 FQ
       VCID: 78A9EEA5AED13507F15-802C
       Part No SW: 3C0 937 049 Q    HW: 3C0 937 049 Q
       Revision: 00H46000    Serial number: 00000000501602
       Coding: 14018E234004150007140000001400000028770B5C0000
       VCID: 372B2D99E34FFA7F38F-8062
       Component: Wischer 261106 020  0501
       Coding: 00065535
       Shop #: WSC 00066
    10 Faults Found:
                        Fault Status: 00101100
                        Reset counter: 13
                        Mileage: 267395 km
                        Voltage: 11.40 V
                        Reset counter: 13
                        Mileage: 267395 km
                        Voltage: 11.40 V
    01505 - Bulb for Blinkers; Rear Right (M8)
                        Reset counter: 32
                        Mileage: 267686 km
                        Voltage: 14.50 V
                        Reset counter: 32
                        Mileage: 267187 km
                        Voltage: 14.25 V
                        Reset counter: 13
                        Mileage: 267395 km
                        Voltage: 11.45 V
                        Reset counter: 13
                        Mileage: 267395 km
                        Voltage: 11.45 V
                        Fault Status: 01101100
                        Reset counter: 6
                        Mileage: 267531 km
                        Voltage: 13.25 V
                        Reset counter: 6
                        Mileage: 267944 km
                        Voltage: 12.40 V
                        Fault Status: 00101010
                        Reset counter: 13
                        Mileage: 267395 km
                        Voltage: 11.45 V
                        Reset counter: 13
                        Mileage: 267395 km
                        Voltage: 11.45 V
       Part No SW: 8E0 035 593 D    HW: 8E0 035 593 D
       Component: SDAR SIRIUS     H03 0060
       Revision: 00000000    Serial number: AUZ4Z7F0012850
       VCID: 2A0D04ED20FD5797B71-807E
                        Reset counter: 228
                        Mileage: 267395 km
       Component: 69 AIRBAG VW8R  034 8000
       Revision: 05034000    Serial number: 003B6D06XN4D
       Coding: 0013881
       VCID: 6C81C2F5EA8989A705D-8038
       Subsystem 2 - Serial number: 6332MSME12461C625
       Subsystem 3 - Serial number: 6342MSME14587E21E
       Subsystem 4 - Serial number: 6351HSME0B43284DC
       Subsystem 5 - Serial number: 6361HSME0B474D03A
       Subsystem 6 - Serial number: 63727SME087F191DE
       Subsystem 7 - Serial number: 63827SME0B230A760
    02511 - Control Module for Seat Occupied Recognition (J706)
       Part No SW: 1K0 953 549 AS    HW: 1K0 953 549 AS
       Coding: 0012021
       VCID: 03538949E71766DFD47-8056
       Part No SW: 1K0 920 973 D    HW: 1K0 920 973 D
       Revision: V0003000    Serial number: VWZ7Z0F4710137
       Coding: 0023203
       Shop #: WSC 02641 067 57207
       VCID: 2E0508FD1C153BB76B9-807A
                        Reset counter: 13
                        Mileage: 267395 km
                        Time: 01:22:58
       Revision:   H12       Serial number: 31001069140761
       Coding: 3FBF0B620F001002
       VCID: 2C0102F52A0949A745D-8078
                        Reset counter: 11
                        Mileage: 267385 km
                        Time: 00:25:49
                        Reset counter: 12
                        Mileage: 267395 km
                        Time: 01:22:59
       Part No SW: 1K5 919 965 A    HW: 1K5 919 965 A
       Component: Kompass         005 0003
       Revision: 00005000    Serial number: 1293324T294J03
       Coding: 0000003
       VCID: 392F2BA1D55BEC0FCEB-806C
       Component: IMMO            3HL 1610
       Component: J386  TUER-SG FT    1127
       Revision: 32008001    Serial number: 00000549069021
       Coding: 0001205
       VCID: 3B2331A9DF67DE1FDC7-806E
    01552 - Motor for Central Locking; Drivers Door (V56); Lock
                        Reset counter: 45
                        Mileage: 260291 km
                        Fault Status: 00111000
                        Reset counter: 43
                        Mileage: 255372 km
                        Reset counter: 45
                        Mileage: 239907 km
       Part No: 1K1 909 144 L
       Component: EPS_ZFLS Kl.070 H07 1806
       Shop #: WSC 02069 000 90108
       VCID: 34311A95F23911671DD-8060
       Part No SW: 1K0 959 433 CD    HW: 1K0 959 433 CD
       Component:    KSG PQ35 RDK 051 0215
       Revision: 00051000    Serial number: 00000000000000
       Coding: 13900F880186281B0904058FB0880F0488DC00
       VCID: 74B1DA95B2B95167DDD-8020
                        Fault Frequency: 15
                        Reset counter: 38
                        Mileage: 267894 km
                        Time: 03:15:54
    Address 47: Sound System        Labels: 3C0-035-456.clb
       Part No: 1K6 035 456 A
       Component: 08K Audioverst.     0005
       Revision: 00003000    Serial number: 00000000017377
       Component: J387  TUER-SG BT    1127
       Revision: 32008001    Serial number: 00000541469030
       Coding: 0001204
       VCID: 3C2132B5DA69D927D5D-8068
       Part No SW: 1K0 035 180 G    HW: 1K0 035 180 G
       Component: Radio DE2       145 0176
       Revision: 00145000    Serial number: VWZ4Z7F2131867
       Coding: 0010401
       VCID: 2411EAD542D981E78DD-8070
       Component: J388   TUER-SG HL   1115
       Revision: 12005001    Serial number: 00000000670782
       Coding: 0001168
       VCID: 3E2538BDCC75CB37FB9-806A
       Component:    RDK              0420
       Coding: 0100101
       Component: J389   TUER-SG HR   1115
       Revision: 12005001    Serial number: 00000000671631
       Coding: 0001168
       VCID: 3FDB45B9CB7FC23FF0F-806A
    00935 - Electric Window Motor; Rear Right (V27)
                        Fault Status: 00100101
                        Reset counter: 13
       VCID: 2D070FF1111340AF523-8078
    End----------(Elapsed Time: 01:42, VBatt start/end: 13.8V/14.0V)-----------
    HQ
    The 2nd link, are you following the instructions under Basic Settings first, then instructions under Special Procedures? Those 2 operations need to be done, back to back in the same diagnostic session.
    Has any part of the airbag system been replaced? If so what and where were parts sourced from?
    Jef
  3. Likes Uwe liked this post
    Feb 2020
    Jef Thank you. No accidents other then this one that we know of and this one did not result in airbag replacement.
    I will try the steps and make sure I do them as outlined maybe I missed something.
