Results 1 to 10 of 10
Thread: 01044 - Control Module Incorrectly Coded 000 - - 2004 vw beetle cab MK60
    Mar 2020
    This is my first post need help to code the abs module. Here is scan the abs module is the original I was told they sent it out for repair but the repair shop nothing was wrong. During my troubleshooting found a bent pin on the abs connector corrected it and here I am now thanks in advance.
    Wednesday,11,March,2020,14:40:24:09909
    VCDS Version: 19.6.2.2 (x64)  HEX-NET CB: 0.4508.4
    VIN: 3VWCD31Y34M321134   License Plate:
    Chassis Type: 1Y (1Y - VW New Beetle Cab (2003 > 2010))
    Scan: 01 02 03 08 15 17 19 25 26 29 35 37 39 46 54 56 65 75
    VIN: 3VWCD31Y34M321134   Mileage: 101520km-63081miles
    Address 01: Engine        Labels: 06A-906-032-AWV.lbl
       Part No: 06A 906 032 PS
       Component: 1.8l 5VT NBC AG6G   5107
       Coding: 00004
       Shop #: WSC 00066
       VCID: FEB0817AF8D140BF57-513C
       3VWCD31Y34M321134     VWZ5Z0C8092283
    Readiness: 0110 1101
       Part No: 09G 927 750 P
       Component: AQ 250 6F           0387
       Coding: 0000008
       VCID: BE30417AE85180BF17-513C
    Address 03: ABS Brakes        Labels: 1C0-907-37x-ASR.lbl
       Part No: 1C0 907 379 K
       Component: ASR FRONT MK60      0103
       Coding: 0018945
       Shop #: WSC 00001 785 00200
       VCID: B228654A2C0954DFE3-5160
    Address 15: Airbags        Labels: 1T0-909-605.lbl
       Part No: 6Q0 909 605 AF
       Component: 05 AIRBAG VW71      0509
       Coding: 0012341
       VCID: FBB6886EBBC3559770-513C
       Subsystem 1 - Part No: 1C0 959 339
       Component: BF-Gewichtsens. 004 0004
    Address 17: Instruments        Labels: 1C0-920-x4x.lbl
       Part No: 1C0 920 951 N
       Component: KOMBI+WEGFAHRS. M73 V02
       Coding: 11234
       Shop #: WSC 26097
       VCID: AC147B325E2D022FA9-4B1E
       Part No: 6N0 909 901
       Component: Gateway K<->CAN    V022
       Coding: 00006
       Shop #: WSC 00066
       VCID: F0ACAF42B28526CFD5-4B00
    Address 26: Auto Roof        Labels: 1Y0-959-255-HYD.lbl
       Part No: 1Y0 959 255
       Component:  VSG  NBC       ü
       VCID: FDB28676A5D75BA74E-513C
       Part No: 1C0 959 799 G
       Component: 6J Komfortgerát HLO 0004
       Coding: 00256
       Shop #: WSC 00066
       VCID: BB36486EAB43959730-4B00
       Subsystem 1 - Part No: 1Y1959801
       Component: 6J Tőrsteuer.FS KLO 0005
       Subsystem 2 - Part No: 1Y1959802A
       Component: Tőrsteuer.BF KLO 0005
       Subsystem 3 - Part No: 1Y0959811
       Component: 6J Tőrsteuer.HL KLO 0001
       Subsystem 4 - Part No: 1Y0959812
       Component: 6J Tőrsteuer.HR KLO 0001
                52-10 - Supply Voltage Too High - Intermittent
                62-00 - No or Incorrect Adjustment
    End----------(Elapsed Time: 04:00, VBatt start/end: 14.1V/14.1V)-----------
  2. Likes Dana liked this post
  3. #2
    Oct 2014
    Arandjelovac, Serbia
    Been there?
    Mar 2020
    did you get yours to work
    Sep 2016
    Riga, Latvia
    Check pins 38 and 14 very carefully. Are they ok at module side? Are corresponding contacts ok at connector side and are they connected together electrically at connector side? Or 38 is connected to 12, maybe?
    Mar 2020
    I used a digital camera and verified all pins and the conector are in good shape Previously I found a pin bent and was getting left wheel speed sensor circuit problem once i corrected it the code whent away so now i have the module code issue.
    Sep 2016
    Riga, Latvia
    Ok, now take a DVOM, switch it to continuity test mode and check continuity between pins 38-14 and 38-12 (connector side)
  8. Likes Boki Ar, Uwe liked this post
    Mar 2020
    all continuity checks good no codes except for code issue. I even checked wheel speed sensors using VCDS all check good.
  10. #8
    United States
    In reply to your PM, I suspect someone installed the incorrect ASR (non ESP) module. This is a temp screen shot of PL24 by VIN:
    https://media.trillian.im/media/?m=a...xeHe9PKg%3D%3D
    If we were to look at scan data from a 1C0 907 379 M unit it would look like:
    > Address 03: ABS Brakes Labels: 1C0-907-37x-ESP-F.lbl
    > Part No: 1C0 907 379 M
    > Component: ESP FRONT MK60 0102
    > Coding: 0019970
    It also showed a slip ring for vehicles with ESP, brake pressure sensor and ESP dashboard switch so I'm reasonably confident it wasn't incorrect in regards to the ABS module type but do confirm the switch in the car has ESP printed on it.
  11. Likes Uwe liked this post
  12. #9
    Mar 2020
    Thanks I belive you are right the vehicle has the ESP button supposedly the unit in the vehicle was the origianal . I will try to get another module and see if I can get it working when it is time to code it could you send me the code based on the infomation on my scan and vin please let me know thakns for your help.
  13. Likes Dana liked this post
  14. #10
    United States
    Thanks for confirming the ESP button is present.
    I'm reasonably confident that 0019970 will be the correct coding (that example scan was from a NAR 1Y chassis 1.8T NBC) but feel free to post the Auto-Scan with the new module installed if you have any coding issues.
  15. Likes Uwe, Fredrick Awuor liked this post
